I don't know how overcoming this error . Thank you. MyPackage := module() export f1, f2; local loc1; option package; f1 := proc() loc1 end proc; f2 := proc( v ) loc1 := v end proc; loc1 := 2; end module: savelib('MyPackage'); Error, cannot open archive, C:\Program Files\Maple 2018\lib, for writing. restart; with(MyPackage); Error, invalid input: with expects its 1st argument, pname, to be of type {`module`, package}, but received MyPackage
x1^4 + x2^4 + 0.4*sin(7*x1) + 0.3*sin(4*Pi*x2) -1 = 0;
The task itself is not needed by anyone, it's just for rest and distraction from work.
(For example, this is not difficult to do with Draghilev's method.)
I have a system of equations that returns a RealRange :
xLp_tmp := RealRange(85.32914119, infinity)
it actually looks like this:
anyway, I want to "pick" the lowerbound of that range and assign it to a variable but I can't figure  out how to do it.
I've tried:
xLp_tmp[1]
lowerbound(xLp_tmp)
but neither worked.  I don't know what else to try.
Thank you in advance for the help.
Dear Forum,
I want to make a Document where some values are initialised and left alone afterwards.
The startup-code seems to be the solution. The manual says, it is executed, when the document is reloaded.
But if i execute the document with "!!!" the startup-code is executed too.
How can I avoid this ?
Is there a good way to write "run once" code ?
Thank you very much
Klaus
startup code is  :
init:=false;
After reloading, this should be false  init = trueNULL
the startup code should be executed after reloading but is executed when the code is executed with !!! . init is set to false again
If the code is executed stepwise , ! by ! , it behaves as expected.
if not init then x := 3; y := 4; init := true end if
2*x = 8NULL
x := 4
4
2*x = 8NULL
Download doesnotrunonce.mw
Dear esteem colleagues,
Please I am trying to plot a function using both implicitplot and contourplot. However, I found out that I have two different plots. What are the differences between them and perhaps which is better?
Thank you all for your time and best regards.
with(GroupTheory):
MinimumPermutationRepresentationDegree(PermutationGroup({[[2, 3], [4, 5]], [[2, 5], [3, 4]]}, degree = 5, supergroup = PermutationGroup({[[2, 3, 4]], [[1, 2], [4, 5]]}, degree = 5)));
#an error appears in Maple 2017
As a newbie I tried to do some simple calculations. Unfortunately one of my calculations does not solve. I assume I do not see the obvious. Would someone be so kind to help me out? Thank you
with(LinearAlgebra)
pH := Vector(2, {(1) = 7.17, (2) = 7.25})
Vector[column](%id = 4598165698)
pCO2 := Vector(2, {(1) = 74, (2) = 56})
Vector[column](%id = 4696862338)
pK := 6.1
6.1
CO2 := `~`[`*`](pCO2, 0.3e-1)
Vector[column](%id = 4696842050)
HCO3 := `~`[`*`](`~`[`*`](0.3e-1, pCO2), 10^`~`[`-`](pH, pK))
Error, (in rtable/Power) exponentiation operation not defined for non-algebraic exponents
TCO2 := CO2+HCO3
28.30272572
VCO2 := 22.4*(28.3-25.41)*5.9
381.9424
Download test.mw
with(LinearAlgebra)
pK := 6.1
6.1
TCO2 := CO2+HCO3
28.30272572
381.9424
Download test.mw
with(Student:-Basics); simplify((b - 1)/(b + 2 - (b^2 + 2)/(b - (b - 2)/(b + 1)))); b - 1 This is correct, but I want to see the step-by-step solution. P.D. I try the ExpandSteps command already but the result doesn't give me the solution. Please, help me. Thanks in advance
Is there an option or a tool to know if maple is trying to finish the calculation or if it is in a bucle?
Is there a Maple function that given a group gives its name?
In a calculation I am encountering expressions of the following kind:
-.27059805007310*sin(.12+epsilon)+.27059805007310*sqrt(1.-cos(.12+epsilon)^2)
As is known, for epsilon < Pi-0.12, the two terms are equal but opposite in sign and the result should be zero (ok, maybe a few 1E-15 for round-off). But for the heck of it I cannot get Maple to simplify this with the assumption e.g. epsilon < 0.1.
This can probably be simplified by squaring the two terms and then subtracting them, but that can possibly lead to other "interesting" effects and besides is a bit cumbersome.
Has anybody found a good way of  doing this?
M.D.
How to build a library (package) containing my own procedures ? Could you give me an example. Thank you.
I've written a Mapleflow document that is supposed to use a microphone array to find the intersection of three equations to locate the source of a gunshot.  But the calculation is "Evaluating," and has been for half an hour.  How do I interrupt the calculation?
I'd up load the file, but
So:
Not_evaluating_theta.mw
When I tried to explain to a student how to set it up, it stopped working.  I tried changing the order, but got the same result. I tried using "t" instead of theta, but got the same result. Please help.
I am trying to simplify a large expression using simplify(), but it takes too long and I eventually run out of processing power after a few days. Is there any way I could get similar results with an alternative function?
Any help is appreciated.
First 380 381 382 383 384 385 386 Last Page 382 of 2429
