My group recently published a DAEsolver in Maple, https://mapletransactions.org/index.php/maple/article/view/16701
This solver is very competive compared to existing large scale DAE solvers (even in other languages) by performing symbolic calculation for analytical Jacobian (including sparsity pattern), and by using parallel sparse direct solver (PARDISO).
The code and paper use ListTools. If the attached procedure can be made threadsafe and parallelized, then the resulting DAEsolver is publishable and will be better than most solvers (from any language) today. We welcome collaborations and suggestions. The code works for N = 40, but kernel connection is lost for higher values of N and it is not stable.
Dr. Venkat Subramanian
PS, for the specific problem, it is trivial to write the Jacobian and residue in a for loop that can be run in parallel (and it helps us to solve > 1 Million or more DAEs), but the attached code (makeproc) helps in solving DAEs resulting from sophisticated discretization approaches for PDEs without user input.
Digits:=15;
15
makeproc:=proc(n0,nf,Nt,Eqode::Array,Vars::list,Vars1::list,Equation::Array,j11::Matrix(storage=sparse))
local i,j,LL,LL2,L,i1,varsdir,varsdir1,node,eqs;
for i from n0 to nf do
eqs:=rhs(Eqode[i]):
L:=indets(eqs)minus{t};#print(L);
if nops(L)>0 then
LL := [seq(ListTools:-Search(L[j], Vars),
             j = 1 .. nops(L))];
 LL2 := ListTools:-MakeUnique(LL);
if LL2[nops(LL2)] = 0 then
             LL := [seq(LL2[i1], i1 = 1 .. nops(LL2) - 1)];
         if LL2[1]= 0 then LL:=[seq(LL2[i1],i1=2..nops(LL2))]: end:#print(1,LL);
varsdir:=[seq(Vars[LL[i1]]=0.5*uu[LL[i1]]+uu_old[LL[i1]],i1=1..nops(LL))];
else varsdir:=[1=1]:end:
Equation[i]:=uu[i]-deltA*subs(varsdir,t=tnew,eqs):#print(i,Equation[i]);
        L := indets(Equation[i]);
        LL := [seq(ListTools:-Search(L[j], Vars1),j = 1 .. nops(L))];
        for j to nops(LL) do
            j11[i, LL[j]] := diff(Equation[i], uu[LL[j]]);
CodeTools[ThreadSafetyCheck](makeproc);
0, 1
#infolevel[all]:=10;
N:=40;h:=1.0/N:
40
with(Threads[Task]):
Eqs:=Array(1..N,1..N):
for i from 1 to N do for j from 1 to N do
if i = 1 then left:=0: else left:=(c[i,j](t)-c[i-1,j](t))/h:end:
if i = N then right:=-0.1: else right:=(c[i+1,j](t)-c[i,j](t))/h:end:
if j = 1 then bot:=0: else bot:=(c[i,j](t)-c[i,j-1](t))/h:end:
if j = N then top:=-0.1: else top:=(c[i,j+1](t)-c[i,j](t))/h:end:
Eqs[i,j]:=diff(c[i,j](t),t)=(right-left)/h+(top-bot)/h-c[i,j](t)^2:
od:od:
eqs1:=Array([seq(seq(Eqs[i,j],i=1..N),j=1..N)]):
ics:=[seq(seq(c[i,j](t)=1.0,i=1..N),j=1..N)]:
Vars:=[seq(seq(c[i,j](t),i=1..N),j=1..N)]:
Vars1:=[seq(uu[i],i=1..N^2)]:
Equation:=Array(1..N^2):j11:=Matrix(1..N^2,1..N^2,storage=sparse):eqs:=copy(Equation):
CodeTools:-Usage(makeproc(1,N^2,N^2,eqs1,Vars,Vars1,Equation,j11));
memory used=21.47MiB, alloc change=24.99MiB, cpu time=235.00ms, real time=231.00ms, gc time=62.50ms
1-deltA*(-1600.00000000000-.50*uu[1600]-1.0*uu_old[1600])
j11[5,5];
1-deltA*(-2400.00000000000-.50*uu[5]-1.0*uu_old[5])
#Equation[1];
makeprocDistribute := proc(i_low, i_high,Nt,Eqode::Array,Vars::list,Vars1::list,Equation::Array,j11::Matrix(storage=sparse))
local i_mid;
if 200 < i_high - i_low then
#if i_low > 250 then
#i_mid := floor(1/2*i_high - 1/2*i_low) + i_low;
i_mid:=iquo(i_low+i_high,2):
Continue(null,
Task = [makeprocDistribute, i_low, i_mid,Nt,Eqode,Vars,Vars1,Equation,j11],
Task = [makeprocDistribute,i_mid + 1, i_high,Nt,Eqode,Vars,Vars1,Equation,j11]);
makeproc(i_low, i_high,Nt,Eqode,Vars,Vars1,Equation,j11); end if;
j11[5,5];
N^2;
1600
NN:=N^2;
1600
CodeTools:-Usage(Start(makeprocDistribute,1,NN,NN,eqs1,Vars,Vars1,Equation,j11)):
memory used=22.01MiB, alloc change=239.31MiB, cpu time=985.00ms, real time=241.00ms, gc time=1.61s
j11[5,5];
Download makeproctest.mw
I analyzed the kinetic equation of the system and got this formula. I want to realize the sweep frequency analysis of the kinetic function by changing the size of omega2, but I don't know how to write a program. Want to ask for help
solve831.mw
In the attached file I would like to use the functions "Gradient" and "Hessian". Hessian should also calculate the determinant and check positive definiteness. I was unable to do that. Other questions for me as a beginner are:
How are the long brackets and the > sign on the left edge created? What does a semicolon at the end of the command mean? How is a 3D plot created? What does "restart" mean?
Regards, Alfred_FAF_20240831.mwAF_20240831.mw
 In the calculation process, I selected (num=5). How can I detect the maximum value of num to ensure the series solution would be converged?
seried.mw
If there any way to make text  parallel to a line in textplot3d.
display(line([1,2,3],[4,5,-2],linestyle=longdash),
        point([2.5,3.5,0.5]),
        textplot3d([2.5,3.5,0.5,"not aligned"]))
I know to ways:
- calling the returned procedure with a value for the independend variable
- printing the procedure with interface(verboseproc=2)
The first requires a procedure and a values that work, the second is quite some typing.
Any other ways?
Update Nov 2024:
The option output = listprocedure provides a way.
Is one not supposed to make _Z local variable?  If not, then how to insure the global _Z do not have some value assigned to it?
In this example below, I build some integral. I used local _Z for upport limit. But now Maple generate internal error.
If I do not declare _Z as local, and leave it global, then no error is generated.
But if I also declare _Z inside the proc as global _Z, then the error also goes away.
So is one always supposed to use _Z as global?
The strange thing _Z is protected, so I cant assign to it value from global space. Message says Try declaring `local _Z`; see ?protect for details. but when I do that, I still get an error.
So is the bottom line here is that one should not declare _Z local to a proc, and just assume it is always global symbol that has no assigned value to it, and that will always be safe to do?  I do not assign value to _Z inside my proc. Just wanted to use it for upper limit, as symbol.
foo:=proc()
 local _Z;
 local F,G,H,n;
 F:=x;G:=x;G:=x;n:=4;
 -RootOf(Intat(F^(-n-1)*H^(-2*n+1)*(-G*F*n*H)^n*n^(-n)/(-
         tau*F^(-n-1)*H^(-2*n+1)*(-G*F*n*H)^n*n^(-n)+F^(-n-1)*H^(-2*n+1)*(-G*F
         *n*H)^n*n^(-n)+tau^n),tau = _Z)-Int(-G,x)+C1)/G*H;
foo()
Error, (in RootOf) expression independent of, _Z
boo:=proc()
 local F,G,H,n;
boo();
-RootOf(Intat(x^3/(H^3*tau^4-tau*x^3+x^3), tau = _Z)-(Int(-x, x))+C1)*H/x
boo2:=proc()
 global _Z;
 local F,G,H,n;
boo2()
_Z:=5;
Error, attempting to assign to `_Z` which is protected.  Try declaring `local _Z`; see ?protect for details.
local _Z;
foo();
Warning, A new binding for the name `_Z` has been created. The global instance of this name is still accessible using the :- prefix, :-`_Z`.  See ?protect for details.
_Z
Download using_Z_inside_proc_august_28_2024.mw
For me this result is suspicious. What do you think?
This ode diff(y(x),x) = f*y(x)^4+g*y(x)+h; is clearly quadrature, since I did not tell Maple that f,g,h depend on x. So this can be solved by just integration. But when asking odeadvisor if it is Chini, it says yes. When asking it what type it is, now it says it is quadrature.
Am I missing something here? I was expecting [NONE] when asking it if it is Chini.
Yes, the ode has the form of Chini, which is   y'=f(x)*y^n + g(x)*y + h(x), where n=4 here. But if f,g,h do not depend on x, then this is now just quadrature. Right? Calling it Chini is little misleading I think.
`The "Physics Updates" version in the MapleCloud is 1796 and is the same as the version installed in this computer, created 2024, August 29, 14:22 hours Pacific Time.`
libname;
ode:=diff(y(x),x) = f*y(x)^4+g*y(x)+h;
DEtools:-odeadvisor(ode,y(x),[Chini]);
diff(y(x), x) = f*y(x)^4+g*y(x)+h
[_Chini]
DEtools:-odeadvisor(ode,y(x))
[_quadrature]
dsolve(ode,y(x),[quadrature]);
x-Intat(1/(_a^4*f+_a*g+h), _a = y(x))-c__1 = 0
dsolve(ode,y(x),[Chini]);
y(x) = -RootOf(Intat(g^4/(_a^4*f*h^3-_a*g^4+g^4), _a = _Z)+g*x+c__1)*h/g
Download question_on_advisor_august_28_2024.mw
Notice another problem in this solutions. If g=0, then the Chini solution gives divison by zero now, while the quadrature solution still works.
I am facing some problems. I want to draw some plots: I have considered the 4th order momentum equation and the 2nd order energy equation; it requires 6 boundary conditions, which I have provided, but till asking for errors (in dsolve/numeric/bvp/convertsys) too few boundary conditions: expected 7, got 6.
eqn1 := {((kappa[1].phi[1]+kappa[2].phi[2]+kappa[3].phi[3])/(phi[1]+phi[2]+phi[3])+(p-1).kappa[f]+(p-1).(kappa[1].phi[1]+kappa[2].phi[2]+kappa[3].phi[3])-(p-1).(phi[1]+phi[2]+phi[3]).kappa[f])/((kappa[1].phi[1]+kappa[2].phi[2]+kappa[3].phi[3])/(phi[1]+phi[2]+phi[3])+(p-1).kappa[f]-(p-1).(kappa[1].phi[1]+kappa[2].phi[2]+kappa[3].phi[3])+(phi[1]+phi[2]+phi[3]).kappa[f]).(diff(theta(eta), eta, eta)+4/3.N.(diff((1+(K-1).theta(eta))^3.(diff(theta(eta), eta)), eta)))+Pr.(((1-phi[3]).((1-phi[2])*(1-phi[1]+phi[1].(`&rho;c__s1`/`&rho;c__f`))+phi[2].(`&rho;c__s2`/`&rho;c__f`))+phi[3].(`&rho;c__s3`/`&rho;c__f`)).(R.f(eta)+alpha.eta).(diff(theta(eta), eta))+Q.theta(eta)+R.Ec.((diff(f(eta), eta, eta))^2)) = 0, diff(f(eta), eta, eta, eta, eta)-(1-phi[1])^2.5.((1-phi[2])^2.5).((1-phi[3])^2.5).((1-phi[3]).((1-phi[2]).(1-phi[1]+phi[1].(`&rho;__s1`/`&rho;__f`))+phi[2].(`&rho;__s2`/`&rho;__f`))+phi[3].(`&rho;__s3`/`&rho;__f`)).(alpha.(eta.(diff(f(eta), eta, eta, eta))+3.*(diff(f(eta), eta, eta)))+(diff(f(eta), eta, eta, eta)).f(eta)-(diff(f(eta), eta)).(diff(f(eta), eta, eta))).R-(1-phi[1])^2.5.((1-phi[2])^2.5).((1-phi[3])^2.5).A.B.e^(-B.eta) = 0, f(-1) = S, f(1) = 1, theta(-1) = 1, theta(1) = 0, (D(f))(-1) = 0, (D(f))(1) = 0}
sys1 := eval(eqn1, {A = 1, B = .5, Ec = .1, K = 1.5, N = .5, Pr = 2, Q = .4, R = 1, S = -.1, p = 3, alpha = .2, `&rho;__f` = 997.1, `&rho;__s1` = 0, `&rho;__s2` = 0, `&rho;__s3` = 5180, `&rho;c__f` = 997.1.4179, `&rho;c__s1` = 0, `&rho;c__s2` = 0, `&rho;c__s3` = 5180.670, phi[1] = 0., phi[2] = 0., phi[3] = 0.3e-1, kappa[1] = 0, kappa[2] = 0, kappa[3] = 9.7, kappa[f] = .613})
sol1 := dsolve(sys1, numeric);
Error, (in dsolve/numeric/bvp/convertsys) too few boundary conditions: expected 7, got 6
t1 := odeplot(sol1, [eta, diff(f(eta), eta)], eta = -1 .. 1, numpoints = 65, thickness = 0, color = green, linestyle = solid);
plots[plots:-display]({t1})
Download A1.mw
is there a versioning concept similiar to Eclipse ?
I did expect the following two plot statements (MaplePrimes is only rendering one statement) to produce the same plot. What did I do wrong when using mod in plot?
kernelopts(version)
`Maple 2024.1, X86 64 WINDOWS, Jun 25 2024, Build ID 1835466`
plot([seq([t, `mod`(t, 10)], t = 1 .. 100)])
plot(`mod`(t, 10), t = 0 .. 100)
Download mod_in_plot.mw
In my Maple 2020, I noticed my program got stuck (overnight so let's say for at least 8 hours) on factorization of relatively small integer, so I tried the command standalone:
ifactor(630743190664091077)
and it just froze. For comparsion I tried other SW and programming libraries and basically all of them had the answer instantly. Also looking at the Maple's methods, if I force pollard or lenstra, it also gets the answer instantly. If my understanding is correct, it gets stuck on the method 'morrbril' which is part of the default mix (I tried also mpqs and it gave FAIL, but at least instantly).
Is that something that still happens by default in newer versions? Seems to me if it gets stuck on 18 decimal digit integer, maybe it's not the best default method...
with(geometry);
Bl := color = black;
y0 := x -> -ln(1 - exp(-x));
y0 := proc (x) options operator, arrow; -ln(1-exp(-x)) end proc
y1 := x -> -ln(-1 + exp(-x));
y1 := proc (x) options operator, arrow; -ln(-1+exp(-x)) end proc
y2 := x -> -ln(1 + exp(-x));
y2 := proc (x) options operator, arrow; -ln(1+exp(-x)) end proc
p := plot(y0(x), x = 0.02 .. 4, scaling = constrained, color = blue);
p1 := plot(y2(x), x = -4 .. 4, scaling = constrained, color = green);
p2 := plot(y1(x), x = -4 .. 0, scaling = constrained, color = red);
display({p, p1, p2}, view = [-4 .. 4, -4 .. 5]);
Calculate its area; Thank you.
Why Maple can not do this basic combining of two terms? What do  I need to do to help Maple do it? Am I not using the correct command?
`The "Physics Updates" version in the MapleCloud is 1795 and is the same as the version installed in this computer, created 2024, August 28, 23:14 hours Pacific Time.`
e:=B^2/(4*(k^n)^(2/3)) - (k^n)^(1/3)*x;
(1/4)*B^2/(k^n)^(2/3)-(k^n)^(1/3)*x
combine(e);
combine(e,symbolic)
(1/4)*B^2*k^(-(2/3)*n)-k^((1/3)*n)*x
combine(e,power)
combine(e,radical)
combine(e,radical,symbolic)
combine(e) assuming positive;
combine(e,abs)
Download how_to_combine_august_28_2024.mw
For reference, using another software, this is what it gives
First 77 78 79 80 81 82 83 Last Page 79 of 2427
