This is some serious problem in Latex in Maple 2024.1
I went back to using _C1, _C2 for my own constants of integration.
But I want to get the nice latex for c__1,c__2.
So to do that, my understanding is that I just need to call Maple's dsolve after restart on some random ode in order to set c__1,c__2 for display only and also for latex.
This below seems to confirm this.  But now the latex generated is all wrong and messed up on some places.
My question is: I want to use use _C1,_C2 (i.e. the traditional constants) in my own code I write which generates solution to an ode, but for Latex, I'd like these to come out as c__1,c__2 since they look nicer.
What is the correct way to do this? What Am I doing wrong here? I do not see it.
#EXAMPLE showing using _C1 for input and latex. All works OK
sol:=y(x) = x+_C1/x^2;
y(x) = x+_C1/x^2
#correct latex. No problem compiling, but not nice looking _C1
latex(sol)
y \! \left(x \right) = x +\frac{\textit{\_C1}}{x^{2}}
#Example showing what happens when making call to dsolve initially
dsolve(diff(y(x),x$2)=0); #this call is used to just activate display of nicer constants
y(x) = c__1*x+c__2
y(x) = x+c__1/x^2
#bad latex, gives error when compiling with texlive
latex(sol)
y \! \left(x \right) = x +\frac{c}{_}
Download latex_problem_maple_2024_july_18_2024.mw
And to confirm this is new problem in Maple 2024, I run the same exact worksheet now in Maple 2023.2, and there it works correctly. i.e. Latex generated is correct in both cases. Here is the Maple 2023.2 worksheet, you can see below the difference in Latex.
y(x) = x+_C1/x^2
latex(sol)
y(x) = c__1*x+c__2
y(x) = x+c__1/x^2
#good Latex now in Maple 2023.2.
latex(sol)
y \! \left(x \right) = x +\frac{c_{1}}{x^{2}}
Download latex_problem_maple_2023.2.mw
If it makes any difference to Maple, I am using the typesetting EXTENDED now for everything. But I do not think Latex should care about this, but thought to mention it just in case.
Consider,  as an example,  the following (simple) transcendental equation.
alpha*((epsilon-1)*x+y-3*x*z-epsilon/3*x^3+b*sin(w)+3)
How to retrieve the coefficients and the terms considering that the unknowns are x,y,z and w?   Something like [x,y,x*z,x^3,sin(w),1] and their coefficients.
many thanks
I have thought before that Maple's dsolve will try to return implicit solution automatically if unable to find explicit one or for some  other reasons it prefers implicit.
But In this ode, we see Maple returns no solution at all for this first order quadrature ode, even though it can find solution when given implicit option.
Is this a correct behaviour? Should it not have returned this solution automatically?
`The "Physics Updates" version in the MapleCloud is 1774 and is the same as the version installed in this computer, created 2024, July 16, 17:18 hours Pacific Time.`
ode:=diff(y(x),x)=sin(y(x));
IC:=y(a)=b;
diff(y(x), x) = sin(y(x))
y(a) = b
maple_sol:=dsolve([ode,IC]);
maple_sol:=dsolve([ode,IC],explicit);
maple_sol:=dsolve([ode,IC],implicit);
x-ln(csc(y(x))-cot(y(x)))-a+ln(csc(b)-cot(b)) = 0
Download why_no_solution_by_dsolve_july_18_2024.mw
Update
I found another example of this problem. Maple gives no solution to this ODE unless option implicit is given. This is not right behaviour. If Maple can't give explicit solution, it should return the implicit one automatically. How is the user supposed to know there is a solution to this ode otherwise?
`The "Physics Updates" version in the MapleCloud is 1786 and is the same as the version installed in this computer, created 2024, August 10, 8:50 hours Pacific Time.`
libname;
ode:=(x^2+y(x)^2-2*y(x))*diff(y(x),x) = 2*x:
IC:=y(0)=1:
sol:=dsolve([ode,IC],y(x));
sol:=dsolve([ode,IC],y(x),'implicit');
-exp(-1)+exp(-y(x))*x^2+exp(-y(x))*y(x)^2 = 0
sol:=dsolve([ode,IC],y(x),'useInt');
y(x) = -RootOf(exp(_Z)*x^2-(Int(_b*(_b-2)/exp(_a), _b = 0 .. -_Z))+Int(_b*(_b-2)/exp(_a), _b = 0 .. 1))
sol:=dsolve([ode,IC],y(x),'explicit');
Download why_does_not_solve_unless_implicit_august_12_2024.mw
I want to obtain the partial derivative of a piecewise function. How it is possible to calculate  the derivative in (0,0) with diff?
I should get, as answer,  a new piecewise function
with(student);
f := (x, y) -> piecewise((x, y) = (0, 0), 0, (x^3*y - x*y^3)/(y^2 + x^2));
 f := proc (x, y) options operator, arrow; piecewise((x, y) =
    (0, 0), 0, (x^3*y-x*y^3)/(y^2+x^2)) end proc
fx := (x, y) -> diff(f(x, y), x);
fx := proc (x, y) options operator, arrow; diff(f(x, y), x) end
   proc
fx(0, 0);
Error, (in fx) invalid input: diff received 0, which is not valid for its 2nd argument
but i obtain an error
anna rita
 I know that (G, A)=Basis(F,output=extended) computes reduced Groebner basis for polynomial ideal F, while  A is a list of lists.  If A is converted to a matrix, we get G=FA. Is there a command to compute matrix B such that F=GB?
This is a simplified case from a colleague who could not get has to work.
While this
I/sqrt(a);
has(%, sqrt(a));
                               I
                              (1/2)
                             a
is a technically correct output from Maple, false is mathematically an incorrect statement (IMO).
I think new users cannot find the explanation for that on their own because in other instances the output is true
has(I/(1 - sqrt(a)), sqrt(a))
Are there better ways than
I/sqrt(a);
has(%, sqrt(a))or has(%,1/sqrt(a));
                               I
                              (1/2)
                             a
Its a bit complicated to include allways the inverse of an expression to capture all instances of an expression.
Should has do this an give a warning that also the inverse is present?
I'm trying to perform a nonlinear curve-fit on a data(named Data in the code) in Maple, but I get an error :
Error, (in Statistics:-NonlinearFit) could not store .476190476190476164*(4.41000000000000014*(4410./[2.08075582127286]^(2/3)+952.380952380952294*[2.08075582127286]^(1/3)+1000.)/[2.08075582127286]^(5/3)-19448.1000000000022/[2.08075582127286]^(7/3)+[1040.37791063642999]-500.-166.666666666666657*(8.82000000000000028/[2.08075582127286]^(2/3)+1.90476190476190466*[2.08075582127286]^(1/3))/[2.08075582127286]-166.666666666666657*(16.8000000000000007/[2.08075582127286]^(1/3)+.907029478458049820*[2.08075582127286]^(2/3))/[2.08075582127286])*[2.08075582127286]-.500000000000000000 in a floating-point rtable
I suspect there's a problem associated with the variable "r". I am trying to find J by solving the equation p__3 = 0. Then J(stored in "r") is used in P__eng1 to perform the curve-fit operation. I have tried using fsolve, and NLPSolve but they ended up in errors. I read the documents but I was unable to solve the problem.
I'm new to Maple and I'd appreciate any comment that helps me solve p__3=0 and to use the J in P__eng1. I have also attached the code.test.mw
Code and data : mapp.zip
I called dsolve with timelimit on this ode.  All of Maple instantly locks up.
I do not mean the worksheet, but everything. I have each worksheet using its own engine,. Not able to open new worksheet, nothing clicks. The whole front end locks up. Can't click on anything.
Killing every mserver.exe does not even resolve this. I had to terminate all of Maple from the task manager. The strange thing, is that looking at task manager I see mserver.exe doing nothing. zero CPU. Only the front end process is at high CPU (the one with the Java icon).  It looks like the Java frontend is locked up for some reason.
Do others see the same thing? does this happen on the mac also? Please make sure to save all your work before trying to run this on your PC.
Maple 2024.1 on windows 10. This is first order Riccati ode.
ode:=(a2*x^2+b2*x+c2)*diff(y(x),x)=y(x)^2+(a1*x+b1)*y(x)+a0*x^2+b0*x+c0;
(a2*x^2+b2*x+c2)*(diff(y(x), x)) = y(x)^2+(a1*x+b1)*y(x)+a0*x^2+b0*x+c0
DEtools:-odeadvisor(ode);
[_rational, _Riccati]
#WARNING. This will freeze all of Maple.
timelimit(30,dsolve(ode));
Download maple_lock_up_july_17_2024.mw
These are GUI options on my end.
UPDATE 1
in Maple 2023.2 also on windows 10,  there is no lock up at all. same code. The solution to the ode is very large. I tried using both typesetting level  to EXTENDED  and  typesetting level MAPLE STANDARD and no hang.
I wonder if this has something to do with why Maple 2024.1 locks up? But I have not changed anything in my end. I made no change in options or anything else. same PC, same graphics card.
UPDATE 2
Found the BUG!!
In Maple 2024.1, if I change the display option typesetting level  to EXTENDED, the front end do not hang.
If I change the display typesetting level MAPLE STANDARD, the ftont end hangs.
But why??
interface(typesetting=extended):
`[Length of output exceeds limit of 1000000]`
interface(typesetting=standard):
#WARNING, this will hang MAPLE now. WHY??
Download maple_lock_up_july_17_2024_2.mw
ps. Reported to Maplesoft support. July 17, 2024. Hopefully this will be fixed in Maple 2024.2
i am looking for all outcome of this function how i can do it
phi := (`\`p_1,p__2`, q__1, q__2, xi) -> p__1*exp(q__1*xi) - p__2*exp(q__2*xi);
for p[1 ] in [0,1,-1,I,-I] do ;
for p[2 ] in [0,1,-1,I,-I] do ;
 for q[1 ] in [0,1,-1,I,-I] do ;
 for q[2 ] in [0,1,-1,I,-I] do ;
result1 := evalf(phi(`\`p_1,p__2`, q__1, q__2, xi));
print('result1);
my code is not correct and not run in fact but it is my try
i am looking for special solution i want give the maple equation and give what answer i want with condition for example i just want thus solution which is A_0,A_1,B_1 not equal to zero and other parameter like (w,lambda,k) are free just this three not equal to zero.
with(SolveTools);
with(LinearAlgebra);
eq12 := -alpha*k^2*A[0] - alpha*k^2*A[1] - alpha*k^2*B[1] + A[0]^3*beta[4] + (3*A[0]^2)*A[1]*beta[4] + (3*A[0]^2)*B[1]*beta[4] + (3*A[0])*A[1]^2*beta[4] + (6*A[0])*A[1]*B[1]*beta[4] + (3*A[0])*B[1]^2*beta[4] + A[1]^3*beta[4] + (3*A[1]^2)*B[1]*beta[4] + (3*A[1])*B[1]^2*beta[4] + B[1]^3*beta[4] + A[0]^2*beta[3] + (2*A[0])*A[1]*beta[3] + (2*A[0])*B[1]*beta[3] + A[1]^2*beta[3] + (2*A[1])*B[1]*beta[3] + B[1]^2*beta[3] - w*A[0] - w*A[1] - w*B[1] = 0
eq10 := (2*alpha)*k^2*A[1] - (2*alpha)*k^2*B[1] - (8*alpha)*lambda^2*A[1] + (8*alpha)*lambda^2*B[1] - (8*gamma)*lambda^2*A[1] + (8*gamma)*lambda^2*B[1] - (6*A[0]^2)*A[1]*beta[4] + (6*A[0]^2)*B[1]*beta[4] - (12*A[0])*A[1]^2*beta[4] + (12*A[0])*B[1]^2*beta[4] - (6*A[1]^3)*beta[4] - (6*A[1]^2)*B[1]*beta[4] + (6*A[1])*B[1]^2*beta[4] + (6*B[1]^3)*beta[4] - (4*A[0])*A[1]*beta[3] + (4*A[0])*B[1]*beta[3] - (4*A[1]^2)*beta[3] + (4*B[1]^2)*beta[3] + (2*w)*A[1] - (2*w)*B[1] = 0
eq8 := -(3*A[1]^2)*B[1]*beta[4] - (3*A[1])*B[1]^2*beta[4] - (2*A[0])*A[1]*beta[3] - (2*A[0])*B[1]*beta[3] + w*A[1] + w*B[1] - (3*A[0]^2)*B[1]*beta[4] + alpha*k^2*A[1] + alpha*k^2*B[1] - (3*A[0]^2)*A[1]*beta[4] + (3*alpha)*k^2*A[0] + (32*alpha)*lambda^2*A[1] + (32*alpha)*lambda^2*B[1] + (32*gamma)*lambda^2*A[1] + (32*gamma)*lambda^2*B[1] - (3*A[0]^3)*beta[4] + (15*A[0])*A[1]^2*beta[4] - (18*A[0])*A[1]*B[1]*beta[4] + (15*A[0])*B[1]^2*beta[4] + (15*A[1]^3)*beta[4] + (15*B[1]^3)*beta[4] - (3*A[0]^2)*beta[3] + (5*A[1]^2)*beta[3] - (6*A[1])*B[1]*beta[3] + (5*B[1]^2)*beta[3] + (3*w)*A[0] = 0
eq6 := -(4*alpha)*k^2*A[1] + (4*alpha)*k^2*B[1] - (48*alpha)*lambda^2*A[1] + (48*alpha)*lambda^2*B[1] - (48*gamma)*lambda^2*A[1] + (48*gamma)*lambda^2*B[1] + (12*A[0]^2)*A[1]*beta[4] - (12*A[0]^2)*B[1]*beta[4] - (20*A[1]^3)*beta[4] + (12*A[1]^2)*B[1]*beta[4] - (12*A[1])*B[1]^2*beta[4] + (20*B[1]^3)*beta[4] + (8*A[0])*A[1]*beta[3] - (8*A[0])*B[1]*beta[3] - (4*w)*A[1] + (4*w)*B[1] = 0
eq4 := -(3*A[1]^2)*B[1]*beta[4] - (3*A[1])*B[1]^2*beta[4] - (2*A[0])*A[1]*beta[3] - (2*A[0])*B[1]*beta[3] + w*A[1] + w*B[1] - (3*A[0]^2)*B[1]*beta[4] + alpha*k^2*A[1] + alpha*k^2*B[1] - (3*A[0]^2)*A[1]*beta[4] - (3*alpha)*k^2*A[0] + (32*alpha)*lambda^2*A[1] + (32*alpha)*lambda^2*B[1] + (32*gamma)*lambda^2*A[1] + (32*gamma)*lambda^2*B[1] + (3*A[0]^3)*beta[4] - (15*A[0])*A[1]^2*beta[4] + (18*A[0])*A[1]*B[1]*beta[4] - (15*A[0])*B[1]^2*beta[4] + (15*A[1]^3)*beta[4] + (15*B[1]^3)*beta[4] + (3*A[0]^2)*beta[3] - (5*A[1]^2)*beta[3] + (6*A[1])*B[1]*beta[3] - (5*B[1]^2)*beta[3] - (3*w)*A[0] = 0
eq2 := (2*alpha)*k^2*A[1] - (2*alpha)*k^2*B[1] - (8*alpha)*lambda^2*A[1] + (8*alpha)*lambda^2*B[1] - (8*gamma)*lambda^2*A[1] + (8*gamma)*lambda^2*B[1] - (6*A[0]^2)*A[1]*beta[4] + (6*A[0]^2)*B[1]*beta[4] + (12*A[0])*A[1]^2*beta[4] - (12*A[0])*B[1]^2*beta[4] - (6*A[1]^3)*beta[4] - (6*A[1]^2)*B[1]*beta[4] + (6*A[1])*B[1]^2*beta[4] + (6*B[1]^3)*beta[4] - (4*A[0])*A[1]*beta[3] + (4*A[0])*B[1]*beta[3] + (4*A[1]^2)*beta[3] - (4*B[1]^2)*beta[3] + (2*w)*A[1] - (2*w)*B[1] = 0
eq0 := alpha*k^2*A[0] - alpha*k^2*A[1] - alpha*k^2*B[1] - A[0]^3*beta[4] + (3*A[0]^2)*A[1]*beta[4] + (3*A[0]^2)*B[1]*beta[4] - (3*A[0])*A[1]^2*beta[4] - (6*A[0])*A[1]*B[1]*beta[4] - (3*A[0])*B[1]^2*beta[4] + A[1]^3*beta[4] + (3*A[1]^2)*B[1]*beta[4] + (3*A[1])*B[1]^2*beta[4] + B[1]^3*beta[4] - A[0]^2*beta[3] + (2*A[0])*A[1]*beta[3] + (2*A[0])*B[1]*beta[3] - A[1]^2*beta[3] - (2*A[1])*B[1]*beta[3] - B[1]^2*beta[3] + w*A[0] - w*A[1] - w*B[1] = 0
COEFFS := solve({eq0, eq10, eq12, eq2, eq4, eq6, eq8}, {k, lambda, w, A[0], A[1], B[1]})
Good day, all.
Please I want to solve the following delay differential equation:
ODE := diff(y(t), t$2) = (2*(1-y(t-1)^2))*(diff(y(t), t))-y(t)
ics := y(0) = 1, (D(y))(0) = 0
using the following codes but there is an error. Please kindly help to modify the codes.
Digits:=30:
f:=proc(n)
	2*(1-(y[n-1])^2)*delta[n]+y[n]:
g:=proc(n)
	-4*y[n-1]*delta[n-1]+2*(1-(y[n-1])^2)*f(n)-delta[n]:
e1:=y[n+2] = -y[n]+2*y[n+1]+(1/120)*h^2*(-3*h*g(n+2)+3*g(n)*h+16*f(n+2)+16*f(n)+88*f(n+1)):
e2:=h*delta[n] = -y[n]+y[n+1]-(1/1680)*h^2*(-128*h*g(n+1)-11*h*g(n+2)+59*g(n)*h+40*f(n+2)+520*f(n)+280*f(n+1)):
e3:=h*delta[n+1] = -y[n]+y[n+1]+(1/1680)*h^2*(-152*h*g(n+1)-10*h*g(n+2)+32*g(n)*h+37*f(n+2)+187*f(n)+616*f(n+1)):
e4:=h*delta[n+2] = -y[n]+y[n+1]+(1/1680)*h^2*(128*h*g(n+1)-101*h*g(n+2)+53*g(n)*h+744*f(n+2)+264*f(n)+1512*f(n+1)):
inx:=0:
ind:=0:
iny:=1:
h:=1/2:
n:=1:
omega:=10:
u:=omega*h:
N:=solve(h*p = 10, p):
err := Vector(round(N)):
exy_lst := Vector(round(N)):
numerical_y1:=Vector(round(N)):
c:=1:
for j from 0 to 2 do
	t[j]:=inx+j*h:
vars:=y[n+1],y[n+2],delta[n+1],delta[n+2]:
step := [seq](eval(x, x=c*h), c=1..N):
printf("%6s%45s%45s\n",
	"h","Num.y","Num.z");
#eval(<vars>, solve({e||(1..4)},{vars}));
st := time():
for k from 1 to N/2 do
	par1:=x[0]=t[0],x[1]=t[1],x[2]=t[2]:
	par2:=y[n]=iny,delta[n]=ind:
	res:=eval(<vars>, fsolve(eval({e||(1..4)},[par1,par2]), {vars}));
	for i from 1 to 2 do
		printf("%6.5f%45.30f%45.30f\n",
		h*c,res[i],res[i+2]):
		numerical_y1[c] := res[i]:
		c:=c+1:
	iny:=res[2]:
	ind:=res[4]:
	inx:=t[2]:
		t[j]:=inx + j*h:
v:=time() - st;
v/4;
printf("Maximum error is %.13g\n", max(err));
NFE=evalf((N/4*3)+1);
#get array of numerical and exact solutions for y1
numerical_array_y1 := [seq(numerical_y1[i], i = 1 .. N)]:
#exact_array_y1 := [seq(exy[i], i = 1 .. N)]:
#get array of time steps
time_t := [seq](step[i], i = 1 .. N):
#display graphs for y1
numerical_plot_y1 := plot(time_t, numerical_array_y1, style = [point], symbol = [asterisk],
				color = [blue,blue],symbolsize = 20, legend = ["TFIBF"]);
 Thank you, and best regards.
I can't isolate a variable from the constraint and move it to one side of the inequality. For example, it's like having theta <= all other terms. I've tried using the isolate and eval functions, but they aren't producing any results or simplifying the expression. What am I doing wrong?
Attaching sheet below (issue marked yellow in background): N_1.mw
I'd like to explore graphically a polynomial surface depending on two parameters a and b.
The problem is that, as soon as I start playing with the sliders, Maple freezes and I have to 'force quit'.
Can you please tell me if you have the same problem with this example?
K := 1 - y*x - (1 - x)*(b*x^3 + a*x^2 + x + 1)*(1 - y)*(b*y^3 + a*y^2 + y + 1)
1-y*x-(1-x)*(b*x^3+a*x^2+x+1)*(1-y)*(b*y^3+a*y^2+y+1)
Explore(plot3d(K, x=0..1, y=0..1,  font= [Times, bold, 20], labels= ['x', 'y','z'],   labelfont= [Times, bold, 40],  title = "K(x,y)"), b = 0..1., a=0..1.);
Download Explore.mw
Hello Dear Professional users,
I have a question regarding the "fsolve" command and also the "assign" command in Maple.
In my previous codes, I just used one time from "fsolve" and then "assign" command.
Today, I want to use "fsolve" and "assign" in a for loop. But, I can not get the results correctly.
For example, previously I reach a system of algebraic equations and the solve my problem easily:
N:=8:
y:=sum(a[n]*t^n,n=0..N):
y:=unapply(y,t):
*****some calculations with a[n] coefficients *****
A:={a set of nonlinear algebraic equations in terms of a[n]}%The number of equations is N+1 (same as the number of a[n] for n=0..N)
sol:=fsolve(A):
assign(sol)
plot(y(t),t=0..1)
Today, my problem is:
N:=8:
M:=4:
for i from 1 to M do
y[i]:=sum(a[i,n]*t^n,n=0..N):
y[i]:=unapply(y[i],t):
end do
@A[i]:={a set of nonlinear algebraic equations in terms of a[i,n]}%The number of equations is N+1 (same as the number of a[n] for n=0..N)
@sol[i]:=fsolve(A[i]):
@assign(sol[i])
@plot(y[i](t),t=0..1)
end do
What I should write instead of "A[i]", "sol[i]", and "assign(sol[i])" the lines started with
@A[i],....
@sol[i],...
@assign(sol[i]),....
Thanks for your attention in advance
With kind regards,
Emran
I am trying to understand how to use Maple to solve a PDE.  Below it is a problem (Henon-Heilles system) where the answer is known.
with(PDEtools);
infolevel[pdsolve]:=3:
declare(Hamil(x,y,u,v));
PDEHamil := u*diff(Hamil(x, y, u, v), x) + v*diff(Hamil(x, y, u, v), y) + (-2*x*y - x)*diff(Hamil(x, y, u, v), u) + (-x^2 + y^2 - y)*diff(Hamil(x, y, u, v), v) = 0;
pdsolve(PDEHamil)
Maple returns no solution, but one solution is:
sH:=1/2*(u^2+v^2)+1/2*(x^2+y^2-2/3*y^3)+x^2*y;
simplify(eval(subs(Hamil(x,y,u,v)=sH,PDEHamil)));
    0=0
What am I missing?
Many thanks.
First 90 91 92 93 94 95 96 Last Page 92 of 2427
