i use other code for equation too when i use allvalues(Root(...)) it is more near but question is this why not satisfy the ode equation this is my equation this parameter are find for this ODe why not satisfy otherwise my equestions must be wrong!
with(PDEtools)
undeclare(prime)
with(DEtools)
with(LinearAlgebra)
with(sumtools)
eq0 := 2*beta*g[1]^3*r[0]^3+2*p^2*sigma*g[1]*r[0]^3 = 0
eq1 := 6*beta*g[1]^3*r[0]^2*r[1]+3*p^2*sigma*g[1]*r[0]^2*r[1]+6*beta*f[0]*g[1]^2*r[0]^2 = 0
eq2 := 6*beta*g[1]^3*r[0]^2*r[2]+6*beta*g[1]^3*r[0]*r[1]^2+2*p^2*sigma*g[1]*r[0]^2*r[2]+p^2*sigma*g[1]*r[0]*r[1]^2+12*beta*f[0]*g[1]^2*r[0]*r[1]+6*beta*f[1]*g[1]^2*r[0]^2+6*beta*f[0]^2*g[1]*r[0]-k^2*sigma*g[1]*r[0]-2*w*g[1]*r[0] = 0
eq3 := 12*beta*g[1]^3*r[0]*r[1]*r[2]+2*beta*g[1]^3*r[1]^3+2*p^2*sigma*g[1]*r[0]*r[1]*r[2]+12*beta*f[0]*g[1]^2*r[0]*r[2]+6*beta*f[0]*g[1]^2*r[1]^2+12*beta*f[1]*g[1]^2*r[0]*r[1]+p^2*sigma*f[1]*r[0]*r[1]+6*beta*f[0]^2*g[1]*r[1]+12*beta*f[0]*f[1]*g[1]*r[0]-k^2*sigma*g[1]*r[1]+2*beta*f[0]^3-k^2*sigma*f[0]-2*w*g[1]*r[1]-2*w*f[0] = 0
eq4 := 6*beta*g[1]^3*r[0]*r[2]^2+6*beta*g[1]^3*r[1]^2*r[2]+2*p^2*sigma*g[1]*r[0]*r[2]^2+p^2*sigma*g[1]*r[1]^2*r[2]+12*beta*f[0]*g[1]^2*r[1]*r[2]+12*beta*f[1]*g[1]^2*r[0]*r[2]+6*beta*f[1]*g[1]^2*r[1]^2+2*p^2*sigma*f[1]*r[0]*r[2]+p^2*sigma*f[1]*r[1]^2+6*beta*f[0]^2*g[1]*r[2]+12*beta*f[0]*f[1]*g[1]*r[1]+6*beta*f[1]^2*g[1]*r[0]-k^2*sigma*g[1]*r[2]+6*beta*f[0]^2*f[1]-k^2*sigma*f[1]-2*w*g[1]*r[2]-2*w*f[1] = 0
eq5 := 6*beta*g[1]^3*r[1]*r[2]^2+3*p^2*sigma*g[1]*r[1]*r[2]^2+6*beta*f[0]*g[1]^2*r[2]^2+12*beta*f[1]*g[1]^2*r[1]*r[2]+3*p^2*sigma*f[1]*r[1]*r[2]+12*beta*f[0]*f[1]*g[1]*r[2]+6*beta*f[1]^2*g[1]*r[1]+6*beta*f[0]*f[1]^2 = 0
eq6 := 2*beta*g[1]^3*r[2]^3+2*p^2*sigma*g[1]*r[2]^3+6*beta*f[1]*g[1]^2*r[2]^2+2*p^2*sigma*f[1]*r[2]^2+6*beta*f[1]^2*g[1]*r[2]+2*beta*f[1]^3 = 0
COEFFS := solve({eq0, eq1, eq2, eq3, eq4, eq5, eq6}, {p, f[0], f[1], g[1]}, explicit)
ode := 2*beta*U(xi)^3+(-k^2*sigma-2*w)*U(xi)+(diff(diff(U(xi), xi), xi))*p^2*sigma = 0
P := f[0]+sum(f[i]*R(xi)^i, i = 1 .. 1)+sum(g[i]*((diff(R(xi), xi))/R(xi))^i, i = 1 .. 1)
f[0]+f[1]*R(xi)+g[1]*(diff(R(xi), xi))/R(xi)
case1 := {p = -sqrt(2)*sqrt(sigma*(4*r[0]*r[2]-r[1]^2)*(k^2*sigma+2*w))/(sigma*(4*r[0]*r[2]-r[1]^2)), f[0] = -(k^2*sigma+2*w)*r[1]/sqrt(-2*beta*(4*r[0]*r[2]-r[1]^2)*(k^2*sigma+2*w)), f[1] = -(2*(k^2*sigma+2*w))*r[2]/sqrt(-2*beta*(4*r[0]*r[2]-r[1]^2)*(k^2*sigma+2*w)), g[1] = -sqrt(-2*beta*(4*r[0]*r[2]-r[1]^2)*(k^2*sigma+2*w))/(beta*(4*r[0]*r[2]-r[1]^2))}
{p = -2^(1/2)*(sigma*(4*r[0]*r[2]-r[1]^2)*(k^2*sigma+2*w))^(1/2)/(sigma*(4*r[0]*r[2]-r[1]^2)), f[0] = -(k^2*sigma+2*w)*r[1]/(-2*beta*(4*r[0]*r[2]-r[1]^2)*(k^2*sigma+2*w))^(1/2), f[1] = -2*(k^2*sigma+2*w)*r[2]/(-2*beta*(4*r[0]*r[2]-r[1]^2)*(k^2*sigma+2*w))^(1/2), g[1] = -(-2*beta*(4*r[0]*r[2]-r[1]^2)*(k^2*sigma+2*w))^(1/2)/(beta*(4*r[0]*r[2]-r[1]^2))}
K := diff(R(xi), xi) = r[0]+r[1]*R(xi)+r[2]*R(xi)^2
S1 := subs(K, P)
f[0]+f[1]*R(xi)+g[1]*(r[0]+r[1]*R(xi)+r[2]*R(xi)^2)/R(xi)
C1 := subs(case1, S1)
-(k^2*sigma+2*w)*r[1]/(-2*beta*(4*r[0]*r[2]-r[1]^2)*(k^2*sigma+2*w))^(1/2)-2*(k^2*sigma+2*w)*r[2]*R(xi)/(-2*beta*(4*r[0]*r[2]-r[1]^2)*(k^2*sigma+2*w))^(1/2)-(-2*beta*(4*r[0]*r[2]-r[1]^2)*(k^2*sigma+2*w))^(1/2)*(r[0]+r[1]*R(xi)+r[2]*R(xi)^2)/(beta*(4*r[0]*r[2]-r[1]^2)*R(xi))
f := U(xi) = C1
U(xi) = -(k^2*sigma+2*w)*r[1]/(-2*beta*(4*r[0]*r[2]-r[1]^2)*(k^2*sigma+2*w))^(1/2)-2*(k^2*sigma+2*w)*r[2]*R(xi)/(-2*beta*(4*r[0]*r[2]-r[1]^2)*(k^2*sigma+2*w))^(1/2)-(-2*beta*(4*r[0]*r[2]-r[1]^2)*(k^2*sigma+2*w))^(1/2)*(r[0]+r[1]*R(xi)+r[2]*R(xi)^2)/(beta*(4*r[0]*r[2]-r[1]^2)*R(xi))
SO := subs(case1, ode)
2*beta*U(xi)^3+(-k^2*sigma-2*w)*U(xi)+2*(diff(diff(U(xi), xi), xi))*(k^2*sigma+2*w)/(4*r[0]*r[2]-r[1]^2) = 0
odetest(f, SO)
same_equation_different_parameter.mw
display([plottools[arc]([op(coordinates(Omega))], r, t .. t + Pi/2, color = red, t4), plottools[arc]([op(coordinates(Omega))], r, t + Pi .. t + (3*Pi)/2, color = coral, t4), plottools[arc]([op(coordinates(Omega))], r, t - Pi/2 .. t, color = cyan, t4), plottools[arc]([op(coordinates(Omega))], r, t + Pi/2 .. t + Pi, color = green, t4)],
draw([Cir(color = blue, t4), cir(color = grey, t4), sT(color = black, t4), XXp(color = black, l3), YYp(color = black, l3), L1(color = black, l3), L2(color = black, l3), N1(color = blue, symbol = solidcircle, symbolsize = 15), N2(color = blue, symbol = solidcircle, symbolsize = 15), N3(color = blue, symbol = solidcircle, symbolsize = 15), M1(color = blue, symbol = solidcircle, symbolsize = 15)]), axes = none, view = [-30 .. 10, -10 .. 10], size = [800, 800])::
plots:-animate(Proc, [t], t = 0 .. 2*Pi, frames = 30).;
why the instruction concerning the arcs is not resected ? Thank you.
I liked the recent question from user goebeld and especially the answer from Rouben Rostamian.
I admit, I didn’t even realize that Maple had VariationalCalculus procedures.
But what if the red and green  points are on the surface x1^4 + x2^4 + x3^4 -1 = 0
Points coordinates (-0.759835685700000, -0.759835685700000, 0.759835685700000) and
 (0.759835685700000, 0.759835685700000, -0.759835685700000).
Where will the shortest distance between these points on a given surface be? Taking into account symmetry, of course.
I have a thirder order ODE with non polynomial coefficients and I naively thought to try dsolve for fun to see what happens and Maple returned DESol with a second order differential equation and an arbitrary coefficient. I know Maple outputs DESol when it cannot find a solution similar to RootOf but the arbitrary constant is what is throwing me off.
I am unsure how to interpret this, if a particular solution is found I could reduce the order and see how I could get with the second order ODE but maple doesn't produce a particular solution when I run that command.
DESol_Question.mw
What is the problem with the integral below when I use a variable n?
with(Units:-Simple)
V__1 := Unit('m'^3) = Units:-Unit(m^3)NULL
V__2 := 2*Unit('m'^3) = 2*Units:-Unit(m^3)NULL
int(1/V, V = V__1 .. V__2)
ln(2)
`assuming`([int(n/V, V = n*Unit('m'^3) .. m*Unit('m'^3))], [n > 0, m > 0])
-ln(n)*n+ln(m)*n
Download Units_Int.mw
Dear all, is there a maple call to calculate the space curve connecting two points of a 3d plane?
e.g. the plane is defined by: f(x,y) = -x^2/9 + y^2/4
The two points are: P = (1,2,0), Q=(1,-1,0)
Searched: space curve laying on 3d plane connecting the two points.
with(PDEtools)
undeclare(prime)
with(DEtools)
with(DifferentialAlgebra)
"with(Student[ODEs][Solve]): "
with(IntegrationTools)
with(inttrans)
with(PDEtools)
with(Physics)
with(PolynomialTools)
with(RootFinding)
with(SolveTools)
with(LinearAlgebra)
with(sumtools)
pde := I*(diff(psi(x, t), t))+alpha*(diff(psi(x, t), `$`(x, 2)))+(beta[3]*abs(psi(x, t))+beta[4]*abs(psi(x, t))^2)*psi(x, t)+gamma*(diff(abs(psi(x, t))^2, `$`(x, 2)))*psi(x, t)/abs(psi(x, t)) = 0
case1 := {k = k, lambda = sqrt(-1/(18*alpha*beta[4]+18*gamma*beta[4]))*beta[3], w = -(9*alpha*k^2*beta[4]+2*beta[3]^2)/(9*beta[4]), A[0] = -beta[3]/(3*beta[4]), A[1] = beta[3]/(3*beta[4]), B[1] = 0}
" psi(x,t):=U(xi)*exp(I*(-k*x+w*t+theta))"
proc (x, t) options operator, arrow, function_assign; U(xi)*exp(I*(-k*x+w*t+theta)) end proc
" U(xi):=-(beta[3] (cosh(xi)-sinh(xi)))/(3 beta[4] cosh(xi))"
proc (xi) options operator, arrow, function_assign; -(1/3)*beta[3]*(cosh(xi)-sinh(xi))/(beta[4]*cosh(xi)) end proc
convert(U(xi), trig)
xi := sqrt(-1/(18*alpha*beta[4]+18*gamma*beta[4]))*beta[3]*(2*alpha*kt+x)
(-1/(18*alpha*beta[4]+18*gamma*beta[4]))^(1/2)*beta[3]*(2*alpha*kt+x)
S := psi(x, t)
-(1/3)*beta[3]*(cosh((-1/(18*alpha*beta[4]+18*gamma*beta[4]))^(1/2)*beta[3]*(2*alpha*kt+x))-sinh((-1/(18*alpha*beta[4]+18*gamma*beta[4]))^(1/2)*beta[3]*(2*alpha*kt+x)))*exp(I*(-k*x+t*w+theta))/(beta[4]*cosh((-1/(18*alpha*beta[4]+18*gamma*beta[4]))^(1/2)*beta[3]*(2*alpha*kt+x)))
solution := subs(case1, S)
-(1/3)*beta[3]*(cosh((-1/(18*alpha*beta[4]+18*gamma*beta[4]))^(1/2)*beta[3]*(2*alpha*kt+x))-sinh((-1/(18*alpha*beta[4]+18*gamma*beta[4]))^(1/2)*beta[3]*(2*alpha*kt+x)))*exp(I*(-k*x-(1/9)*(9*alpha*k^2*beta[4]+2*beta[3]^2)*t/beta[4]+theta))/(beta[4]*cosh((-1/(18*alpha*beta[4]+18*gamma*beta[4]))^(1/2)*beta[3]*(2*alpha*kt+x)))
pdetest(psi(x, t) = -beta[3]*(cosh(sqrt(-1/(18*alpha*beta[4]+18*gamma*beta[4]))*beta[3]*(2*alpha*k+x))-sinh(sqrt(-1/(18*alpha*beta[4]+18*gamma*beta[4]))*beta[3]*(2*alpha*k+x)))*exp(I*(-k*x-(9*alpha*k^2*beta[4]+2*beta[3]^2)*t/(9*beta[4])+theta))/(3*beta[4]*cosh(sqrt(-1/(18*alpha*beta[4]+18*gamma*beta[4]))*beta[3]*(2*alpha*k+x)))*exp(I*(-k*x-(9*alpha*k^2*beta[4]+2*beta[3]^2)*t/(9*beta[4])+theta)), pde)
Error, (in pdetest) unable to determine the indeterminate function
Download pde-solve.mw
Dear all, in the example below I create a matrix(3x2) and each element contains a vector. How can I avoid the double brackets of the matrix elements or eliminate the double brackets?
Thanks for help
with(PolynomialTools);
with(RootFinding);
with(SolveTools);
with(LinearAlgebra);
NULL;
NULL;
E1 := (-alpha*k^2*A[1] - alpha*k^2*B[1] + 3*A[0]^2*A[1]*beta[4] + 3*A[0]^2*B[1]*beta[4] + A[1]^3*beta[4] + 3*A[1]^2*B[1]*beta[4] + 3*A[1]*B[1]^2*beta[4] + B[1]^3*beta[4] + 2*A[0]*A[1]*beta[3] + 2*A[0]*B[1]*beta[3] - w*A[1] - w*B[1])*cosh(xi)^6 + (-alpha*k^2*A[0] + A[0]^3*beta[4] + 3*A[0]*A[1]^2*beta[4] + 6*A[0]*A[1]*B[1]*beta[4] + 3*A[0]*B[1]^2*beta[4] + A[0]^2*beta[3] + A[1]^2*beta[3] + 2*A[1]*B[1]*beta[3] + B[1]^2*beta[3] - w*A[0])*sinh(xi)*cosh(xi)^5 + (2*alpha*k^2*A[1] + alpha*k^2*B[1] - 2*alpha*lambda^2*A[1] + 2*alpha*lambda^2*B[1] - 2*gamma*lambda^2*A[1] + 2*gamma*lambda^2*B[1] - 6*A[0]^2*A[1]*beta[4] - 3*A[0]^2*B[1]*beta[4] - 3*A[1]^3*beta[4] - 6*A[1]^2*B[1]*beta[4] - 3*A[1]*B[1]^2*beta[4] - 4*A[0]*A[1]*beta[3] - 2*A[0]*B[1]*beta[3] + 2*w*A[1] + w*B[1])*cosh(xi)^4 + (alpha*k^2*A[0] - A[0]^3*beta[4] - 6*A[0]*A[1]^2*beta[4] - 6*A[0]*A[1]*B[1]*beta[4] - A[0]^2*beta[3] - 2*A[1]^2*beta[3] - 2*A[1]*B[1]*beta[3] + w*A[0])*sinh(xi)*cosh(xi)^3 + (-alpha*k^2*A[1] + 4*alpha*lambda^2*A[1] + 4*gamma*lambda^2*A[1] + 3*A[0]^2*A[1]*beta[4] + 3*A[1]^3*beta[4] + 3*A[1]^2*B[1]*beta[4] + 2*A[0]*A[1]*beta[3] - w*A[1])*cosh(xi)^2 + (3*A[0]*A[1]^2*beta[4] + A[1]^2*beta[3])*sinh(xi)*cosh(xi) - 2*alpha*lambda^2*A[1] - 2*gamma*lambda^2*A[1] - A[1]^3*beta[4] = 0;
N := 6;
for i from 0 to N do
    equ[1][i] := coeff(E1, {cosh(xi)^i, sinh(xi)^i}, i) = 0;
             //        2               2
equ[1][0] := \\-alpha k  A[1] - alpha k  B[1]
           2                      2                    3
   + 3 A[0]  A[1] beta[4] + 3 A[0]  B[1] beta[4] + A[1]  beta[4]
           2                           2               3
   + 3 A[1]  B[1] beta[4] + 3 A[1] B[1]  beta[4] + B[1]  beta[4]
   + 2 A[0] A[1] beta[3] + 2 A[0] B[1] beta[3] - w A[1] - w B[1]/
          6   /        2            3
  cosh(xi)  + \-alpha k  A[0] + A[0]  beta[4]
   + 3 A[0] A[1]  beta[4] + 6 A[0] A[1] B[1] beta[4]
                2               2               2
   + 3 A[0] B[1]  beta[4] + A[0]  beta[3] + A[1]  beta[3]
                               2                 \
   + 2 A[1] B[1] beta[3] + B[1]  beta[3] - w A[0]/ sinh(xi)
          5   /         2               2
  cosh(xi)  + \2 alpha k  A[1] + alpha k  B[1]
                   2                      2
   - 2 alpha lambda  A[1] + 2 alpha lambda  B[1]
                   2                      2
   - 2 gamma lambda  A[1] + 2 gamma lambda  B[1]
           2                      2
   - 6 A[0]  A[1] beta[4] - 3 A[0]  B[1] beta[4]
           3                 2
   - 3 A[1]  beta[4] - 6 A[1]  B[1] beta[4]
   - 3 A[1] B[1]  beta[4] - 4 A[0] A[1] beta[3]
                                            \         4   /
   - 2 A[0] B[1] beta[3] + 2 w A[1] + w B[1]/ cosh(xi)  + \alpha
   2            3                      2
  k  A[0] - A[0]  beta[4] - 6 A[0] A[1]  beta[4]
                                    2                 2
   - 6 A[0] A[1] B[1] beta[4] - A[0]  beta[3] - 2 A[1]  beta[3]
                                 \                  3   /
   - 2 A[1] B[1] beta[3] + w A[0]/ sinh(xi) cosh(xi)  + \
        2                      2                      2
-alpha k  A[1] + 4 alpha lambda  A[1] + 4 gamma lambda  A[1]
           2                      3
   + 3 A[0]  A[1] beta[4] + 3 A[1]  beta[4]
           2                                            \
   + 3 A[1]  B[1] beta[4] + 2 A[0] A[1] beta[3] - w A[1]/
  cosh(xi)
     /           2               2        \
   + \3 A[0] A[1]  beta[4] + A[1]  beta[3]/ sinh(xi) cosh(xi)
                   2                      2            3
   - 2 alpha lambda  A[1] - 2 gamma lambda  A[1] - A[1]  beta[4] =
  0/ = 0
                       equ[1][1] := 0 = 0
                       equ[1][2] := 0 = 0
                       equ[1][3] := 0 = 0
                       equ[1][4] := 0 = 0
                       equ[1][5] := 0 = 0
                       equ[1][6] := 0 = 0
NULL;
NULL;
Download loop_for_coeficent.mw
Is the a print or plot function that can generate from an expression an expression tree
and/or the corresponding expression DAG
Taken from ?ProgrammingGuide,Chapter02
I was just using Maple to do a simple calculation but the units came out all complicated.
The expression in question is work done by a van der Waals gas. The units should come out to Joules per mol.
When I do the calculation manually (second expression below) I do get that result, albeit in more basic units than Joules.
In the first expression, in which I am using subs to sub in values with units into the expression, the final expression is very complicated. Why?
with(Units:-Simple)
simplify(subs({R = 8.314*Unit('J'/('K'*'mol')), T = 298*Unit('K'), V__1 = Unit('L'/'mol'), V__2 = 50*Unit('L'/'mol'), a = 2.283*Unit('L'^2*'bar'/'mol'^2), b = 0.4278e-1*Unit('L'/'mol')}, -R*T*ln((V__2-b)/(V__1-b))+a*(1/V__1-1/V__2)))
(-9798.522418*Units:-Unit(J/(K*mol))*Units:-Unit(K)*Units:-Unit(L/mol)+2.23734*Units:-Unit(L^2*bar/mol^2))/Units:-Unit(L/mol)
How do we simplify the units above so they become the same as the units in the same (manual) calculation below?
-(8.314*Unit('J'/('K'*'mol'))*298)*Unit('K')*ln((50*Unit('L'/'mol')-0.4278e-1*Unit('L'/'mol'))/(Unit('L'/'mol')-0.4278e-1*Unit('L'/'mol')))+2.283*Unit('L'^2*'bar'/'mol'^2)/Unit('L'/'mol')
-9570.222418*Units:-Unit(m^2*kg/(s^2*mol))
Download Units_-_Subs.mw
Proc := proc(t) local t4, l3, R, r, eq, sol; _EnvHorizontalName := 'x'; _EnvVerticalName := 'y'; t4 := thickness = 4; l3 := linestyle = dot; R := 9; r := 1/2*R; geometry:-point(OO, 0, 0); geometry:-circle(Cir, [OO, R]); geometry:-point(K, R*cos(t), R*sin(t)); geometry:-point(Omega, r*cos(t), r*sin(t)); geometry:-circle(cir, [Omega, r]); eq := geometry:-Equation(cir); geometry:-line(XXp, y = 0); geometry:-line(YYp, x = 0); geometry:-line(L1, y = x); geometry:-line(L2, y = -x); geometry:-projection(M1, K, XXp); geometry:-coordinates(M1); geometry:-point(K2, geometry:-coordinates(M1)[1] - 2*R, 0); geometry:-coordinates(K2); geometry:-segment(sT, K2, M1); geometry:-point(N1, 0, R*sin(t)); subs(y = x, eq); sol := solve(%, x); geometry:-point(N2, sol[2], sol[2]); subs(y = -x, eq); sol := solve(%, x); geometry:-point(N3, sol[2], -sol[2]); plots:-display(geometry:-draw([Cir(color = blue, t4), cir(color = grey, t4), sT(color = black, t4), XXp(color = black, l3), YYp(color = black, l3), L1(color = black, l3), L2(color = black, l3), N1(color = blue, symbol = solidcircle, symbolsize = 15), N2(color = blue, symbol = solidcircle, symbolsize = 15), N3(color = blue, symbol = solidcircle, symbolsize = 15), M1(color = blue, symbol = solidcircle, symbolsize = 15)]), axes = none, view = [-30 .. 10, -10 .. 10], size = [800, 800]); end proc;
plots:-animate(Proc, [t], t = 0 .. 2*Pi, frames = 200);
NULL;
I am trying to program  this drawing, how to improve this code ? Thank you.
I know this question has been asked time and time again. Starting of with the expr . That is the end goal I want to achieve.  How would I reduce the expansion to get it into 1-f(x,y,z)/g(x,y,z) format?. I have tried all sorts of approaches.
expr:=1 - (x__1*x__2 + y__1*y__2 - z__1*z__2)^2/((x__1^2 + y__1^2 - z__1^2)*(x__2^2 + y__2^2 - z__2^2))
1-(x__1*x__2+y__1*y__2-z__1*z__2)^2/((x__1^2+y__1^2-z__1^2)*(x__2^2+y__2^2-z__2^2))
normal( (1) );
(x__1^2*y__2^2-x__1^2*z__2^2-2*x__1*x__2*y__1*y__2+2*x__1*x__2*z__1*z__2+x__2^2*y__1^2-x__2^2*z__1^2-y__1^2*z__2^2+2*y__1*y__2*z__1*z__2-y__2^2*z__1^2)/((x__1^2+y__1^2-z__1^2)*(x__2^2+y__2^2-z__2^2))
simplify( (2) );
((y__2^2-z__2^2)*x__1^2-2*x__2*(y__1*y__2-z__1*z__2)*x__1+(y__1^2-z__1^2)*x__2^2-(y__1*z__2-y__2*z__1)^2)/((x__1^2+y__1^2-z__1^2)*(x__2^2+y__2^2-z__2^2))
radnormal(%)
Test:=combine(%)
n:={op(numer(Test))}
{x__1^2*y__2^2, x__2^2*y__1^2, -x__1^2*z__2^2, -x__2^2*z__1^2, -y__1^2*z__2^2, -y__2^2*z__1^2, -2*x__1*x__2*y__1*y__2, 2*x__1*x__2*z__1*z__2, 2*y__1*y__2*z__1*z__2}
d:={op(expand(denom(Test)))}
{x__1^2*x__2^2, x__1^2*y__2^2, x__2^2*y__1^2, y__1^2*y__2^2, z__1^2*z__2^2, -x__1^2*z__2^2, -x__2^2*z__1^2, -y__1^2*z__2^2, -y__2^2*z__1^2}
d subset n
d intersect n
{x__1^2*y__2^2, x__2^2*y__1^2, -x__1^2*z__2^2, -x__2^2*z__1^2, -y__1^2*z__2^2, -y__2^2*z__1^2}
add(%[i],i=1..nops(%))
x__1^2*y__2^2-x__1^2*z__2^2+x__2^2*y__1^2-x__2^2*z__1^2-y__1^2*z__2^2-y__2^2*z__1^2
factor( (10) );
n minus d
{-2*x__1*x__2*y__1*y__2, 2*x__1*x__2*z__1*z__2, 2*y__1*y__2*z__1*z__2}
Download 2024-07-20_Q_Simplify_Reformat.mw
Good afternoon, please I have the following question to see if someone can help me.
I am calculating an integral with a root and when Maple gives me the result it does so in power. I want the result to be given in square root, both this integral and others that I am going to solve.
Whenever I call RandomGraph(20,200), Maple crashes both on the laptop and on the PC: any suggestion?
with(GraphTheory); with(RandomGraphs)
interface(version)
G := RandomGraph(20, 200)
Download crash.mw
First 89 90 91 92 93 94 95 Last Page 91 of 2427
