I tried
interface(warnlevel=0); infolevel[all]:=0;prinlevel:=0;kernelopts('printlevel'=0);
to suppress the warnings I get from this code
f:=z^3;
z_map:=proc(f,re,im)
  if((re>0) and (im>0) and (im<1-re))then
    eval(f,z=re+I*im);
    NULL;
p_re:=plots:-display(seq(plot([Re('z_map(f,re,im)'),Im('z_map(f,re,im)'),im=0..1]),re=0..10,0.1)):
p_im:=plots:-display(seq(plot([Re('z_map(f,re,im)'),Im('z_map(f,re,im)'),re=0..1]),im=0..10,0.1),color=green):
plots:-display(p_re,p_im,scaling=constrained)
The reason for the warnings is clear. The input lines are too long to be plotted. However, the resulting plot is exactly what I intended. Programatically truncating the lines would make the warning disappear, but it would make the code much more complicated.
What else can be done to suppress this kind of warning.
For Mathematica  math software app,there is a plugin to use in chatGPT pro ( paid subscription ) and maybe this can be done for Maple too ?
Haven't used the plugin for Mathematica yet, am curious about it.
Let me have the AI look at the Riemann Hypothesis :)
Have a few books on it, but can't get through that math with all those special functions.
Why does the execution of procedure J2 in the attached file fire an error?
it looked to me as if I had built it the same way as J1.
# Basically I want do do something like that,
J1 := proc()
  local z:
  z := proc(u) fsolve(sqrt(x)=u, x) end proc:
  evalf(Int(''z''(u), u=0..1))
J1();
.3333333333
# but when z is more complex finction of two arguments.
# Unfortunately a direct transposition of what worked above no longer works.
J2 := proc()
  local z:
   z := proc(q1, q2)
     exp(
       2*(
         fsolve(1/2+(1/2)*erf((1/2)*x*sqrt(2)) = q1, x)
         fsolve(1/2+(1/2)*erf((1/2)*x*sqrt(2)) = q2, x)
       fsolve(1/2+(1/2)*erf((1/2)*x*sqrt(2)) = sqrt(q1), x)^2
       fsolve(1/2+(1/2)*erf((1/2)*x*sqrt(2)) = sqrt(q2), x)^2
  evalf(Int(''z''(q1, q2), q1=0..1, q2=0..1))
J2();
Error, (in evalf/int) q1 is in the equation, and is not solved for
Download integration_issue.mw
Can you help me fix this issue?
How can I get y=x in output (4) when  g is equal to f?
f := x -> F(x)
proc (x) options operator, arrow; F(x) end proc
((f@@(-1))@f)(x);
x
# Let us assume that y is defined this way
y := ((f@@(-1))@g)(x);
(f@@(-1))(g(x))
# When g is identical to f I would like to get y=x
'y' = eval(y, g=f);
'y' = eval(y, g = (x -> f(x)))
y = (f@@(-1))(F(x))
y = (f@@(-1))(F(x))
Download inverse_f.mw
This is something I use a fair bit. I have procedures with alternative spelling options for the colours Red Green and Blue.
Have shown a single example copied from  an overloaded procedure. It there a nicer way of handling this than what I am doing?
There is a section in help under "Procedure Parameter Declarations" on "Indexed Keyword Parameters"  but I don't see how to use it here. These procedures are used inside a package.
GeomClr:="Blue";  # can be "Blue", "blue", "B", "b"  or;
                  #        "Green", "green", "G", "g"  or;
                  #        "Red2, "red", "R", "r";
Prntmsg:="y" ; #  or anything that is not"y"
"Blue"
"y"
spread:=proc(p0::{satisfies(s -> type(s, [algebraic $ 2])),'Vector[row]'(2, algebraic)},
              p1::{satisfies(s -> type(s, [algebraic $ 2])),'Vector[row]'(2, algebraic)},
              clr::`string`:= GeomClr,
              prnt::`string`:=Prntmsg)
           option overload;
           uses LinearAlgebra;
           #print(clr,p0,p1);
           if clr="b" or clr="B" or clr="blue" or clr="Blue" then
              if prnt="y" then
                print("Spread 2 [x,y] Points/Vectors wrt origin Blue");
               return 1 - BilinearForm(p0, p1, conjugate = false)^2/(BilinearForm(p0, p0, conjugate = false)*BilinearForm(p1, p1, conjugate = false));
           elif clr="g" or clr="G" or clr="green" or clr="Green" then
              if prnt="y" then
               print( "Spread 2 [x,y] Points/Vectors wrt origin Green");
               return -1/4*(p0[1]*p1[2] - p0[2]*p1[1])^2/(p0[1]*p0[2]*p1[1]*p1[2]);
           elif clr="r" or clr="R" or clr="red" or clr="Red" then
              if prnt="y" then
               print( "Spread 2 [x,y] Points/Vectors wrt origin Red");
               return -(p0[1]*p1[2] - p0[2]*p1[1])^2/((p0[1]^2 - p0[2]^2)*(p1[1]^2 - p1[2]^2));
sb:=spread(<3|2>,<4|-5>);
529/533
sg:=spread(<3|2>,<4|-5>,"g");
529/480
sr:=spread(<3|2>,<4|-5>,"r");
529/45
1/sb+1/sr+1/sg
sr:=spread(<3|2>,<4|-5>,"r","n");
529/45
Download Q_2024-02-09_Alternative_Spelling_in_Proc.mw
I just came across an issue when solving a simple thermodynamics problem. Steam enters a turbine at 140 psia and 1000 F and expands isentropically to 2psia. When I try to determine the exit temperature, the problem occurs. If I set the units for the problem to FPS, I get the answer in F. The problem is that the numerical value is wrong. The numerical value corresponds to degree R, not F. The numerical value given is 585 F, it should be 585 R.  If I set the problem to SI units, the answer is in K. The answer given is 325 K.  I can then convert it to degree F. This way I get the correct answer.
According to the Maple documentation, both commands can handle inequalities. I'm only interested in checking when a semialgebraic set is empty, so I thought SemiAlgebraicSetTools:-IsEmpty would be generally faster than computing the solutions with the SemiAlgebraic command. However, the following code shows otherwise:
Code 1:
with(SolveTools, SemiAlgebraic);
B_poly := -(x + 4)*(x + 3)*(x + 2)*(x + 1)*(x - 1)*(x - 2)*(x - 3)*(x - 4);
g := -1/100000*(x+4)*(x+3)*(x+2)*(x+1)*(x-1)*(x-2)*(x-3)*(x-4)*(-1/670*(x+4)
*(x+3)*(x+2)*(x+1)*(x-1)*(x-2)*(x-3)*(x-4)-669/670)^136+1/100000*(x+4)*(x+3)*(x
+2)*(x+1)*(x-1)*(x-2)*(x-3)*(x-4)*(1/670*(x+4)*(x+3)*(x+2)*(x+1)*(x-1)*(x-2)*(x
-3)*(x-4)-669/670)^136;
f := -4347225/87808*x^8 - 17375/392*x^7 + 629491375/395136*x^6 +
   266375/252*x^5 - 200677775/12544*x^4 - 3174625/504*x^3 +
   11067842125/197568*x^2 - 53625/98*x - 126496075/4116;
SemiAlgebraic(
  [B_poly >= 0, g - f >= 0], [x]);
Code 2:
with(RegularChains, SemiAlgebraicSetTools, PolynomialRing);
local R := PolynomialRing([x]);
SemiAlgebraicSetTools:-IsEmpty([B_poly >= 0, g-f >= 0], R);
My computer finishes 'Code 1' in about 20 seconds, while 'Code 2' doesn't terminate. Am I misunderstanding something about how to use these commands for my problem? I'd appreciate it if you could clarify why this is happening and when to use each command in each case. Thanks!
For example, given plot f(x)= x^5+x. plot the function given by g(x)= f(x-2)+3
Also, when plotting my graphs they look different than other graphing software.
How to rectify this error.
S-D_effect-RK.mw
What technique would you try to solve the following non-linear differential equation for real g(x) given h(x) is real (finite positive) polynomial?      h(x) = g(x) + g'(x)/g(x),      where g'(x) = dg(x)/dx
I want to convert the maple result
arctan(y/x) to arctan(y,x),
so if x is equal zero i obtain pi/2 and not diveided by zero
i have two euations including integration which has two unkwnon x1 and x2.
how can i get these equations solved, thanks for the help.
with(DirectSearch)
[BoundedObjective, CompromiseProgramming, DataFit, ExponentialWeightedSum, GlobalOptima, GlobalSearch, Minimax, ModifiedTchebycheff, Search, SolveEquations, WeightedProduct, WeightedSum]
with(Student:-Calculus1):
with(Student:-NumericalAnalysis):
A:=convert(taylor(exp(Q),Q,6),polynom);
1+Q+(1/2)*Q^2+(1/6)*Q^3+(1/24)*Q^4+(1/120)*Q^5
Q:=a[11]*(E[r])^2+a[22]*(E[theta])^2+2*a[12]*E[r]*E[theta];
E[r]^2*a[11]+2*E[r]*E[theta]*a[12]+E[theta]^2*a[22]
psi:=0.5*c*(exp(Q)-1);
.5*c*(exp(E[r]^2*a[11]+2*E[r]*E[theta]*a[12]+E[theta]^2*a[22])-1)
F:=Matrix(3,3,[[lambda[r],0,0],[0,lambda[theta],0],[0,0,lambda[z]]]);
Matrix(3, 3, {(1, 1) = lambda[r], (1, 2) = 0, (1, 3) = 0, (2, 1) = 0, (2, 2) = lambda[theta], (2, 3) = 0, (3, 1) = 0, (3, 2) = 0, (3, 3) = lambda[z]})
sigma[r]:=-p+diff(psi,E[r])*F[1,1]^2;
-p+.5*c*(2*E[r]*a[11]+2*E[theta]*a[12])*exp(E[r]^2*a[11]+2*E[r]*E[theta]*a[12]+E[theta]^2*a[22])*lambda[r]^2
sigma[theta]:=-p+diff(psi,E[theta])*F[2,2]^2;
-p+.5*c*(2*E[r]*a[12]+2*E[theta]*a[22])*exp(E[r]^2*a[11]+2*E[r]*E[theta]*a[12]+E[theta]^2*a[22])*lambda[theta]^2
sigma[z]:=-p+diff(psi,E[z])*F[3,3]^2;
-p
p1:=diff(psi,E[r])*F[1,1]^2;#Pressure is constituted form 3 parts, one part is p1, other part is p2 and a constant p0
E[r]:=0.5*(lambda[r]^2-1);
.5*lambda[r]^2-.5
E[theta]:=0.5*(lambda[theta]^2-1);
.5*lambda[theta]^2-.5
E[z]:=0.5*(lambda[z]^2-1);
.5*lambda[z]^2-.5
lambda[r]:=x2*sqrt((r^2-x1)/x2)/r;
x2*((r^2-x1)/x2)^(1/2)/r
lambda[theta]:=r/sqrt((r^2-x1)/x2);
r/((r^2-x1)/x2)^(1/2)
(14)
lambda[z]:=1/x2;
1/x2
(15)
sigma[r];
-p+.5*c*(2*(.5*x2*(r^2-x1)/r^2-.5)*a[11]+2*(.5*r^2*x2/(r^2-x1)-.5)*a[12])*exp((.5*x2*(r^2-x1)/r^2-.5)^2*a[11]+2*(.5*x2*(r^2-x1)/r^2-.5)*(.5*r^2*x2/(r^2-x1)-.5)*a[12]+(.5*r^2*x2/(r^2-x1)-.5)^2*a[22])*x2*(r^2-x1)/r^2
(16)
sigma[theta]:
sigma[z]:
#p2:=int((sigma[r]-sigma[theta])/r,r):%Pressure is constituted form 2 parts, one part is p1, other part is p2 and and a constant p0
Digits:=10:
c:=790000:
a[11]:=0.539:
a[22]:=0.368:
a[12]:=0.653:
p_in:=10000:
p_out:=0:
r_in:=5.4e-3:
r_out:=6.1e-3:
F_a:=0.381846:
p21:=(c/2)*(((r^2-x1)/r^3)-(x2*r/(r^2-x1)))*exp(Q);
395000*((r^2-x1)/r^3-x2*r/(r^2-x1))*exp(.539*(.5*x2*(r^2-x1)/r^2-.5)^2+1.306*(.5*x2*(r^2-x1)/r^2-.5)*(.5*r^2*x2/(r^2-x1)-.5)+.368*(.5*r^2*x2/(r^2-x1)-.5)^2)
(17)
p22:=(c/2)*Int(exp(Q)*(3*x2*r^6-r^6+5*x1*r^4-x1*x2*r^4-7*x1^2*r^2+3*x1^3)/(r^4*(r^2-x1)^2),r=r_in..r_out);#This is the part that should be maintained as an integral until the final solution
395000*(Int(exp(.539*(.5*x2*(r^2-x1)/r^2-.5)^2+1.306*(.5*x2*(r^2-x1)/r^2-.5)*(.5*r^2*x2/(r^2-x1)-.5)+.368*(.5*r^2*x2/(r^2-x1)-.5)^2)*(3*r^6*x2-r^6-r^4*x1*x2+5*r^4*x1-7*r^2*x1^2+3*x1^3)/(r^4*(r^2-x1)^2), r = 0.54e-2 .. 0.61e-2))
(18)
p2:=p21-p22;#p2 is computed using the integration by part method
395000*((r^2-x1)/r^3-x2*r/(r^2-x1))*exp(.539*(.5*x2*(r^2-x1)/r^2-.5)^2+1.306*(.5*x2*(r^2-x1)/r^2-.5)*(.5*r^2*x2/(r^2-x1)-.5)+.368*(.5*r^2*x2/(r^2-x1)-.5)^2)-395000*(Int(exp(.539*(.5*x2*(r^2-x1)/r^2-.5)^2+1.306*(.5*x2*(r^2-x1)/r^2-.5)*(.5*r^2*x2/(r^2-x1)-.5)+.368*(.5*r^2*x2/(r^2-x1)-.5)^2)*(3*r^6*x2-r^6-r^4*x1*x2+5*r^4*x1-7*r^2*x1^2+3*x1^3)/(r^4*(r^2-x1)^2), r = 0.54e-2 .. 0.61e-2))
(19)
p0:=(p_out+eval(p2,r=r_out));#p0 is the constant which is defined form the boundary conditions either p_out=subs(r=r_out,sigma[r]) or p_in=subs(r=r_in,sigma[r])
395000*(-4405655.099*x1+163.9344262-0.61e-2*x2/(-x1+0.3721e-4))*exp(.539*(13437.24805*x2*(-x1+0.3721e-4)-.5)^2+1.306*(13437.24805*x2*(-x1+0.3721e-4)-.5)*(0.18605e-4*x2/(-x1+0.3721e-4)-.5)+.368*(0.18605e-4*x2/(-x1+0.3721e-4)-.5)^2)-395000*(Int(exp(.539*(.5*x2*(r^2-x1)/r^2-.5)^2+1.306*(.5*x2*(r^2-x1)/r^2-.5)*(.5*r^2*x2/(r^2-x1)-.5)+.368*(.5*r^2*x2/(r^2-x1)-.5)^2)*(3*r^6*x2-r^6-r^4*x1*x2+5*r^4*x1-7*r^2*x1^2+3*x1^3)/(r^4*(r^2-x1)^2), r = 0.54e-2 .. 0.61e-2))
(20)
p:=p1+p2+p0;#p is the total pressure
395000.0*(.5390*x2*(r^2-x1)/r^2-1.1920+.6530*r^2*x2/(r^2-x1))*exp(.539*(.5*x2*(r^2-x1)/r^2-.5)^2+1.306*(.5*x2*(r^2-x1)/r^2-.5)*(.5*r^2*x2/(r^2-x1)-.5)+.368*(.5*r^2*x2/(r^2-x1)-.5)^2)*x2*(r^2-x1)/r^2+395000*((r^2-x1)/r^3-x2*r/(r^2-x1))*exp(.539*(.5*x2*(r^2-x1)/r^2-.5)^2+1.306*(.5*x2*(r^2-x1)/r^2-.5)*(.5*r^2*x2/(r^2-x1)-.5)+.368*(.5*r^2*x2/(r^2-x1)-.5)^2)-790000*(Int(exp(.539*(.5*x2*(r^2-x1)/r^2-.5)^2+1.306*(.5*x2*(r^2-x1)/r^2-.5)*(.5*r^2*x2/(r^2-x1)-.5)+.368*(.5*r^2*x2/(r^2-x1)-.5)^2)*(3*r^6*x2-r^6-r^4*x1*x2+5*r^4*x1-7*r^2*x1^2+3*x1^3)/(r^4*(r^2-x1)^2), r = 0.54e-2 .. 0.61e-2))+395000*(-4405655.099*x1+163.9344262-0.61e-2*x2/(-x1+0.3721e-4))*exp(.539*(13437.24805*x2*(-x1+0.3721e-4)-.5)^2+1.306*(13437.24805*x2*(-x1+0.3721e-4)-.5)*(0.18605e-4*x2/(-x1+0.3721e-4)-.5)+.368*(0.18605e-4*x2/(-x1+0.3721e-4)-.5)^2)
(21)
#p:=H+H00;
eq1:=Int((sigma[r]-sigma[theta])/r,r=r_in..r_out);
Int((395000.0*(.5390*x2*(r^2-x1)/r^2-1.1920+.6530*r^2*x2/(r^2-x1))*exp(.539*(.5*x2*(r^2-x1)/r^2-.5)^2+1.306*(.5*x2*(r^2-x1)/r^2-.5)*(.5*r^2*x2/(r^2-x1)-.5)+.368*(.5*r^2*x2/(r^2-x1)-.5)^2)*x2*(r^2-x1)/r^2-395000.0*(.6530*x2*(r^2-x1)/r^2-1.0210+.3680*r^2*x2/(r^2-x1))*exp(.539*(.5*x2*(r^2-x1)/r^2-.5)^2+1.306*(.5*x2*(r^2-x1)/r^2-.5)*(.5*r^2*x2/(r^2-x1)-.5)+.368*(.5*r^2*x2/(r^2-x1)-.5)^2)*r^2*x2/(r^2-x1))/r, r = 0.54e-2 .. 0.61e-2)
(22)
eq2:=Int(2*Pi*sigma[z]*r,r=r_in..r_out);
Int(2*Pi*(-395000.0*(.5390*x2*(r^2-x1)/r^2-1.1920+.6530*r^2*x2/(r^2-x1))*exp(.539*(.5*x2*(r^2-x1)/r^2-.5)^2+1.306*(.5*x2*(r^2-x1)/r^2-.5)*(.5*r^2*x2/(r^2-x1)-.5)+.368*(.5*r^2*x2/(r^2-x1)-.5)^2)*x2*(r^2-x1)/r^2-395000*((r^2-x1)/r^3-x2*r/(r^2-x1))*exp(.539*(.5*x2*(r^2-x1)/r^2-.5)^2+1.306*(.5*x2*(r^2-x1)/r^2-.5)*(.5*r^2*x2/(r^2-x1)-.5)+.368*(.5*r^2*x2/(r^2-x1)-.5)^2)+790000*(Int(exp(.539*(.5*x2*(r^2-x1)/r^2-.5)^2+1.306*(.5*x2*(r^2-x1)/r^2-.5)*(.5*r^2*x2/(r^2-x1)-.5)+.368*(.5*r^2*x2/(r^2-x1)-.5)^2)*(3*r^6*x2-r^6-r^4*x1*x2+5*r^4*x1-7*r^2*x1^2+3*x1^3)/(r^4*(r^2-x1)^2), r = 0.54e-2 .. 0.61e-2))-395000*(-4405655.099*x1+163.9344262-0.61e-2*x2/(-x1+0.3721e-4))*exp(.539*(13437.24805*x2*(-x1+0.3721e-4)-.5)^2+1.306*(13437.24805*x2*(-x1+0.3721e-4)-.5)*(0.18605e-4*x2/(-x1+0.3721e-4)-.5)+.368*(0.18605e-4*x2/(-x1+0.3721e-4)-.5)^2))*r, r = 0.54e-2 .. 0.61e-2)
(23)
#eq1:=Quadrature((sigma[r]-sigma[theta])/r,r=r_in..r_out,method=gaussian[5],output=value):
#eq2:=Quadrature(2*Pi*sigma[z]*r,r=r_in..r_out,method=gaussian[5],output=value):
eq1=evalf(p_out-p_in)
Int((395000.0*(.5390*x2*(r^2-x1)/r^2-1.1920+.6530*r^2*x2/(r^2-x1))*exp(.539*(.5*x2*(r^2-x1)/r^2-.5)^2+1.306*(.5*x2*(r^2-x1)/r^2-.5)*(.5*r^2*x2/(r^2-x1)-.5)+.368*(.5*r^2*x2/(r^2-x1)-.5)^2)*x2*(r^2-x1)/r^2-395000.0*(.6530*x2*(r^2-x1)/r^2-1.0210+.3680*r^2*x2/(r^2-x1))*exp(.539*(.5*x2*(r^2-x1)/r^2-.5)^2+1.306*(.5*x2*(r^2-x1)/r^2-.5)*(.5*r^2*x2/(r^2-x1)-.5)+.368*(.5*r^2*x2/(r^2-x1)-.5)^2)*r^2*x2/(r^2-x1))/r, r = 0.54e-2 .. 0.61e-2) = -10000.
(24)
eq2=F_a
Int(2*Pi*(-395000.0*(.5390*x2*(r^2-x1)/r^2-1.1920+.6530*r^2*x2/(r^2-x1))*exp(.539*(.5*x2*(r^2-x1)/r^2-.5)^2+1.306*(.5*x2*(r^2-x1)/r^2-.5)*(.5*r^2*x2/(r^2-x1)-.5)+.368*(.5*r^2*x2/(r^2-x1)-.5)^2)*x2*(r^2-x1)/r^2-395000*((r^2-x1)/r^3-x2*r/(r^2-x1))*exp(.539*(.5*x2*(r^2-x1)/r^2-.5)^2+1.306*(.5*x2*(r^2-x1)/r^2-.5)*(.5*r^2*x2/(r^2-x1)-.5)+.368*(.5*r^2*x2/(r^2-x1)-.5)^2)+790000*(Int(exp(.539*(.5*x2*(r^2-x1)/r^2-.5)^2+1.306*(.5*x2*(r^2-x1)/r^2-.5)*(.5*r^2*x2/(r^2-x1)-.5)+.368*(.5*r^2*x2/(r^2-x1)-.5)^2)*(3*r^6*x2-r^6-r^4*x1*x2+5*r^4*x1-7*r^2*x1^2+3*x1^3)/(r^4*(r^2-x1)^2), r = 0.54e-2 .. 0.61e-2))-395000*(-4405655.099*x1+163.9344262-0.61e-2*x2/(-x1+0.3721e-4))*exp(.539*(13437.24805*x2*(-x1+0.3721e-4)-.5)^2+1.306*(13437.24805*x2*(-x1+0.3721e-4)-.5)*(0.18605e-4*x2/(-x1+0.3721e-4)-.5)+.368*(0.18605e-4*x2/(-x1+0.3721e-4)-.5)^2))*r, r = 0.54e-2 .. 0.61e-2) = .381846
(25)
fsolve({eq1=evalf(p_out-p_in),eq2=F_a},{x1,x2});
fsolve({Int((395000.0*(.5390*x2*(r^2-x1)/r^2-1.1920+.6530*r^2*x2/(r^2-x1))*exp(.539*(.5*x2*(r^2-x1)/r^2-.5)^2+1.306*(.5*x2*(r^2-x1)/r^2-.5)*(.5*r^2*x2/(r^2-x1)-.5)+.368*(.5*r^2*x2/(r^2-x1)-.5)^2)*x2*(r^2-x1)/r^2-395000.0*(.6530*x2*(r^2-x1)/r^2-1.0210+.3680*r^2*x2/(r^2-x1))*exp(.539*(.5*x2*(r^2-x1)/r^2-.5)^2+1.306*(.5*x2*(r^2-x1)/r^2-.5)*(.5*r^2*x2/(r^2-x1)-.5)+.368*(.5*r^2*x2/(r^2-x1)-.5)^2)*r^2*x2/(r^2-x1))/r, r = 0.54e-2 .. 0.61e-2) = -10000., Int(2*Pi*(-395000.0*(.5390*x2*(r^2-x1)/r^2-1.1920+.6530*r^2*x2/(r^2-x1))*exp(.539*(.5*x2*(r^2-x1)/r^2-.5)^2+1.306*(.5*x2*(r^2-x1)/r^2-.5)*(.5*r^2*x2/(r^2-x1)-.5)+.368*(.5*r^2*x2/(r^2-x1)-.5)^2)*x2*(r^2-x1)/r^2-395000*((r^2-x1)/r^3-x2*r/(r^2-x1))*exp(.539*(.5*x2*(r^2-x1)/r^2-.5)^2+1.306*(.5*x2*(r^2-x1)/r^2-.5)*(.5*r^2*x2/(r^2-x1)-.5)+.368*(.5*r^2*x2/(r^2-x1)-.5)^2)+790000*(Int(exp(.539*(.5*x2*(r^2-x1)/r^2-.5)^2+1.306*(.5*x2*(r^2-x1)/r^2-.5)*(.5*r^2*x2/(r^2-x1)-.5)+.368*(.5*r^2*x2/(r^2-x1)-.5)^2)*(3*r^6*x2-r^6-r^4*x1*x2+5*r^4*x1-7*r^2*x1^2+3*x1^3)/(r^4*(r^2-x1)^2), r = 0.54e-2 .. 0.61e-2))-395000*(-4405655.099*x1+163.9344262-0.61e-2*x2/(-x1+0.3721e-4))*exp(.539*(13437.24805*x2*(-x1+0.3721e-4)-.5)^2+1.306*(13437.24805*x2*(-x1+0.3721e-4)-.5)*(0.18605e-4*x2/(-x1+0.3721e-4)-.5)+.368*(0.18605e-4*x2/(-x1+0.3721e-4)-.5)^2))*r, r = 0.54e-2 .. 0.61e-2) = .381846}, {x1, x2})
(26)
SolveEquations([eq1=evalf(p_out-p_in),eq2=F_a]);
Warning, objective function returns unfeasible value HFloat(undefined) for initial point [x1 = .9, x2 = .9]; trying to find a feasible initial point
Error, (in DirectSearch:-Search) cannot find feasible initial point; specify a new one
fsolve_problem.mw
For this integro-differential equation,
Equation:= int[y'(x)* (x^2)/[(x^2)-1],x)  =  (int[sqrt(y(x)])^(-2/3)
Maple is able to obtain an exact intrinsic solution
from which an exact solution can be extracted, namely,
ExtrinsicSolution:= y(x) = sqrt(3)*(-8*_C1*x^(8/3) + 12*x^2 - 3)^(3/4)
My question concerns how was this solution obtained.
Even more, specifically, 'odeadvisor' suggests converting the
equation in question to the form
ode:= y = G(x,diff(y(x),x));
However, I cannot reconcile how this can be applied to an equation which
contains two integrals. (Regretably, I am not able to directly, attach my
Maple worksheet directly on to this sheet). The situation is that after
applying 'dsolve' to the above 'Equation', Maple comes back with an
intrinsic solution which can was used to obtain the 'ExtrinsicSolution' in
the above.  So it is the missing steps between applyingthe dsolve command
to Equation and the intrinsic solution which MS provides which, in turn, leads
to the 'Extrinsic Solution' above. I would greatly, appreciate if anyone can
fill in the missing steps.
I was trying this ode with Maple
Do you agree this solution is not correct by Maple?
ode:=diff(y(t),t)+y(t)=Dirac(t);
ic:=y(0)=1;
sol:=dsolve([ode,ic],y(t),method='laplace');
It gives  y(t) = 2*exp(-t)
But from the discussion in the above link we see this is wrong solution. Maple also does not verify it:
odetest(sol,[ode,y(0)=1])
[-Dirac(t), -1]
Would this be considered a bug I should report or not? Note this result is only when using Laplace method. The default method gives better solution.
ic:=y(0)=1;
sol:=dsolve([ode,ic],y(t));
Maple 2023.2.1
How to convert barycentric coordinates to cartesian ? Thank you
First 131 132 133 134 135 136 137 Last Page 133 of 2426
