Are there any restrictions regarding path and filename length in Maple?
I am experiencing problems working with a file on a server, path and file length is 207 characters.
Using Maple-18 on Window 11...
I have a set of curves in a Maple 'vector.' I want to plot them all on the same figure, but if call 'display' with the vector it makes separate plots for each one. I have to all it with each plot individual to get them on the same plot:
lc is a 'vector' of curves (I use 'vector' because I want to append and that doesn't work for 'list')
display(lc) -- plots a separate plot for each element of lc
display(lc[1], lc[2], lc[3],...) puts them all on one plot as needed, but as there will be a large numbe of curvesr it's extremely tedious.
It is a Huygens principle based simulation of diffraction.
estart; with(Physics); with(LinearAlgebra); with(VectorCalculus); with(Optimization); with(Statistics); with(ArrayTools); with(plots); with(plottools); with(Threads); with(MmaTranslator[Mma]), with(StringTools); with(CodeGeneration); with(ImageTools); with(ImageTools:-Draw); VectorCalculus:-`*`(Setup(mathematicalnotation = true), Setup(coordinatesystems = cartesian))
estart
[annulus, arc, arrow, circle, cone, cuboid, curve, cutin, cutout, cylinder, disk, dodecahedron, ellipse, ellipticArc, exportplot, extrude, getdata, hemisphere, hexahedron, homothety, hyperbola, icosahedron, importplot, line, octahedron, parallelepiped, pieslice, point, polygon, prism, project, rectangle, reflect, rotate, scale, sector, semitorus, sphere, stellate, tetrahedron, torus, transform, translate]
`Default differentiation variables for d_, D_ and dAlembertian are:`*{X = (x, y, z, t)}
`Systems of spacetime Coordinates are:`*{X = (x, y, z, t)}
radius := 1.0
1.0
alpha := sin((1/4)*Pi)
(1/2)*2^(1/2)
step := .2
.2
radius := 100.0
100.0
l1 := line([0, 0], [100, 100])
CURVES([[0., 0.], [100., 100.]])
loAng := 0.
0.
hiAng := (1/2)*Pi
(1/2)*Pi
c1 := arc([0, 0.], radius, loAng .. Pi, color = "red")
c2 := arc([step, 0.], -alpha*step+radius, loAng .. hiAng, color = "blue")
c3 := arc([2*step, 0.], -2*alpha*step+radius, loAng .. Pi, color = "purple")
c4 := arc([3*step, 0.], -3*alpha*step+radius, loAng .. Pi, color = "black")
plots[display](l1, c1, c2, c3, c4, view = [0. .. radius, 0 .. radius])
`cir≔arc`([x, 0.], radius-step, loAng .. hiAng, i, color = "red")
`cir≔arc`([x, 0.], 99.8, 0. .. (1/2)*Pi, i, color = "red")
xLimitWall := 500.0; nScatter := 20; step := xLimitWall/(nScatter+1); x := 0.; for i from 0 to nScatter do x := x+step; cir := arc([x, 0.], radius-step, 0 .. Pi, color = "red"); if i = 0 then lc := Vector([cir]) else i; cir; Append(lc, cir) end if end do; lc
xLimitWall := 500.0
nScatter := 20
step := 23.80952381
x := 0.
x := 23.80952381
cir := CURVES(Vector(4, {(1) = ` 200 x 2 `*Matrix, (2) = `Data Type: `*float[8], (3) = `Storage: `*rectangular, (4) = `Order: `*Fortran_order}), COLOUR(RGB, 1.00000000, 0., 0.))
x := 47.61904762
x := 71.42857143
x := 95.23809524
x := 119.0476190
x := 142.8571428
x := 166.6666666
x := 190.4761904
x := 214.2857142
x := 238.0952380
x := 261.9047618
x := 285.7142856
x := 309.5238094
x := 333.3333332
x := 357.1428570
x := 380.9523808
x := 404.7619046
x := 428.5714284
x := 452.3809522
x := 476.1904760
x := 499.9999998
Vector[column](%id = 4400555778)
lc[1]
CURVES(Matrix(%id = 4400554242), COLOUR(RGB, 1.00000000, 0., 0.))
lc(2)
lc
lc[1]
Download JFKWEdgeDifractionDirection.mwJFKWEdgeDifractionDirection.mwen.
Maple 2022.2
> restart
> expr = x^4-10*x^2+1
> plot(expr)
produces an error message:
com.maplesoft.maplets.ComponentAccessException: not a valid plot structure
plot(expr, x) works Ok.
Tom Dean
Hi, I'm trying to figure out, how to differentiate the following expression:
I also don't get how to properly index (indefinite) sum terms... Grateful for any advice!
How to fix the error?
How are they (tanh(a+b) , tanh(a-b)) defined in Maple?
Ger.mw
How to find the series.I'm getting this error.Please help to solve this.
AF.mw
I want to express my two variable function f using Taylor expansion. But no success yet.
Why Taylor series can not estimate my function in desired interval [-1<x,y<1]?
with(Student[MultivariateCalculus]):
f := -5023626067733175609651265492842895195168362165*xx^5*yy^9*(1/5575186299632655785383929568162090376495104)+2207379816207475241162406248223006569040862935*xx^5*yy^8*(1/2787593149816327892691964784081045188247552)+5795161625895678368156852916105373987594511979*xx^6*(1/22300745198530623141535718272648361505980416)-539977758872163289054492124375185771143918033*xx^6*yy*(1/696898287454081973172991196020261297061888)+782685832362921584689673760969891945953777553*xx^6*yy^2*(1/5575186299632655785383929568162090376495104)+749877940244270735637721966049124917356845885*xx^6*yy^3*(1/174224571863520493293247799005065324265472)+14159347676475748959036290080103848146860867025*xx^6*yy^4*(1/11150372599265311570767859136324180752990208)-2937701213452088192123555543440803264914467299*xx^6*yy^5*(1/348449143727040986586495598010130648530944)-23673134207774883972271882396704370580007933039*xx^6*yy^6*(1/5575186299632655785383929568162090376495104)-62755544772437504320590342390381422715234113715/89202980794122492566142873090593446023921664+35696532930567486560276536615522532283474689213*yy*(1/2787593149816327892691964784081045188247552)+43423414494451507811145033075147441881593811799*yy^2*(1/22300745198530623141535718272648361505980416)+1173296429365947392287371443632107462978009165*xx^6*yy^7*(1/174224571863520493293247799005065324265472)-56566850002827011453690682806041619180254985625*yy^3*(1/696898287454081973172991196020261297061888)+57447439083834576362467553225131370438848237035*xx^6*yy^8*(1/22300745198530623141535718272648361505980416)-1277356081222180962342283013232991241852904465*xx^6*yy^9*(1/696898287454081973172991196020261297061888)-29946355461657315300256240552185966952551471*xx^7*(1/1393796574908163946345982392040522594123776)+998213736763384913910074759047227544847506773*xx^7*yy*(1/11150372599265311570767859136324180752990208)-2038600361316622246653155899145012259420048867785*yy^4*(1/44601490397061246283071436545296723011960832)+10578825782023300845453772557509072093336001*xx^7*yy^2*(1/43556142965880123323311949751266331066368)-4303517165264733669855129139552505045324631645*xx^7*yy^3*(1/11150372599265311570767859136324180752990208)-652299342907430898149182084981866414949696905*xx^7*yy^4*(1/696898287454081973172991196020261297061888)+11170081785792631086653879206603595320491089331*xx^7*yy^5*(1/11150372599265311570767859136324180752990208)+116540829629507365267125159526451609264014215*xx^7*yy^6*(1/87112285931760246646623899502532662132736)+211134394987302797546644924545169826774270265159*yy^5*(1/1393796574908163946345982392040522594123776)-14785537121406447202257499440081382142298519099*xx^7*yy^7*(1/11150372599265311570767859136324180752990208)+1970986683407627074325019523003479974617451789943*yy^6*(1/22300745198530623141535718272648361505980416)-868641325364973493898126340263842300348545855*xx^7*yy^8*(1/1393796574908163946345982392040522594123776)+216255546256559295251079313253452049445763455*xx^7*yy^9*(1/348449143727040986586495598010130648530944)-4089215965643055747590786827106386135115380275*xx^8*(1/89202980794122492566142873090593446023921664)+1869246621670048362557342074310025153518449965*xx^8*yy*(1/2787593149816327892691964784081045188247552)+18712604797880071317805036942199122521197359575*xx^8*yy^2*(1/22300745198530623141535718272648361505980416)-3479476522267890993628796487849129439635143625*xx^8*yy^3*(1/696898287454081973172991196020261297061888)-77131555128675321096947207038878222843991869993*yy^7*(1/696898287454081973172991196020261297061888)-206512033439850904054937113093163624192322042825*xx^8*yy^4*(1/44601490397061246283071436545296723011960832)+15350689937843699961175740256400109996121380375*xx^8*yy^5*(1/1393796574908163946345982392040522594123776)+157001869330425518481531763580902779395436599415*xx^8*yy^6*(1/22300745198530623141535718272648361505980416)-6686861200533386632065997818427854246215113305*xx^8*yy^7*(1/696898287454081973172991196020261297061888)-3917684154726736823398471536296978037714283086195*yy^8*(1/89202980794122492566142873090593446023921664)-285743684916570536194588196441080828723328178675*xx^8*yy^8*(1/89202980794122492566142873090593446023921664)+8094790880015327525694605814920739418439287725*xx^8*yy^9*(1/2787593149816327892691964784081045188247552)+30423874459994412977383604476886160940746185*xx^9*(1/5575186299632655785383929568162090376495104)-1197236208181378637639504269592639035279087665*xx^9*yy*(1/44601490397061246283071436545296723011960832)-72716798311978341010558827315982986191821905*xx^9*yy^2*(1/696898287454081973172991196020261297061888)+5138909461003175489938484170634052266819688725*xx^9*yy^3*(1/44601490397061246283071436545296723011960832)+1206817075246069632318716986669541278160772775*xx^9*yy^4*(1/2787593149816327892691964784081045188247552)-12993287722661922638788467553649639108437064835*xx^9*yy^5*(1/44601490397061246283071436545296723011960832)-431284328058774504067793959976795724976545555*xx^9*yy^6*(1/696898287454081973172991196020261297061888)+17639360745426635511855086638766468926126459875*xx^9*yy^7*(1/44601490397061246283071436545296723011960832)-2146702909675882809503682033933399905335826325*xx^9*yy^9*(1/11150372599265311570767859136324180752990208)+1587967252519403636411870604735180043125989625*xx^9*yy^8*(1/5575186299632655785383929568162090376495104)+76828297887427851822683521168415270943435162685*yy^9*(1/2787593149816327892691964784081045188247552)+220816865194317615868568855814620996552449073*xx*(1/5575186299632655785383929568162090376495104)-9205355621994819342146712860571987786619361601*xx*yy*(1/44601490397061246283071436545296723011960832)-104255809907916433055923335622932126645726549*xx*yy^2*(1/696898287454081973172991196020261297061888)+27484692689867334306687311759874973819976026005*xx*yy^3*(1/44601490397061246283071436545296723011960832)+1583056855557692418384969876461998197073089695*xx*yy^4*(1/2787593149816327892691964784081045188247552)-36304948749180317956941914133403396762716230691*xx*yy^5*(1/44601490397061246283071436545296723011960832)-590212436135125327923049635849260481403670583*xx*yy^6*(1/696898287454081973172991196020261297061888)+27046038795224386955728969793334632924015008227*xx*yy^7*(1/44601490397061246283071436545296723011960832)+2168816628024980374461014350770096009019357665*xx*yy^8*(1/5575186299632655785383929568162090376495104)-2255097230860381206152749351617455809672044745*xx*yy^9*(1/11150372599265311570767859136324180752990208)+35122173917479363738100862234581108137514304171*xx^2*(1/22300745198530623141535718272648361505980416)-17449701902039745490242163912540688306429882361*xx^2*yy*(1/696898287454081973172991196020261297061888)-11540959773500599403794316292492996114189538863*xx^2*yy^2*(1/5575186299632655785383929568162090376495104)+27287439738914744607616926917914225474665410565*xx^2*yy^3*(1/174224571863520493293247799005065324265472)+929769947314964740179937673332890647768037984465*xx^2*yy^4*(1/11150372599265311570767859136324180752990208)-100809382380090436397261413740272360141145204891*xx^2*yy^5*(1/348449143727040986586495598010130648530944)-930314746723434588666177195703059675161177190255*xx^2*yy^6*(1/5575186299632655785383929568162090376495104)+36390552938954376406834468187448925576623439893*xx^2*yy^7*(1/174224571863520493293247799005065324265472)+1872760743346397986120124413411813119412045269675*xx^2*yy^8*(1/22300745198530623141535718272648361505980416)-35643509355104072817665294345590475660747146425*xx^2*yy^9*(1/696898287454081973172991196020261297061888)-125283292999146417157156696376640452081866835*xx^3*(1/1393796574908163946345982392040522594123776)+5011420945327438626354964312196465908094234685*xx^3*yy*(1/11150372599265311570767859136324180752990208)+29341459645317546529685572705520876577051855*xx^3*yy^2*(1/87112285931760246646623899502532662132736)-15637727799880882327290754576104647826715168925*xx^3*yy^3*(1/11150372599265311570767859136324180752990208)-851688199122087410134053760306093104684621525*xx^3*yy^4*(1/696898287454081973172991196020261297061888)+23458516464006675395891679247259419002768896835*xx^3*yy^5*(1/11150372599265311570767859136324180752990208)+39584968580329795728950940517214770307434335*xx^3*yy^6*(1/21778071482940061661655974875633165533184)-20361225581568567923686744589522827658576624955*xx^3*yy^7*(1/11150372599265311570767859136324180752990208)-1174244552874873223035231031480900497934023075*xx^3*yy^8*(1/1393796574908163946345982392040522594123776)+941109349474535911451616661821106567867537125*xx^3*yy^9*(1/1393796574908163946345982392040522594123776)-48412290717709997717153300332089796247538326265*xx^4*(1/44601490397061246283071436545296723011960832)+17196469545705046799299985950707233685621881055*xx^4*yy*(1/1393796574908163946345982392040522594123776)-9551461763890264957289963973620923748598225435*xx^4*yy^2*(1/11150372599265311570767859136324180752990208)-26051472095770585704126329008135447818638784275*xx^4*yy^3*(1/348449143727040986586495598010130648530944)-765302392604646459013613426858243443467023490875*xx^4*yy^4*(1/22300745198530623141535718272648361505980416)+94251624724512021502035994822030873708141367565*xx^4*yy^5*(1/696898287454081973172991196020261297061888)+843981485493394825713526892530506348990296828805*xx^4*yy^6*(1/11150372599265311570767859136324180752990208)-33218490572036542393092937176469859040906121155*xx^4*yy^7*(1/348449143727040986586495598010130648530944)-1758702445038817232726176779731884586549332868025*xx^4*yy^8*(1/44601490397061246283071436545296723011960832)+31380186488931551370058361496245928395816772575*xx^4*yy^9*(1/1393796574908163946345982392040522594123776)+184838927094446995029201369223921105703104647*xx^5*(1/2787593149816327892691964784081045188247552)-6817973449093402642853212701104432585928821163*xx^5*yy*(1/22300745198530623141535718272648361505980416)-113510140727511300460098712979462156361337425*xx^5*yy^2*(1/348449143727040986586495598010130648530944)+23570688854853763073042723518782612790921757535*xx^5*yy^3*(1/22300745198530623141535718272648361505980416)+1613038118657167505912389296857854524947676825*xx^5*yy^4*(1/1393796574908163946345982392040522594123776)-44608078263668464626393951292252447406629869273*xx^5*yy^5*(1/22300745198530623141535718272648361505980416)-588774433706353379897742534304221654039246663*xx^5*yy^6*(1/348449143727040986586495598010130648530944)+47950825635610780986659544491454706340397108297*xx^5*yy^7*(1/22300745198530623141535718272648361505980416):
g := .5*(1+tanh(f)):
plot3d(g, xx = -1 .. 1, yy = -1 .. 1, color = red, style = surface)
h := Student:-MultivariateCalculus:-TaylorApproximation(g, [xx, yy] = [0, 0], 35):
plot3d(h, xx = -1 .. 1, yy = -1 .. 1, color = red, style = surface)
Download taylorProblem.mw
How I can solve a PDE on two regions with matching conditions at the common boundary?
T1.mw
In Maple 2023 I haven't been able to sign in to the Maple Cloud.
In Maple 2022 there was no problem. In fact in my Maple 2022.2 I'm actually signed in right now.
I need this to get updates to the Physics updates.
The toolbar in 2023.2 has a grayed out icon saying "Sign in". Nothing happens if I click on it.
PS. I'm also signed in right now to Maple 2021.2. So the problem couldn't be that I cannot be logged in to more than one Maple release.
[Moderator: long pasted output deleted - OP has provided file in reply]
According to the documentation of MmaTranslator:-Mma:-PolynomialReduce, this command yields . However,
MmaTranslator:-Mma:-PolynomialReduce(x**2+y**2,{x-y,y+a});
                       [         2    2]
                       [[0, 0], x  + y ]
In[1]:= PolynomialReduce[x^2+y^2,{x-y,y+a}](*Mathematica*)
Out[1]= {{x + y, -2 a + 2 y}, 2 a^2}
In SymPy and in MuPAD:
The output of both is the same as that of Mma; only the result given by Maple is inconsistent with Mathematica's.
The example above is so simple that the desired result can be found simply by hand. Here is a larger example:
Given two polynomials .txt and .txt, as well as a list of polynomials .txt, I would like to evaluate
# Suppose that one has downloaded these three files.
poly1, poly2 := fscanf("poly1.txt", "%a")[], fscanf("poly2.txt", "%a")[]:
pList := MmaTranslator:-Mma:-ReadList("pList.txt"):
MmaTranslator:-Mma:-PolynomialReduce((a - poly1)*(a - poly2), pList);
 But its result is just “[[0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0], ]”, while when a=0 it should be “[[0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 1, 1, 1, 2, 1, 1, 1, 1, 0, 0, 0, 1, 2, 1, 0, 2, 2, 3, 1, 1, 1, 2, 1, 0, 0, 0, 1, 1, 2, 1, 0, 1, 0, 1, 1, 0, 0, 0, 0, 0, 0], 0]”.
So why does  return a distinct value?
Can MapleSim simulate a situation where a cable passes through a hole in an object, where the cable is constrained by the hole and the object also experiences forces from the cable because of the hole?
How would I solve for the product of two terms ( s*V or s^2*V). This is a simple example but I would be applying this on much higher order equations.
     V = Vx/(a*s^2 + b*s + c)
How do i retrieve the expression fra a "Fit" command so that i can use the expression for later calculations.
As you can see from the picture below, i use the "Fit" command to find an expression based on the values specified in X and Y. From there i would like to use the expression to find points on the line and to automate the proces. I can succesfully retrieve the expression by using the reference label, but is there another way to retrieve the expression so that i can avoid having to display the expression after evaluating?
I guess the question can be rephrased to: How do i retrieve the same information as the label reference does, but with a command and without using a label reference?
What would be the procedure to find the eigenvalues for a coupled harmonic oscillators characterized by eigenvalue E1 and E2? Are they treated as parameters in the numerical solution of the system of ode?
thanks in advance
First 179 180 181 182 183 184 185 Last Page 181 of 2457
