Hi all
Let us consider the set [f1=x-y, f2=-x^2+y^2, f3=x*y+x*z, f4=-x*y*z+z^3, f5=x*y^2+y*z^2-z^3] contain homogeneous polynomials in K[x,y,z]. It has the elements of degree 1,2, and 3. Now, we start from degree 1 so we have [x-y]. Now, we go to degree 2. Now, we shall multiply f1 by the variables and add to this set f2 and f3 i.e. we have now
[x-y], [x^2-x*y, x*y-y^2, x*z-y*z, -x^2+y^2, x*y+x*z]
 We have to continue to degree 3 and multiply f1 by all monomials in degree two in k[x,y,z] and multiply f2 and f3 by any variable and add them to f4 and f5 so we have finalyas a output:
[[x-y], [x^2-x*y, x*y-y^2, x*z-y*z, -x^2+y^2, x*y+x*z], [x^3-x^2*y, x^2*y-x*y^2, x^2*z-x*y*z, x*y^2-y^3, x*y*z-y^2*z, x*z^2-y*z^2, -x^3+x*y^2, -x^2*y+y^3, -x^2*z+y^2*z, x^2*y+x^2*z, x*y^2+x*y*z, x*y*z+x*z^2, -x*y*z+z^3, x*y^2+y*z^2-z^3]]. How can I do this automatically by a simple and efficient method in Maple?
Maple (2023.1) opens regularly but I cannot use "open" or "save" or "save as" and after opening Maple I no longer can close it.
That is a big problem for me.
The issue is on my new laptop Lenovo L13 Yoga with Windows 11.
Any suggestion? Thanks
hi i have a problem where maple dosent have a varible theta inside cos and sin and when i give it a size it dosent solve the equtation
The function f := x -> (x + 1)*(x^2 + (m - 5)*x - 7*m + 2) satifies
solve(discrim(f(x), x) = 0, m) has three solutions 1, -17, -1
How to find the integer numbers a, b, c, d, k, t so that the function
f := x -> x^3 + (a*m + b)*x^2 + (c*m + d)*x + k*m+t  satifies the equation
solve(discrim(f(x), x) = 0, m)  has three  integer numbers m?
Consider the function f:=x-> a*x^2 + b*m*x + x^3 + c*m.
I tried
f := x -> x^3 + a*x^2 + b*m*x + c*m;
solve(f(x) = 0, m);
g := x -> -x^2*(a + x)/(b*x + c);
solve(diff(g(x), x) = 0, x);
n := 0;
f := x -> -x^2*(a + x)/(b*x + c);
for a from -10 to 20 do
    for b to 20 do
for c from -10 to 20 do
mydelta := a^2*b^2 - 10*a*b*c + 9*c^2;
if 0 < mydelta and type(mydelta, integer) then
x1 := (-b*a - 3*c + sqrt(a^2*b^2 - 10*a*b*c + 9*c^2))/(4*b):
x2 := -(b*a + sqrt(a^2*b^2 - 10*a*b*c + 9*c^2) + 3*c)/(4*b):
x3 := 0:
if type(x1, integer) and type(x2, integer) and nops({0, x1, x2}) = 3 and type(f(x1), integer) and type(f(x2), integer) then n := n + 1; L[n] := [a, b, c]; end if; end if; end do; end do; end do;
L := convert(L, list);
I get
L := [[-10, 1, 6], [-10, 2, 12], [-9, 3, 5], [-8, 1, 10], [-5, 1, 3], [-4, 1, -6], [4, 1, 6], [5, 1, -3], [6, 3, 20], [7, 1, 15], [8, 1, -10], [8, 1, 12], [9, 3, -5], [10, 1, -6], [10, 1, 12], [12, 1, 18], [14, 1, -4], [15, 1, -9], [18, 1, 20], [18, 3, -10], [18, 3, 4], [20, 1, 2]]
With L[1], solve(discrim(x^3 - 10*x^2 + m*x + 6*m, x) = 0, m) ;
The equation has three integer solutions: 0, 12, -500
I have a PDE, with unknown u(t,x,t) ,  zero boundary condition and initial condition given
I converted the equaiton using finite difference to get a system of algebraic equation
The system is solved at each time step
I think i have a problem to update the solution inside the loop.
I hope find the problem or why the numerical solution is different to exact solution at last time
System_finite_difference.mw
Thank you for your help
Hi Everyone; I have plotted two different expressions separately and then shown them in a single graph. From the final display, we can observe that the peak of one expression, A is larger than that of another expression B. Now, the question is, how do I calculate the decrease or increase in the percentage of both curves? This means the peak of expression A is 20%, 8%, or 7% decreases or increases as of expression A.
Help_percentage_inccrease_or_decrease.mw
more explanation, each curve has its maximum point at some value of x, need to calculate that point for each curve. Then, we combined all curves we observed that the peak of each curve is smaller than others, so I am interested to observing that difference in percentage at the maximum value of x.
for reference, I uploading a file of which idea I want to implement for my problem. This is not my problem, but I want to implement it like this.
For_reference.mw
I have written a maple-code that is visualizing cycles or periods of inverse numbers in any base in a coloured plot.
For example 1/13=0,76923 076923 ... (so period-lenght is 6, the cycle-digits are visualized)
Now I would like to run the Maple Code wich produces the plot (via display-comand) on an ipad.
The ipad will be located in a museum or galerie. In the most easily way the user just touch a button on the ipad-screen and the maple-code produces a random plot which is displayed. Later some choosable parameters for the plot are added.
I have make some tests with embedded components in Maple.
So my idea is to do this with maple-player. I read about Maple Player features:
- Interact with applications that make use of embedded components, such as sliders, buttons, and math entry boxes. Maple will perform the computations and display updated results and visualizations
Questions:
1) how do I run Maple code in Maple Player (a little example with a button- and a plot-component will help)
2) do I need to upgrade Maple 2021  to do that ?
3) What does a mapleplayer license cost for each ipad ?
Thanks for support :)
Delay differential equations in Chebfun lists 15 examples "taken from the literature". Many of them can be (numerically) solved in Maple without difficulty, yet when I attempt to solve the  in the above link, Maple's internal solver `dsolve/numeric` just halts with an error.
plots:-odeplot(dsolve({D(u)(t) + u(t)**2 + 2*u(1/2*t) = 1/2*exp(t), u(0) = u(1/3)}, type = numeric, range = 0 .. 1/3), size = ["default", "golden"]);
Error, (in dsolve/numeric) delay equations are not supported for bvp solvers
Even if I guess an initial (or final) value artificially, the solution is still less reliable (For instance, what is the approximate endpoint value? 0.26344 or 0.2668?):
dde := D(u)(t) + u(t)**2 + u(t/2)*2 = exp(t)/2:
x__0 := 2668/10000:
sol0 := dsolve([dde, u(0) = x__0], type = numeric, 'delaymax' = 1/6, range = 0 .. 1/3):
plots['odeplot'](sol0, [[t, u(t)], [t, x__0]], 'size' = ["default", "golden"]);
x__1 := 26344/100000:
sol1 := dsolve([dde, u(1/3) = x__1], type = numeric, 'delaymax' = 1/6, range = 0 .. 1/3):
plots['odeplot'](sol1, [[t, u(t)], [t, x__1]], size = ["default", "golden"]);
Compare:  (Note that the reference numerical solution implies that its minimum should be no less than 0.258 (Is this incorrect?).).
And actually, the only known constraint is simply u(0)=u(⅓) (so neither value is known beforehand). Can Maple process this boundary condition automatically (that is, without the need for manual preprocessing and in absence of any other prior information)?
I have read the help page How to | Numeric Delay Differential Equations and Numerical Solution of Difficult ODE Boundary Value Problems, but it appears that those techniques are more or less ineffective here. So, how do I solve such a "first order nonlinear 'BVP' with pantograph delay" in Maple?
I'm unsure how to fix the error with sin, the help guide suggests using the command Describe (Sin)
#Clear memory.
#Initialise variables and arrays.
h:=((pi/20)^2);
n:=15;
k:=0.1;
m:=10;
t:=Array(0..m):
x:=Array(0..n):
u:=Array(0..n,0..m):
#Initialise the x array and the initial u(x,0) boundary.
   for i from 0 to n do
x[i]:=i*h;
u[i,0]:=x[i];
#Initialise the t array and the u(x,t)side boundaries.
  for j from 0 to m do
t[j]:=j*k;
u[0,j]:=0;
u[n,j]:=pi/2;
#Use the 2D explicit finite difference method.
for j from 0 to m-1 do
    for i from 1 to n-1 do
      u[i,j+1]:=(400*u[i-1,j]-400*u[i,j]+400*u[i+1,j]+1)/(pi^2)*(4*sin(2*x));
#Display the u(x,t) values.
printf("2D Explicit Finite Difference Method\n");
printf("------------------------------------\n");
printf(" x\t\t t\t\t u\n");
    printf("% 9.4f\t% 9.4f\t% 9.4f\n",x[i],t[m],u[i,m]);
(1/400)*pi^2
15
.1
10
Error, invalid input: sin expects its 1st argument, x, to be of type algebraic, but received Array(0..15, [0,1/200*pi^2,1/100*pi^2,3/200*pi^2,1/50*pi^2,1/40*pi^2,3/100*pi^2,7/200*pi^2,1/25*pi^2,9/200*pi^2,1/20*pi^2,11/200*pi^2,3/50*pi^2,13/200*pi^2,7/100*pi^2,3/40*pi^2])
 x                 t                 u
   0.0000           1.0000           0.0000
Error, (in fprintf) number expected for floating point format
Download Asst_2_Q3bcd.mw
#Clear memory.
h:=0.1;
n:=10;
x:=Array(0..n):
y:=Array(0..n):
x[0]:=0;
y[0]:=2;
yd:=-1;
#Initialise the x array.
for i from 1 to n do
    x[i]:=x[0]+i*h;
#Calculate the first y value.
y[1]:=(203*y[0]-22*yd+4)/220:
#Calculate the remaining y values.
    y[i+1]:=203*y[i]-110*y[i-1]+4*exp^(-3*x[i])/110;
#Display the x and y arrays.
printf("1D Explicit Finite Difference Method\n");
printf("x\t\ty\n");
     printf("%f\t %f\n",x[i],y[i]);
.1
10
-1
x                y
0.000000         2.000000
0.100000         1.963636
0.200000
Download Asst_2_Q1c.mw
I dont understand the cause of this error, can anyone please assist?
I am trying to write a procedure that takes two intervals of real numbers (in interval notation) and checks if one is a subset of the other. For example, isSubset([-5,2],[-10,infinity)) would return true, but isSubset([-5,2],(-5,infinity)) would return false. Any idea how to go about this? I am having difficulty knowing where to start.
I have an equation, I would like to collect or regroup all similar terms
MCode.mw
Hello!!
Matrice: (x,y)=(-2,-3),(-1,2),(3,4),(1,-2)
When plotting 3 lines with points are ok, but the fourth line os missing! All 4 points are there
How to include the 4th line?
Kjell
For instance, “[1, 2, 3]”, “[``([1, 2]), uneval([3])]”, and “[[1, 2], [3, 'NULL']]” are fully rectangular. “[1, 2, [3]]”, “[`[]`(1, 2), [3]]”, and “[[1, 2], [3, NULL]]” are considered nonrectangular, but if we temporarily freeze the "ragged" parts or regard them as a depth-1 container, the corresponding expressions will seem rectangular. `type(…, list(Non(list)))` and `type(…, listlist(Non(list)))` check these, but they do not work for general cases.
To be specific, the desired output should be something like
IsRectangular([[[l, 2], [3, 4]], [[5, 6], [7, 8]]]);
                            true, 3
IsRectangular([[[O, l, 2], [3, 4]], [[5, 6], [7, 8]]]);
                            false, 2
IsRectangular([[[[l], 2], [3, 4]], [[5, 6], [7, 8]]], 3);
                            true, 3
IsRectangular([[O, [l, 2], [3, 4]], [[5, 6], [7, 8]]], 2);
                            false, 1
The results above can be obtained by some observations. However, if the input has deeper levels, evaluating this will be a punishing work:
test__1 := [[[[[[[[-288],[-287],[-286]],[[-285],[-284],[-283]],[[-282],[-281],[-280]],[[-279],[-278],[-277]]]],[[[[-276],[-275],[-274]],[[-273],[-272],[-271]],[[-270],[-269],[-268]],[[-267],[-266],[-265]]]],[[[[-264],[-263],[-262]],[[-261],[-260],[-259]],[[-258],[-257],[-256]],[[-255],[-254],[-253]]]]],[[[[[-252],[-251],[-250]],[[-249],[-248],[-247]],[[-246],[-245],[-244]],[[-243],[-242],[-241]]]],[[[[-240],[-239],[-238]],[[-237],[-236],[-235]],[[-234],[-233],[-232]],[[-231],[-230],[-229]]]],[[[[-228],[-227],[-226]],[[-225],[-224],[-223]],[[-222],[-221],[-220]],[[-219],[-218],[-217]]]]]],[[[[[[-216],[-215],[-214]],[[-213],[-212],[-211]],[[-210],[-209],[-208]],[[-207],[-206],[-205]]]],[[[[-204],[-203],[-202]],[[-201],[-200],[-199]],[[-198],[-197],[-196]],[[-195],[-194],[-193]]]],[[[[-192],[-191],[-190]],[[-189],[-188],[-187]],[[-186],[-185],[-184]],[[-183],[-182],[-181]]]]],[[[[[-180],[-179],[-178]],[[-177],[-176],[-175]],[[-174],[-173],[-172]],[[-171],[-170],[-169]]]],[[[[-168],[-167],[-166]],[[-165],[-164],[-163]],[[-162],[-161],[-160]],[[-159],[-158],[-157]]]],[[[[-156],[-155],[-154]],[[-153],[-152],[-151]],[[-150],[-149],[-148]],[[-147],[-146],[-145]]]]]],[[[[[[-144],[-143],[-142]],[[-141],[-140],[-139]],[[-138],[-137],[-136]],[[-135],[-134],[-133]]]],[[[[-132],[-131],[-130]],[[-129],[-128],[-127]],[[-126],[-125],[-124]],[[-123],[-122],[-121]]]],[[[[-120],[-119],[-118]],[[-117],[-116],[-115]],[[-114],[-113],[-112]],[[-111],[-110],[-109]]]]],[[[[[-108],[-107],[-106]],[[-105],[-104],[-103]],[[-102],[-101],[-100]],[[-99],[-98],[-97]]]],[[[[-96],[-95],[-94]],[[-93],[-92],[-91]],[[-90],[-89],[-88]],[[-87],[-86],[-85]]]],[[[[-84],[-83],[-82]],[[-81],[-80],[-79]],[[-78],[-77],[-76]],[[-75],[-74],[-73]]]]]],[[[[[[-72],[-71],[-70]],[[-69],[-68],[-67]],[[-66],[-65],[-64]],[[-63],[-62],[-61]]]],[[[[-60],[-59],[-58]],[[-57],[-56],[-55]],[[-54],[-53],[-52]],[[-51],[-50],[-49]]]],[[[[-48],[-47],[-46]],[[-45],[-44],[-43]],[[-42],[-41],[-40]],[[-39],[-38],[-37]]]]],[[[[[-36],[-35],[-34]],[[-33],[-32],[-31]],[[-30],[-29],[-28]],[[-27],[-26],[-25]]]],[[[[-24],[-23],[-22]],[[-21],[-20],[-19]],[[-18],[-17],[-16]],[[-15],[-14],[-13]]]],[[[[-12],[-11],[-10]],[[-9],[-8],[-7]],[[-6],[-5],[-4]],[[-3],[-2],[-1],[-0]]]]]]],[[[[[[[0],[1],[2]],[[3],[4],[5]],[[6],[7],[8]],[[9],[10],[11]]]],[[[[12],[13],[14]],[[15],[16],[17]],[[18],[19],[20]],[[21],[22],[23]]]],[[[[24],[25],[26]],[[27],[28],[29]],[[30],[31],[32]],[[33],[34],[35]]]]],[[[[[36],[37],[38]],[[39],[40],[41]],[[42],[43],[44]],[[45],[46],[47]]]],[[[[48],[49],[50]],[[51],[52],[53]],[[54],[55],[56]],[[57],[58],[59]]]],[[[[60],[61],[62]],[[63],[64],[65]],[[66],[67],[68]],[[69],[70],[71]]]]]],[[[[[[72],[73],[74]],[[75],[76],[77]],[[78],[79],[80]],[[81],[82],[83]]]],[[[[84],[85],[86]],[[87],[88],[89]],[[90],[91],[92]],[[93],[94],[95]]]],[[[[96],[97],[98]],[[99],[100],[101]],[[102],[103],[104]],[[105],[106],[107]]]]],[[[[[108],[109],[110]],[[111],[112],[113]],[[114],[115],[116]],[[117],[118],[119]]]],[[[[120],[121],[122]],[[123],[124],[125]],[[126],[127],[128]],[[129],[130],[131]]]],[[[[132],[133],[134]],[[135],[136],[137]],[[138],[139],[140]],[[141],[142],[143]]]]]],[[[[[[144],[145],[146]],[[147],[148],[149]],[[150],[151],[152]],[[153],[154],[155]]]],[[[[156],[157],[158]],[[159],[160],[161]],[[162],[163],[164]],[[165],[166],[167]]]],[[[[168],[169],[170]],[[171],[172],[173]],[[174],[175],[176]],[[177],[178],[179]]]]],[[[[[180],[181],[182]],[[183],[184],[185]],[[186],[187],[188]],[[189],[190],[191]]]],[[[[192],[193],[194]],[[195],[196],[197]],[[198],[199],[200]],[[201],[202],[203]]]],[[[[204],[205],[206]],[[207],[208],[209]],[[210],[211],[212]],[[213],[214],[215]]]]]],[[[[[[216],[217],[218]],[[219],[220],[221]],[[222],[223],[224]],[[225],[226],[227]]]],[[[[228],[229],[230]],[[231],[232],[233]],[[234],[235],[236]],[[237],[238],[239]]]],[[[[240],[241],[242]],[[243],[244],[245]],[[246],[247],[248]],[[249],[250],[251]]]]],[[[[[252],[253],[254]],[[255],[256],[257]],[[258],[259],[260]],[[261],[262],[263]]]],[[[[264],[265],[266]],[[267],[268],[269]],[[270],[271],[272]],[[273],[274],[275]]]],[[[[276],[277],[278]],[[279],[280],[281]],[[282],[283],[284]],[[285],[286],[287]]]]]]]]:
test__2 := [[[[[[[[-288],[-287],[-286]],[[-285],[-284],[-283]],[[-282],[-281],[-280]],[[-279],[-278],[-277]]]],[[[[-276],[-275],[-274]],[[-273],[-272],[-271]],[[-270],[-269],[-268]],[[-267],[-266],[-265]]]],[[[[-264],[-263],[-262]],[[-261],[-260],[-259]],[[-258],[-257],[-256]],[[-255],[-254],[-253]]]]],[[[[[-252],[-251],[-250]],[[-249],[-248],[-247]],[[-246],[-245],[-244]],[[-243],[-242],[-241]]]],[[[[-240],[-239],[-238]],[[-237],[-236],[-235]],[[-234],[-233],[-232]],[[-231],[-230],[-229]]]],[[[[-228],[-227],[-226]],[[-225],[-224],[-223]],[[-222],[-221],[-220]],[[-219],[-218],[-217]]]]]],[[[[[[-216],[-215],[-214]],[[-213],[-212],[-211]],[[-210],[-209],[-208]],[[-207],[-206],[-205]]]],[[[[-204],[-203],[-202]],[[-201],[-200],[-199]],[[-198],[-197],[-196]],[[-195],[-194],[-193]]]],[[[[-192],[-191],[-190]],[[-189],[-188],[-187]],[[-186],[-185],[-184]],[[-183],[-182],[-181]]]]],[[[[[-180],[-179],[-178]],[[-177],[-176],[-175]],[[-174],[-173],[-172]],[[-171],[-170],[-169]]]],[[[[-168],[-167],[-166]],[[-165],[-164],[-163]],[[-162],[-161],[-160]],[[-159],[-158],[-157]]]],[[[[-156],[-155],[-154]],[[-153],[-152],[-151]],[[-150],[-149],[-148]],[[-147],[-146],[-145]]]]]],[[[[[[-144],[-143],[-142]],[[-141],[-140],[-139]],[[-138],[-137],[-136]],[[-135],[-134],[-133]]]],[[[[-132],[-131],[-130]],[[-129],[-128],[-127]],[[-126],[-125],[-124]],[[-123],[-122],[-121]]]],[[[[-120],[-119],[-118]],[[-117],[-116],[-115]],[[-114],[-113],[-112]],[[-111],[-110],[-109]]]]],[[[[[-108],[-107],[-106]],[[-105],[-104],[-103]],[[-102],[-101],[-100]],[[-99],[-98],[-97]]]],[[[[-96],[-95],[-94]],[[-93],[-92],[-91]],[[-90],[-89],[-88]],[[-87],[-86],[-85]]]],[[[[-84],[-83],[-82]],[[-81],[-80],[-79]],[[-78],[-77],[-76]],[[-75],[-74],[-73]]]]]],[[[[[[-72],[-71],[-70]],[[-69],[-68],[-67]],[[-66],[-65],[-64]],[[-63],[-62],[-61]]]],[[[[-60],[-59],[-58]],[[-57],[-56],[-55]],[[-54],[-53],[-52]],[[-51],[-50],[-49]]]],[[[[-48],[-47],[-46]],[[-45],[-44],[-43]],[[-42],[-41],[-40]],[[-39],[-38],[-37]]]]],[[[[[-36],[-35],[-34]],[[-33],[-32],[-31]],[[-30],[-29],[-28]],[[-27],[-26],[-25]]]],[[[[-24],[-23],[-22]],[[-21],[-20],[-19]],[[-18],[-17],[-16]],[[-15],[-14],[-13]]]],[[[[-12],[-11],[-10]],[[-9],[-8],[-7]],[[-6],[-5],[-4]],[[-3],[-2,0],[-0]]]]]]],[[[[[[[-1],[1],[2]],[[3],[4],[5]],[[6],[7],[8]],[[9],[10],[11]]]],[[[[12],[13],[14]],[[15],[16],[17]],[[18],[19],[20]],[[21],[22],[23]]]],[[[[24],[25],[26]],[[27],[28],[29]],[[30],[31],[32]],[[33],[34],[35]]]]],[[[[[36],[37],[38]],[[39],[40],[41]],[[42],[43],[44]],[[45],[46],[47]]]],[[[[48],[49],[50]],[[51],[52],[53]],[[54],[55],[56]],[[57],[58],[59]]]],[[[[60],[61],[62]],[[63],[64],[65]],[[66],[67],[68]],[[69],[70],[71]]]]]],[[[[[[72],[73],[74]],[[75],[76],[77]],[[78],[79],[80]],[[81],[82],[83]]]],[[[[84],[85],[86]],[[87],[88],[89]],[[90],[91],[92]],[[93],[94],[95]]]],[[[[96],[97],[98]],[[99],[100],[101]],[[102],[103],[104]],[[105],[106],[107]]]]],[[[[[108],[109],[110]],[[111],[112],[113]],[[114],[115],[116]],[[117],[118],[119]]]],[[[[120],[121],[122]],[[123],[124],[125]],[[126],[127],[128]],[[129],[130],[131]]]],[[[[132],[133],[134]],[[135],[136],[137]],[[138],[139],[140]],[[141],[142],[143]]]]]],[[[[[[144],[145],[146]],[[147],[148],[149]],[[150],[151],[152]],[[153],[154],[155]]]],[[[[156],[157],[158]],[[159],[160],[161]],[[162],[163],[164]],[[165],[166],[167]]]],[[[[168],[169],[170]],[[171],[172],[173]],[[174],[175],[176]],[[177],[178],[179]]]]],[[[[[180],[181],[182]],[[183],[184],[185]],[[186],[187],[188]],[[189],[190],[191]]]],[[[[192],[193],[194]],[[195],[196],[197]],[[198],[199],[200]],[[201],[202],[203]]]],[[[[204],[205],[206]],[[207],[208],[209]],[[210],[211],[212]],[[213],[214],[215]]]]]],[[[[[[216],[217],[218]],[[219],[220],[221]],[[222],[223],[224]],[[225],[226],[227]]]],[[[[228],[229],[230]],[[231],[232],[233]],[[234],[235],[236]],[[237],[238],[239]]]],[[[[240],[241],[242]],[[243],[244],[245]],[[246],[247],[248]],[[249],[250],[251]]]]],[[[[[252],[253],[254]],[[255],[256],[257]],[[258],[259],[260]],[[261],[262],[263]]]],[[[[264],[265],[266]],[[267],[268],[269]],[[270],[271],[272]],[[273],[274],[275]]]],[[[[276],[277],[278]],[[279],[280],[281]],[[282],[283],[284]],[[285],[286],[287]]]]]]]]:
test__3 := [[[[[[[[-288],[-287],[-286]],[[-285],[-284],[-283]],[[-282],[-281],[-280]],[[-279],[-278],[-277]]]],[[[[-276],[-275],[-274]],[[-273],[-272],[-271]],[[-270],[-269],[-268]],[[-267],[-266],[-265]]]],[[[[-264],[-263],[-262]],[[-261],[-260],[-259]],[[-258],[-257],[-256]],[[-255],[-254],[-253]]]]],[[[[[-252],[-251],[-250]],[[-249],[-248],[-247]],[[-246],[-245],[-244]],[[-243],[-242],[-241]]]],[[[[-240],[-239],[-238]],[[-237],[-236],[-235]],[[-234],[-233],[-232]],[[-231],[-230],[-229]]]],[[[[-228],[-227],[-226]],[[-225],[-224],[-223]],[[-222],[-221],[-220]],[[-219],[-218],[-217]]]]]],[[[[[[-216],[-215],[-214]],[[-213],[-212],[-211]],[[-210],[-209],[-208]],[[-207],[-206],[-205]]]],[[[[-204],[-203],[-202]],[[-201],[-200],[-199]],[[-198],[-197],[-196]],[[-195],[-194],[-193]]]],[[[[-192],[-191],[-190]],[[-189],[-188],[-187]],[[-186],[-185],[-184]],[[-183],[-182],[-181]]]]],[[[[[-180],[-179],[-178]],[[-177],[-176],[-175]],[[-174],[-173],[-172]],[[-171],[-170],[-169]]]],[[[[-168],[-167],[-166]],[[-165],[-164],[-163]],[[-162],[-161],[-160]],[[-159],[-158],[-157]]]],[[[[-156],[-155],[-154]],[[-153],[-152],[-151]],[[-150],[-149],[-148]],[[-147],[-146],[-145]]]]]],[[[[[[-144],[-143],[-142]],[[-141],[-140],[-139]],[[-138],[-137],[-136]],[[-135],[-134],[-133]]]],[[[[-132],[-131],[-130]],[[-129],[-128],[-127]],[[-126],[-125],[-124]],[[-123],[-122],[-121]]]],[[[[-120],[-119],[-118]],[[-117],[-116],[-115]],[[-114],[-113],[-112]],[[-111],[-110],[-109]]]]],[[[[[-108],[-107],[-106]],[[-105],[-104],[-103]],[[-102],[-101],[-100]],[[-99],[-98],[-97]]]],[[[[-96],[-95],[-94]],[[-93],[-92],[-91]],[[-90],[-89],[-88]],[[-87],[-86],[-85]]]],[[[[-84],[-83],[-82]],[[-81],[-80],[-79]],[[-78],[-77],[-76]],[[-75],[-74],[-73]]]]]],[[[[[[-72],[-71],[-70]],[[-69],[-68],[-67]],[[-66],[-65],[-64]],[[-63],[-62],[-61]]]],[[[[-60],[-59],[-58]],[[-57],[-56],[-55]],[[-54],[-53],[-52]],[[-51],[-50],[-49]]]],[[[[-48],[-47],[-46]],[[-45],[-44],[-43]],[[-42],[-41],[-40]],[[-39],[-38],[-37]]]]],[[[[[-36],[-35],[-34]],[[-33],[-32],[-31]],[[-30],[-29],[-28]],[[-27],[-26],[-25]]]],[[[[-24],[-23],[-22]],[[-21],[-20],[-19]],[[-18],[-17],[-16]],[[-15],[-14],[-13]]]],[[[[-12],[-11],[-10]],[[-9],[-8],[-7]],[[-6],[-5],[-4]],[[-3],[-2,-0]]]]]]],[[[[[[-1],[[1],[2]],[[3],[4],[5]],[[6],[7],[8]],[[9],[10],[11]]]],[[[[12],[13],[14]],[[15],[16],[17]],[[18],[19],[20]],[[21],[22],[23]]]],[[[[24],[25],[26]],[[27],[28],[29]],[[30],[31],[32]],[[33],[34],[35]]]]],[[[[[36],[37],[38]],[[39],[40],[41]],[[42],[43],[44]],[[45],[46],[47]]]],[[[[48],[49],[50]],[[51],[52],[53]],[[54],[55],[56]],[[57],[58],[59]]]],[[[[60],[61],[62]],[[63],[64],[65]],[[66],[67],[68]],[[69],[70],[71]]]]]],[[[[[[72],[73],[74]],[[75],[76],[77]],[[78],[79],[80]],[[81],[82],[83]]]],[[[[84],[85],[86]],[[87],[88],[89]],[[90],[91],[92]],[[93],[94],[95]]]],[[[[96],[97],[98]],[[99],[100],[101]],[[102],[103],[104]],[[105],[106],[107]]]]],[[[[[108],[109],[110]],[[111],[112],[113]],[[114],[115],[116]],[[117],[118],[119]]]],[[[[120],[121],[122]],[[123],[124],[125]],[[126],[127],[128]],[[129],[130],[131]]]],[[[[132],[133],[134]],[[135],[136],[137]],[[138],[139],[140]],[[141],[142],[143]]]]]],[[[[[[144],[145],[146]],[[147],[148],[149]],[[150],[151],[152]],[[153],[154],[155]]]],[[[[156],[157],[158]],[[159],[160],[161]],[[162],[163],[164]],[[165],[166],[167]]]],[[[[168],[169],[170]],[[171],[172],[173]],[[174],[175],[176]],[[177],[178],[179]]]]],[[[[[180],[181],[182]],[[183],[184],[185]],[[186],[187],[188]],[[189],[190],[191]]]],[[[[192],[193],[194]],[[195],[196],[197]],[[198],[199],[200]],[[201],[202],[203]]]],[[[[204],[205],[206]],[[207],[208],[209]],[[210],[211],[212]],[[213],[214],[215]]]]]],[[[[[[216],[217],[218]],[[219],[220],[221]],[[222],[223],[224]],[[225],[226],[227]]]],[[[[228],[229],[230]],[[231],[232],[233]],[[234],[235],[236]],[[237],[238],[239]]]],[[[[240],[241],[242]],[[243],[244],[245]],[[246],[247],[248]],[[249],[250],[251]]]]],[[[[[252],[253],[254]],[[255],[256],[257]],[[258],[259],[260]],[[261],[262],[263]]]],[[[[264],[265],[266]],[[267],[268],[269]],[[270],[271],[272]],[[273],[274],[275]]]],[[[[276],[277],[278]],[[279],[280],[281]],[[282],[283],[284]],[[285],[286],[287]]]]]]]]:
Is there a generalized test procedure (e.g., ListTools:-IsRectangular) that effectively works for any nested list of an arbitrary nesting level?
HI every one ! i want to know how can i calculate tt component and rr component in Einstein eq or Energy-Momentum eq.please give me a cod for drive component of any equation in maple
First 201 202 203 204 205 206 207 Last Page 203 of 2457
