There are two issues I am having with images in Maple Flow 2022.
1. When I need to move an image up or down in the document it instantly flies to the top or off in to the vast corner of the document with the tiniest motion of the mouse. It's utterly ridiculous. Is there a setting to change this behaviour in Maple Flow? I have changed settings on my desktop with no change, so I believe it is Maple Flow's behavior.
2. When I do put an image somewhere and save the document and open it some time later, the images are moved in position on top of text. No amount of moving them and saving them ever changes this and I can't export a document that I need to submit for calculations on a report because of this.
Could you suggest a more elegent way to remove any entry in piecewise which has undefined in it?
expr:=(s+exp(-Pi*s)-exp(-2*Pi*s))/(s*(s^2+2*s+2));
inttrans:-invlaplace(expr,s,t);
Y:=convert(%,piecewise);
#remove all entries in piecwise which has undefined
To obtain this
I can;t just apply select on piecewise. So currently I convert piecwise to list of lists, each sublist has the 2 entries you see above in each row.
Next apply select. Then use piecewise again on the result. This works, but wondering if there is a better way.
Attached worksheet.
expr := (s+exp(-Pi*s)-exp(-2*Pi*s))/(s*(s^2+2*s+2))
exp(-t)*sin(t)+(1/2)*(-1+exp(-t+2*Pi)*(cos(t)+sin(t)))*Heaviside(t-2*Pi)+(1/2)*(1+exp(-t+Pi)*(cos(t)+sin(t)))*Heaviside(t-Pi)
piecewise(t < Pi, exp(-t)*sin(t), t = Pi, undefined, t < 2*Pi, exp(-t)*sin(t)+1/2+(1/2)*exp(-t+Pi)*(cos(t)+sin(t)), t = 2*Pi, undefined+(1/2)*exp(-Pi), 2*Pi < t, exp(-t)*sin(t)+(1/2)*exp(-t+2*Pi)*(cos(t)+sin(t))+(1/2)*exp(-t+Pi)*(cos(t)+sin(t)))
Y:=[op(Y)]:
Y:=seq([Y[n],Y[n+1]],n=1..nops(Y)-1,2):
ListTools:-Flatten(select(not has,[Y],'undefined')):
piecewise(op(%))
piecewise(t < Pi, exp(-t)*sin(t), t < 2*Pi, exp(-t)*sin(t)+1/2+(1/2)*exp(-t+Pi)*(cos(t)+sin(t)), 2*Pi < t, exp(-t)*sin(t)+(1/2)*exp(-t+2*Pi)*(cos(t)+sin(t))+(1/2)*exp(-t+Pi)*(cos(t)+sin(t)))
Download remove_undefined.mw
Another very strange result from simplify.  Consider
simplify(a*f(x) + b*f(x) + a*g(x))
Which is what is expected. Now
expr := a*f(x) + b*f(x) + a*g(x) + 1/(a*f(x) + b*f(x) + a*g(x));
simplify(expr)
gives
why?  I expected (a+b)*f(x) also in the first expression. Compare for reference the same thing in Mathematica where it does them both the same way:
You see it simplified it to (a+b)*f(x)+a*g(x) in both places as expected.
I tried using size option for simplify, but it had no effect.
How can one obtain same result shown above using Maple? And why it does not automatically produce this result?
Maple 2022.2
I give up.
Why
the_rule:=A::anything+B::anything=A*B;
applyrule(the_rule,a+b);
returns 0?
I was expecting a*b
No clue from help what I am doing wrong.
Maple 2022.2
trace gives this
trace(applyrule);
{--> enter applyrule, args = A::anything+B::anything = A*B, a+b
                        answer := a + b
                             i :=
                           i := a + b
                          answer := b
                             i := b
                          answer := 0
                             i := 0
                          answer := 0
I am not sure why it is doing the above still.
I think I will stick to evalindents and subsindets as I do not understand applyrule very well.
OdeSys := diff(U(Y), Y, Y)+Theta(Y)+N*(Theta(Y)*Theta(Y))-(M*M)*U(Y) = 0, diff(Theta(Y), Y, Y)+E*(diff(U(Y), Y))^2 = 0;
Cond := U(0) = lambda*(D(U))(0), Theta(0) = A+g*(D(Theta))(0), U(1) = 0, Theta(1) = B; sys := [OdeSys, Cond];
Ans := dsolve(sys);
I'm new to maple and I dont know how to solve this equation for k=1 to 4 and finding the roots. If anyone can help with this.
Equation  "cos(k).cosh(k)-1=0"
B := ((cos(k)) . (cosh(k))) - 1 = 0;
               B := (cos(k)) . (cosh(k)) - 1 = 0
solve(B, k);
               RootOf((cos(_Z)) . (cosh(_Z)) - 1)
solve(B, k);
plot(((cos(l)) . (cosh(l))) - 1, l = 5*_8);
Error, (in plot) unexpected option: l = 5*_8
solve(B, k = 1 .. 4);
Error, invalid input: too many and/or wrong type of arguments passed to solve; first unused argument is k = 1 .. 4
solve(B, k, k = 1 .. 4);
solve({B}, {k = 1 .. 4});
NULL;
One might be flabbergasted by the following
with(ColorTools):
Colors dosn't appear to match values given from this wavelength to rgb converter from here https://www.johndcook.com/wavelength_to_RGB.html
Although the color is in agreement when converting the value given back into a color value.
So in maple WavelengthToColor(622) does not match the color above however (heads up using the method="linear" option makes it closer) if we go through the paces and convert #ff6f00 to a color, it comes out properly.  One might think is something wrong with the WavelengthToColor command?
HexToRGB24("#ff6f00")
RGB24ToRGB([255,111,0])
Color([1,.43529412,0])
Ok the color seems right but that's not what WavelengthToColor(622) gives
So as it turns out using method=linear makes it closer.
Time is short I haven't time to compose the question properly but likely has something to do with the HSV Colorspaces.  It's confusing.
Does Maple Flow support unit prefixes?
Can I "cast" units from one prefixed form to another? For example show 1000ohm as 1Kohm?
Given an expression, I want to do an operation each time the pattern  f(arg1)+f(arg2) is found by replacing it by f(arg1+arg2). Regadless of how many there are. For example
f(A)+f(B) -> f(A+B) and  f(A)+f(B)+f(C) -> f(A+B+C)  and so on. But here is the catch, there could be anything else in the expressions. These will be left unchanged.
So f(A)+f(B)+x -> f(A+B)+x
I can do it in Maple only when the input is exactly f(A)+f(B)  when the input is f(A)+f(B)+f(C) and so on.
But this is not practical as I need to make new type for each case.
I need a general way that will work for any expression like in the above example.
I am now using evalindets, but I do not know how to tell it the type for the general pattern of  f(n1)+f(n2)+.....+f(nn) to replace these with f(n1+n2+....nn).
For reference, this is code in Mathematica I am trying to translate to maple.
expr = Sin[x] + f[A] + f[B] + 10*Exp[x]/13 + Cos[x] + f[c] + f[10*c];
expr //. f[a_] + f[b_] :> f[a + b]
In the above //. means repeated replacement. So it will keep replacing the same pattern over and over and this works regardless of where f(a)+f(b) show up. They can be anywhere in the sum.
I wish I can the same in Maple using evalindets. I tried patmatch also, and same problem. Which is how to make it general. This is what I tried
expr:=f(A)+f(B);
evalindets(expr,`&+`('specfunc(f)','specfunc(f)'),F->f( op([1,1],F) + op([2,1],F) ) );
Which works
But to detect expr:=f(A)+f(B)+f(C) it would need new code
expr:=f(A)+f(B)+f(C);
evalindets(expr,`&+`('specfunc(f)','specfunc(f)','specfunc(f)'),F->f( op([1,1],F) + op([2,1],F) + op([3,1],F) ) );
Obviously this approach will not work. It will also fail once a new term is added in between.
But how to extend this to the general case of
expr:=sin(x)+f(A)+f(B)+10*exp(x)/13+cos(x)+f(C)+f(10*C);
Is there a way to tell Maple to apply the pattern over and over like with Mathematica so it works for general case? I need to try to do this using either patmatch or evalindets. Ofcourse I can do it the hard way, by iterating over the expression and collecting all the f() and add their arguments one by one each `+` subtype. But that is now what I looking for.
There should be something similar to how it is done in Mathematica, but using Maple command. Notice that the Mathematica example will work regadless of where the f(a)+f(b) shows up.
expr = Sin[x] + f[A] + f[B] + 10*Exp[x]/13 + Cos[x] + f[c] + 1/(f[10*c] + x + f[99])
ps. may be I need to use subsindets['nocache'] need to look more into it.
Are there rules of thumb to follow to decide to use evalindets vs. subsindets?  They seems to do the same thing, but I did not read every details of the help pages.  Is the difference similar to difference between using eval vs. subs? i.e.
          eval(expr,A=2)
vs.
         subs(A=2,expr) ?
For example
expr:=ln(A)+ln(B);
evalindets(expr,`&+`('specfunc(ln)','specfunc(ln)'),f->ln(op([1,1],f)*op([2,1],f)));
subsindets( expr, `&+`('specfunc(ln)','specfunc(ln)'), f->ln(op([1,1],f)*op([2,1],f)));
Both give
I am learning very basic matrix ops in Maple and I'm running into questions nearly at every step.
At the risk asking too many trivial questions, I have written my ~7 questions in the attached worksheet in red font.
Any answers will be appreciated.
matrix_ops_Qs.mw
matrix_ops_Qs.pdf
After using maple for quite a while, I am still confused by some basic concepts.
Given the following table, how can I select the indices for which the entry is not null ([])?
table([1 = NULL, 2 = NULL, 3 = NULL, 4 = NULL, 5 = NULL, 6 = NULL, 7 = 5, 9 = NULL, 8 = NULL, 11 = 4, 10 = NULL, 13 = NULL, 12 = NULL, 15 = 9, 14 = NULL, 18 = NULL, 19 = 8, 16 = 9, 17 = NULL, 22 = 9, 23 = NULL, 20 = NULL, 21 = 8, 27 = NULL, 26 = 8, 25 = 4, 24 = NULL, 31 = NULL, 30 = 9, 29 = NULL, 28 = 9, 36 = NULL, 37 = 9, 38 = 9, 39 = NULL, 32 = 5, 33 = NULL, 34 = NULL, 35 = NULL, 45 = NULL, 44 = NULL, 47 = NULL, 46 = NULL, 41 = 8, 40 = NULL, 43 = NULL, 42 = NULL, 54 = NULL, 55 = NULL, 52 = NULL, 53 = NULL, 50 = NULL, 51 = NULL, 48 = 5, 49 = 9, 60 = 8, 59 = NULL, 58 = 7, 57 = 7, 56 = NULL])
Many thanks
Hello Everyone,
My questions is about a straight forward as my title suggests. I know how to compute the variation by hand and of course it is in plently of books, but I would like to know how I could possibly do it in Maple as I have some terms with non-trivial contributions where I infact need that specific variation.
I have attached my file I have been working with that has more comments.
RicciAction.mw
Maple has corrupted my file without notice. I get the error "There was a problem in the loading process, you worksheet may be incomplete."
I've tried restarting maple, checked my backup folder, and followed maples troubleshooting process (maplesoft support) without any luck.
Anyone who might help me here?
File: Assignment2.mw
The algebraic equation in four variables is:
expr := (a^2 + b^2 + c^2 + d^2 - 4)*(a^2 + b^2 + c^2 + d^2) + 4*d*c*b*a - (a + b + c + d - 2)*(a + b + c + d) + 6:
solve(expr = 0, useassumptions, allsolutions) assuming nonnegative;
Unfortunately, I've been waiting for a long time, and I have no more time to wait; I have to interrupt the current session by hand. However, it appears that MMA can solve it within bearable time:
Did Maple miss something here?
First 230 231 232 233 234 235 236 Last Page 232 of 2427
