I have no idea what LaTeX, is other than a helpful tool for publishing. However, I'd like to start using it for several reasons, but don't know where to begin. Can anyone suggest a very first starting point for someone in my position ? v/r, Thanks,
I'm new to Maple. I'm quite competent with Matlab, with competent meaning I have some experience using it for analysis of physical data. I'm very experienced in using my TI-89 Titanium I have decided to give Maple a try since I'm not satisfied with the way Matlab handles symbolic expressions. I also want to tryif there's anything better than Matlab. I'm majoring in physics, and I hope to get my bachelor degree in a year. So far I have been writing all my assignments that needed a computer in Microsoft Word, but that is far from satisfactory. I have been considering learning myself LaTeX, but I have been thinking if it's just as good to use Maple to write articles and documents. Can I write an article as fast in Maple as I can in LaTeX? Speed is key for me naturally. Can I write LaTeX directly in Maple?
I am writing a program in which, after some calculations, I want to give the user some information and then ask them if they want the program to continue. I've tried using readline(terminal) and readstat, but I have the following problem: the information that I want the user to see is printed at the bottom of the screen and Maple gives a dialog box to get the user input. With the dialog box showing, the user can't scroll down to see the data. Is there a way to make sure that the data shows up before the dialog box pops up? Or is there another way to get input from a user?
I was wondering if I could change the values on the x-axes. I want to have the value 3500 at origo and 0 at "3500" normally is, can this be done?
On subscripts. I like to use them as part of variable names but Maple does this to me.
Lets say I have
Maple Equation
My question is about how Maple handles differentials.
In its derivation of an equation for pressure as a function of depth my physics text comes up with this:
Maple Equation
from which it gets
Maple Equation
How can I write with 2D math in text mode? That is, I want to create a document with mathematical expressions but I don't want Maple to do any mathematical operations on them. Imagine that you're trying to write a page in a textbook with expressions put in normal notation and interspersed with comments - that's what I'm trying to do. I've tried Text>Maple Input, Text>2D Input, Text>2D Math, Text>Normal, etc, etc but they all just put out 1D. And if I try to use "Math" instead it invariably does some sort of simplification or normalization or some such when I don't want it to touch the expressions I enter at all.
Hi, I have a question. I work with maple in a fairly unusual way. I use the vim editor and the command line interface (don't try to change this it won't help). Then I typeset my results using the latex mode. I am wondering of late if I can read my input into the graphical version of maple and control the formatted output produced by the gui. i.e. is there some analog of `latex/special_names`[x1] := `x_1` For the gui interface. I can't seem to find this documented anywhere. Thank you, Derek
Hi all I have a(x) and b(x), a(x) is only interesting from x=0..5 and b(x) from 5..10. How can I define those to into one c(x)? I guess I need the piecewise function, but I don't understand anything from the help file.. Can anyone please explain it to me, thanks.
i need to take a sphere and and graph a point going around the sphere. i have the code: restart: with(plots): with(plottools): x1:=(u,v)-> sin(u*Pi)*cos(v*Pi); y1:=(u,v)-> sin(u*Pi)*sin(v*Pi); z1:=(u,v)-> cos(u*Pi); x2:=(u,v)-> 3*sin(u*Pi)*cos(v*Pi); y2:=(u,v)-> 3*sin(u*Pi)*sin(v*Pi); z2:=(u,v)-> 3*cos(u*Pi); p1:=plot3d([x1(u,v), y1(u,v),z1(u,v)] ,u=0..1,v=0..2,color=blue, axes=normal): points:={seq([x1(k/50),y1(k/50),z1(k/50)], k=0..314 )}: display(p1); pointplot3d:(points); only i get the error Error, invalid input: x1 uses a 2nd argument, v, which is missing how do i put in arguments for u & v?
I had a new homework in maple but there is two questions that i have a hard time figuring them out. If somewone could help me it would be nice. 1. It says that E=L{v1,v2,v3,v4} (all vectors) where v1= (-5,3,2,0,1), v2=(0,-1,1,3,0), v3=(3,1,0,0,2) and v4=(1,4,4,2,0). Discribe E, which is a subset of R5 (and the teacher would like a description like this exemple: E={(x,y) ∈R2 ∣ 2x-3y=2} 2. A matrix: A := Matrix(5, 5, {(1, 1) = 1, (1, 2) = 0, (1, 3) = 0, (1, 4) = 0, (1, 5) = 0, (2, 1) = 0, (2, 2) = 4, (2, 3) = 0, (2, 4) = 0, (2, 5) = 0, (3, 1) = 0, (3, 2) = 0, (3, 3) = 52, (3, 4) = 0, (3, 5) = 0, (4, 1) = 0, (4, 2) = 0, (4, 3) = 0, (4, 4) = 7, (4, 5) = 0, (5, 1) = 0, (5, 2) = 0, (5, 3) = 0, (5, 4) = 0, (5, 5) = 3})
how do i expand [ln(1+x)]^2??? and find partial derivatives of functions
I'm generating fairly complex shapes and dumping the x,y,z coordinates of each point to a text file. The shapes have a high degree of spherical symmetry, so they usually look like a torus or ellipsoid. I've been using pointplot3d to plot the shapes using 'style=line'. The result is something that looks close enough to a wireframe plot. However, for my final thesis I will be submitting, I'd like to show the shapes opaquely (with hidden lines). Basically, the type of plot generated by: plot3d(sin(phi)^2, theta=0..2*Pi, phi=0..Pi,coords=spherical,style=wireframeopaque,color=black);
Hello everybody, does anyone know how to integrate the output of BsplineCurve in maple 8? I can plot it over a given interval, but if I try to perform the corresponding definite integral, I get the following error message: Error, (in int) wrong number (or type) of arguments as opposed to the output of the Spline routine, which can be integrated without problems. Thank you for your help.
Hi everybody, is there any Maple package to deal with algebraic curves? The problem I have to solve is the following: my thesis advisor gave me a polynomial equation in two variables, which I know it is a Riemann surface of genus 0. As far as I know, there is a theorem which says that this surface is birationally equivalent to an elliptic curve. There should be also an algorithm which receives the equation as input and outputs the rational parametrization of the Riemann surface. Moreover, this algorithm should be available in a Maple package (my advisor told me this... the problem is that he does not remember the name of the package, nor the function!!!).
First 2334 2335 2336 2337 2338 2339 2340 Last Page 2336 of 2469
