with(DEtools); with(LinearAlgebra)
diff(u(x, t), t) = [Matrix([[0, (1/2)*mu*k^2], [2*A^2-(1/2)*mu*k^2, 0]])]*u(x, t)
diff(u(x, t), t) = [Matrix(%id = 36893489823894642308)]*u(x, t)
"where u(x,t)=[u1 u2]^(T) is a vector. The solution of differential equation (1) is u=v*exp(w*t)."
where*w^2 = -(1/4)*mu^2*k^4+mu*k^2*A^2
"How can we solve differntial equation*(1) on Maple"?""
Download dsol.mw
Hello guys
Could someone help me create a simple palette to contain, for example, three functions that I use constantly?
           conve1(a), conve2(a) and conve3(a).
I tried through the help documentation, but I couldn't.
Sincerely,
Oliveira
hello. i write a for loop and i want to maple give me the answer like the below pic
thanks in advance
for oo to 2 do
    M[oo] := EI*(4*theta(oo) + 2*theta(oo + 1))/L;
I use Maple 2022 on a MacBook Pro. In most of the plots I create I use symbol=solidcircle and symbolsize=12.
Is there a way to make those (and perhaps oher) settings user default so I don't need them in every plot command?
Jose
After studying the plottools:-transform command, I intend to visualize the following regions with constrained parameters in
(plottools[transform](proc (u, v) options operator, arrow; [u^3-v^2, u^2-v^3] end proc))(plots[inequal](`or`(u^2+4*v^2 <= 4, `and`(u^2+v^2 < 4, 4*v >= (u+2)^2+2*v^2)), nolines))
(plottools[transform](proc (s, t) options operator, arrow; [s^2*sqrt(t)*cos(t), s^2*sin(t)] end proc))(plots[inequal](`and`(`and`(s >= 1, 5*s <= 5+t), t < 5), s = 1 .. 2, t = 0 .. 5))
But Mma gives
The first instance (with default settings) is the same, but as for the second instance, which graph is correct?
with(plottools):
transform((u, v) -> [u^3 - v^2, u^2 - v^3])(inequal(Or(u^2 + 4*v^2 <= 4, And(u^2 + v^2 < 4, (u + 2)^2 + 2*(v - 1)^2 <= 2)), nolines));
transform((s, t) -> [s^2*sqrt(t)*cos(t), s^2*sin(t)])(inequal(`and`(1 <= s, 5*s <= 5 + t, t < 5), s = 1 .. 2, t = 0 .. 5));
Download TransformedRegion.mws
I take the liberty to rephrase my previous question as I believe the title was not very clear and so maybe some power users did not look at it. I am making the transition from Mathcad towards Maple and get stuck solving the equation in the attached worksheet. In mathcad I would solve it like this:
How can I achieve results in Maple? I know it is a very powerful program but for me the learning curve is at this moment quite steep. Any help would be very much appreciated.
Multiple_input.mw
plot-problem.mw
I have done something but what?
I want to use maple notation for input and  output.
I have done something to mess this up.
How do I get rid of the typesetting messages?
L:=[["O",3.85090000,0.45160000,0.00120000],
["O",−2.59990000,1.40410000,−0.00180000],
["N",−1.57050000,−0.71710000,0.00010000],
["C",−0.20660000,−0.42310000,−0.00020000],
["C",0.22050000,0.90470000,0.00040000],
["C",0.72980000,−1.45700000,−0.00070000],
["C",1.58410000,1.19860000,0.00020000],
["C",2.09330000,−1.16290000,−0.00070000],
["C",2.52040000,0.16480000,−0.00030000],
["C",−2.64850000,0.17820000,0.00090000],
["C",−3.97350000,−0.54200000,0.00100000],
["H",−0.44360000,1.75770000,0.00120000],
["H",0.41130000,−2.49630000,−0.00100000],
["H",−1.80100000,−1.70860000,0.00010000],
["H",1.90530000,2.23700000,0.00090000],
["H",2.81800000,−1.97260000,−0.00080000],
["H",−4.06550000,−1.14630000,−0.90580000],
["H",−4.79040000,0.18440000,0.02880000],
["H",−4.04450000,−1.18860000,0.88020000],
["H",3.96500000,1.41760000,0.00170000]];
S:={{1,9},{1,20},{2,10},{3,4},{3,10},{3,14},{4,5},{4,6},
{5,7},{5,12},{6,8},{6,13},{7,9},{7,15},{8,9},{8,16},{10,11},
{11,17},{11,18},{11,19}}
Now I have list L above a Set S below
Now we delete from L all having "H" in first position and also  the subsets of the set S which as all contain those  list position number where L had "H"
Kind help with function which can
Takes input of the list and sets returns the new list and set where the above are done
First of all I would like to wish all of you a happy, prosperous but especially healthy 2023! I have again a beginner question. Why is test2 not working in the attached document?
Thank you so much for your assistance!
QuestionFDS.mw
I remember a section “Tell us what we can do better” at the bottom of online help pages. I used this whenever I came across a potential error worth investigating.
Has this section disappeared (I hope not) or do I have a browser issue?
with(geometry);
_EnvHorizontalName = 'x';
_EnvVerticalName = 'y';
Vdot := proc(U, V) local i; add(U[i]*V[i], i = 1 .. 2); end proc;
dist := proc(M, N) sqrt(Vdot(M - N, M - N)); end proc;
EQ := proc(M, N) local eq, a, b, c; eq := simplify(expand((y - M[2])/(x - M[1]) - (N[2] - M[2])/(N[1] - M[1]))*(x - P1[1])*(P2[1] - P1[1])); a := coeff(eq, x); b := coeff(eq, y); c := tcoeff(eq, [x, y]); RETURN(-a*x/c - b*y/c - 1); end proc;
R := 5;
ang := [2/3*Pi, -3*Pi*1/4, -Pi*1/6];
seq(point(`||`(P, i), [R*cos(ang[i]), R*sin(ang[i])]), i = 1 .. 3);
seq(dsegment(`||`(seg, i), [`||`(P, i), `||`(P, irem(i, 3) + 1)]), i = 1 .. 3);
circle(cir, [point(OO, [0, 0]), R]);
sol := solve(subs(x = 2, Equation(cir, [x, y])), y);
point(A, [2, sol[1]]);
triangle(Tri, [P1, P2, P3]);
incircle(inc, Tri, 'centername' = oo);
circle(Cr, [A, oo]);
sol := solve({Equation(Cr, [x, y]), Equation(inc, [x, y])}, {x, y});
point(H1, [subs(sol, x), subs(sol, y)]);
line(L, [A, oo]);
reflection(H2, H1, L);
line(L1, [A, H1]);
line(L2, [A, H2]);
Equation(cir, [x, y]);
Equation(L1, [x, y]);
sol := solve({Equation(L1, [x, y]), Equation(cir, [x, y])}, {x, y});
evalf(%);
point(M1, [subs(sol, x), subs(sol, y)]);
sol2 := solve({Equation(L2, [x, y]), Equation(cir, [x, y])}, {x, y});
evalf(%);
point(M2, [subs(sol2, x), subs(sol2, y)]);
triangle(TR, [M1, M2, A]);
display([draw([P1(symbol = solidcircle, symbolsize = 8, color = blue), P2(symbol = solidcircle, symbolsize = 8, color = blue), P3(symbol = solidcircle, symbolsize = 8, color = blue), A(symbol = solidcircle, symbolsize = 8, color = black), H1(symbol = solidcircle, symbolsize = 8, color = black), H2(symbol = solidcircle, symbolsize = 8, color = black), L1(color = black), L2(color = black), seg1(color = magenta), seg2(color = magenta), seg3(color = magenta), Cr(color = black), cir(color = magenta), inc(color = blue)]), textplot([seq([coordinates(`||`(P, i))[], convert(`||`(P, i), string)], i = 1 .. 3)], 'align' = {'above', 'left'})], view = [-6 .. 10, -15 .. 6], scaling = constrained, size = [800, 800], axes = none);
It seems that there is conusion between M1 and M2. How to write letters A, M1 ,M2, H1, H2 ? Thank you.
The range is wrong. For details, see below, please.
assume(x, RealRange(0, 1))
plot([sqrt(x*(2 - x)/3), 1 - sqrt((1 - x^2)/3)], legend = InertForm:-Display~([sqrt(x*(2 - x) %/ 3), 1 - sqrt((1 %- x^2) %/ 3)], 'inert' = false));
smartplot([sqrt(x*(2 - x)/3), 1 - sqrt((1 - x^2)/3)]);
smartplot([''piecewise'(And(0 <= x, x <= 1), sqrt(x*(2 - x)/3))', ''piecewise'(And(0 <= x, x <= 1), 1 - sqrt((1 - x^2)/3))']);
smartplot(['piecewise(And(0 <= x, x <= 1), sqrt(x*(2 - x)/3))', 'piecewise(And(0 <= x, x <= 1), 1 - sqrt((1 - x^2)/3))']);
smartplot([''piecewise''(And(0 <= x, x <= 1), sqrt(x*(2 - x)/3)), ''piecewise''(And(0 <= x, x <= 1), 1 - sqrt((1 - x^2)/3))]);
x := 'x'NULL
Download SmartPlots.mw
The help page claims that smartplot(..) will call 2-D plot procedures ultimately, but why is the smartplots command incompatible with the use of assume?
Good day everyone,
I have been having problems with a system of PDE solution using `numeric`.
It's giving me the error code "Error, (in pdsolve/numeric/par_hyp) input system is too far from a 'standard' form (see ?pdsolve,numeric for more detail)" and I have checked to the best of my ability for the error but could not see anything.
The code is attached below.
Please, anyone with useful information should help. Thanks
Numeric.mw
How do I find the solutions "left" and "right" with only answers in the range 0 to +1?
The domain of eq1 and eq2 is 0 <=beta <= 1.
So I'm only interested in left[1] and right[2]:
Here is the code:
eq[1]:=(1/6)*beta^3+(1/2)*xi^2*beta-(1/2)*beta^2-(1/2)*xi^2+(1/3)*beta = 0;
eq[2]:=(1/6)*beta*(beta^2+3*xi^2-6*xi+2) = 0;
left:=solve(eq[1],xi);
right:=solve(eq[2],xi);
left:=plot(left[1],beta=0..1,thickness=2,color=blue);
right:=plot(right[2],beta=0..1,thickness=2,color=blue);
How do I plot a volume of revolution? I can plot other volumes using Student[Calculus1]]:-VolumeOfRevolution, but not this one. I get a blank plot. I do get the correct volume from output=value..
How do I plot this using plot3d?
a := 0; b := 1;
f := (x) -> x^2+2;
g := (x) -> 1/2*x+1;
V := int(f(x)^2 - g(x)^2,x=a..b)*Pi;
Student[Calculus1]:-VolumeOfRevolution(f(x),g(x),x=a..b,output=value);
Student[Calculus1]:-VolumeOfRevolution(f(x),g(x),x=a..b,output=plot);
First 279 280 281 282 283 284 285 Last Page 281 of 2463
