I want to solve a system of 3 simple real linear odinary differential equations.
The solution using dsolve has some extra imaginary terms with very small (10^-10) coefficients.   How to I get just the real part of the solution.
Here is an example code:
v1 := 1;
v2 := 0.5;
k := 0.12;
p1 := 0.328;
p2 := 0.74;
l1 := 0.31;
l2 := 1.16;
sysode := diff(Cp(t), t) = -(p1 + p2 + k)*Cp(t) + l1*C1(t) + l2*C2(t), diff(C1(t), t) = (p1*Cp(t) - l1*C1(t))/v1, diff(C2(t), t) = (p2*Cp(t) - l2*C2(t))/v2;
ics := Cp(0) = 0.347, C1(0) = 0., C2(0) = 0.;
sol := convert(dsolve([sysode, ics]), float);
Hello everybody!! Can you please help me figure it out. I wrote the code, but for some reason I have an infinite loop going on, it counts normally to the cycle, as the cycle reaches, then everything is infinite
f:=unapply(2*x-4*cos(x)-0.6,x); #the equation itself
f1:=unapply(diff(f(x),x),x); #its derivative
a:=-0.5; b:=1.5; eps:=0.001: #interval and accuracy
phi:=unapply((4*cos(x)-0.6)/2,x); #solving the equation with respect to x
x[0]:=1; #I take any point from the interval
x[1]:=evalf(phi(x[0]));
L:=evalf(abs(phi(b)-phi(a))/abs(b-a));
L1:=evalf(abs(phi(x[1])-phi(x[0]))/abs(x[1]-x[0]));
psi:=unapply(abs(diff(phi(x),x)),x);
plot([psi(x),1],x=a..b,color=[red,green]);
n:=1:
while abs(evalf(x[n]-x[n-1])) > eps do
n:=n+1:
x[n]:=evalf(phi(x[n-1]));
od;
fsolve(f(x)=0,x=a..b);
I'm trying to solve a coupled inductor problem.  All I'm trying to do is solve for the currents (which I could do), then solve for resonance by setting the imaginary part of I1 to 0 and solving for omega.  I then want to plug this resonant frequency back into I1 and evaluate it for some component values and coupling coefficient.
The problem is that even though I define the various variables as real,  Maple doesn't seem to recognize them as such.  I suspect I've failed to define one of them, and that is why it is responding like it is, but I can't find it.
I'm also getting some weird behavior.....for example if I type :  wres0, I get the value I assigned to it --that's fine.  But then, when I type : wres0/(2*pi), I get an error, "Error, unable to parse 'mverbatim"   --- what does this mean?
This should be a pretty straight forward calculation on Maple, but at this point, I think I may be better off doing it by hand!  I appreciate any help you can provide.  Thank you.
reflected_load.mw
Hello :)
So what I was trying to find Galois group for quartic polynomials in a form f=x^+a_3*x^3+a_2*x^2+a_1*x+a_0, where 0<=a_i<=2 and a_0 <>0. I get polynomials and galois groups - that's not an issue. Lets say I specifically need polynomials with group D_4 so I run script
A := {seq(0 .. 2)};
A0 := A minus {0};
m := numelems(A)^3*(numelems(A) - 1);
a := Iterator:-CartesianProduct(A0, A $ 3);
s := seq(x^4 + add(v[i]*x^(i - 1), i = 1 .. 4), v = a);
for k to m do
if irreduc(s[k]) = 'true' then print(f[k] = s[k], galois(s[k])); end if end do;
This one gives all list of polynomalias and their galois group.
for k to m do
    if irreduc(s[k]) = 'true' then if galois(s[k]) = ("4T3", {"D(4)"}, "-", 8, {"(1 3)", "(1 2 3 4)"}) then print(f[k] = s[k], galois(s[k])); end if; end if;
This one gives me a list of D_4 specifically.
When 0<=a_i<=2 - there are not many polynomials so I cant count it by hand, but if I make a sequence larger there are too many polynomials to count them manually. So the question is how to count how many polynomials there are with a group D_4? Or lets say how do I count how many polynomials are in each group?
v2i2v_circuit.msim
I try to design a circuit to make a voltage-current-voltage translation. In my assumption, probe1.v is equal to probe2.v and it will generate a current(probe2.v / R4) through NMOS. The NMOS acts as a closed switch. Probe3.v is equal to CV3 and i can get "Probe4.v = CV1 + CV3". However, when the circuit operates, probe3.v isn't equal to CV3 and probe1.v isn't equal to probe2.v. I have tried to rise the differential input resistance and differential amplifier to make the Uin+ close to Uin- in op amp, but it doesn"t work effectively.
In addition, the closed resisitance of NMOS is also taken into consideration and i try to make it pretty below Kohm.
Could you help me fix the problem?
Please help me solve the following problem about complex numbers with Maple: w= (3+zi)/(2+z) whose geometric representation in the "oxy" plane is a straight line. Calculate module of z. Thank you so much.
I have a code (see below) for the following number sequence and want to produce a graph as well as the numerical data, please advise how to do it.
Sequence definition: Lexicographicaly least sequence of nonnegative integers commencing 1,3,5,7 such that any four  consecutive terms are mutually coprime.
The code I have so far is:
ina := proc (n) false end :
a := proc (n) option remember; local k;
if n < 5 then k := 2*n-1
else for k from 2 while ina(k) or igcd(k, a(n-1)) <> 1 or igcd(k, a(n-2)) <> 1 or igcd(k, a(n-3)) <> 1
do  od
fi; ina(k) := true; k
seq(a(n), n = 1 .. 100);
1, 3, 5, 7, 2, 9, 11, 13, 4, 15, 17, 19, 8, 21, 23, 25, 16, 27,
  29, 31, 10, 33, 37, 41, 14, 39, 43, 47, 20, 49, 51, 53, 22, 35,
  57, 59, 26, 55, 61, 63, 32, 65, 67, 69, 28, 71, 73, 45, 34, 77,
  79, 75, 38, 83, 89, 81, 40, 91, 97, 87, 44, 85, 101, 93, 46,
  95, 103, 99, 52, 107, 109, 105, 58, 113, 121, 111, 50, 119,
  127, 117, 62, 115, 131, 123, 56, 125, 137, 129, 64, 133, 139,
  135, 68, 143, 149, 141, 70, 151, 157, 153
I have tried listplot but for some reason cant get the correct format
Hope you can help
Best regards
David.
eqs.mw
km := 0.1784124116e-1/(6.8*e-9)
NULLNULL
kf := 3141.592654
3141.592654
up := 10
10
lw := 0.1e-1
0.1e-1
eq1 := C1*C2*C3*C4(C1*R2*R3*R4+C2*R1*R3*R4+C3*R1*R2*R4+C4*R1*R2*R3) = 84
eq2 := C1*C2*C3*C4(C1*C2*R3*R4+C1*C3*R2*R4+C1*C4*R2*R3+C2*C3*R1*R4+C2*C4*R1*R3+C3*C4*R1*R2) = 126
eq3 := C1*C2*C3*C4*(C1*C2*C3*R4+C1*C2*C4*R3+C1*C3*C4*R2+C2*C3*C4*R1) = 36
eq4 := -C1*C2*C3*C4*R1*R2*R3*R4*Rin+C1^2*C2^2*C3^2*C4^2 = 0
eq5 := C1*C2*C3*C4*(C1*C2*C3*R4+C1*C2*C4*R3+C1*C3*C4*R2+C2*C3*C4*R1)-Rin*C1^2*C2*C3*C4*R2*R3*R4-C1*C2^2*C3*C4*R1*R3*R4*Rin-C1*C2*C3^2*C4*R1*R2*R4*Rin-C1*C2*C3*C4^2*R1*R2*R3*Rin-C1*C2*C3*R1*R2*R3*R4-C1*C2*C4*R1*R2*R3*R4-C1*C3*C4*R1*R2*R3*R4-C2*C3*C4*R1*R2*R3*R4 = 0
eq6 := C1*C2*C3*C4*(C1*C2*R3*R4+C1*C3*R2*R4+C1*C4*R2*R3+C2*C3*R1*R4+C2*C4*R1*R3+C3*C4*R1*R2)-C1^2*C2^2*C3*C4*R3*R4*Rin-C1^2*C2*C3^2*C4*R2*R4*Rin-C1^2*C2*C3*C4^2*R2*R3*Rin-C1*C2^2*C3^2*C4*R1*R4*Rin-C1*C2^2*C3*C4^2*R1*R3*Rin-C1*C2*C3^2*C4^2*R1*R2*Rin-C1^2*C2*C3*R2*R3*R4-C1^2*C2*C4*R2*R3*R4-C1^2*C3*C4*R2*R3*R4-C1*C2^2*C3*R1*R3*R4-C1*C2^2*C4*R1*R3*R4-C1*C2*C3^2*R1*R2*R4-C1*C2*C4^2*R1*R2*R3-C1*C3^2*C4*R1*R2*R4-C1*C3*C4^2*R1*R2*R3-C2^2*C3*C4*R1*R3*R4-C2*C3^2*C4*R1*R2*R4-C2*C3*C4^2*R1*R2*R3 = 0
eq7 := C1*C2*C3*C4*(C1*R2*R3*R4+C2*R1*R3*R4+C3*R1*R2*R4+C4*R1*R2*R3)-C1^2*C2^2*C3^2*C4*R4*Rin-C1^2*C2^2*C3*C4^2*R3*Rin-C1^2*C2*C3^2*C4^2*R2*Rin-C1*C2^2*C3^2*C4^2*R1*Rin-C1^2*C2^2*C3*R3*R4-C1^2*C2^2*C4*R3*R4-C1^2*C2*C3^2*R2*R4-C1^2*C2*C4^2*R2*R3-C1^2*C3^2*C4*R2*R4-C1^2*C3*C4^2*R2*R3-C1*C2^2*C3^2*R1*R4-C1*C2^2*C4^2*R1*R3-C1*C3^2*C4^2*R1*R2-C2^2*C3^2*C4*R1*R4-C2^2*C3*C4^2*R1*R3-C2*C3^2*C4^2*R1*R2 = 0
eq8 := -C1^2*C2^2*C3^2*C4^2*Rin+C1*C2*C3*C4*R1*R2*R3*R4-C1^2*C2^2*C3^2*R4-C1^2*C2^2*C4^2*R3-C1^2*C3^2*C4^2*R2-C2^2*C3^2*C4^2*R1 = 0
eq9 := Rin = 1/9
Rin = 1/9
fsolve({eq1, eq2, eq3, eq4, eq5, eq6, eq7, eq8, eq9}, {C1, C2, C3, C4, R1, R2, R3, R4, Rin}, {C1 = lw .. up, C2 = lw .. up, C3 = lw .. up, C4 = lw .. up, R1 = lw .. up, R2 = lw .. up, R3 = lw .. up, R4 = lw .. up, Rin = lw .. up})
fsolve({Rin = 1/9, C1*C2*C3*C4(C1*R2*R3*R4+C2*R1*R3*R4+C3*R1*R2*R4+C4*R1*R2*R3) = 84, C1*C2*C3*C4(C1*C2*R3*R4+C1*C3*R2*R4+C1*C4*R2*R3+C2*C3*R1*R4+C2*C4*R1*R3+C3*C4*R1*R2) = 126, C1*C2*C3*C4*(C1*C2*C3*R4+C1*C2*C4*R3+C1*C3*C4*R2+C2*C3*C4*R1) = 36, C1*C2*C3*C4*(C1*C2*C3*R4+C1*C2*C4*R3+C1*C3*C4*R2+C2*C3*C4*R1)-Rin*C1^2*C2*C3*C4*R2*R3*R4-C1*C2^2*C3*C4*R1*R3*R4*Rin-C1*C2*C3^2*C4*R1*R2*R4*Rin-C1*C2*C3*C4^2*R1*R2*R3*Rin-C1*C2*C3*R1*R2*R3*R4-C1*C2*C4*R1*R2*R3*R4-C1*C3*C4*R1*R2*R3*R4-C2*C3*C4*R1*R2*R3*R4 = 0, C1*C2*C3*C4*(C1*R2*R3*R4+C2*R1*R3*R4+C3*R1*R2*R4+C4*R1*R2*R3)-C1^2*C2^2*C3^2*C4*R4*Rin-C1^2*C2^2*C3*C4^2*R3*Rin-C1^2*C2*C3^2*C4^2*R2*Rin-C1*C2^2*C3^2*C4^2*R1*Rin-C1^2*C2^2*C3*R3*R4-C1^2*C2^2*C4*R3*R4-C1^2*C2*C3^2*R2*R4-C1^2*C2*C4^2*R2*R3-C1^2*C3^2*C4*R2*R4-C1^2*C3*C4^2*R2*R3-C1*C2^2*C3^2*R1*R4-C1*C2^2*C4^2*R1*R3-C1*C3^2*C4^2*R1*R2-C2^2*C3^2*C4*R1*R4-C2^2*C3*C4^2*R1*R3-C2*C3^2*C4^2*R1*R2 = 0, C1*C2*C3*C4*(C1*C2*R3*R4+C1*C3*R2*R4+C1*C4*R2*R3+C2*C3*R1*R4+C2*C4*R1*R3+C3*C4*R1*R2)-C1^2*C2^2*C3*C4*R3*R4*Rin-C1^2*C2*C3^2*C4*R2*R4*Rin-C1^2*C2*C3*C4^2*R2*R3*Rin-C1*C2^2*C3^2*C4*R1*R4*Rin-C1*C2^2*C3*C4^2*R1*R3*Rin-C1*C2*C3^2*C4^2*R1*R2*Rin-C1^2*C2*C3*R2*R3*R4-C1^2*C2*C4*R2*R3*R4-C1^2*C3*C4*R2*R3*R4-C1*C2^2*C3*R1*R3*R4-C1*C2^2*C4*R1*R3*R4-C1*C2*C3^2*R1*R2*R4-C1*C2*C4^2*R1*R2*R3-C1*C3^2*C4*R1*R2*R4-C1*C3*C4^2*R1*R2*R3-C2^2*C3*C4*R1*R3*R4-C2*C3^2*C4*R1*R2*R4-C2*C3*C4^2*R1*R2*R3 = 0, -C1*C2*C3*C4*R1*R2*R3*R4*Rin+C1^2*C2^2*C3^2*C4^2 = 0, -C1^2*C2^2*C3^2*C4^2*Rin+C1*C2*C3*C4*R1*R2*R3*R4-C1^2*C2^2*C3^2*R4-C1^2*C2^2*C4^2*R3-C1^2*C3^2*C4^2*R2-C2^2*C3^2*C4^2*R1 = 0}, {C1, C2, C3, C4, R1, R2, R3, R4, Rin}, {C1 = 0.1e-1 .. 10, C2 = 0.1e-1 .. 10, C3 = 0.1e-1 .. 10, C4 = 0.1e-1 .. 10, R1 = 0.1e-1 .. 10, R2 = 0.1e-1 .. 10, R3 = 0.1e-1 .. 10, R4 = 0.1e-1 .. 10, Rin = 0.1e-1 .. 10})
Ra := Rin*km
0.1784124116e-1*Rin/(6.8*e-9)
(14)
Cb := C1*km/kf
0.5679043442e-5*C1/(6.8*e-9)
(15)
Download eqs.mw
#im tryin to solve 9 equation having 9 varibales but the fsolve doesnt solve for C1 to R4, what i am doing wrong??
I am working on a sequence: seq([seq([a[i,j],b[?]],i=1..3)], j=1..3)], it has in total 9 output of a such as a[1,1],a[2,1],a[3,1],a[1,2],a[2,2],a[3,2],a[1,3],a[2,3],a[3,3], yet I need to the output of b like b[1],b[2],b[3],b[4],b[5],b[6],b[7],b[8],b[9]. I have tried to put something like seq([seq([a[i,j],b[f]],i=1..3,f=1..9)] j=1..3)] but it does not work...
Could someone help me?
Greatly appreciated!
I have a power series, the genral term contains sign(sin(n)),
everything is well defined, but when I apply summation to the general term, i can not see sign(sin(n)), its dropped.. why
and how deduce the the limit to get the radius of convergence
Cauchy_criteria.mw
thank you for any help
I'm trying to solve a differential equation with boundary conditions using dsolve. However dsolve return nothing. Any help to understand what's happening?
Here's my code:
eq1:=diff(psi(s),s,s)=t*sin(psi(s))-r*cos(psi(s));
eq2:=diff(x(s),s)=cos(psi(s));
eq3:=diff(y(s),s)=sin(psi(s));
cond1:=x(0)=0;
cond2:=x(1)=d+1;
cond3:=y(0)=0;
cond4:=psi(0)=0;
cond5:=D(psi)(0)=0;
cond6:= y(1)=0;
dsolve({eq1,eq2,eq3,cond1,cond2,cond3,cond4,cond5,cond6});
I  compute the radius of convergence of power series using maple,
but the code does not give any result
radius_convergence_PSeries.mw
This worksheet animates part of the motion of the classic ladder sliding down a wall.
Please answer the two questions posed in the opening text.
Respondents will need to establish their own link to the DirectSearch package
Slide_Ladder.mw
Hi, I am very new in maple. I want to create a list of 54 quartic polynomials f=x^4 + a_3*x^3 + a_2*x^2 + a_1*x + a_0 with coefficients 0<=a_i<=2 and a_0 <> 0 .
f := x ->  x^4 + add(a[i]*x^i, i = 0 .. 3);
for m to 54 do
    pol[m] := f(x);
How do I incorporate conditions 0<=a_i<=2 and a_0 <> 0 into this cycle so I can get 54 different combinations of coefficients? Thank you.
u := (H(x, t, z)+sqrt(R))*exp(I*R*x);
                /              (1/2)\
                \H(x, t, z) + R     / exp(I R x)
I*(Diff(u, z))+Diff(u, `$`(x, 2))+Diff(u, `$`(t, 2))+(abs(u)*abs(u))*u-((abs(u)*abs(u))*abs(u)*abs(u))*u;
  / d  //              (1/2)\           \\
I |--- \\H(x, t, z) + R     / exp(I R x)/|
  \ dz                                   /
     / 2                                   \
     |d  //              (1/2)\           \|
   + |-- \\H(x, t, z) + R     / exp(I R x)/|
     / 2                                   \
     |d  //              (1/2)\           \|                  2
   + |-- \\H(x, t, z) + R     / exp(I R x)/| + (exp(-Im(R x)))
  |              (1/2)|  /              (1/2)\
  |H(x, t, z) + R     |  \H(x, t, z) + R     / exp(I R x) -
                                        4
                 4 |              (1/2)|  /              (1/2)\
  (exp(-Im(R x)))  |H(x, t, z) + R     |  \H(x, t, z) + R     /
  exp(I R x)
value(%);
  / d            \              / d  / d            \\
I |--- H(x, t, z)| exp(I R x) + |--- |--- H(x, t, z)|| exp(I R x)
  \ dz           /              \ dx \ dx           //
         / d            \
   + 2 I |--- H(x, t, z)| R exp(I R x)
         \ dx           /
     /              (1/2)\  2
   - \H(x, t, z) + R     / R  exp(I R x)
     / d  / d            \\                             2
   + |--- |--- H(x, t, z)|| exp(I R x) + (exp(-Im(R x)))
     \ dt \ dt           //
  |              (1/2)|  /              (1/2)\
                                        4
                 4 |              (1/2)|  /              (1/2)\
  exp(I R x)
simplify(%);
  / d            \              / d  / d            \\
  \ dz           /              \ dx \ dx           //
         / d            \                 2
   + 2 I |--- H(x, t, z)| R exp(I R x) - R  exp(I R x) H(x, t, z)
         \ dx           /
      (5/2)              / d  / d            \\
   - R      exp(I R x) + |--- |--- H(x, t, z)|| exp(I R x)
                         \ dt \ dt           //
                             |              (1/2)|
   + exp(-2 Im(R x) + I R x) |H(x, t, z) + R     |  H(x, t, z)
                             |              (1/2)|   (1/2)
   + exp(-2 Im(R x) + I R x) |H(x, t, z) + R     |  R
                                                  4
                             |              (1/2)|
   - exp(-4 Im(R x) + I R x) |H(x, t, z) + R     |  H(x, t, z)
                                                  4
                             |              (1/2)|   (1/2)
   - exp(-4 Im(R x) + I R x) |H(x, t, z) + R     |  R
collect(%, exp(I*R*x));
 /  (5/2)       / d            \      2
 |-R      + 2 I |--- H(x, t, z)| R - R  H(x, t, z)
 \              \ dx           /
        / d            \   / d  / d            \\
    + I |--- H(x, t, z)| + |--- |--- H(x, t, z)||
        \ dz           /   \ dx \ dx           //
      / d  / d            \\\
    + |--- |--- H(x, t, z)||| exp(I R x)
      \ dt \ dt           ///
                              |              (1/2)|
                              |              (1/2)|   (1/2)
                                                   4
                              |              (1/2)|
                                                   4
                              |              (1/2)|   (1/2)
First 322 323 324 325 326 327 328 Last Page 324 of 2427
