Hello. I have the PDE
u_t + u_xxx = 0
And the function u(x,0) = 2 / cosh2(x)
I want to plot it on the u(x,t) - x axes on 2D plane. And then make more plots as time passes in order to show that u(x,0) disperses.
Thanks for any help.
For making a Maple package, an mla file, I were always using a same 4 lines code in a Maple worksheet and it was fine, but in Maple 2022 I receive an error message instead with the same 4 lines of code. Here is a simple example. Let's say I have a directory on my computer "C:\Home\Maple projects\Test_package", inside this directory I have one file "main.mpl" and a folder called "Functions" with a single file "Test.mm". The content of these two files are in below.
main.mpl
# This is just to test savelib at Maple 2022
unprotect('testSavelin');
testSavelib := module()
	option package;
	description "This is just a test.";
	export ModuleCopy, ModuleApply, ModulePrint;
	export Test;
kernelopts( includepath = currentdir() ):
$include "Functions\\Test.mm"
end module;
protect('testSavelib');
Test.mm
Test := proc( x :: integer )
	description "prints a message saying what integer you have given to this function.";
	printf("You have inserted the integer %d.\n", x);
Now I open a Maple worksheet and do the followings.
kernelopts(includepath="C:\\Home\\Maple projects\\Test_package"):
read("C:\\Home\\Maple projects\\Test_package\\main.mpl");
LibraryTools:-Create("C:\\Home\\Maple projects\\Test_package\\test.mla");
savelib('testSavelib'," C:\\Home\\Maple projects\\Test_package\\test.mla ");
On previous versions of Maple the result would be a test.mla file with the testSavelib package in it. But in Maple 2022 I receive an error message instead, and the test.mla is an empty mla.
Error, could not open ` C:\Home\Maple projects\CAD project\test.mla \testSavelib.m` for writing
Here is a screenshot.
Maple is usually very fast, and I recently upgraded to 2022 edition.
However in the new version, I tried to solve this equation here.
solve(1 + 0.15 = (1 + r__x)^1.28858)
It took Maple 2022, 46 to 118 sec to come up with a solution to the above. I run Windows 11 latest version, have 32 GB of ram and dual NVME disks in my laptop.
Windows 11 uses almost a Gigabyte of memory do this calculation.
So what could be wrong? Is mserver not working proberly?
solve(9*log10(x + 1) = root[3](x), x);
How come maple can't solve this equation with the standard command?
And what can I do to find all the solutions?
EDIT: For some reason I can't repply.
@Kitonum , thanks for answer.
I suspect there may be more real solutions than the ones in your example, but if I change the range some of those in your example goes missing. Is that a bug?
Bonjour,
Comment transformer cette suite de résultat que renvoie Maple, en liste unique :
                               9
                               7
En une liste unique telle que :
L: = [
1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 2, 3, 1, 4,1, 11, 9, 7 ]
Merci
HELLO,
How to transform this result in one list :
                               9
                               7
In a simple list such that :
L: = [
Thank You
I want to extract the highest linear and non-linear terms in an equation without their coefficients
How I can do it?
For example in the following equation, the highest linear and nonlinear without coefficients are diff(u(T),T$3) and u(T)*diff(u(T),T), respectively.
w*a*diff(u(T),T)+a*u(T)*diff(u(T),T)-(b^2)*a*w*diff(u(T),T$3)=0
How can the Cartesian Product of sets be implemented recursively in Maple?
Let k be a positive integer and Si , i=1,...k be nonempty finite sets.
How can Mk:=S1 x S2 x ...x Sk be constructed with Maple by recursion?
Maple 2022:
It appears that one can use push_back() with an empty DEQueue(), but not push_front().
Since the queue is double-ended and empty, this doesn't make much sense to me. So should this be considered a "bug"?
See the attached
# This works
  A:=DEQueue();
  empty(A);
  push_back(A,2);
module DEQueue () local num, head, tail, storage, dsp; option object; end module
# But this results in an error!
  B:=DEQueue();
  empty(B);
  push_front(B,2);
Error, invalid return value from method moduledefinition: 'NULL'
Download DEQueue_Prob.mw
I have just started using the GR functions available in Maple and have struggled to implement locally flat coordinates whilst using an arbitrary metric. I would like Maple to know that the first partial of g_ is 0 but that the second may not be. This knowledge would help simplify down some of the bulky expressions for the Riemann tensor in terms of g_. Any suggestions would be great as I have very little background knowledge with the submodule.
For_mapleprimes.mw
g := 9.81;
with(DEtools);
odeplot(dsolve({diff(x(t), t, t) = 0, diff(y(t), t, t) = -g + y(t)^2, x(0) = 1, y(0) = 0, D(x)(0) = 0, D(y)(0) = 0}, numeric), numpoints = 1000);
Hi, do you know why this plot is ragged? and my second question do you know how to get a single function x(t) or y(t) from this numeric solution instead getting parametrization plot [x(t),y(t)]? Thanks in advance.
Hi Im not sure how to solve this issue, I am new to maple and can't figure out what is going wrong. Any help is very much appreciated.
I am trying to find the solution (\Psi) as approaches zero. However, after applying the limit the solution becomes zero. See the attached .mw file.limit.mw
A question by @Shameera  I was working on has disapeared meanwhile.
It was related to this previous thread 233822-How--To-Solve-This-Equation-By-Using but has not been displaced in it.
Did a regolaror do this or was it  @Shameera ?
Why do I get 2 wrong answers here?
I see that they are all false but the last answer is close enough for my purposes
  with(RealDomain)
"`f__1`(x):=6.-sqrt(-x^(2)+8*x+9.)" = proc (x) options operator, arrow, function_assign; 6.-RealDomain:-sqrt(-RealDomain:-`^`(x, 2)+8*x+9.) end procNULL
  l__ength := solve(10 = int(f__1(x), x = 0 .. l), l) = 8.855609656, -.4725737205, 6.810993084NULL
10 = int(f__1(x), x = 0 .. l__ength[1]) = 10 = 16.02268001"(->)"false
10 = int(f__1(x), x = 0 .. l__ength[2]) = 10 = -1.586294894"(->)"false``
10 = int(f__1(x), x = 0 .. l__ength[3]) = 10 = 10.00000001"(->)"false
Download Not_working.mw
I have a routine which returns a certain result. In the simplest case the result should be p[[1]].
The result is indeed p[[1]]. However, when I ask whether the result is equal to p[[1]], Maple says false.
Why does is not recognize these two things as being equal?
First 326 327 328 329 330 331 332 Last Page 328 of 2427
