Imagine you want to precisely refer to this help page
The only way I am aware of is typing the whole string
Task,building,spe……
that it can be pasted as Maple input (with a leading ?) or as search term in the help system.
Are there other methods (like creating a hyperlink by right click somewhere) to extract this information/string once you are in the help system on a specific page?
How do I write this out in maple?
Sketch the graph of y =x^2+7x+3/x^2 , locate all maximum and minimum values, intervals of increase and decrease, and inflection points.
How do I write this in maple?
Find the point on the parabola x + y 2 = 0 that is closest to the point (0, -3).
Graph the curve with equation y(y2 −1)(y − 2)= x(x −1)(x − 2)
At how many points does the curve have horizontal tangents?
Estimate the x-coordinates of these points.
Find the equations of the tangent lines at the points (0,1) and (0,2)
Find the exact x-coordinates of the points of these points.
Create even more fanciful curves by modifying the equation.
PLEASE WRITE STEP BY STEP IN MAPLE
How to get rid of the boundary
display(ellipse([0, 0], 2, 1, filled=true, color = red),size=[1000,500],axes=none);
or how to make the boundary the same color as the filled region?
I am trying to adapt the code with Direct Search 2 for my needs but do not quite understand the syntaxis :( . I have system with 8 first order but nonlinear odes and 20 parameters but for starters I fix most of them (to estimate time consumption for full calculations etc). The part of the code where it ``breaks'' looks as follows:
#argument
X0:=Vector([24, 36, 48, 60, 72, 84], datatype = float):
#value
Y0:=Vector([13.8e+9, 12.13333333e+9, 10.7e+9, 10.5e+9, 9.8e+9, 10.1e+9], datatype = float):
#so this is the data - time in X0 and corresponding observables (at that time instances) at Y0
par_sol:=dsolve(dsys, numeric, range=0..85,  parameters=[eta_L, L0]);
#parametric numerical solution with eta_L parameter of the model and L0 initial condition to fit
ffit2 := proc(etaLValue, L0Value, tValue) global old_eta, old_L0; local res;
if not [etaLValue, L0Value,tValue]::list(numeric) then
      return 'procname'(args); end if;
if old_eta<>etaLValue and old_L0<>L0Value then
      (old_eta,old_L0) := etaLValue,L0Value;
      par_sol('parameters'=[eta_L=etaLValue,L0=L0Value]);
   res:=rhs(par_sol(tValue)[4]); end proc;
# this is just adapted copy of your function
par_sol(parameters=[eta_L=0.004, L0=1.1e10]);
par_sol(84)[4];ffit2(0.004, 1.1e10, 84);
#their output coincide OK; same for another trio of parameters
DS2:=CodeTools:-Usage(
        DirectSearch:-DataFit(ffit2,X0,Y0,t,
                              [ eta_L=0.001 .. 0.1, L0=1.5e10 .. 1.7e10
#and here it breaks:
Warning, initial point [L0Value = .9, tValue = .9] does not satisfy the inequality constraints; trying to find a feasible initial point
Error, (in DirectSearch:-Search) cannot find feasible initial point; specify a new one
But tValue is a time variable - I integrate over it, it is not a parameter to fit - I evaluate ffit2 at it. So basically ffit2 return exactly the model value which need to be fited with data in Y0 at times specified in X0. I thought it is easier than the other problems I saw in examples with Direct Search 2 and still I can't get through syntax neither with it not with NonlinearFit of core Maple...
I would appreciate if you could point me what I am doing wrong. Just in case I also attach full version of the file.01test.mw
Thank you in advance!
Hello. I want to organize some parameter
F=fsolve(1+x^2=j).
If j=-5, for example, an empty value 'F=' will be returned. How can I write the expression
If F=(void), then action 1, else action 2 end if
The fact is that I just don't know how to write the result (void), that is, the result of 'F ='
I was wondering how one uses maple to solve for variables that comprise the limits of an integral?
X and R are between 0 and 1.
Any thoughts would be greatly appreciated, thanks in advance...!
Download Solvingforlimitsofintegrals.mw
When should i use ->  for a procedure definition and when not ?
In my post i do see examples of  procedures which are made on two different ways.
proc  ..end proc;
Still difficult to get a procedure on two ways
test:=x->x^2;
Typesetting:-mprintslash([(test := x -> x^2)],[x -> x^2])
test(2);
4
test:= proc()
local x,a;
a:= x^2;
end ;
Typesetting:-mprintslash([(test := proc () local x, a; a := x^2; end proc)],[
proc () local x, a; a := x^2; end proc])
test(2);
x^2
test(3);
x^2
As you can see with the standard proc definition i getlost with  calculating x^2
In the past I worked with mathcad where it was very easy to work with units. Now I try to switch to Maple but I am still struggling when I want to implement units. In the simple attached worksheet I try to multiply vector a in [m] with vector b in [cm]. I get an answer in [m] but I cannot convert the answer to another unit. Right clicking allows me to change the unit e.g. to mm but nothing happens in the worksheet. When I use convert, the units are expressed numerical in cm but the vector still shows m. My apologies in advance for this simple questions but I find no way to solve my issue.
CollabExample.mw
Anyone can help me to convert matlab codes to maple, pls, this is my code p
Who deleted my post - "How to factor out specific parts from expression"
Can i make a natural numberline what shows the enumber of primes at each of 1000 numbers
I have her
0-1000 : 168
1000 -2000: 135
2000-3000 : 127
3000- 4000: 120
4000 -5000 : 119
then a gap (jump)
10^7- 1000- 10^7  : 53
You can see that the "number of primes"  is fluctuating
Can i make a procedure what calculates the latest mersenne prime number ?
Problem is only that there is a theorem: there are arbitrary long series of divisible numbers on the numberline
There are gaps of length n - 1, where are no primenumbers  in positioned.
The idea is to get a idea of the distribution of primes to make a guess from where to start to find another one?
First 359 360 361 362 363 364 365 Last Page 361 of 2427
