the error in summation , How can this be corrected?
U[0] := x^2;
for k from 0 to 1 do U[k+1] := sum(U[s]*(diff(U[k-s], x)), s = 0 .. k) end do;
U[0]*(diff(U[0], x));
                              2 x
U[1];
simplified_MPH_to_RPM_to_engineering_units.mw
Good Morning,
I don't know why I have such difficulties with rotational units, esp the 2*pi conversions with radians and revolutions.
   We are often back solving from MPH of the vehicle back to RPM of the wheel (revolutions per minute [or seconds]) to Rad/sec for engineering units such as torque*RPM calcs for power - kW.
Almost everytime I try to use units to convert the units the worksheet will revert to "atomic" units.   I quote "atomic" as this is what I appears to be.:  See graphic (also simplifiied worksheet attached)
The unit length(radius) seems to be a factor that is not well documented.   It also seems the earlier rplies include extra work to use convert and possibly "symbolic = true") as an extra step per Acer in an earlier posting several years ago.
When running calcs the convert, or simplify (to cancel length units m and inches out) the cancelations and the unit combinations seem to work awkwardly in this particular area.
Let
f := beta/(2*sigma*GAMMA(1/beta))*exp(-(abs(x-mu)/sigma)^beta);
where mu::real, beta > 0, sigma > 0.
How can we obtain the expression of F?
F := int(f, x=-infinity..s)
Reverse problem (a priori simpler):
It's known that
F := 1/2+signum(x-mu)/(2*GAMMA(1/beta))*(GAMMA(1/beta)-GAMMA(1/beta, abs((x-mu)/sigma)^beta))
How can we check that diff(F, x)=f?
Even with the assumptions on beta, mu and sigma and additional assumptions x>0 or x<0, I can't verify that diff(F, x)=f.
Hello, dear members! I try to solve the 1-D Wave Equation with initial and boundary conditions. And I have a problem when I'm trying to find the coeffs of Fourier series, that they depend on initial conditions. This is my code for Maple:
with(PDETools);
# set the PDE, ic(initial conds) and bc (boundary conds)
pde := diff(u(x, t), t, t) = a^2*diff(u(x, t), x, x);
ic := u(x, 0) = 0, D[2](u)(x, 0) = psi(x);
bc := u(0, t) = 0, u(l, t) = 0;
psi := piecewise(0 <= x and x <= l/2, x, l/2 <= x and x <= l, l - x);
# using Fourier method for solving (I require use this methods)
res := pdsolve(pde, HINT = T(t)*X(x));
ode1 := op(1, op(1, op(2, res)));
ode2 := op(2, op(1, op(2, res)));
ode2 := subs(_c[1] = -lambda, ode2);
# solve 2 ODE
# equation rely X(x)
dsolve({ode2, X(0) = 0}, X(x));
sin(sqrt(lambda)*l) = 0;
solve(%, lambda, allsolutions);
lambda := (Pi*n/l)^2;
X := (x, n) -> sin(Pi*n*x/l);
# equation rely T(t)
ode1 := subs(_c[1] = -lambda, ode1);
dsolve({%, T(0) = 0}, T(t));
T := (t, n) -> C1[n]*sin(Pi*n*a*t/l);
# write the general solutions
Un := (x, t, n) -> T(t, n)*X(x, n);
# find the coeffs series
simplify(subs(t = 0, diff(u(x, t), t)) = psi);
((2/l)*l/(Pi*n*a)*int(psi*X(x, n), x = 0 .. l) assuming (x < l))
simplify(%) assuming n::posint;
combine(%);
C1[n] := factor(%)
But I got it:
How to find this C1 coefficient and solve this equation? Maple doesn't work now. This command does not give the result.
I attached mws files, so pdeLR_11.mw is another code for solving, but it is not working so((!
Maybe I use this command wrong, or step-function is not convenient for maple?
Any helpful advice would be very cool. I am grateful in advance!
https://drive.google.com/file/d/1VznAvxcpF3ME9MMBjfKKifsbrbOb9uSY/view?usp=sharing
https://drive.google.com/file/d/15D7BCRwHliYb2OseH81i81RjQP7NRFgS/view?usp=sharing
I know that the "rotate" can rotate image of a function, but we see that the coordinate axes don't change as much. For example:
with(plottools):
p:=plot(sin(x),x=0..2*Pi):
r := rotate(p, Pi/4):display(p, r)
Although someone seems to have asked a similar question a long time ago, it was far from what I needed.
https://www.mapleprimes.com/questions/97812-Flip-Plot-Exchange-X-And-Yaxes
What I want to do is rotate the axes and the image at the same time rather than just flip axes.  The schematic diagram is as follows.
How can the value of uu(.1, .1, .1)  as a number, and what is the error when drawing?
uu := proc (x, y, t) options operator, arrow; e^(.2*t)*(e^(-x)+e^(-y)) end proc;
evalf(uu(.1, .1, .1));
                              2.
                              0.08
                             e
plot3d(uu(x, y, .1), x = 1 .. 2, y = 1 .. 2);
Warning, expecting only range variables [x, y] in expression e^.2e-1*(e^(-x)+e^(-y)) to be plotted but found name e
I have a pair of vectors, one containing x values, and the other containing the corresponding y values.
I plot them using: plot(x_vector, y_vector)
If I have another pair of vectors, x2_vector and y2_vector.
How to I plot them on the same graph so that I can compare them?
Recently I have wanted to add some questions/answers to "Favourites" . I added some posts a few years ago. Now I can't figure out how do do it. A good example is this evenings question on setting up a library. How to install a library on Maple? - MaplePrimes
The answer has useful links. And this is a particular topic I tend to have difficulty with.
On a Windows machine, I want to install a library in Maple?
Could you please help me?
Thank you in advance.
Sincerely yours
Dear Collaboratory, as a former mathcad user I am trying to transfer slowly towards Maple. In the attached file I have a problem in solving the ODE numerical. I would appreciate it if someone would be willing to help me out. I tried to upload my maple file but I am not sure it is attached.
I am trying to integrate a function from -infinity to infinity.  When I enter the integrate command into Maple, I just get the command back.  Does anyone know how to properly code the command for an indefinite integral?
I have attached the relevant worksheet.Indefinite_Integral.mw
When converting a list which includes lists to a set, duplicate entries are dropped.
However converting a list with vectors to a set, no duplicate entries are dropped.
Any explanation to that behaviour?
a := {Vector(2, [1, 0]), Vector(2, [2, 0])}
{Vector[column](%id = 36893490347685388884), Vector[column](%id = 36893490347685389004)}
b := [Vector(2, [1, 0]), Vector(2, [2, 0]), Vector(2, [1, 0])]
[Vector[column](%id = 36893490347747359308), Vector[column](%id = 36893490347747359428), Vector[column](%id = 36893490347747359548)]
c := convert(b, set)
{Vector[column](%id = 36893490347747359308), Vector[column](%id = 36893490347747359428), Vector[column](%id = 36893490347747359548)}
d := [[1, 0], [2, 0], [1, 0]]``
e := convert(d, set)
{[1, 0], [2, 0]}
Download DuplicateEntries.mw
Please can you give me a hand with numerical solving and visualising the integral equation with stochastic term B(t), using quadrature method ?
I had a look at the "stochastic" package by Sasha Cyganowski
Look forward to your help.
nada
I need help on maple code for solving both linear and non linear boudary condition for fractional order partial differential equation
I don't understand the number of solutions of my trigonometric equation if i work with solve command ( see maple file)
Ideas ?
TrigoSolve.mw
First 400 401 402 403 404 405 406 Last Page 402 of 2458
