hello I would like to ask how to implement phase singularities using wavelets in maple.
https://pdfs.semanticscholar.org/03cf/d388491c4fc7bc41c5f99a284feb7b2c34f1.pdf
http://mmlab.ie.cuhk.edu.hk/archive/2009/pami09_theory.pdf
Good day all.
If I generate a list containing (say) 100 elements or more, and each element is an ordered pair - is it possible to assign a letter to each element? The first 26 elements will have equal A to Z, the next 26 will take A1 to Z1, and so on.
For example if the list is [ [5,3], [2,5], ..., [3,1]], how do I construct it to become [A=[5,3], B=[2,5], ..., V3=[3,1]]?
Please see attached.
Thank's a lot for your time.
MaplePrimes_Label_Lists.mw
I'm new to the Maple software, and have been having difficulty figuring out how to plot a 3-D figure for given xyz values. Could anyone provide any guidance on this? I've attached the relevant document to provide the specific values in case that would be helpful.
Best,
Shane
Download Shane_Kreller_M6_Maple_Assignment.mw
What am I doing wrong? Seems like some unit compatibility problem when tryaing to solve simple task with momentum conservation rule...
with(Units);
Automatically loading the Units[Simple] subpackage
m__2 := 0.400*Unit('kg');
m__1 := 0.300*Unit('kg');
x__w := 0.700*Unit('m');
v__2p := 0.000;
v__1p := 2*Unit(('m')/('s'));
Download zadanie_z_jednostakim_-_problem.mw
m__1*v__1p + m__2*v__2p = m__1*v__1k + m__2*v__2k;
                                               /s\
             0.6 = (0.3 v__1k + 0.4 v__2k) Unit|-|
                                               \m/
subs(v__2p = 0, 0.600 = (0.300*v__1k + 0.400*v__2k)*Units[Unit](s/m));
                                               /s\
                                               \m/
v__1k := solve(0.600 = (0.300*v__1k + 0.400*v__2k)*Units[Unit](s/m), v__1k);
                                                  /m\
           v__1k := (-1.333333333 v__2k + 2.) Unit|-|
                                                  \s/
1/2*m__1*v__1p^2 + 1/2*m__2*v__2p^2 = 1/2*m__1*v__1k^2 + 1/2*m__1*v__2k^2;
Error, (in Units:-Simple:-+) the following expressions imply incompatible dimensions: {.1500000000*(-1.333333333*v__2k+2.)^2*Units:-Unit(J)+.1500000000*Units:-Unit(kg)*v__2k^2}
Sitting and trying find solution in help and on forum but no chance.
I hope if someone copy code into maple it will look lik on my screen. Anyway I have uploaded file and below You have screen picture.
If I remove units from variables on the top all is working like a charm.
Please help me find an error guys.
Reagrds
Marcin
I'm a student in calculus II.
What is name of the integration technique that Maple is using in the first step? This is a problem without a walkthrough in my textbook and while I got the same answer using integration by parts my solution looks different until the end because I didn't change the variables.
Corey
Good day.
I am wrestling a simple network (maze-type) problem and I hope someone can assist.
Given a standard x-y framework with several nodes whose locations are known, I would like to visit each node by starting from the origin, (0,0), and returning to that same point, A. (see attached)
However, I am permitted only to move horizontally and vertically within the maze.
Given that restriction, is there a routine that allows me to visit all locations, B, C, D, and E, such that the rectilinear distance is a minimum?
If there is a solution to this problem, can the distance also be given and order of visits specified?
Thanks for reading!
MaplePrimes_Path.mw
I have created a simple piecewise function to represent the radius r(x) of a circular cylinder of length 2a and radius b with ellipsoidal end caps of length e << a and e << b to get a smooth transition of r(x) at the two ends for use in slender body theory. The piecewise function does not behave as I had expected, and this is the first time that I have used a piecewise function. What am I doing wrong? The attached (I hope) Maple worksheet shows both my expected behavior and the actual behaviort. Any help will be greatly appreciated. Thanks.
Neill Smith
Piecewise_Cylinder_Geom.mw
how to draw these 3 lines and then project them on the plans Oxy,Oxz,Oyz;
3 given lines a := [3*t-7, -2*t+4, 3*t+4]; b := [m+1, 2*m-9, -m-12];c:={x = -200/29-2*t, y = 114/29+3*t, z = 119/29+4*t}, how to show these lines and the projections on the 3 planes ? Thank you.
I solve a system of equations, and am having difficulty 1) understanding what I"m seeing, 2) using the results.
Download substitution_help.mw
At (21), I get the solution to the system of equations.  I then want to use substitute a value for xC1 that supports the solution, and plug it into the other variables that are solved in terms of it.  However, I can't figure out how to do this.  I keep getting errors like:
Error, invalid input: eval expects its 2nd argument, eqns, to be of type {integer, equation, set(equation)}, but received {Rsrc = .9640102828*xC1^2+0.2570694087e-2*(140625.*xC1^4-151321.*xC1^2)^(1/2), xC2 = -0.1333333333e-2*(281250.*xC1^3+750.*xC1*(140625.*xC1^4-151321.*xC1^2)^(1/2)+51018750.*xC1^2+136050.*(140625.*xC1^4-151321.*xC1^2)^(1/2)-151321.*xC1)/(375.*xC1^2+(140625.*xC1^4-151321.*xC1^2)^(1/2)), xC1 <= -363.3194071}
please see attached file.
I assume I'm getting 2 solutions.  I'm picking the first one and trying to then solve for the other variables once I pick a value for xC1.
Thank you,
I have a complex transfer function.  I've defined everyting as "real" via:
assum := Rsrc::real, C1::real, Lp::real, C2::real, f::real, RL::real, 0 < Rsrc, 0 < C1, 0 < Lp, 0 < C2, 0 < RL, 0 < f
I'm expecting simplify to reduce the following transfer function so that the denominator is real, but I can't get it to do it:
I have every variable defined as real, so I am not sure why it won't simplify this expression.
Dear Users! Hope everything fine here. For any vales of M and N I generated the system of equation.
for j from 2 while j <= N do
for i while i <= M do
omega[2]*(2-b[1])*u[i, j]+(2*b[1]*omega[2]-b[2]*omega[2]-omega[2]+1)*u[i, j-1]-omega[2]*(sum((b[l+2]-2*b[l+1]+b[l])*u[i, j-l-1], l = 1 .. j-2))
end do end do
But I want to convert it into matrix for example if N = 3 and M = 4, I need the following form
I am waiting for your response.
Hello everyone !,
I would like to generate two random complex vectors (x1 and x2) several time and I want to check how these two vectors (j iteration) close to their previous values (j-1 iteration): abs (x1(j)-x1(j-1)) < 10^-4 and abs (x2(j)-x2(j-1)) < 10^-4. Therefore, I want that my program stop when this criteria is satisfied for x1 and x2 simultaneously.
I know how to check that for one element of the vector but not all the elements of the vector.
code:
Comp.vect.mw
I see that from Maple 2018 there is a command to compute the so called Radial Basis Function Interpolation:
https://www.maplesoft.com/support/help/Maple/view.aspx?path=Interpolation%2FRadialBasisFunctionInterpolation
I am trying to implement that code in Maple 2015, but it returns the error
Error, (in h) bad index into Vector
Displaying the vectors computed with the procedure, they seem correct, but the function that I want to return seems to fail (it is a summatory).
Attached the maple file
RBF_Interpolation.mw
I will appreciate any suggestion. Many thanks in advance for your comments!
BR,
GGM
 How to insert legends in the surfdata?
plots:-surfdata({Mat1}, ll1 .. ul1, ll2 .. ul2, dimension = 2, colorscheme = ["Blue", "Green", "Yellow", "Red"], axes = boxed, axesfont = [TIMES, BOLD, 16], axis = [thickness = 2], labelfont = [TIMES, BOLD, 16], labels = ["R", "Ma"])
Now I have a Matrix say
Now I have another matrix say
Now my second matrix has to be appended below the previous matrix the number of coulmns will the same in each case.
Again if create a new matrix I will ask it to append below the already appended new matrix and so on
and lastly I want to export the matrix to excel.
If someone can help your work will be 100% acknowledged
I alpologize for any inconvince caused kind help
First 417 418 419 420 421 422 423 Last Page 419 of 2458
