I am trying to solve a surface integral but I am not able to get Maple to give me an actual value.  Please can you help?
This is what I wrote:
with(Student[VectorCalculus]):
with(Student[MultivariateCalculus]):
x:=u; y:=v; z:=(2*u*v)/(4*v-3*u);
r:=<x,y,z>;
ru:=diff(r,u);
rv:=diff(r,v)
n:=simplify(CrossProduct(ru,rv));
f:=(x,y,z)->x^2*y+3*x*z-2*y^2;
simplify(Int(f(x,y,z)*Norm(n),u=1..2,v=1..4));
int(f(x,y,z)*Norm(n),u=1..2,v=1..4, numeric=true);
Hi, everyone!
I'm trying to do some computations with (truncated) multivariable power series, which I'd like to put into Hironaka standard basis form.  This is almost the same as a Groebner basis, except that the "leading" terms have smallest degree instead of largest.  This requires slight changes to the algorithms in order to make sure they terminate.  Does anyone know if this has been implemented in Maple or have a good way to fake it?  Here's what I've thought of:
  • Using the Groebner package with grlex_min instead of grlex.  The documentation warns that this may not terminate, and sure enough, it doesn't.  (At least not before my computer runs out of memory.)
  • Replacing the truncated power series with their palindromes, using the Groebner package, and then switching back, making sure all the degrees are correctly accounted for.  This should work, but it's going to be a major pain.
  • Reimplementing the Groebner routines.  I'd really rather not, but I'd love to know if anyone else has.
Anybody have any other ideas or suggestions?
----Josh
Dear community,
I am new to maple and was trying to get a solution for simple Hagen Poiseuille Flow. Hagen Poiseuille Flow  has governing equation as :
ode2 := -v+mu((diff(r*(diff(ur), r)), r))/r) = 0
here 'v' is a constant (pressure gradient) and the equation is in cylindrical coordinates
the problem has two boundary conditions as u(R) = 0 and u(0) = 'finite'.
I am struck at the second condition as there seems to be no option to say maple that the solution should be finite at a point.
Can anyone help me in this regard?
Alternatively, I can give second boundary condition as (D(u))(0) = 0. However, this gives a solution as follows:
dsolve({ode2, u(R) = 0, (D(u))(0) = 0}, u(r)):
u(r) = (1/4)*RootOf(-mu(_Z)+v)*r^2-(1/4)*RootOf(-mu(_Z)+v)*R^2
This doesn't look very easy, and I don't know what to do with this.
The solution for the above differential equation is simple and can be obtained on paper. Please help.
Hello. I am trying to solve this system of equations but I can't get Maple to show all solutions.
I have solve the system by hand and there are two more solutions (x=x, y=1) and (x=x, y=-1).
Thanks for any help !
For example, the line:
> for x from 1 by 0.2 to 2 do print (fsolve (x*y = 1)) end do;
returns a list of 6 values of y. Is there any way of transferring this list into a spreadshhet program, such as SigmaPlot or Excel, as a column other than cutting-and-pasting? A simple cut-and-paste (I've tried) leaves empty cells in-between entries. An alternative is to right-click with the mouse and choose "Conversions" => "Make into List" or "Make into Set", which results in:
> R1 := {.8333333333, .5555555556, .6250000000, 1., .7142857143, .5000000000};
> R0 := [1., .8333333333, .7142857143, .6250000000, .5555555556, .5000000000];
These can be saved into a text file that can be opened in Excel and only needs to be transposed (the results are pasted as a row). Although the solution above would be fine for a small number of values, it would be cumbersome for a larger number of values.
I was looking for a way to make maple assign an individual name to a list of values or equations. Say, for example, that you solve an equation with two solutions, and would like to make Maple assign the first solution to a name "A" and the second solution to a name "B" automatically. This would optimize a document I'm working on significantly.
Kind Regards
Hi, could someone tell me what this comma inside the arctan means?
Screenshot: https://photos.app.goo.gl/ZHyfdqcxWDgvgMZL7
i want to compute and draw  lattice points from a given lattice basis.
for example 2d cartesian coordinate system;
thank
How to display combinations without repetition of a set ( order does not matter)
CAP13Combinatoire.mw
My points are all numerical values. Why gives me such error?
Download temp.mw
I need to represent the contourplot of sum a function as
contourplot(sum(BesselJ(n,r),n=0..5),r=-10..10).
can anyone know what the problem is ?
Hello Maple experts;
We've talked about this subject before. odetest not verifying dsolve output. And very useful input was given:
https://www.mapleprimes.com/questions/227546-How-To-Make-Odetest-Verify-Dsolve
https://www.mapleprimes.com/questions/227638-How-To-Make-Odetest-Give-Zero-On-Its
Here, I thought to give a collection from my ode database of ode's that are solved by Maple, but odetest does not give zero, all in one place.
I know this is a hard problem to get odetest to always verify its own solution. May be each case needs custom solution?
It would be nice if this area in Maple could be improved on more if possible (Maple is already a CAS leader in solving ODE's).
If some of the experts here like to see if they can get odetest to give zero on some of these examples, they are welcome to and will be useful to see. I only tried just simplify().
I depend on odetest to tell me if my solution is correct or not, and getting false negative makes me spend more time trying to find where my error in my solution, where there might be no error there, and it is just that odetest could not verify it.
These are all from different text books. I put the reference on each ODE where it was obtained from.
Two of these ODE can also hang or take very long time. I indicated that there so one might want to skip these two.
edit added new one, #1822, uploaded new worksheet
`Standard Worksheet Interface, Maple 2020.2, Windows 10, November 11 2020 Build ID 1502365`
Physics:-Version()
`The "Physics Updates" version in the MapleCloud is 884 and is the same as the version installed in this computer, created 2020, November 25, 16:49 hours Pacific Time.`
#796
#Book: Elementary differential equations with boundary value problems. William F. Trench. Brooks/Cole 2001
#Section: Section 1.2 Page 14
#Problem number: 9.
ode:=diff(y(x),x) = abs(y(x))+1;
sol:=dsolve(ode,y(x));
odetest(sol[1],ode):
simplify(%);
diff(y(x), x) = abs(y(x))+1
y(x) = -exp(-x)/_C1+1, y(x) = exp(x)*_C1-1
(-abs((-exp(-x)+_C1)/_C1)*_C1+exp(-x)-_C1)/_C1
#878
#Section: Section 2.3 Page 55
#Problem number: 10.
ode:=diff(y(x),x) = x*(y(x)^2-1)^(2/3);
odetest(sol,ode):
simplify(%);
diff(y(x), x) = x*(y(x)^2-1)^(2/3)
(1/2)*x^2-(-signum(y(x)^2-1))^(2/3)*y(x)*hypergeom([1/2, 2/3], [3/2], y(x)^2)/signum(y(x)^2-1)^(2/3)+_C1 = 0
-x*(4*y(x)^2*(y(x)^2-1)^(2/3)*signum(y(x)^2-1)^(1/3)*hypergeom([3/2, 5/3], [5/2], y(x)^2)+9*(y(x)^2-1)^(2/3)*signum(y(x)^2-1)^(1/3)*hypergeom([1/2, 2/3], [3/2], y(x)^2)+9*(-signum(y(x)^2-1))^(1/3))
#903
#Section: Section 2.4 Page 57
#Problem number: 13.
ode:=diff(y(x),x)-y(x) = x*y(x)^(1/2);
ic:=y(0)=4;
sol:=dsolve([ode,ic],y(x));
odetest(sol,ode):
simplify(%);
diff(y(x), x)-y(x) = x*y(x)^(1/2)
y(0) = 4
y(x) = 16*(exp((1/2)*x))^2-8*x*exp((1/2)*x)+x^2-16*exp((1/2)*x)+4*x+4
-x*(((-8*x-16)*exp((1/2)*x)+x^2+4*x+16*exp(x)+4)^(1/2)-4*exp((1/2)*x)+x+2)
#1330
#Book: Differential equations and their applications, 3rd ed., M. Braun
#Section: Section 1.10. Page 80
#Problem number: 5.
ode:=diff(y(t),t) = 1+y(t)+y(t)^2*cos(t);
sol:=dsolve(ode,y(t)):
timelimit(60,odetest(sol,ode)); #WARNING, will either hang or take long time then timeout
diff(y(t), t) = 1+y(t)+y(t)^2*cos(t)
#1498
#Book: Differential Gleichungen, Kamke, 3rd ed
#Section: section 1.0
#Problem number: 25.
ode:=diff(y(x),x) = c*x^(-1+v)+b*x^(2*v)-a*y(x)^2;
sol:=dsolve(ode,y(x)):
odetest(sol,ode): #output too long to post
diff(y(x), x) = c*x^(-1+v)+b*x^(2*v)-a*y(x)^2
#1822
#Book: Advanced Mathematica, Book2, Perkin and Perkin, 1992
#Section: Chapter 11.3, page 316
ode:=x*y(x)*diff(y(x),x) = (y(x)^2-9)^(1/2);
ic:=y(exp(4)) = 5;
odetest(sol,[ode,ic]);
#needs:
odetest(sol,[ode,ic]) assuming x>1
x*y(x)*(diff(y(x), x)) = (y(x)^2-9)^(1/2)
y(exp(4)) = 5
y(x) = (9+ln(x)^2)^(1/2)
[-ln(x)*(csgn(ln(x))-1), 0]
[0, 0]
#1966
#Book: Differential equations for engineers by Wei-Chau XIE, Cambridge Press 2010
#Section: Chapter 2
#Problem number: 92.
ode:=2*x*diff(y(x),x)-y(x) = ln(diff(y(x),x));
simplify(%);
odetest(sol[2],ode);
simplify(%);
2*x*(diff(y(x), x))-y(x) = ln(diff(y(x), x))
y(x) = 1+(4*_C1*x+1)^(1/2)-ln((1/2)*(1+(4*_C1*x+1)^(1/2))/x), y(x) = 1-(4*_C1*x+1)^(1/2)-ln(-(1/2)*(-1+(4*_C1*x+1)^(1/2))/x)
-ln(2)+ln((1+(4*_C1*x+1)^(1/2))/x)-ln((2*x*_C1+(4*_C1*x+1)^(1/2)+1)/(x*(1+(4*_C1*x+1)^(1/2))))
-ln(2)+ln(-(-1+(4*_C1*x+1)^(1/2))/x)-ln((-2*x*_C1+(4*_C1*x+1)^(1/2)-1)/(x*(-1+(4*_C1*x+1)^(1/2))))
-ln(2)+ln((-(4*_C1*x+1)^(1/2)+1)/x)-ln((-2*x*_C1+(4*_C1*x+1)^(1/2)-1)/(x*(-1+(4*_C1*x+1)^(1/2))))
#2031
#Book: Ordinary differential equations and their solutions. By George Moseley Murphy. 1960
#Section: Various 3
#Problem number: 57.
ode:=diff(y(x),x) = a*x^(n-1)+b*x^(2*n)+c*y(x)^2;
odetest(sol,ode):
simplify(%)
diff(y(x), x) = a*x^(n-1)+b*x^(2*n)+c*y(x)^2
(1/2)*(-20*(I*a*c*(n+6/5)*b^(3/2)+(1/5)*b*a*(2*x^(n+1)*b+a)*c^(3/2)+(6/5)*(n+4/3)*(I*b^(5/2)*x^(n+1)*c-b^2*c^(1/2)*(n+1)))*(n+1)*WhittakerW(-(I*c^(1/2)*a+(-2*n-2)*b^(1/2))/(b^(1/2)*(2*n+2)), 1/(2*n+2), (2*I)*b^(1/2)*c^(1/2)*x^(n+1)/(n+1))+WhittakerW(-I*c^(1/2)*a/(b^(1/2)*(2*n+2)), 1/(2*n+2), (2*I)*b^(1/2)*c^(1/2)*x^(n+1)/(n+1))*(-(7*I)*a*c*(n^2+(16/7)*n+8/7)*b^(3/2)-5*a^2*b*(n+6/5)*c^(3/2)+3*b^2*(2+n)*(n+4/3)*n*c^(1/2)+I*c^2*a^3*b^(1/2)))*_C1/(c^(3/2)*b^(3/2)*(I*c^(1/2)*a+(-3*n-4)*b^(1/2))*x^2*(WhittakerW(-I*c^(1/2)*a/(b^(1/2)*(2*n+2)), 1/(2*n+2), (2*I)*b^(1/2)*c^(1/2)*x^(n+1)/(n+1))*_C1+WhittakerM(-I*c^(1/2)*a/(b^(1/2)*(2*n+2)), 1/(2*n+2), (2*I)*b^(1/2)*c^(1/2)*x^(n+1)/(n+1))))
#2372
#Section: Various 14
#Problem number: 407
ode:=diff(y(x),x)*(x^3+1)^(2/3)+(1+y(x)^3)^(2/3) = 0;
odetest(sol,ode):
simplify(%)
(diff(y(x), x))*(x^3+1)^(2/3)+(1+y(x)^3)^(2/3) = 0
-9*((4/9)*(1+y(x)^3)^(2/3)*Pi*3^(1/2)*LegendreP(-1/3, -1/3, (-y(x)^3+1)/(1+y(x)^3))*(-x^3)^(1/6)+(-(4/9)*(1+y(x)^3)^(1/3)*Pi*3^(1/2)*(x^3+1)^(1/3)*LegendreP(-1/3, -1/3, (-x^3+1)/(x^3+1))+GAMMA(2/3)*(-x^3)^(1/6)*((-y(x)^6-y(x)^3)*hypergeom([4/3, 5/3], [7/3], -y(x)^3)+x^3*(1+y(x)^3)^(1/3)*hypergeom([4/3, 5/3], [7/3], -x^3)*(x^3+1)^(2/3)))*(-y(x)^3)^(1/6))/((-x^3)^(1/6)*(9*hypergeom([4/3, 5/3], [7/3], -y(x)^3)*y(x)^3*(-y(x)^3)^(1/6)*(1+y(x)^3)^(1/3)*GAMMA(2/3)-4*Pi*3^(1/2)*LegendreP(-1/3, -1/3, (-y(x)^3+1)/(1+y(x)^3))))
#3035
#Section: Various 37
#Problem number: 1118.
ode:=(diff(y(x),x)^2+1)^(1/2)+a*diff(y(x),x) = x;
sol:=[dsolve(ode,y(x))]:
simplify(%);
odetest(sol[2],ode):
simplify(%)
((diff(y(x), x))^2+1)^(1/2)+a*(diff(y(x), x)) = x
((a^2+x^2-1)^(1/2)*(a^2-1)*((a^4+(x^2-1)*a^2+2*a*x*(a^2+x^2-1)^(1/2)+x^2)/(a^2-1)^2)^(1/2)+a^3+a*x^2+x*(a^2+x^2-1)^(1/2)-a)/((a^2+x^2-1)^(1/2)*(a^2-1))
-((-a^2+1)*(a^2+x^2-1)^(1/2)*((a^4+(x^2-1)*a^2-2*a*x*(a^2+x^2-1)^(1/2)+x^2)/(a^2-1)^2)^(1/2)+a^3+a*x^2-x*(a^2+x^2-1)^(1/2)-a)/((a^2+x^2-1)^(1/2)*(a^2-1))
#3036
#Problem number: 1119.
ode:=(diff(y(x),x)^2+1)^(1/2)+a*diff(y(x),x) = y(x);
sol:=[dsolve(ode,y(x))];
simplify(%);
simplify(%)
((diff(y(x), x))^2+1)^(1/2)+a*(diff(y(x), x)) = y(x)
[x-Intat(-(a-1)*(a+1)/(-a*_a+(_a^2+a^2-1)^(1/2)), _a = y(x))-_C1 = 0, x-Intat((a-1)*(a+1)/(a*_a+(_a^2+a^2-1)^(1/2)), _a = y(x))-_C1 = 0]
(((y(x)^2*a^2+a^4-2*y(x)*(y(x)^2+a^2-1)^(1/2)*a+y(x)^2-a^2)/(a^2-1)^2)^(1/2)*a^2-(y(x)^2+a^2-1)^(1/2)*a+y(x)-((y(x)^2*a^2+a^4-2*y(x)*(y(x)^2+a^2-1)^(1/2)*a+y(x)^2-a^2)/(a^2-1)^2)^(1/2))/(a^2-1)
(((y(x)^2*a^2+a^4+2*y(x)*(y(x)^2+a^2-1)^(1/2)*a+y(x)^2-a^2)/(a^2-1)^2)^(1/2)*a^2+(y(x)^2+a^2-1)^(1/2)*a-((y(x)^2*a^2+a^4+2*y(x)*(y(x)^2+a^2-1)^(1/2)*a+y(x)^2-a^2)/(a^2-1)^2)^(1/2)+y(x))/(a^2-1)
#3040
#Problem number: 1126.
ode:=a*x*(diff(y(x),x)^2+1)^(1/2)+x*diff(y(x),x)-y(x) = 0;
odetest(sol[1],ode): #too large to display
odetest(sol[2],ode): #too large to display
a*x*((diff(y(x), x))^2+1)^(1/2)+x*(diff(y(x), x))-y(x) = 0
[x-exp(arcsinh(((-a^2*x^2+x^2+y(x)^2)^(1/2)*a+y(x))/((a^2-1)*x))/a)*_C1/((-a^2*x^2+a^2*y(x)^2+2*(-a^2*x^2+x^2+y(x)^2)^(1/2)*a*y(x)+x^2+y(x)^2)/((a^2-1)^2*x^2))^(1/2) = 0, x-exp(-arcsinh(((-a^2*x^2+x^2+y(x)^2)^(1/2)*a-y(x))/((a^2-1)*x))/a)*_C1/(-(a^2*x^2-a^2*y(x)^2+2*(-a^2*x^2+x^2+y(x)^2)^(1/2)*a*y(x)-x^2-y(x)^2)/((a^2-1)^2*x^2))^(1/2) = 0]
#3054
#Problem number: 1146.
ode:=ln(diff(y(x),x))+4*x*diff(y(x),x)-2*y(x) = 0;
simplify(%);
simplify(%);
ln(diff(y(x), x))+4*x*(diff(y(x), x))-2*y(x) = 0
[y(x) = (1/2)*ln((1/4)*(-1+(16*_C1*x+1)^(1/2))/x)-1/2+(1/2)*(16*_C1*x+1)^(1/2), y(x) = (1/2)*ln(-(1/4)*(1+(16*_C1*x+1)^(1/2))/x)-1/2-(1/2)*(16*_C1*x+1)^(1/2)]
ln(2)+ln((8*x*_C1-(16*_C1*x+1)^(1/2)+1)/(x*(-1+(16*_C1*x+1)^(1/2))))-ln((-1+(16*_C1*x+1)^(1/2))/x)
ln(2)+ln((-8*x*_C1-(16*_C1*x+1)^(1/2)-1)/(x*(1+(16*_C1*x+1)^(1/2))))-ln((-1-(16*_C1*x+1)^(1/2))/x)
#3128
#Book: Differential Equations, By George Boole F.R.S. 1865
#Section: Chapter 7
#Problem number: 7.
ode:=y(x) = a*diff(y(x),x)+(diff(y(x),x)^2+1)^(1/2);
simplify(%);
simplify(%);
y(x) = a*(diff(y(x), x))+((diff(y(x), x))^2+1)^(1/2)
((y(x)^2+a^2-1)^(1/2)*a-y(x)-((y(x)^2*a^2+a^4-2*y(x)*(y(x)^2+a^2-1)^(1/2)*a+y(x)^2-a^2)/(a^2-1)^2)^(1/2)*(a^2-1))/(a^2-1)
(-(y(x)^2+a^2-1)^(1/2)*a-y(x)-((y(x)^2*a^2+a^4+2*y(x)*(y(x)^2+a^2-1)^(1/2)*a+y(x)^2-a^2)/(a^2-1)^2)^(1/2)*(a^2-1))/(a^2-1)
#3129
#Section: Chapter 7
#Problem number: 8.
ode:=x = a*diff(y(x),x)+(diff(y(x),x)^2+1)^(1/2);
simplify(%);
simplify(%);
x = a*(diff(y(x), x))+((diff(y(x), x))^2+1)^(1/2)
[y(x) = (1/2)*x*(a^2+x^2-1)^(1/2)/((a-1)*(a+1))+(1/2)*ln(x+(a^2+x^2-1)^(1/2))*a^2/((a-1)*(a+1))-(1/2)*ln(x+(a^2+x^2-1)^(1/2))/((a-1)*(a+1))+(1/2)*a*x^2/((a-1)*(a+1))+_C1, y(x) = -(1/2)*x*(a^2+x^2-1)^(1/2)/((a-1)*(a+1))-(1/2)*ln(x+(a^2+x^2-1)^(1/2))*a^2/((a-1)*(a+1))+(1/2)*ln(x+(a^2+x^2-1)^(1/2))/((a-1)*(a+1))+(1/2)*a*x^2/((a-1)*(a+1))+_C1]
-((a^2+x^2-1)^(1/2)*(a^2-1)*((2*a*x*(a^2+x^2-1)^(1/2)+a^4+(x^2-1)*a^2+x^2)/(a^2-1)^2)^(1/2)+a^3+a*x^2+x*(a^2+x^2-1)^(1/2)-a)/((a^2+x^2-1)^(1/2)*(a^2-1))
#3136
#Section: Chapter 7
#Problem number: 15
ode:=y(x) =x*diff(y(x),x)+a*x*(diff(y(x),x)^2+1)^(1/2);
simplify(%):# output too large
y(x) = x*(diff(y(x), x))+a*x*((diff(y(x), x))^2+1)^(1/2)
#3138
#Section: Chapter 7
#Problem number: 17
ode:=x+y(x)*diff(y(x),x) = a*(diff(y(x),x)^2+1)^(1/2);
odetest(sol[1],ode): #WARNING. hangs. try with timelimit
[y(x) = (a*(tan(RootOf(a^2*_Z^2*cos(2*_Z)+2*_C1*a*_Z*cos(2*_Z)+4*sin(_Z)*a*x*_Z-a^2*_Z^2+_C1^2*cos(2*_Z)+a^2*cos(2*_Z)+4*sin(_Z)*_C1*x-2*_C1*a*_Z-_C1^2+a^2-2*x^2))^2+1)^(1/2)-x)/tan(RootOf(a^2*_Z^2*cos(2*_Z)+2*_C1*a*_Z*cos(2*_Z)+4*sin(_Z)*a*x*_Z-a^2*_Z^2+_C1^2*cos(2*_Z)+a^2*cos(2*_Z)+4*sin(_Z)*_C1*x-2*_C1*a*_Z-_C1^2+a^2-2*x^2)), y(x) = (a*(tan(RootOf(a^2*_Z^2*cos(2*_Z)+2*_C1*a*_Z*cos(2*_Z)-4*sin(_Z)*a*x*_Z-a^2*_Z^2+_C1^2*cos(2*_Z)+a^2*cos(2*_Z)-4*sin(_Z)*_C1*x-2*_C1*a*_Z-_C1^2+a^2-2*x^2))^2+1)^(1/2)-x)/tan(RootOf(a^2*_Z^2*cos(2*_Z)+2*_C1*a*_Z*cos(2*_Z)-4*sin(_Z)*a*x*_Z-a^2*_Z^2+_C1^2*cos(2*_Z)+a^2*cos(2*_Z)-4*sin(_Z)*_C1*x-2*_C1*a*_Z-_C1^2+a^2-2*x^2))]
edit 12/23/2020
Found one more.
#3647
ode:=diff(y(x),x)=2*(x*sqrt(y(x))-1)*y(x);
ic:=y(0)=1;
sol:=dsolve([ode,ic]);
odetest(sol,ode);
The above becomes zero only for x>-1
ps. I added this to the worksheet, but since upload now does not work, did not re upload so not to lose the display above. Will do that later when it is working.
edit 12/25/2020
Found one more.
#3607
#Book: Fundamentals of Differential Equations. By Nagle, Saff and Snider. 9th edition. Boston. Pearson 2018.
#Section: Chapter 2, First order differential equations. Section 2.2 Exercises. page 46
#Problem number: 19.
ode:=1/2*diff(y(x),x) = (y(x)+1)^(1/2)*cos(x);
ic:=y(Pi)=0:
sol:=dsolve([ode,ic],y(x)):
res:=odetest(sol,ode);
edit 12/26/2020
Found one more
#3613
#Problem number: 26.
ode:=(x+1)*diff(y(x),x)+y(x)^(1/2) = 0;
ic:=y(0) = 1;
PDEtools:-Solve(res=0,x) assuming real;
edit 1/10/2021
Found one more
#2406
#Problem number: 406.
ode:=(x^3+1)^(2/3)*diff(y(x),x)+(y(x)^3+1)^(2/3) = 0;
check:=simplify(odetest(sol,ode));  #tried other simplication, can't get it to zero. But sol is correct
Download examples_of_odes_that_do_not_odetest.mw
Hello! I am trying to create a DEplot for some differential equations. I have used DEplot before and it works just fine and the direction field arrows appear however with this question it is not working. I have tried restarting my system, removing some options, and still am having issues. The interface version I am working with is "Standard Worksheet Interface, Maple 2020.1, Mac OS X, July 30 2020 Build ID 1482634".  Any help would be appreciated. Thank you!
Maple program for extended Euclidean algorithm for polynomials with rational coefficients
54*x^3-54*x^2+84*x-48
-12*x^3-28*x^2+72*x-32
I have problem that Maple is not evaluating integral (I need equation for distance for Lissajous curve):
with(Physics);
with(LinearAlgebra);
with(IntegrationTools);
x := A*sin(a*t + d);
y := B*sin(b*t);
u := diff(x, t);
u2 := diff(y, t);
u3 := sqrt(u^2 + u2^2);
u5 := int(u3, t);
I am only getting:
First 502 503 504 505 506 507 508 Last Page 504 of 2458
