At my first steps in vectorcalculus i calculating a scalar line integral, but the concept how to do this is not  yet clear to me
ecxample_4_-_blz407_toegepaste_wiskunde.mw
https://drive.google.com/file/d/1K5mnfCAB_zSzLGNNz1rkUyjvRhCgpFi4/view?usp=sharing
Any idea why symgen hangs when using formal algorithm on this first order ode? I was just comparing the Lie symmetries generated for this ode using different algorithms when I noticed this hang on formal.
The textbook gives this result btw
From help on symgen it says
The first algorithms, called formal, formulates a linear PDE system for the infinitesimals [xi, eta], then formally triangularize this system - using differential algebra techniques - finally tacking the resulting uncoupled system. When successful, this algorithm returns the complete set of point symmetries admitted by a given ODE of order 2 or higher. NOTE: this algorithm is advantageous mainly for 2nd and higher order ODEs. The algorithm works as well in the case of first order ODEs, but in this case the subproblems it will need to solve to find the symmetries are as difficult to solve as the first order ODE itself.
But on Maple 2020.1 server seems to hang, taking 100% CPU. I had to terminate mserver.exe manually since clicking on interreupt button from worksheet has no effect. This only happens with formal algoritm. All others work very fast.
I know help says this is meant for second order ODE's, but it also says it works  well for first order.  It seems to be stuck in solve call somewhere. Is this to be expected sometimes when using formal algo in symgen for first order ode's?
Maple can solve the ODE very quickly otherwise.
The following ode also hangs in symgen
ode:=diff(y(x),x)=x*y(x)^2-2*y(x)/x-1/x^3;
interface(version)
Physics:-Version()
`The "Physics Updates" version in the MapleCloud is 794 and is the same as the version installed in this computer, created 2020, September 3, 23:37 hours Pacific Time.`
#hangs on formal, why?
ode:=diff(y(x),x)=(y(x)-4*x*y(x)^2-16*x^3)/(y(x)^3+4*x^2*y(x)+x);
DEtools:-symgen(ode,y(x),way=formal)
diff(y(x), x) = (y(x)-4*x*y(x)^2-16*x^3)/(y(x)^3+4*x^2*y(x)+x)
sol:=dsolve(ode,implicit)
(1/2)*y(x)^2+(1/2)*arctan((1/2)*y(x)/x)+2*x^2-_C1 = 0
Download symgen_issue_1.mw
There are 3 lists of data
how to plot 3 lines with x axis represent time 1,2,3...
Problem with pdsolve/numeric
Contextualizing:
I created a routine for solving a thermo-mechanical problem. The size of the spatial domain is a function of time and the thermo-mechanical behavior of the structure.
The solution is obtained by discretizing the time domain in n intervals. The thermo-mechanical responses are obtained at each time t[i] =t[i-1]+dt.
The material exhibits elastic and elastoplastic mechanical behavior and thus the problem was divided into two consecutive phases (phase 1 and 2).
The heat problem is nonlinear because the thermal properties are variable (termal conductivity, specific heat, and density).
The problem:
In phase 2, the pdsolve/numeric command returns an error for the solution of the heat conduction equation (equation called pde1). I believe this error is related to the derivative of thermal conductivity k(x1) (piecewise function).
I tested many alternatives (I wrote the pde1 equation in two different ways), I checked the routine many times and I don't understand the reason for the error. With each attempt, the command returns a different error.
Thanks for your attention and help.
Problem.mw
Display all lattices on a set with 3 elements.
hi
could you help me to solve this problem
dose the following problem has solution?and how can i write it in maple?
this is a problem 6 equation and 4 unknown variable
sys := 1.20710678118654752440084436211*x-.207106781186547524400844362106*y = 1, -1.20710678118654752440084436210*x+1.20710678118654752440084436210*z+.207106781186547524400844362105*y-.207106781186547524400844362105*w+1.61353108866376978508023871599*z-1.61353108866376978508023871599*w = 0, 1.41421356237309504880168872421*x-1.41421356237309504880168872421*z-1.41421356237309504880168872421*y+1.41421356237309504880168872421*w-1.37455258362134694054214893147*z-1.37455258362134694054214893147*w = 0, -1.20710678118654752440084436210*x-1.20710678118654752440084436210*z+.207106781186547524400844362105*y+.207106781186547524400844362105*w+.238978505042422844538089784517*x-.238978505042422844538089784517*y = 0, 1.41421356237309504880168872421*x+1.41421356237309504880168872421*z-1.41421356237309504880168872421*y-1.41421356237309504880168872421*w+1.37455258362134694054214893147*x-1.37455258362134694054214893147*x = 0
I wish to write 2D output strings in various colors. Normally I use printf, though I'm willing to hear other suggestions.
An optimal procedure would one where I pass it the string, and a ColorName color such as "DodgerBlue" or "xkcd blue", but I'm happy if it means passing my own hex code.  Thanks.
Hi every one
I'm having some plots in maple, but the layout is not pretty enough, I want export in to MATLAB. Does some one please have an idea on how I can go about it?.
I'm using Maple 16
Thank you in anticipation
Hi everyone.
I have a 2D function and I wanna after Differentiating from it with respect to tau (at any amount of sigma value) and equaling this derivative to zero solve the infinite system of equations.
P[n](tau)==LegendreP(n - 1/2, cosh(tau)) , Q[n](tau)==LegendreQ(n - 1/2, cosh(tau))
are Legendre function.
Thanks in advanced
FUNCTION_f.mw
"restart;:N:=3: f(sigma,tau):=(sqrt(cosh(tau)-cos(sigma)))*(∑)(A[n]*P[n]((tau)) -n*Q[n]((tau)) )*sin(n*sigma)"
proc (sigma, tau) options operator, arrow, function_assign; sqrt(cosh(tau)-cos(sigma))*(sum((A[n]*P[n](tau)-n*Q[n](tau))*sin(n*sigma), n = 1 .. N)) end proc
W := simplify(diff(f(sigma, tau), tau))
(1/2)*((2*A[2]*(cosh(tau)-cos(sigma))*(diff(P[2](tau), tau))+(-4*cosh(tau)+4*cos(sigma))*(diff(Q[2](tau), tau))+sinh(tau)*(A[2]*P[2](tau)-2*Q[2](tau)))*sin(2*sigma)+(2*A[3]*(cosh(tau)-cos(sigma))*(diff(P[3](tau), tau))+(-6*cosh(tau)+6*cos(sigma))*(diff(Q[3](tau), tau))+sinh(tau)*(A[3]*P[3](tau)-3*Q[3](tau)))*sin(3*sigma)+sin(sigma)*(2*A[1]*(cosh(tau)-cos(sigma))*(diff(P[1](tau), tau))+(-2*cosh(tau)+2*cos(sigma))*(diff(Q[1](tau), tau))+sinh(tau)*(A[1]*P[1](tau)-Q[1](tau))))/(cosh(tau)-cos(sigma))^(1/2)
Download FUNCTION_f.mw
During the computation of a series, I needed the value Psi(1/12)  of the digamma function at a rational point.
simplify, convert/elementary or other usual convertions do not help.
But Maple knows the formula for Psi(r) when r is rational:
FunctionAdvisor(special_values, Psi)[24][1]: convert(%,`global`);
Psi(n+p/q) = q*(Sum(1/(k*q+p), k = 0 .. n-1))+2*(Sum(cos(2*Pi*p*k/q)*ln(sin(Pi*k/q)), k = 1 .. floor((1/2)*q+1/2)-1))-(1/2)*Pi*cot(Pi*p/q)-ln(2*q)-gamma
(simplify@value)(eval(%, [n=0, p=1, q=12]));
Psi(1/12) = ((2*3^(1/2)-6)*ln(2+3^(1/2))+(-Pi-2*gamma-6*ln(2)-3*ln(3))*3^(1/2)-Pi+2*gamma+6*ln(2)+3*ln(3))/(2*3^(1/2)-2)
evalf(%);
-12.44790533 = -12.44790533
The question is: why does not Maple use this formula when asked? Or, is there a convertion which I was missing?
I have written the following attached code to use Euler explicit method to solve the following IVP
diff(y(x), x) = 2*(1+x)-y(x), y(2) = 5
With Exact solution  y(x) = 2*x+exp(-x)/exp(-2)
However, I found out that my exact results are not correct while the numerical results are okay. What have I done wrong in the code? Can someone modify the code?
Thank you and kind regards.
 I recently tried using Maple 2020 to run example code for the Grid package provided in Section 15.8 of the Maple Programming Guide. Unfortunately, none of the sample code appears to work as advertised.
Firstly, when I try to run the first sequential Mandelbrot example provided, I get the following error:
Error, (in Mandelbrot:-MandelLoop) `break` outside of loop
This was easily fixed by replacing the break statement in the while with a boolean value flag, while k < iter and flag do (see attached image). With this minor change to the example provided in the manual, I was able to get the code sequential code to run in 45.743 seconds on a quad core laptop. The modifications to the sample code are highlighted in red below.
 MandelLoop := proc( X, Y, imageArray, i_low, i_high, j_low, j_high, iter, bailout )
        local flag, i, j, Xc, Yc, Xtemp, Ytemp, Xold, Yold, k, t;
        option hfloat;
        for i from i_low to i_high do
           for j from j_low to j_high do
               Xtemp := X[i];
               Ytemp := Y[j];
               Xc := Xtemp;
               Yc := Ytemp;
               k := 0;
               flag := true:
                   Xold := Xtemp;
                   Yold := Ytemp;
                   Xtemp := Xold^2-Yold^2+Xc;
                   Ytemp := 2*Xold*Yold+Yc;
                   t := Xtemp^2+Ytemp^2;
                   if Xtemp^2+Ytemp^2 >= bailout then
                        imageArray[i, j, 1] := k - ln( ln( t ) )/ln(2.);
                        imageArray[i, j, 2] := imageArray[i, j, 1];
                        imageArray[i, j, 3] := imageArray[i, j, 1];
                        #break;
                        flag := false:
                  k := k+1;
               end do
The second, and seemingly more serious problem occurred when I tried to run the code in the last example that uses the Client/Server model to parallelise the Mandelbrot calculation. The code provided in the Programming Guide once again gives the break outside of loop error. However, after replacing the break statement in the Computeline procedure with a boolean flag as above, I found the code runs but does not enter either the Server procedure or the Computeline procedure that is actually supposed to do the work. This can be verified by including print statements in the Computeline or Server procedures. The parallelised code ran in less than one second, compared to 45 seconds for the sequential code. Unfortunately this was not due to a 45-fold speed up on my quad core laptop, but the fact that the code using the code parallelised using Grid Package did nothing whatsoever.
I have sent a number of e-mail requests to Maple Support asking them to explain these apparent errors and so far have received no response.
Any solutions to these problems from the Maple user community would be much appreciated.
John
Hi . Can I download Maple on my IPad Pro 12.9?
P1 := x^2+y^2-4:
P2 := y^2-2*x+2:
Original question is find CAD of (some y)[P1 <0 and P2 <0]
how to use maple 12 and maple 2015 to find Q1,Q2,Q3 which are projection of P1 and P2
my book show sample points are [-4,-1-sqrt(7),-3,-2,0,1,3/2,-1+sqrt(7),9/5,2,3]
but FindSamples result is not the same with my book, is it my book wrong or FindSamples function wrong?
I find result of my script is the same as book's quantifier position at 7,8,9 though sample points has little different
how to generalize my following script to multiple variables x, y, z, and more ?
I compare with maple 2015 result are different from my book solution, is maple 2015 more advanced version CAD?
with(ListTools):
P1 := x^2+y^2-4:
P2 := y^2-2*x+2:
Q1 := x^2 + 2*x - 6;
Q2 := x^2 - 4;
Q3 := x - 1;
sourcesamples := sort(evalf([solve(Q1), solve(Q2), solve(Q3)]),`<`);
FindSamples:=proc(sourcesamples)
local N, P;
N:=nops(sourcesamples);
P:=proc(a,b)
local a1, b1, m1, n, m;
if a=b then error "Should be a<>b" fi;
a1,b1:=op(convert(sort([a,b],(x,y)->evalf(x)<evalf(y)),rational));
count := 0:
for n from 1 do
m1:=a1*n;
m:=`if`(type(m1,integer),m1+1,ceil(m1));
count := count + 1:
if is(m/n>a1) and is(m/n<b1) then return m/n fi;
od;
print("count=",count);
[ceil(sourcesamples[1])-1, seq(op([sourcesamples[i],P(sourcesamples[i],sourcesamples[i+1])]), i=1..N-1),sourcesamples[N],floor(sourcesamples[N])+1];
RemoveComplex := proc(yy)
local result, k:
result := []:
for k in yy do
if Im(k) = 0 then
result := [op(result), k]:
end if:
if result = [] then
result := []:
end if:
return result:
Joinsolution := proc(param1, param2group)
local result, k:
result := []:
for k in param2group do
result := [op(result), [param1, k]]:
return result:
CADsamples := FindSamples(sourcesamples):
CADresult1 := []:
for mm in CADsamples do
#print(mm):
if MakeUnique(RemoveComplex([solve(subs(x=mm, P1)), solve(subs(x=mm, P2))])) = [] then
CADresult1 := [op(CADresult1), op(Joinsolution(mm,[0]))];
CADresult1 := [op(CADresult1), op(Joinsolution(mm,FindSamples(sort(evalf(MakeUnique(RemoveComplex([solve(subs(x=mm, P1)), solve(subs(x=mm, P2))]))),`<`))))];
end if:
CADresult1;
for mm in CADresult1 do
if subs(x=mm[1],subs(y=mm[2], P1)) < 0 and subs(x=mm[1],subs(y=mm[2], P2)) < 0 then
print("solution ", mm, SearchAll(mm[1],CADsamples), evalf(mm)):
end if:
Compare with
with(RegularChains):
with(ChainTools):
with(MatrixTools):
with(ConstructibleSetTools):
with(ParametricSystemTools):
with(SemiAlgebraicSetTools):
with(FastArithmeticTools):
R := PolynomialRing([x,y]):
sys := [x^2+y^2-4,y^2-2*x+2]:
N := []:
P := []:
H := [x]:
dec := RealTriangularize(sys,N,P,H,R):
proj := Projection(sys, N, P, H, 1, R);
Display(dec, R);
P := SamplePoints(sys, R);
Display(P, R);
cad := CylindricalAlgebraicDecompose(sys, R);
The following transfer function has zero/pole cancelation. I am trying to create a transfer function object, but Maple automatically simplifies the transfer function before it gets to the DynamicSystem call, which result in different output than what I expected.
I do set the cancellation=false option, even though this is the default. The problem is Maple does pole/zero cancelation before the call.
I tried to add '' around it to delay evaluation, but it did not work.
alias(DS=DynamicSystems):
DS:-SystemOptions(cancellation=false,complexfreqvar=s):
tf:=DS:-TransferFunction('-(s - 1)/((-2 + s)*(s - 1))'):
DS:-PrintSystem(tf)
You can see it did pole/zero cancelation.
In Matlab and Mathematica, this does not happen. For example
Clear["Global`*"];
sys = TransferFunctionModel[-(s - 1)/((-2 + s) (s - 1)), s]
Same with Matlab:
>> s=tf('s');
>> sys_tf =-(s - 1)/((-2 + s)*(s - 1))
sys_tf =
     -s + 1
  s^2 - 3 s + 2
Continuous-time transfer function.
What do I need to do in Maple to keep the transfer function without pole/zero cancelation (this affects the state space realization later on when this cancelation happens)
I am using Maple 2019 at this moment as Maple 2020 is busy.
First 536 537 538 539 540 541 542 Last Page 538 of 2458
