It would seem that if a package is loaded at the "top-level" via with() and the worksheet also has a procedure definition which contains a 'uses' statement for the same package (OK, admittedly a bit redundant), the commands from the relevant package actually "go missing".
See the output from test4() in the attached.
I can't believe that this is deliberate, because when trying to 'compartmentalise' code, then a 'uses' statement in a procedure seems like a good idea. To have this fail because the "top-level" worksheet contains a with() statement loading the same package seems perverse.
Please don't post workarounds - I already know several ways to do achieve it. I'm trying to find out if this behaviour is "deliberate" or a "bug". If the latter, it has been around for a long time because I have checked all the way back to Maple 18: every version exhibits the same behaviour
  kernelopts(version);
  test1:= proc(M::Matrix)
               uses LinearAlgebra:
               return MatrixInverse(M):
  test2:= proc(M::Matrix)
               return LinearAlgebra:-MatrixInverse(M):
  test3:= proc(M::Matrix)
  test4:= proc(M::Matrix)
               uses LinearAlgebra:
  test1( Matrix( [[1,2],[3,4]]));
  test2( Matrix( [[1,2],[3,4]]));
  test3( Matrix( [[1,2],[3,4]]));
  test4( Matrix( [[1,2],[3,4]]));
`Maple 2020.0, X86 64 WINDOWS, Mar 4 2020, Build ID 1455132`
Matrix(2, 2, {(1, 1) = -2, (1, 2) = 1, (2, 1) = 3/2, (2, 2) = -1/2})
MatrixInverse(Matrix(%id = 18446744074373391174))
Download usewith.mw
Please everybody, help me to make phaseportrait 3D
f:= (ln(4x-4)/4)-(ln(4x+4)/4)+(arctan(x)/2)
When I do plots([f(x),f(x)-2,f(x)+2]), the graphs don't extend infinitely like I want. They stop just themselves. How get I the plots to extended more? I attached a picture.
it really confused, with generating different sample some times the command fsolve is working and some times don't . is there any other way to solve this system of equations. because I am going to generate 1000 samples and for each sample, I supposed to solve this system.
f[1] := VectorCalculus:-`+`(VectorCalculus:-`+`(VectorCalculus:-`+`(VectorCalculus:-`+`(VectorCalculus:-`*`(VectorCalculus:-`+`(n_x, n_y), 1/theta1), VectorCalculus:-`-`(sum(VectorCalculus:-`*`(VectorCalculus:-`*`(VectorCalculus:-`+`(theta2, -1), x[t]), 1/VectorCalculus:-`+`(VectorCalculus:-`*`(VectorCalculus:-`*`(theta1, theta2), x[t]), 1)), t = 1 .. n_x))), VectorCalculus:-`-`(sum(VectorCalculus:-`*`(VectorCalculus:-`*`(VectorCalculus:-`+`(2, R_x[t]), x[t]), 1/VectorCalculus:-`*`(VectorCalculus:-`+`(VectorCalculus:-`*`(VectorCalculus:-`*`(theta1, theta2), x[t]), 1)^VectorCalculus:-`+`(1, VectorCalculus:-`-`(1/theta2)), VectorCalculus:-`+`(VectorCalculus:-`+`(VectorCalculus:-`+`(VectorCalculus:-`*`(VectorCalculus:-`*`(theta1, theta2), x[t]), 1)^(1/theta2), -1), theta3))), t = 1 .. n_x))), VectorCalculus:-`-`(sum(VectorCalculus:-`*`(VectorCalculus:-`*`(VectorCalculus:-`+`(theta2, -1), y[T]), 1/VectorCalculus:-`+`(VectorCalculus:-`*`(VectorCalculus:-`*`(theta1, theta2), y[T]), 1)), T = 1 .. n_y))), VectorCalculus:-`-`(sum(VectorCalculus:-`*`(VectorCalculus:-`*`(VectorCalculus:-`+`(2, R_y[T]), y[T]), 1/VectorCalculus:-`*`(VectorCalculus:-`+`(VectorCalculus:-`*`(VectorCalculus:-`*`(theta1, theta2), y[T]), 1)^VectorCalculus:-`+`(1, VectorCalculus:-`-`(1/theta2)), VectorCalculus:-`+`(VectorCalculus:-`+`(VectorCalculus:-`+`(VectorCalculus:-`*`(VectorCalculus:-`*`(theta1, theta2), y[T]), 1)^(1/theta2), -1), theta4))), T = 1 .. n_y))):
N_x := 30:
n_x := 30:
R_x := [seq(0, nl = 1 .. 30)];
[0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0]
`λλ` := 5; -1; QQ := 1; -1; `αα1` := 2; -1; `αα2` := 4
4
W := GenerateUniform(n_x, 0, 1):
fsolve({f[1], f[2], f[3], f[4]}, {theta1 = 0 .. infinity, theta2 = 0 .. infinity, theta3 = .5 .. infinity, theta4 = .5 .. infinity})
Download ask_maple.mw
I just need someone to explain to me why the following occurs:
showstat(rand)
rand := proc(r::{posint, numeric .. numeric}, $)
   1   if nargs = 0 then
   2     RandomTools:-MersenneTwister:-GenerateInteger()
   3     try
   4       if type(r,('numeric') .. ('numeric')) then
   5         if rhs(r) < lhs(r) then
   6           error "invalid range, end points are out of order"
             elif not type(r,('integer') .. ('integer')) then
   7           return () -> RandomTools:-Generate(float(('range') = r,('method') = ('uniform')))
             end if
   8       return RandomTools:-MersenneTwister:-NewGenerator(('range') = r)
         catch :
   9       error
         end try
       end if
end proc
showstat(RandomTools:-MersenneTwister:-GenerateInteger)
RandomTools:-MersenneTwister:-GenerateInteger := proc({range::{integer, integer .. integer} := 1000000000000}, $)
local bits, divisor, offset;
   1   if nargs = 0 then
   2     return MTKernelInterface(4)
   3   if type(range,'integer') then
   4     divisor := range;
   5     offset := 0
   6     if rhs(range) < lhs(range) then
   7       error "illegal range, end points out of order"
   8     if lhs(range) = rhs(range) then
   9       return lhs(range)
  10     offset := lhs(range);
  11     divisor := rhs(range)-offset+1
  12   if divisor = 0 then
  13     return offset
  14   bits := MTKernelInterface(5,divisor);
  15   MTKernelInterface(6,divisor,bits)+offset
end proc
showstat(MTKernelInterface)
Error, (in showstat) procedure name expected
Download rand_showstat.mw
Does maple provide any method for finding the saddle point of a function? Thank you
I am trying to write maple program for Gauss Siedel method. I needed two for loop. One for running the iterative method and the other for checking where (the number of iteration required) the results converge.
Please, I need help.
Hi guys! I'm having trouble using int with a few expressions, for example:
is returning
however simpler expressions such as
int(x^2 + x, x)
or int(x/2 + 1/2, x)
are working correctly and returning
respectively. I'm using Maple 2020 in worksheet mode using Math 2D Input/Output.
Here's my screen, any help would be much appreciated thanks!
I'm trying to solve for Double Inequality. (1.1) and (1.3) combined.
Thanks in Advance
Example: Solving a Double Inequality
-3 <= 6*x-1
0 <= 6*x+2
(1.1)
[[-1/3 <= x]]
(1.2)
6*x-1 < 3
6*x < 4
(1.3)
"(->)"[[x < 2/3]]
"ex1(x):=6 x-1"
proc (x) options operator, arrow, function_assign; 6*x-1 end proc
(1.4)
"ex2(y):=3"
proc (y) options operator, arrow, function_assign; 3 end proc
(1.5)
"ex3(y):=-3"
proc (y) options operator, arrow, function_assign; -3 end proc
(1.6)
Download Double_Inequality.mw
I was wondering is there an easier way for me to solve an Equation Involving an Absolute Value?
Example: Solving an Equation Involving an Absolute Value
x^2-3*x = -4*x+6
x^2-3*x = -4*x+6
(1.1)
[[x = 2], [x = -3]]
(1.2)
-x^2+3*x = -4*x+6
-x^2+3*x = -4*x+6
(1.3)
[[x = 1], [x = 6]]
(1.4)
"ex7(x):=|x^(2)-3 x|+4 x-6"
proc (x) options operator, arrow, function_assign; abs(x^2-3*x)+4*x-6 end proc
(1.5)
Download Absolute_Value.mw
Mapple doesn' work at document mode.How can i solve the problem.(My Os is Win 10 )
I am trying to solve ODE with bvp[midrich], and I need to prove the validity of this method.
Where can i read about realization of bvp[midrich]. What scheme does it use? Аre there any articles on this subject?
In Maple 2019.2, I'm trying to compute series expansions. For the input
series(1/z^4/(1-z), z=0, 1);
Maple gives me a series of the expression around z=0, truncated to 1 term, i.e.
z^(-4) + O(z^(-3))
But with the input
series(1/z^4/(1-z), z=0, 2);
Maple gives me the result
z^(-4) + z^(-3) + z^(-2) + z^(-1) + 1 + z + O(z^2)
Apparently Maple has decided not to give a series with 2 terms, but a series up to O(z^2). I'm surprised that the third argument of "series" is not treated in a consistent manner. I've restarted the Maple server between the two computations, so it's not a memory effect.
In the above example, this is just a minor annoyance, but I'm actually dealing with huge expressions, and for performance reasons it's important to truncate the series expansion at the desired order and stop further computations. Has anyone encountered this problem?
Please how can I caluclate an integrale based on data set (Q) usiing any integral method
Q := [21521.7, 11966.6, 7859.78, 7947.54, 9667.45, 10206.8, 10934.0, 10925.0, 11151.5, 10964.6, 11009.0, 11087.0, 11164.3, 11215.7, 11272.7, 11319.0, 11354.6, 11386.2, 11413.5, 11436.3, 11456.0, 11473.2, 11488.2, 11501.1, 11512.7, 11523.0, 11532.2, 11540.3, 11547.7, 11554.3, 11560.3, 11565.8, 11570.7, 11575.3, 11579.4, 11583.2, 11586.7, 11590.0, 11592.9, 11595.7, 11598.2, 11600.6]
Download simpson.mw
First 581 582 583 584 585 586 587 Last Page 583 of 2464
