Years ago i used maple as in a worksheet
Nowadys there are two ways to use Maple: in document mode and worksheet mode ?
Very confusing this and it seems that the old worksheet mode has nothing to do with the document mode
Now in Maple i don't now how to use the worksheet mode anymore.
Can this worksheet mode used togehter with the document mode?
This is real troublesome exercise  to use Maple, why should i use the document mode and offers it the same functionality as in the worksheet mode ?
I am trying to isolate theta/V in this equation, but Maple will only allow me to solve for either theta or V. Is there a way to make Maple solve for the expression instead of the variable?
I have attached the Maple document below. It contains some other stuff but it is mostly this equation I am interested in. It can be found near the bottom. I hope someone can help.
Best regards
Opdelt_TF_Maple.mw
Why does Maple product history page   stop at Maple 6, year 2000?
Maple starterd in 1984. There are more versions before version 6. I think this official Maple page should list every release made in Maple and do not understand why it stop at version 6 only.
Wikipedia has more complete and detailed history of Maple products, starting with version 1 in 1982, with minor versions also shown than Maple own official web page gives.
btw, Wilipedia says version 6 was released in December 6, 1999. But Maple official page says version 6 was released in 2000.
Any help why this code fail
PDE := diff(u(x,y), y$2 ) + diff(u(x,y), x$2) = 0;
BC:= u(x,0)=0, u(x,100)=100, u(0,y)=0, u(10,y)=0;
sol:=pdsolve([PDE,BC],numeric);
gives
Error, (in pdsolve/numeric/process_PDEs) PDEs can only contain dependent variables with direct dependence on the independent variables of the problem, got {u(0, y), u(10, y), u(x, 0), u(x, 100)}
But sol:=pdsolve([PDE,BC])  works OK and gives analytical solution.
What error Am I doing in the above code in this case?
Maple 2020 with Physics 642
Is there any possibility to define which units are used in components, like MathContainers?
I would like to have kN/m, I get mm2*kg/m3*m/s2...
I'd like to find chromatic number of some graphs. But I find a strange thing of function ChromaticNumber.
with(GraphTheory):
g1:=Graph(4):
DrawGraph(g1);
ChromaticNumber(g1)
It is Ok!
But when I use following codes, an error will be issued.
with(GraphTheory):
graphsof4 := [NonIsomorphicGraphs(4, output = graphs, outputform = graph)]:
DrawGraph(graphsof4[1]);
ChromaticNumber(graphsof4[1]);
I try to take a partial derivative of compound expressions. Usage of diff, Diff, substitution variables instead of time-variant variables (subs) couldn't help me.
restart; PDEtools[declare](`θ__l`(t), `β__l`(t), `θ__si`(t), `β__si`(t), psi(t), x(t), z(t)); PDEtools[declare](prime = t); V__1lx := diff(x(t), t)-(1/2)*l__b*sin(psi(t))*(diff(psi(t), t))-l__1c*sin(`θ__l`(t)-psi(t))*(diff(`θ__l`(t), t)-(diff(psi(t), t))); V__1lz := diff(z(t), t)-(1/2)*l__b*cos(psi(t))*(diff(psi(t), t))-l__1c*cos(`θ__l`(t)-psi(t))*(diff(`θ__l`(t), t)-(diff(psi(t), t))); V__1l := simplify(V__1lx^2+V__1lz^2, size); diff(V__1l, psi); Diff(V__1l, psi)
Diff((diff(x(t), t)-(1/2)*l__b*sin(psi(t))*(diff(psi(t), t))+l__1c*sin(-theta__l(t)+psi(t))*(diff(theta__l(t), t)-(diff(psi(t), t))))^2+(diff(z(t), t)-(1/2)*l__b*cos(psi(t))*(diff(psi(t), t))-l__1c*cos(-theta__l(t)+psi(t))*(diff(theta__l(t), t)-(diff(psi(t), t))))^2, psi)
Download DiffExpr.mw
Should I use implicitdiff? If yes, how does it work?
Also, I don't understand, why the derivative of theta_l is displayed so strange, as if the derivative is taken from the index l?
P.S. This question is a continuation of my last topic: https://www.mapleprimes.com/questions/229551-Operations-On-Several-Defined-Functions
Hello everyone! I was trying to draw a circle point by point using animate, but there's a catch: I'd like it to be created in front of the user, that is seeing every point being drawn in sequence.
Like this, but with the point leaving a trail behind him.
Can anyone help?
I'm trying to evaluate if the matrizes are the same but i cant figure out why it say they are different.
with(DEtools);
DEplot(diff(y(t), t$2)-3*(diff(y(t), t))+2*y(t) = exp(t), [[y(0) = 0, (D(y))(0) = 2]], stepsize = .1, linecolor = black, thickness = 2);
Is there a way to enter a formula into the coloums to generate the output?
I did the Table of Values by Hand which will take a long time for real data.
Thanks in Advance
Example: Verifying Inverse Functions Numerically
"ex17f6(x):=(x-5)/(2):"
"ex17g6(x):=2 x+5:"
y3:
ex17f6(ex17g6(x))
x
(1.1)
y4:
ex17g6(ex17f6(x))
x
(1.2)
NULLNULL
Table 1: Table of Values
x
y3
y4
-2
-2
-2
-1
-1
-1
4
4
4
Download InverseNum.mw
Why are these functions not graphed correctly?
Example: Verifying Inverse Functions Graphically
"ex17f5(x):=2 x^(3)-1:"
"ex17g5(x):=((x+1)/(2))^(1/(3)):"
Download inverseExample.mw
Hi everyone, I have problem solving a given optimization problem using the Karush Khun Tucke conditions. The working is as follows:
with(linalg);
f := 49*x[1]+94*x[2]+90*x[3]+24*x[4]+6*x[5]+63*x[6]+17*x[7]+65*x[8]+72*x[9]+40*x[10]+67*x[11]+99*x[12]+97*x[13]+53*x[14]+22*x[15]+47*x[16]+60*x[17]+36*x[18]+54*x[19]+67*x[20]+46*x[21]+55*x[22]+42*x[23]+70*x[24];
49 x[1] + 94 x[2] + 90 x[3] + 24 x[4] + 6 x[5] + 63 x[6]
   + 17 x[7] + 65 x[8] + 72 x[9] + 40 x[10] + 67 x[11] + 99 x[12]
   + 97 x[13] + 53 x[14] + 22 x[15] + 47 x[16] + 60 x[17]
   + 36 x[18] + 54 x[19] + 67 x[20] + 46 x[21] + 55 x[22]
   + 42 x[23] + 70 x[24]
g[1] := x[1]+x[2]+x[3]+x[4]+x[5]+x[6]+x[7]+x[8]+x[9]+x[10]+x[11]+x[12]-475;
  x[1] + x[2] + x[3] + x[4] + x[5] + x[6] + x[7] + x[8] + x[9]
     + x[10] + x[11] + x[12] - 475
g[2] := x[13]+x[14]+x[15]+x[16]+x[17]+x[18]+x[19]+x[20]+x[21]+x[22]+x[23]+x[24]-30;
 x[13] + x[14] + x[15] + x[16] + x[17] + x[18] + x[19] + x[20]
    + x[21] + x[22] + x[23] + x[24] - 30
for i from 3 to 26 do g[i] := -x[i] end do;
h[1] := 54-x[1];
                           54 - x[1]
h[2] := 30-x[2];
                           13 - x[2]
h[3] := 13-x[3];
                           13 - x[3]
h[4] := 41-x[4];
                           41 - x[4]
h[5] := 97-x[5];
                           97 - x[5]
h[6] := 11-x[6];
                           11 - x[6]
h[7] := 62-x[7];
                           62 - x[7]
h[8] := 59-x[8];
                           59 - x[8]
h[9] := 35-x[9];
                           35 - x[9]
h[10] := 42-x[10];
                           42 - x[10]
h[11] := 19-x[11];
                           19 - x[11]
h[12] := 12-x[12];
                           12 - x[12]
vars := [x[1], x[2], x[3], x[4], x[5], x[6], x[7], x[8], x[9], x[10], x[11], x[12], x[13], x[14], x[15], x[16], x[17], x[18], x[19], x[20], x[21], x[22], x[23], x[24]];
H := Hessian(f, vars);
Hessian(49 x[1] + 94 x[2] + 90 x[3] + 24 x[4] + 6 x[5] + 63 x[6]
   + 42 x[23] + 70 x[24], [x[1], x[2], x[3], x[4], x[5], x[6],
  x[16], x[17], x[18], x[19], x[20], x[21], x[22], x[23], x[24]])
grad_f := Del(f, vars);
Del(49 x[1] + 94 x[2] + 90 x[3] + 24 x[4] + 6 x[5] + 63 x[6]
for i to 26 do grad_g[i] := Del(g[i], vars) end do;
for i to 12 do grad_h[i] := Del(h[i], vars) end do;
eq[1] := grad_f+sum(mu[i]*g[i], i = 13 .. 26)+sum(lambda[i]*h[j], j = 1 .. 12) = 0;
Error, (in sum) summation variable previously assigned, second argument evaluates to 13 = 13 .. 37
eq[2] := g[i] <= 0;
                          -x[13] <= 0
eq[3] := h[j] <= 0;
                           h[j] <= 0
eq[4] := mu[i] >= 0;
                          0 <= mu[13]
eq[5] := lambda[j] <= 0;
                         lambda[j] <= 0
eq[6] := mu[i]*g[i] = 0;
                       -mu[13] x[13] = 0
eval(solve({eq[1], eq[2], eq[3], eq[4], eq[5], eq[6]}, [vars, lambda[j], mu[i]]));
Error, invalid input: too many and/or wrong type of arguments passed to solve; first unused argument is [[x[1], x[2], x[3], x[4], x[5], x[6], x[7], x[8], x[9], x[10], x[11], x[12], x[13], x[14], x[15], x[16], x[17], x[18], x[19], x[20], x[21], x[22], x[23], x[24]], lambda[j], mu[13]]
I'm trying to change with a Maple Worksheet the parameters of a MapleSim Model in Real-matrices format.
is there any way to do that?
actually i get the failure note:
<<Error, (in SetParameters) non-vectorized values in vector parameters: [list= ""]>>
Thank You
Johann
I have the Ubuntu of Linux app installed in Windows 10. Could anyone help me with exactly how to install Maple2020.0LinuxX64Installer.run in the Ubuntu terminal? Many thanks.
First 586 587 588 589 590 591 592 Last Page 588 of 2459
