How to cmaple or mw file maple dualaxisplot output to jpeg file after press and run?
How to cmaple print int(f(x),x) after append to text command instead of /
I want to draw circle passing thought three points S, A, B on the sphere by using tikz-3dplot-circleofsphere, its document at here https://github.com/matthias-wolff/tikz-3dplot-circleofsphere/blob/master/tikz-3dplot-circleofsphere.pdf The command to draw is
\tdplotCsDrawCircle[style]{r}{alpha}{beta}{epsilon}
With Maple, I can find the coordinates of center and radius of circle. I tried
with(geom3d):
 a := 3:
 b := 4:
 h := 5:
 point(A, 0, 0, 0):
 point(B, a, 0, 0):
 point(C, a, b, 0):
 point(DD, 0, b, 0):
 point(S, 0, 0, h):
 sphere(s, [A, B, C, S], 'centername' = m); detail(s); plane(p, [S, A, B], [x, y, z]); coordinates(projection(H, m, p));
R := distance(H, S)
But, I can't to find the angles alpha, beta, epsilon to draw this circle. How can I find  the angles alpha, beta, epsilon?
  interface(rtablesize=10):
# Define gamma as local (don't like doing this!)
  local gamma:local pi:
# Replaced 'indexed' parameters with 'inert subscript'
# parameters - otherwise one gets a problem defining
# both the unindexed 'phi' and the indexed phi[c]
if false then
  A__h := .18: beta__1 := 0.8354e-1: psi := 0.7258e-1: mu__r := 0.51e-1: sigma := .165: alpha := .65: xi := 0.5e-1: gamma := .131: A__b := .7241: beta__o := 0.65e-1: mu__b = 0.17e-1:
end if:
# D() is Maple's differential operator replated D(T)
# with DD(T) in the following to avoid confusion
  ODE1 := diff(S(T), T) = A__h-psi*beta__1*S(T)*G(T)-mu__r*S(T):
  ODE2 := diff(G(T), T) = psi*beta__1*S(T)*G(T)-sigma*psi*beta__1*R(T)*B(T)-(alpha+xi+mu__r)*G(T):
  ODE3 := diff(A(T), T) = alpha*G(T)-(gamma+mu__r)*A(T):
  ODE4 := diff(R(T), T) = gamma*A(T)+sigma*psi*beta__1*R(T)*B(T)- mu__r*R(T):
  ODE5 := diff(C(T), T) = A__b - psi*beta__o*C(T)*I(T)- mu__b*C(T):
  ODE6 := diff(B(T), T) = psi*beta__o*C(T)*I(T)- mu__b*B(T):
if false then
  S0 := 100: G0 := 190: A0 := 45: R0 := 20: C0 := 35: B0 := 25:
end if:
# system + ic
sys := { ODE1, ODE2, ODE3, ODE4, ODE5, ODE6,
                   S(0) = S0, G(0) = G0, A(0) = A0, R(0) = R0, C(0) = C0, B(0) = B0
params := convert(indets(sys, name) minus {T}, list);
[A0, A__b, A__h, B0, C0, G0, R0, S0, alpha, beta__1, beta__o, gamma, mu__b, mu__r, psi, sigma, xi]
# Solve system
  ans := dsolve( { ODE1, ODE2, ODE3, ODE4, ODE5, ODE6,
                 parameters = params,
                 numeric
Error, (in dsolve/numeric) 'parameters' must be specified as a list of unique unassigned names
# define parameter values
DefaultValues := [ A__h = .18, beta__1 = 0.8354e-1, psi = 0.7258e-1, mu__r = 0.51e-1, sigma = .165, alpha = .65, xi = 0.5e-1, gamma = .131, A__b = .7241, beta__o = 0.65e-1, mu__b = 0.17e-1,
     S0 = 100, G0 = 190, A0 = 45, R0 = 20, C0 = 35, B0 = 25
# Form the list of numerical values ordered as params
ValuatedParams := subs(DefaultValues, params)
Warning, inserted missing semicolon at end of statement
[45, .7241, .18, 25, 35, 190, 20, 100, .65, 0.8354e-1, 0.65e-1, .131, 0.17e-1, 0.51e-1, 0.7258e-1, .165, 0.5e-1]
# Instanciate the solution for this set of values
ans(parameters=ValuatedParams)
ans(parameters = [45, .7241, .18, 25, 35, 190, 20, 100, .65, 0.8354e-1, 0.65e-1, .131, 0.17e-1, 0.51e-1, 0.7258e-1, .165, 0.5e-1])
# Plot solutions for a few of the dependent variablss
# just to show everything is working (more-or-less!)
  plots:-odeplot( ans, [T, S(T)] , T=0..10);
  plots:-odeplot( ans, [T, G(T)] , T=0..10);
  plots:-odeplot( ans, [T, A(T)] , T=0..10);
   plots:-odeplot( ans, [T,R(T)] , T=0..10);
  plots:-odeplot( ans, [T, C(T)] , T=0..10);
  plots:-odeplot( ans, [T, B(T)] , T=0..10);
if false then
  plots:-odeplot( ans, [T, A(T)], T=0..10);
  plots:-odeplot( ans, [T, R(T)] , T=0..10);
end if:
# How two use the parametric solution?
# Here an example with only one variable parameter, but this could be generalized to many
# (the main problem is then more a problem of "readability" than a technical one).
f := proc(VariableName::symbol, ParamName::symbol, ParamValues::list, params, ParamDefault, sol)
  local V, k, p, MyChoice, ValuatedParams:
  V := unapply(VariableName(T), T):
  k := 0:
  for p in ParamValues do
    k := k+1:
    MyChoice       := map(u -> if lhs(u)=ParamName then lhs(u)=p else u end if, ParamDefault):
    ValuatedParams := subs(MyChoice, params):
    sol(parameters=ValuatedParams):
    plot||k := plots:-odeplot(
                               sol,
                               [T, V(T)] ,
                               T=0..5,
                               legend=p,
                               color=ColorTools:-Color([rand()/10^12, rand()/10^12, rand()/10^12])
  plots:-display(seq(plot||k, k=1..numelems(ParamValues)));
f(B, epsilon, [0.0001, 0.334, 5.078], params, DefaultValues, ans);
f(B, beta, [0.1, 0.28, 0.35], params, DefaultValues, ans);
f(B, alpha , [0.23,0.28, 0.32], params, DefaultValues, ans);
f(J, tau , [0.04, 0.05, 0.06], params, DefaultValues, ans);
f(C, theta__h , [0.6, 0.7902, 0.8], params, DefaultValues, ans);
Download Mapdocx.mw
I need to build a system of linear equations from a list of polynomials.  The list of indeterminates is as follows:
incog:=[theta[1, 1], theta[1, 2], theta[2, 1], theta[2, 2], theta[2, 6], theta[3, 0], theta[3, 3], theta[3, 4], theta[3, 5]];
The list of polynomials is:
eq:=[1, theta[1, 1]+theta[2, 2]+theta[3, 3], -theta[1, 1]-theta[2, 2], theta[2, 6]*theta[3, 5], -theta[1, 1]*theta[3, 3]-theta[2, 2]*theta[3, 3], -theta[1, 1]*theta[2, 6]*theta[3, 5]+theta[1, 2]*theta[2, 6]*theta[3, 4], theta[1, 1]*theta[2, 2]*theta[3, 3]-theta[1, 2]*theta[2, 1]*theta[3, 3]+theta[1, 2]*theta[2, 6]*theta[3, 0]];
eq[1], eq[2] and eq[5] will be used as examples, although all of them should be used.
In eq[1], there are no indeterminates, therefore the first line of the matrix related to the system of equations is:
[0, 0, 0, 0, 0, 0, 0, 0, 0]
In eq[2], there is a summation of  three indeterminates and the outcome is a set of three lines (summation of indeterminates)
[1, 0, 0, 0, 0, 0, 0, 0, 0]
[0, 0, 0, 1, 0, 0, 0, 0, 0]
[0, 0, 0, 0, 0, 0, 1, 0, 0]
In eq[5], there is a summation of a product of indeterminates and outcome is a set of two lines as follows:
[1, 0, 0, 0, 0, 0, 1, 0, 0]
[0, 0, 0, 1, 0, 0, 1, 0, 0]
Carrying on like this will result in a matrix of 14 lines with zeros and ones in positions related to the indeterminates.  Building the matrix is what matters to me.
I have a thousand of such problems with different indeterminates and set of polynomials.
Any ideas on how to build a function to automatically create the matrices would be most appreciated.
Cheers
Ed
I am woking on a pharmo model for a freind, and it includes a variable called depot that needs to jump up by 150 every 24 hours.
currently I have written it as:
diff(Depot(t), t) = piecewise(t = 0, -Ka*Depot(t)+150, t = 24, -Ka*Depot(t)+150, -Ka*Depot(t))
clearly thats wrong though, as the +150 s don't make it jump up by 150 because of the small step size.
(at t=0, it adds 150*a small step size, at 24 it looks like it adds 150* a vastly smaller step size, what I want would be much closer to a series of pulses each decaying to almost 0 and then getting boosted to just over 150)
My intuition is that i need to use the dirac delta function but in such a way that its integral adds 150 instantaneoulsy every 24 hours. I have no idea how to do that!
Lindas_signal_transduction_model_2.mw
[Edit:
I've just realised that this ode has an obvious solution, so you can trivially make a function that adds 150 every 24 hours and exponentially decays in between.  However there are other models that hopefully i'll being doing similar work on, that don't have nice solutions]
When i export an animation as a gif the dimensions are (by default it seems) 400x400 pixels (w x h).
But my slide show requires a dimension of 1920 x 1080 pixels.
How to I tell maple to export a gif of predefined dimensions?
I can manually adjust the dimensions of the animation by grabbing a corner and pulling it right and down and then export it, but its hit and miss.
Here is an example animation written by Kitonum
with(DEtools):
rho := 0.1:
w0 := 2:
sys := a->[diff(x(t),t) = y(t),diff(y(t),t) = -2*rho*y(t) - w0^2*(x(t)+a)];
P:=a->DEplot(sys(a), [x(t),y(t)], t = 0 .. 20-2*a, x=-2..2, y=-1.9..1.7, [[x(0) = cos(a)-a, y(0) = sin(a)]], scene = [x(t),y(t)], linecolor=blue, numpoints=1000):
plots:-animate(plots:-display,['P'(a), size=[600,300]], a=-0.7..1.4, frames=90);
When I first open my worksheet, my PolynomalInterpolation code looks and works fine,
However, when I press enter, it only displays the command text,
Why is this happening? How can I fix it?
Fyi, this solution to 1D wave pde is wrong. The solution does not even satisfy the PDE itself. Compared it to a numerical solution and they are not the same solution. Do not have time now to write the hand solution. But it is clear the solution is not valid.
I do not know now how to roll back to earlier version of the Physcis packages to see if this used to work OK before. Since when typing Physics:-Version(420) It gives error
Error, (in Physics:-Version) unable to determine the Physics Updates version, could you please report the problem to support@maplesoft.com
And Physics:-Version(425) seems to hang. I am not sure if these commands are supposed to automatically download the physics package from the cloud and install it on my PC or what.
Any way, could someone please verify the solution they get is the same as shown below? May be someone with earlier physics package could try to see if they get different solution?
Physics:-Version()
`The "Physics Updates" version in the MapleCloud is 429 and is the same as the version installed in this computer, created 2019, September 23, 0:14 hours, found in the directory C:\Users\me\maple\toolbox\2019\Physics Updates\lib\`
pde:=diff(u(x,t),t$2)=4*diff(u(x,t),x$2);
ic:=u(x,0)=0,D[2](u)(x,0)=sin(x)^2;
bc:=u(-Pi,t)=0,u(Pi,t)=0;
sol:=pdsolve([pde,ic,bc],u(x,t))
diff(diff(u(x, t), t), t) = 4*(diff(diff(u(x, t), x), x))
u(x, 0) = 0, (D[2](u))(x, 0) = sin(x)^2
u(-Pi, t) = 0, u(Pi, t) = 0
u(x, t) = t*sin(x)^2
pdetest(sol,pde)
-8*t*(2*cos(x)^2-1)
simplify(diff(rhs(sol),t$2)-4*diff(rhs(sol),x$2))
-16*t*cos(x)^2+8*t
Download sept_23_2019.mw
  Hello,every one :
There is a recursive formula where parameters a,b,c and d are real numbers with a>=b, c>=d;
rsolve({f(n+1)-((a-1)*(b-1)+(c+d))*f(n)-c*d*f(n-1)=0, f(0)=a,f(1)=a*(b - 1)+c},f):
simplify(%)
Final expression is too complex, If possible,I'd like to get a more concise expression.
The screenshots of my running results are as follows:
Thanks in advance.
How can I make Maple preserve old outcomes?
Can someone help me with the kind of document I have to submit to prove my student status?
I'm trying to debug a problem with define_external, and I would love some help!
I have a Maple module that contains this line of Maple code:
EigValsVecsC := define_external('EigValsVecsC', LIB = cat(dll_home,"\\operators.dll"), 'm'::ARRAY(datatype=float[8]), 'n'::integer[4], 'eig_vals'::ARRAY(datatype=float[8]), 'eig_vecs'::ARRAY(datatype=float[8]), 'THREAD_SAFE');
Running the Maple code to create the module produces this error message:
"Error, (in ModuleLoad) external linking: error loading external library C:\Users\zander\maple\toolbox\EigLib\misc\operators.dll: The specified procedure could not be found."
I've discovered that there's a single line of C++ code (in the C++ function EigValsVecsC) that I can comment out to make the problem go away.  Here's the line of C++ code:
MKL_INT info = LAPACKE_dsyev(LAPACK_ROW_MAJOR, 'V', 'U', eig_vecs.rows(), eig_vecs.raw(), eig_vecs.rows(), eig_vals.raw());
To clarify:
  • C++ compilation succeeds for operators.dll (which contains the function EigValsVecsC), with this one line either commented or uncommented.
  • The C++ function EigValsVecsC works correctly when not called from Maple (i.e., called from Visual Studio or the command line), with this one line either commented or uncommented.  (Of course, it doesn't work fully correctly with this one line commented, since this one line is the whole point of the function.  But it runs successfully and does the correct massaging of inputs.)
  • When this one line of C++ code is commented, the Maple module builds successfully, and I can call EigValsVecsC in Maple and get results back showing that, in the C++ code, the inputs to the commented line are being set up properly.
The relevant include statement in the C++ code is:
#include "mkl_lapacke.h"
I don't have to comment out the include statement (though the compiler may well be ignoring it if it's never used, when the call to LAPACKE_dsyev is commented out).
I have no good theories about what the problem may be.  I've been trolling the Web for any helpful information, and I've come up with nothing.
Can anyone help?  Thanks!
So my question is fairly simple, and it MUST've been asked multiple times before, but i had no luck using the search tool to find any results matching my question; or at least not any ones with answers that seemed to work.
For Maple 2019
Whenever i want to define a new function g(x) as the derivative of the function f(x), that is
f(x) := 3*x + 2
g(x):= f'(x)
g(3) --> Error
This is an annoyance almost every day of working with Maple for my engineering studies, and while i accidentally found a workaround for integrals, i need to figure out how to use derivatives in my expressions without needing to copy+paste the outputs.
Bonus question: why is the x in the derivative seen as a variable and not an operator? An
with(inttrans)
eq1 := 2*(diff(y__1(t), t)) = -2*y__1(t)-3*y__2(t)+2*u__1
eq2 := diff(y__2(t), t) = 4*y__1(t)-6*y__2(t)+2*u__1+4*u__2
help("laplace")
We have two coupled differential equations relating two outputs (y__1, y__2 ) with two inputs u__1, u__2
The objective of the exercise is to obtain the four transfer functions relating the outputs to the inputs, in other words, we must find:
To save time, we will from now on write Y__1 instead of Y__1(s) , etc.
In order to find tese relations, we must solve Y__1 and Y__2 as a function of U__1 and U__2
Since our model is defined in the time-domain, the first step is to perform Laplace Transform:
Note tha y__1(0) and y__2(0)are zero because y__1 and y__2 are deviation variables, as indicated in the problem description of this exercise.
Now we have a set of two equations with two unknowns, which can be solved algebraically
(this is the advantage of the Laplace Transform). For example, from equation (3) we can
isolate Y__2:
We can substitute the expression (5) in equation (4) to obtain Y__1, as follows:
We can multiply both sides by -3 and expand the products to get:
Now we must group the factors multiplying Y__1, U__1 and U__2
Note that this relation is analogous to:
Y__1 = G__11*U__1+G__12*U__2
Since the effects of `U__1 ` and U__2 are additive, if we want to obtain the relation between one output and only one input ( for example Y__1 and "`U__1`)" we can set the other input to zero, i.e. U__2 = 0.
We still have to obtan the relation between Y__2 and the inputs. We can use equation (5) and (6):
Finally we can find the relations:
Download Transfer_function.mw
I have this problem:
in which I have to find the four transfer functions relating the outputs(yand y2) to the inputs (u1,u2).
The u and y are deviation variables.
The objective is to find the four transfer functions:
So I have done it by hand but I was wondering if there are any maple commands, that could be used to solve such a question?
I found the transfer functions to be:
First 673 674 675 676 677 678 679 Last Page 675 of 2459
