PDEtools[declare]((f, g)(x), prime = x);
de1 := diff(f(x), x, x, x, x)-(H*H)*(diff(f(x), x, x))-R*(diff(f(x), x, x))*(diff(f(x), x))+R*(diff(f(x), x, x, x))*f(x);
de2 := diff(g(x), x, x)-(H*H)*g(x)-R*(diff(f(x), x))*g(x)+R*(diff(g(x), x))*f(x); R := 1; H := 1;
dd1 := {de1 = 0, de2 = 0, f(0) = 0, f(1) = 1, g(0) = 1, g(1) = 1, (D(f))(0) = 0, (D(f))(1) = 0};
r1 := dsolve(dd1, numeric, output = Array([0., 0.5e-1, .10, .15, .20, .25, .30, .35, .40, .45, .50, .55, .60, .65, .70, .75, .80, .85, .90, .95, 1.00]));
de2 := diff(g(x), x, x)-(H*H)*g(x)-R*(diff(f(x), x))*g(x)+R*(diff(g(x), x))*f(x); R := 5; H := 5;
r2 := dsolve(dd1, numeric, output = Array([0., 0.5e-1, .10, .15, .20, .25, .30, .35, .40, .45, .50, .55, .60, .65, .70, .75, .80, .85, .90, .95, 1.00]));
odeplot({r1, r2}, [x, f(x)]);
                f(x) will now be displayed as f
I tried to open Maple but it just won't launch it just stays in the loading screen but it doesn't load. I tried everything Uninstalled it and installed it again, uninstalled Java and installed it again, updated all my drivers but it just seems like it doesn't work. Please help if you can.
I have been using Maple for the last three years with almost no complaints. Great product.
However recently I have acquired a new laptop and upon installing Maple I noticed the GUI appeared different from my past experience. Some "buttons" are now tiny and severely impractical to click:
As you can see the X-icon use to close individual sheets is tiny and so are the "click and drag" squares in the corners of the plot. The problem extends to other objects/buttons not shown in the picture.
The toolbar icons are NOT a problem.
My screen resolution is 3840x2160 and the high resolution must be the problem but when i lower my display resolution nothing changes.
Any help will be greatly appreciated!
     I'm attempting to solve a rather trivial trigonometric equation, but solve seems to be behaving rather inconsistently. If I attempt this equation
eq := G*cos(x+C1) = A*sin(x):
vars :=  {G, C1, x}:
solve(eq, vars);
it returns the correct, expected result
{C1 = -1/2*Pi, G = A, x = x}, {C1 = 1/2*Pi, G = -A, x = x}, {C1 = C1, G = G, x = arctan(cos(C1)*G/(G*sin(C1)+A))}
However, if I remove x from the list vars of variables for which to solve, I expect it to return the first two elements, {C1 = -1/2*Pi, G = A}, {C1 = 1/2*Pi, G = -A}. However, this isn't what happens. Instead, solve returns {C1 = C1, G = A*sin(x)/cos(x+C1)}; it's true that this is a valid solution, but it seems to be missing the two I want. Is there a way to recover the desired solutions?
And a related question: even without removing x from vars, solve appears to have trouble with the equation. Simply changing sin to cos, as so
eq := G*cos(x+C1) = A*cos(x):
vars :=  {G, C1, x}:
solve(eq, vars);
Now only returns
{C1 = C1, G = G, x = arctan((G*cos(C1)-A)/sin(C1)/G)}, {C1 = C1, G = G, x = arctan((-G*cos(C1)-A)/sin(C1)/G)}
That is, it is missing the expected solutions {C1 = 0, G = A}, {C1 = Pi, G = -A}. Is there a reason for this difference?
Thank you very much!
I would like to do some computations with Maple using elliptic functions. The implementation in Maple wants me to provide the g2 and g3 invariants. However, what I have is the half-periods. Does Maple have a function, that calculates the invariants from the half-periods? I know I can do that myself, but I'd like to write something concise and probably the output of a built-in function will be precisely, what the other functions are looking for.
Hi, I'm a new user of Maple 2016.  I'm plotting a surface using plot3d and I'd like to add a line on the surface. You can see my unsatisfying attempt to do this below.  The line that shows in the third figure is basically what I want to show but I don't want the rest of the second surface at all, just the line visible on the first surface.
Tom
p1 := plot3d((1/2)*(-100+(1/2)*(200*Ab__T+200*Ag__T+20000)/sqrt(Ab__T^2-2*Ab__T*Ag__T+Ag__T^2+200*Ab__T+200*Ag__T+10000))/Ab__T, Ab__T = 1 .. 1000, Ag__T = 10 .. 1000, axis[1, 2] = [mode = log])
I next want to add a line along the "ridge" in the figure. I'll try using a proc
p2 := proc (Ab__T, Ag__T) if abs(Ab__T-Ag__T+100) < 10 then (1/2)*(-100+(1/2)*(200*Ab__T+200*Ag__T+20000)/sqrt(Ab__T^2-2*Ab__T*Ag__T+Ag__T^2+200*Ab__T+200*Ag__T+10000))/Ab__T else 0 end if end proc:
p3 := plot3d(p2, 1 .. 1000, 10 .. 1000, grid = [200, 200])
plots:-display(p1, p3)
Download surface_plot_question.mw
{{(1/2)*(-100+(1/2)*(200*Ab__T+200*Ag__T+20000)/(Ab__T^2-2*Ab__T*Ag__T+Ag__T^2+200*Ab__T+200*Ag__T+10000)^(1/2))/Ab__T}}
Hello, I have a simple system that I'm attempting to solve:
eq:={r*cos(c) = a, r*sin(c) = 0}:
If I pass this system to solve(eq, {r,c}), it correctly returns the results {c = 0, r = a}, {c = Pi, r = -a}. However, PDEtools:-Solve(eq, {r,c}) does not find a solution. Even adding the option 'solver'='solve' doesn't help.
According to its help page, PDEtools/Solve is a unified command for solving algebraic or differential equations, so I would expect it to easily handle this system. Is there an additional option I should be passing PDEtools/Solve to make it work like solve in this case?
The only difference between the code that works and the code that doesnt, is that in one Identity is rearranged to as such that the rhs is 0, i am really really curious to work out why this occurs, the only difference is that one evaluates to 1/2=1/2, and the other evaluates to 0=0, but i dont see why maple would return one of those evaluations as false
delta(x, y) = piecewise(x = y, 1, x <> y, 0)
{x}*is*the*fractional*part*of*x
`&Mscr;`(p, q) = {`mod`(p, q)+(1/4)*q*(q-1)}
"`&Dscr;`(q)="
1-(delta({(1/4)*q}, 0)+delta({(1/4)*q}, 0))+delta({(1/4)*q}, 0)*delta({(q-1)*(1/4)}, 0)+1/2*(delta({(q-2)*(1/4)}, 0)+delta({(1/4)*q}, 0)-delta({(q-2)*(1/4)}, 0)*delta({(q-3)*(1/4)}, 0))
CONJECTURE: c`in`(p, q, nonnegint^2)", `&Mscr;`(p,q)=`&Dscr;`(q)"
CHALLENGE: FIND: `in`(p, q, integer^2*such*that*`&Mscr;`(p, q)) and integer^2*such*that*`&Mscr;`(p, q) <> `&Dscr;`(p, q)
2, 3, 6, 7, 10, 11, 14, 15, 18, 19
{`mod`(p[i], p[j])+(1/4)*p[j]*(p[j]-1)} = 1-delta({(1/4)*p[j]}, 0)-delta({(p[j]-1)*(1/4)}, 0)+delta({(1/4)*p[j]}, 0)*delta({(p[j]-1)*(1/4)}, 0)+1/2*(delta({(p[j]-2)*(1/4)}, 0)+delta({(p[j]-3)*(1/4)}, 0)-delta({(p[j]-2)*(1/4)}, 0)*delta({(p[j]-3)*(1/4)}, 0))
Numbers congruent to 2 or 3 mod 4.
WHEN ALL TERMS ARE PLACED ON THE LHS AND 0 ON THE OTHER, THE OUTPUT PLACES ALL p,q IN THE SET T, AS I EXPECTED.
restart; S := {}; with(combinat); with(numtheory); T := {}; F := {}; C := {}; AlphaTotal := {}; BetaTotal := {}
delta := proc (x, y) options operator, arrow; piecewise(x = y, 1, x <> y, 0) end proc
Identity := proc (p, q) options operator, arrow; frac(`mod`(p, q)+(1/4)*q*(q-1))+delta(frac((1/4)*q), 0)+delta(frac((1/4)*q-1/4), 0)-delta(frac((1/4)*q), 0)*delta(frac((1/4)*q-1/4), 0)+(1/2)*delta(frac((1/4)*q-1/2), 0)+(1/2)*delta(frac((1/4)*q-3/4), 0)-(1/2)*delta(frac((1/4)*q-1/2), 0)*delta(frac((1/4)*q-3/4), 0)-1 = 0 end proc
GenerateOddPrimeNumberPairs := proc (N) options operator, arrow; choose([seq(ithprime(k), k = 1 .. N)], 2) end proc
AssignToTrueOrFalseSet := proc (x, y) global T, F; if is(Identity(x, y)) = true then T := `union`({[x, y]}, T) else F := `union`({[x, y]}, F) end if end proc
QueryIdentity := proc (N) local P, k; P := GenerateOddPrimeNumberPairs(N); for k to nops(P) do AssignToTrueOrFalseSet(P[k][1], P[k][2]) end do end proc
QueryIdentity(20); T; F
{[2, 3], [2, 5], [2, 7], [2, 11], [2, 13], [2, 17], [2, 19], [2, 23], [2, 29], [2, 31], [2, 37], [2, 41], [2, 43], [2, 47], [2, 53], [2, 59], [2, 61], [2, 67], [2, 71], [3, 5], [3, 7], [3, 11], [3, 13], [3, 17], [3, 19], [3, 23], [3, 29], [3, 31], [3, 37], [3, 41], [3, 43], [3, 47], [3, 53], [3, 59], [3, 61], [3, 67], [3, 71], [5, 7], [5, 11], [5, 13], [5, 17], [5, 19], [5, 23], [5, 29], [5, 31], [5, 37], [5, 41], [5, 43], [5, 47], [5, 53], [5, 59], [5, 61], [5, 67], [5, 71], [7, 11], [7, 13], [7, 17], [7, 19], [7, 23], [7, 29], [7, 31], [7, 37], [7, 41], [7, 43], [7, 47], [7, 53], [7, 59], [7, 61], [7, 67], [7, 71], [11, 13], [11, 17], [11, 19], [11, 23], [11, 29], [11, 31], [11, 37], [11, 41], [11, 43], [11, 47], [11, 53], [11, 59], [11, 61], [11, 67], [11, 71], [13, 17], [13, 19], [13, 23], [13, 29], [13, 31], [13, 37], [13, 41], [13, 43], [13, 47], [13, 53], [13, 59], [13, 61], [13, 67], [13, 71], [17, 19], [17, 23], [17, 29], [17, 31], [17, 37], [17, 41], [17, 43], [17, 47], [17, 53], [17, 59], [17, 61], [17, 67], [17, 71], [19, 23], [19, 29], [19, 31], [19, 37], [19, 41], [19, 43], [19, 47], [19, 53], [19, 59], [19, 61], [19, 67], [19, 71], [23, 29], [23, 31], [23, 37], [23, 41], [23, 43], [23, 47], [23, 53], [23, 59], [23, 61], [23, 67], [23, 71], [29, 31], [29, 37], [29, 41], [29, 43], [29, 47], [29, 53], [29, 59], [29, 61], [29, 67], [29, 71], [31, 37], [31, 41], [31, 43], [31, 47], [31, 53], [31, 59], [31, 61], [31, 67], [31, 71], [37, 41], [37, 43], [37, 47], [37, 53], [37, 59], [37, 61], [37, 67], [37, 71], [41, 43], [41, 47], [41, 53], [41, 59], [41, 61], [41, 67], [41, 71], [43, 47], [43, 53], [43, 59], [43, 61], [43, 67], [43, 71], [47, 53], [47, 59], [47, 61], [47, 67], [47, 71], [53, 59], [53, 61], [53, 67], [53, 71], [59, 61], [59, 67], [59, 71], [61, 67], [61, 71], [67, 71]}
BUT WHEN THE EQUALITY IS DEFINED AS FOLLOWS, SOME RESULTS ARE PLACED IN THE F SET. (INDICATING THE EQUALITY FOR ALL [p,q] is FALSE)
Identity := proc (p, q) options operator, arrow; frac(`mod`(p, q)+(1/4)*q*(q-1)) = 1-delta(frac((1/4)*q), 0)-delta(frac((1/4)*q-1/4), 0)+delta(frac((1/4)*q), 0)*delta(frac((1/4)*q-1/4), 0)+(1/2)*delta(frac((1/4)*q-1/2), 0)+(1/2)*delta(frac((1/4)*q-3/4), 0)-(1/2)*delta(frac((1/4)*q-1/2), 0)*delta(frac((1/4)*q-3/4), 0) end proc:
GenerateNumberPairs := proc (N) options operator, arrow; choose([seq(ithprime(k), k = 1 .. N)], 2) end proc:
AssignToTrueOrFalseSet := proc (x, y) global T, F; if is(Identity(x, y)) = true then T := `union`({[x, y]}, T) else F := `union`({[x, y]}, F) end if end proc:
QueryIdentity := proc (N) local P, k; P := GenerateNumberPairs(N); for k to nops(P) do AssignToTrueOrFalseSet(P[k][1], P[k][2]) end do end proc:
QueryIdentity(20):
{[2, 5], [2, 13], [2, 17], [2, 29], [2, 37], [2, 41], [2, 53], [2, 61], [3, 5], [3, 13], [3, 17], [3, 29], [3, 37], [3, 41], [3, 53], [3, 61], [5, 13], [5, 17], [5, 29], [5, 37], [5, 41], [5, 53], [5, 61], [7, 13], [7, 17], [7, 29], [7, 37], [7, 41], [7, 53], [7, 61], [11, 13], [11, 17], [11, 29], [11, 37], [11, 41], [11, 53], [11, 61], [13, 17], [13, 29], [13, 37], [13, 41], [13, 53], [13, 61], [17, 29], [17, 37], [17, 41], [17, 53], [17, 61], [19, 29], [19, 37], [19, 41], [19, 53], [19, 61], [23, 29], [23, 37], [23, 41], [23, 53], [23, 61], [29, 37], [29, 41], [29, 53], [29, 61], [31, 37], [31, 41], [31, 53], [31, 61], [37, 41], [37, 53], [37, 61], [41, 53], [41, 61], [43, 53], [43, 61], [47, 53], [47, 61], [53, 61], [59, 61]}
{[2, 3], [2, 7], [2, 11], [2, 19], [2, 23], [2, 31], [2, 43], [2, 47], [2, 59], [2, 67], [2, 71], [3, 7], [3, 11], [3, 19], [3, 23], [3, 31], [3, 43], [3, 47], [3, 59], [3, 67], [3, 71], [5, 7], [5, 11], [5, 19], [5, 23], [5, 31], [5, 43], [5, 47], [5, 59], [5, 67], [5, 71], [7, 11], [7, 19], [7, 23], [7, 31], [7, 43], [7, 47], [7, 59], [7, 67], [7, 71], [11, 19], [11, 23], [11, 31], [11, 43], [11, 47], [11, 59], [11, 67], [11, 71], [13, 19], [13, 23], [13, 31], [13, 43], [13, 47], [13, 59], [13, 67], [13, 71], [17, 19], [17, 23], [17, 31], [17, 43], [17, 47], [17, 59], [17, 67], [17, 71], [19, 23], [19, 31], [19, 43], [19, 47], [19, 59], [19, 67], [19, 71], [23, 31], [23, 43], [23, 47], [23, 59], [23, 67], [23, 71], [29, 31], [29, 43], [29, 47], [29, 59], [29, 67], [29, 71], [31, 43], [31, 47], [31, 59], [31, 67], [31, 71], [37, 43], [37, 47], [37, 59], [37, 67], [37, 71], [41, 43], [41, 47], [41, 59], [41, 67], [41, 71], [43, 47], [43, 59], [43, 67], [43, 71], [47, 59], [47, 67], [47, 71], [53, 59], [53, 67], [53, 71], [59, 67], [59, 71], [61, 67], [61, 71], [67, 71]}
BUT CHECKING THESE RESULTS 'MANUALLY' CONFIRMS THE EQUALITY IS INDEED TRUE FOR ALL ODD PRIME PAIRS  p,q.
{seq(F[k][2], k = 1 .. nops(F))}
{3, 7, 11, 19, 23, 31, 43, 47, 59, 67, 71}
seq(frac(`mod`(F[k][1], F[k][2])+(1/4)*F[k][2]*(F[k][2]-1)), k = 1 .. nops(F))
1/2, 1/2, 1/2, 1/2, 1/2, 1/2, 1/2, 1/2, 1/2, 1/2, 1/2, 1/2, 1/2, 1/2, 1/2, 1/2, 1/2, 1/2, 1/2, 1/2, 1/2, 1/2, 1/2, 1/2, 1/2, 1/2, 1/2, 1/2, 1/2, 1/2, 1/2, 1/2, 1/2, 1/2, 1/2, 1/2, 1/2, 1/2, 1/2, 1/2, 1/2, 1/2, 1/2, 1/2, 1/2, 1/2, 1/2, 1/2, 1/2, 1/2, 1/2, 1/2, 1/2, 1/2, 1/2, 1/2, 1/2, 1/2, 1/2, 1/2, 1/2, 1/2, 1/2, 1/2, 1/2, 1/2, 1/2, 1/2, 1/2, 1/2, 1/2, 1/2, 1/2, 1/2, 1/2, 1/2, 1/2, 1/2, 1/2, 1/2, 1/2, 1/2, 1/2, 1/2, 1/2, 1/2, 1/2, 1/2, 1/2, 1/2, 1/2, 1/2, 1/2, 1/2, 1/2, 1/2, 1/2, 1/2, 1/2, 1/2, 1/2, 1/2, 1/2, 1/2, 1/2, 1/2, 1/2, 1/2, 1/2, 1/2, 1/2, 1/2, 1/2
seq(frac(-delta(frac((1/4)*F[k][2]), 0)-delta(frac((F[k][2]-1)*(1/4)), 0)+delta(frac((1/4)*F[k][2]), 0)*delta(frac((F[k][2]-1)*(1/4)), 0)+1/2*(delta(frac((F[k][2]-2)*(1/4)), 0)+delta(frac((F[k][2]-3)*(1/4)), 0)-delta(frac((F[k][2]-2)*(1/4)), 0)*delta(frac((F[k][2]-3)*(1/4)), 0))+1), k = 1 .. nops(F))
[seq(frac(`mod`(T[k][1], T[k][2])+(1/4)*T[k][2]*(T[k][2]-1)), k = 2 .. nops(T))]
[0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0]
seq(frac(-delta(frac((1/4)*T[k][2]), 0)-delta(frac((T[k][2]-1)*(1/4)), 0)+delta(frac((1/4)*T[k][2]), 0)*delta(frac((T[k][2]-1)*(1/4)), 0)+1/2*(delta(frac((T[k][2]-2)*(1/4)), 0)+delta(frac((T[k][2]-3)*(1/4)), 0)-delta(frac((T[k][2]-2)*(1/4)), 0)*delta(frac((T[k][2]-3)*(1/4)), 0))+1), k = 1 .. nops(F))
0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0
Download KRONECKER_delta_RECIPROCITY.mw
I am trying to plot some movement equations, but the following error keeps happening:
when I tryed to rewrite the equation the error became:
Error, (in DEtools/convertsys) invalid specification of initial conditions
Can someone help me with those errors?
Here is the code:
with(LinearAlgebra);
with(linalg);
with(DifferentialGeometry);
with(VariationalCalculus);
with(Tensor);
with(tensor);
with(Tools);
DGsetup([t, x, y, z], M)
g1 := evalDG(N(t)^2*`&t`(dt, dt)-a(t)^2*(`&t`(dx, dx)+`&t`(dy, dy)+`&t`(dz, dz)))
g1inv := InverseMetric(g1)
C1 := Christoffel(g1)
RM1 := CurvatureTensor(C1)
RM1g := CurvatureTensor(g1)
ContractIndices(RM1, [[1, 3]])
ContractIndices(RM1g, [[1, 3]])
RT := RicciTensor(g1, RM1)
ContractIndices(RT, g1inv, [[1, 1], [2, 2]])
S1 := RicciScalar(g1, RM1)
RM1contra := RaiseLowerIndices(g1inv, RM1, [2, 3, 4])
RM1cov := RaiseLowerIndices(g1, RM1, [1])
Kret1 := ContractIndices(RM1contra, RM1cov, [[1, 1], [2, 2], [3, 3], [4, 4]])
eval(simplify(subs(N(t) = 1, Kret1)))
Lag := a(t)^3*N(t)*Kret1
phi = phi(t)
Lam := -(1/2)*a(t)^3*N(t)*((diff(phi, t))^2/N(t)^2+m^2*phi)
Ltot := Lag+Lam
EqELN := EulerLagrange(Ltot, t, N(t))
EqN := eval(simplify(subs(N(t) = 1, EqELN)))
Eqa := subs(N(t) = 1, Ltot)
EqELa := EulerLagrange(EqaD, t, a(t))
tini := 0
with(DEtools)
with(plots)
tfin = 10
(D(a))(tini) = 0
((D@@2)(a))(tini) = 0
((D@@3)(a))(tini) = 0
phi := a^-3
Dphi := 0
(D(N))(tini) = 0
((D@@2)(N))(tini) = 0
((D@@3)(N))(tini) = 0
sys1 := {EqN, a(tini) = 0.1e-2, (D(a))(tini) = 0.1e-2, ((D@@2)(a))(tini) = 0.1e-2, ((D@@3)(a))(tini) = 1}
tfin = 2
p1 := dsolve(sys1, type = numeric, abserr = 1.*10^(-8), relerr = 1.*10^(-8), range = tini .. tfin)
figN := odeplot(p1, [t, a(t)])
sys2 := {EqELa, a(tini) = 0.1e-6, (D(a))(tini) = 0.1e-4, ((D@@2)(a))(tini) = 0.1e-5, ((D@@3)(a))(tini) = 1, ((D@@4)(a))(tini) = 0.1e-5}
p2 := dsolve(sys2, type = numeric, abserr = 1.*10^(-8), relerr = 1.*10^(-8), range = tini .. tfin)
figa := odeplot(p2, [t, a(t)])
How do I plot the following with Maple 2015?
For my differential equations class we have to input the following problem into Maple, I've never used maple before and I was wondering if someone who is experienced with maple could help me out with the code to put into Maple. Thanks I appreciate it!
Using the Maple program, Write the procedure RungeKutta(f, a, b, aplpha, n) which use the improved Euler's method to approximate the solution of the initial-value problem y'=f(t,y), a\leqt\leqb, y(a)= alpha at (n+1) equally spaced numbers in the interval [a,b]
The input parameters are as follow:
f is the name of the function f(t,y);
a and b are the end points of the interval of integration;
alpha is the initial condition.
The output: array w is the approximation of y at the (n+1) values of t.
I'm really not sure what else to say that isnt already obvious from the worksheet i uploaded, it's pretty obvious what i am trying to do i just dont understand what neutral operator even is, and couldn't find anything on the help page i was directed to by the error.
with(StringTools):
Join([convert(A, 'string'), "=", convert(B, 'string'), "(mod", convert(Set2[1], 'string'), ")"])
"A = B (mod Set2[1] )"
"convert(&equiv;,'string')"
Error, invalid neutral operator
Download INVALID_NEUTRAL_OPERATOR.mw
I employed the sort command to sort through 10 solutions to a series of order 10.  However, I do not follow the logic of the output.  So I attempted to sort by ascending order by the magnitude, but I am getting errors which I am having trouble circumnavigating.  Can show me how to sort my solutions properly?
The worksheet is in my reply below.
with(PDEtools);
assume(k::real, x::real, omega::real, t::real, theta::real, c::real);
tr0 := c*(t*upsilon+x) = xi;
tr1 := I*(k*x+omega*t+theta);
tr2 := phi(lhs(tr0))*exp(tr1);
PDE := proc (u) options operator, arrow; I*(diff(u, t))+diff(u, x, x)-I*sigma*u*(conjugate(u)*(diff(u, x))-u*(diff(conjugate(u), x))) end proc;
Eq1 := PDE(tr2);
Eq2 := simplify(convert(expand(subs(tr0, Eq1)), diff));
for_maple_prime.mw
Hi, I'm currently studying the dynamics of a system of ODEs and I would like to plot a bifurcation diagram using Maple.
The system is:
diff(x(t), t) = -y(t)-z(t)
 diff(y(t), t) = x(t)+a*y(t)
diff(z(t), t) = b+x(t)*z(t)-c*z(t).
Can anyone help me with a procedure to output a bifurcation diagram for the system?
First 877 878 879 880 881 882 883 Last Page 879 of 2459
