when i replace mu=0 in my equation mu[3] and mu[4] also become zero why ?
with(PDEtools)
with(LinearAlgebra)
with(SolveTools)
undeclare(prime)
B[1] := 0; mu := 0
U1 := lambda*(1+sqrt(-lambda)*(cosh(xi*sqrt(-lambda))*B[2]+sinh(xi*sqrt(-lambda))*B[1])*`&+-`(sqrt(lambda/(lambda^2*B[1]^2-lambda^2*B[2]^2-mu^2))))*beta[0]*exp(I*(d*x+e*y+f*t^beta/beta))/(B[1]*cosh(xi*sqrt(-lambda))*lambda+B[2]*sinh(xi*sqrt(-lambda))*lambda+mu)
(1+(-lambda)^(1/2)*cosh(xi*(-lambda)^(1/2))*B[2]*`&+-`((-1/(lambda*B[2]^2))^(1/2)))*beta[0]*exp(I*(d*x+e*y+f*t^beta/beta))/(B[2]*sinh(xi*(-lambda)^(1/2)))
V1 := -mu[4]*b*lambda^2*(1+sqrt(-lambda)*(cosh(xi*sqrt(-lambda))*B[2]+sinh(xi*sqrt(-lambda))*B[1])*`&+-`(sqrt(lambda/(lambda^2*B[1]^2-lambda^2*B[2]^2-mu^2))))^2*beta[0]^2/((B[1]*cosh(xi*sqrt(-lambda))*lambda+B[2]*sinh(xi*sqrt(-lambda))*lambda+mu)^2*a*mu[3])
Error, numeric exception: division by zero
Download tester.mw
The local command is really horribly treated in the manual. Very difficult to figure out heads from tails.
What follows is Maple code to unprotect the metric tensor g_[], and alter the components. that part I figured out by trial and error where the manual fails to clearly describe how.
But, the problem I now have, is that the unprotected metric does not show the tensor "visual matrix" form anymore if I execute  g_[] . So it makes it all unusable.
How do I enter the unprotected and altered g_[] back into maple so it can be used to calculate the Ricci tensor, Einstein tensor and such ? I guess it will have to be protected again etc. ?
Here is the code
with(Physics);
g_[sc];
g_[];
_local(g_[]);
g_[1, 2] := 1;
g_[3, 3];
Physics:-g_[1, 1];
g_[1, 2];
Physics:-g_[1, 1];
g_[];
for x to 4 do
    for y to 4 do g_[x, y] := Physics:-g_[x, y]; end do;
g_[];
So the question is. How do you reverse a localalized metric back to being protected after you altered the metric ?
I am sure that this question must be answered. But when I do a search in the "Search" box, I always receive a page where it  is mentioned that there is an error of generating the page.  So this has been the case for more than a month, or maybe more. I don't know why this is happening.  So that is the reason why I ask a question here.
I would like to put an entry in the file maple.ini so that each time I do the command "plot", the size of the plot in the document will be a size=[300,300] in pixels.  That is supposed to give a plot of 8 cm by 8 cm.  So when I print the document, which will be the size of the plot on the printed page.  I want to do that because if I do not modify the size of the plot by default in the document, it takes up too much space in the page.  I want to do it in maple.ini so I don't have to do it manually each time I plot a function.
How we can calculate solution of this ODE by give assumption to the equation , we have otehr case too, like lambda>0&mu<0
I have a lot of questions about using evalf/Int with Monte-Carlo like methods.
They are red written in the attached file and concern several different points.
I would like you to answer each of them and not to focus on a specific one.
method=_MonteCarlo uses the Fortran procedure d01gbc (maybe Maple rewritten?): the original NAG procedure is described here d01gbc
kernelopts(version)
domain := 0.8..3.;
f := x -> 1/(1 + sinh(2*x)*log(x)^2);
.8 .. 3.
proc (x) options operator, arrow; 1/(1+sinh(2*x)*log(x)^2) end proc
infolevel[`evalf/int`] := 4:
# I understand _CubaSuave used a random sample of size 134000 of the (x, y) integration domain.
# Am I right?
evalf(Int(f(x), [x=domain, y=0..1], method=_CubaSuave, epsilon=1e-4));
printf("\n%s\n", cat("-"$100));
# Did _CubaDivonne used a random sample of size 3256 ?
evalf(Int(f(x), [x=domain, y=0..1], 'method=_CubaDivonne', epsilon=1e-4));
# What is the true number of points _MonteCarlo used?
evalf(Int(f(x), [x=domain, y=0..1], method=_MonteCarlo, epsilon=1e-4));
Control_multi: integrating on [.8, 0] .. [3., 1] the integrand
1/(1+sinh(2*x)*ln(x)^2)
cuba: transformed original integrand
cuba: with lower bounds [.8, 0.] and upper bounds [3., 1.], to the following integrand to be integrated over the unit n-cube:
2.2/(1+sinh(4.4*x+1.6)*ln(2.2*x+.8)^2)
cuba: integration completed successfully
cuba: # of integrand evaluations: 134000
cuba: estimated (absolute) error: 6.73167e-05
cuba: chi-square probability that the error is not reliable: 1
cuba: number of regions that the domain was divided into: 134
HFloat(0.6770776956970137)
cuba: # of integrand evaluations: 3256
cuba: estimated (absolute) error: 6.37672e-05
cuba: chi-square probability that the error is not reliable: 0
cuba: number of regions that the domain was divided into: 22
HFloat(0.6768372810943345)
trying d01gbc (nag_multi_quad_monte_carlo)
d01gbc: epsrel=.1e-3; minpts=0; maxpts=500000000; method=2; cont=0
d01gbc: procedure for evaluation is:
proc (X) 1/(1.+sinh(2.*X[1])*ln(X[1])^2) end proc
d01gbc: result=.676840185506968228
d01gbc: relerr=.103631215397982221e-4; usedpts=1044
.6768401855
# By the way, why is infolevel[`evalf/int`] output discarded?
.6768401855
# Let us suppose I don(t care of the accuracy of the result as I am capable to assess it
# by some other way:
#      How can I use a Monte-Carlo integration method with a given number of points?
#      Why there is no estimation of the integral returned?
infolevel[`evalf/int`] := 0:
evalf(
  Int(
    , method=_CubaVegas
    , methodoptions=[minimalpoints = 10^3, maximalpoints = 10^3]
cuba: could not attain requested accuracy
cuba: # of integrand evaluations: 1000
cuba: estimated (absolute) error: 0.025423
cuba: chi-square probability that the error is not reliable: -999
evalf/int: error from Control_multi was:
"could not attain requested accuracy; try increasing epsilon or absepsilon or maximalpoints"
Int(Int(1/(1.+sinh(2.*x)*ln(x)^2), x = .8 .. 3.), y = 0. .. 1.)
evalf(
  Int(
    , method=_CubaSuave
evalf(
  Int(
"NAG d01gbc expects epsilon >= 0.5e-4, but received %1", .5000000000e-9
# Example 8 of the reference given in the question text
evalf(Int(4*x1*x3^2*exp(2*x1*x3)/(1+x2+x4)^2, [seq(x||i=0..1, i=1..4)], method=_MonteCarlo, epsilon=1e-2))
.5753724460
# Why is not the seeed updated ?
for j from 1 to 3 do
  Threads:-Sleep(10):
.5753724460
.5753724460
.5753724460
# Here a new seed is forced at each iteration but the estimations of the integral are always the same.
# This is impossible as these estimationsare the realizations of a random variable: so they cannot be identical.
# So, does evalf/Int always use the same internal seed?
# More importantly: does it really use a random generator?
  seed := randomize(rand()());
  J := evalf(Int(4*x1*x3^2*exp(2*x1*x3)/(1+x2+x4)^2, [seq(x||i=0..1, i=1..4)], method=_MonteCarlo, epsilon=1e-2)):
  print('seed' = seed,  'J' = J);
Control_multi: integrating on [0, 0, 0, 0] .. [1, 1, 1, 1] the integrand
d01gbc: epsrel=.1e-1; minpts=0; maxpts=500000000; method=2; cont=0
proc (X) 4.*X[1]*X[3]^2*exp(2.*X[1]*X[3])/(1.+X[2]+X[4])^2 end proc
d01gbc: result=.574090186993690188
d01gbc: relerr=.675204841605886539e-2; usedpts=8064
seed = 233366062458, J = .5740901870
seed = 887991988815, J = .5740901870
seed = 416683078956, J = .5740901870
# This is what one expects from Monte-Carlo integration
use Statistics in
  for i from 1 to 10 do
    S := Sample(Uniform(op(domain)), 100):
    print('seed' = seed,  'J' = Mean(f~(S)) * (- `-`(op(domain))) );
end use:
seed = 36995932795, J = HFloat(0.6280945376385327)
seed = 976943479321, J = HFloat(0.7320842356827296)
seed = 542869221880, J = HFloat(0.6519958887669823)
seed = 303692769322, J = HFloat(0.6134976803250747)
seed = 443233702046, J = HFloat(0.6304929479488379)
seed = 881136125112, J = HFloat(0.6528328283998008)
seed = 708639694457, J = HFloat(0.6601745158455014)
seed = 675811574035, J = HFloat(0.7640187396123023)
seed = 164464632871, J = HFloat(0.7949627835070758)
seed = 604897894346, J = HFloat(0.5922357495886873)
Download Numerical_integration_Using_MC_methods.mw
On considère un cercle fixe O et un point fixe A extérieur. Une sécante variable BC à ce cercle passe par un point fixe J.
Démontrer que le cercle ABC passe par un second point fixe P.
Proc := proc(m)
local xA, yA, xB, yB, xC, yC, xJ, yJ, tx, dr, Oo, c1, r, eqBJ, eq1, sol;
_EnvHorizontalName := 'x'; _EnvVerticalName := 'y';
xJ := 5; yJ := 1; geometry:-point(A, 2, 4); geometry:-point(J, xJ, yJ); geometry:-point(Oo, 0, 0);
r := 3; c1 := plottools[geometry:-circle]([0, 0], r, color = blue);
eqBJ := y = m*(x - xJ) + yJ; geometry:-line(BJ, eqBJ, [x, y]);
eq1 := x^2 + y^2 = r^2; sol := solve({eqBJ, eq1}, {x, y}, explicit);
xB := subs(sol[1], x); yB := subs(sol[1], y);
geometry:-point(B, xB, yB); xC := subs(sol[2], x); yC := subs(sol[2], y);
geometry:-point(C, xC, yC); geometry:-circle(c2, [A, B, C]); geometry:-line(AB, [A, B]); geometry:-line(AC, [A, C]);
eq1 := x^2 + y^2 = r^2; sol := solve({eqBJ, eq1}, {x, y},explicit);
xB := subs(sol[1], x); yB := subs(sol[1], y); geometry:-point(B, xB, yB);
xC := subs(sol[2], x); yC := subs(sol[2], y); geometry:-point(C, xC, yC);
tx := plots:-textplot([[geometry:-coordinates(A)[], "A"], [geometry:-coordinates(B)[], "B"], [geometry:-coordinates(C)[], "C"], [geometry:-coordinates(J)[], "J"]], font = [times, bold, 16], align = [above, right]);
dr := geometry:-draw([AB(color = black), c2(color = magenta), A(color = blue, symbol = solidcircle, symbolsize = 16),
B(color = red, symbol = solidcircle, symbolsize = 16), C(color = red, symbol = solidcircle, symbolsize = 16),
J(color = red, symbol = solidcircle, symbolsize = 16)]); plots:-display([dr, c1, tx], axes = normal, view = [-5 .. 6, -4 .. 6], scaling = constrained);
plots:-animate(Proc, [m], m = -0.9 .. 0.2*Pi, frames = 50);
Error, (in plots/animate) two lists or Vectors of numerical values expected
NULL;
I am trying to find out point P; Thank you for your help.
From time to time Maple output containts brackets that are nor needed. Example:
int(f(x),x=a..c)-int(f(x),x=a..b);
simplify(%) assuming c>b
Why is that? Is there a way not to have these brackets printed?
Is there a way to force Maple to use basic linear algebra results?
Here is a result you can find in any linear algebra book (this one comes from Harville's Matrix Algebra From a Statistician's Perspective)
I'm using Maple to check my work and it would be helpful if some basic linear algebra results would be injected in Maple's algorithm.
kernelopts(version); interface(version)
`Maple 2024.2, X86 64 WINDOWS, Oct 29 2024, Build ID 1872373`
`Standard Worksheet Interface, Maple 2024.2, Windows 11, October 29 2024 Build ID 1872373`
restart; with(LinearAlgebra)
alias(`&bigotimes;` = LinearAlgebra:-KroneckerProduct)
`&bigotimes;`
for dim from 2 to 5 do A := Matrix(dim, dim, shape = symmetric, symbol = a); print(dim, Equal(1/`&bigotimes;`(A, A), `&bigotimes;`(1/A, 1/A)), simplify(1/`&bigotimes;`(A, A)-`&bigotimes;`(1/A, 1/A), symbolic)) end do; for dim from 2 to 5 do A := Matrix(dim, dim, shape = symmetric, symbol = a); print(dim, Equal(simplify(1/`&bigotimes;`(A, A)), simplify(`&bigotimes;`(1/A, 1/A))), simplify(1/`&bigotimes;`(A, A)-`&bigotimes;`(1/A, 1/A), symbolic)) end do
2, true, [`?`]
3, false, [`?`]
4, false, Matrix(16, 16, {(1, 1) = 0, (1, 2) = 0, (1, 3) = 0, (1, 4) = 0, (1, 5) = 0, (1, 6) = 0, (1, 7) = 0, (1, 8) = 0, (1, 9) = 0, (1, 10) = 0, (1, 11) = 0, (1, 12) = 0, (1, 13) = 0, (1, 14) = 0, (1, 15) = 0, (1, 16) = 0, (2, 1) = 0, (2, 2) = 0, (2, 3) = 0, (2, 4) = 0, (2, 5) = 0, (2, 6) = 0, (2, 7) = 0, (2, 8) = 0, (2, 9) = 0, (2, 10) = 0, (2, 11) = 0, (2, 12) = 0, (2, 13) = 0, (2, 14) = 0, (2, 15) = 0, (2, 16) = 0, (3, 1) = 0, (3, 2) = 0, (3, 3) = 0, (3, 4) = 0, (3, 5) = 0, (3, 6) = 0, (3, 7) = 0, (3, 8) = 0, (3, 9) = 0, (3, 10) = 0, (3, 11) = 0, (3, 12) = 0, (3, 13) = 0, (3, 14) = 0, (3, 15) = 0, (3, 16) = 0, (4, 1) = 0, (4, 2) = 0, (4, 3) = 0, (4, 4) = 0, (4, 5) = 0, (4, 6) = 0, (4, 7) = 0, (4, 8) = 0, (4, 9) = 0, (4, 10) = 0, (4, 11) = 0, (4, 12) = 0, (4, 13) = 0, (4, 14) = 0, (4, 15) = 0, (4, 16) = 0, (5, 1) = 0, (5, 2) = 0, (5, 3) = 0, (5, 4) = 0, (5, 5) = 0, (5, 6) = 0, (5, 7) = 0, (5, 8) = 0, (5, 9) = 0, (5, 10) = 0, (5, 11) = 0, (5, 12) = 0, (5, 13) = 0, (5, 14) = 0, (5, 15) = 0, (5, 16) = 0, (6, 1) = 0, (6, 2) = 0, (6, 3) = 0, (6, 4) = 0, (6, 5) = 0, (6, 6) = 0, (6, 7) = 0, (6, 8) = 0, (6, 9) = 0, (6, 10) = 0, (6, 11) = 0, (6, 12) = 0, (6, 13) = 0, (6, 14) = 0, (6, 15) = 0, (6, 16) = 0, (7, 1) = 0, (7, 2) = 0, (7, 3) = 0, (7, 4) = 0, (7, 5) = 0, (7, 6) = 0, (7, 7) = 0, (7, 8) = 0, (7, 9) = 0, (7, 10) = 0, (7, 11) = 0, (7, 12) = 0, (7, 13) = 0, (7, 14) = 0, (7, 15) = 0, (7, 16) = 0, (8, 1) = 0, (8, 2) = 0, (8, 3) = 0, (8, 4) = 0, (8, 5) = 0, (8, 6) = 0, (8, 7) = 0, (8, 8) = 0, (8, 9) = 0, (8, 10) = 0, (8, 11) = 0, (8, 12) = 0, (8, 13) = 0, (8, 14) = 0, (8, 15) = 0, (8, 16) = 0, (9, 1) = 0, (9, 2) = 0, (9, 3) = 0, (9, 4) = 0, (9, 5) = 0, (9, 6) = 0, (9, 7) = 0, (9, 8) = 0, (9, 9) = 0, (9, 10) = 0, (9, 11) = 0, (9, 12) = 0, (9, 13) = 0, (9, 14) = 0, (9, 15) = 0, (9, 16) = 0, (10, 1) = 0, (10, 2) = 0, (10, 3) = 0, (10, 4) = 0, (10, 5) = 0, (10, 6) = 0, (10, 7) = 0, (10, 8) = 0, (10, 9) = 0, (10, 10) = 0, (10, 11) = 0, (10, 12) = 0, (10, 13) = 0, (10, 14) = 0, (10, 15) = 0, (10, 16) = 0, (11, 1) = 0, (11, 2) = 0, (11, 3) = 0, (11, 4) = 0, (11, 5) = 0, (11, 6) = 0, (11, 7) = 0, (11, 8) = 0, (11, 9) = 0, (11, 10) = 0, (11, 11) = 0, (11, 12) = 0, (11, 13) = 0, (11, 14) = 0, (11, 15) = 0, (11, 16) = 0, (12, 1) = 0, (12, 2) = 0, (12, 3) = 0, (12, 4) = 0, (12, 5) = 0, (12, 6) = 0, (12, 7) = 0, (12, 8) = 0, (12, 9) = 0, (12, 10) = 0, (12, 11) = 0, (12, 12) = 0, (12, 13) = 0, (12, 14) = 0, (12, 15) = 0, (12, 16) = 0, (13, 1) = 0, (13, 2) = 0, (13, 3) = 0, (13, 4) = 0, (13, 5) = 0, (13, 6) = 0, (13, 7) = 0, (13, 8) = 0, (13, 9) = 0, (13, 10) = 0, (13, 11) = 0, (13, 12) = 0, (13, 13) = 0, (13, 14) = 0, (13, 15) = 0, (13, 16) = 0, (14, 1) = 0, (14, 2) = 0, (14, 3) = 0, (14, 4) = 0, (14, 5) = 0, (14, 6) = 0, (14, 7) = 0, (14, 8) = 0, (14, 9) = 0, (14, 10) = 0, (14, 11) = 0, (14, 12) = 0, (14, 13) = 0, (14, 14) = 0, (14, 15) = 0, (14, 16) = 0, (15, 1) = 0, (15, 2) = 0, (15, 3) = 0, (15, 4) = 0, (15, 5) = 0, (15, 6) = 0, (15, 7) = 0, (15, 8) = 0, (15, 9) = 0, (15, 10) = 0, (15, 11) = 0, (15, 12) = 0, (15, 13) = 0, (15, 14) = 0, (15, 15) = 0, (15, 16) = 0, (16, 1) = 0, (16, 2) = 0, (16, 3) = 0, (16, 4) = 0, (16, 5) = 0, (16, 6) = 0, (16, 7) = 0, (16, 8) = 0, (16, 9) = 0, (16, 10) = 0, (16, 11) = 0, (16, 12) = 0, (16, 13) = 0, (16, 14) = 0, (16, 15) = 0, (16, 16) = 0})
5, false, Matrix(25, 25, {(1, 1) = 0, (1, 2) = 0, (1, 3) = 0, (1, 4) = 0, (1, 5) = 0, (1, 6) = 0, (1, 7) = 0, (1, 8) = 0, (1, 9) = 0, (1, 10) = 0, (1, 11) = 0, (1, 12) = 0, (1, 13) = 0, (1, 14) = 0, (1, 15) = 0, (1, 16) = 0, (1, 17) = 0, (1, 18) = 0, (1, 19) = 0, (1, 20) = 0, (1, 21) = 0, (1, 22) = 0, (1, 23) = 0, (1, 24) = 0, (1, 25) = 0, (2, 1) = 0, (2, 2) = 0, (2, 3) = 0, (2, 4) = 0, (2, 5) = 0, (2, 6) = 0, (2, 7) = 0, (2, 8) = 0, (2, 9) = 0, (2, 10) = 0, (2, 11) = 0, (2, 12) = 0, (2, 13) = 0, (2, 14) = 0, (2, 15) = 0, (2, 16) = 0, (2, 17) = 0, (2, 18) = 0, (2, 19) = 0, (2, 20) = 0, (2, 21) = 0, (2, 22) = 0, (2, 23) = 0, (2, 24) = 0, (2, 25) = 0, (3, 1) = 0, (3, 2) = 0, (3, 3) = 0, (3, 4) = 0, (3, 5) = 0, (3, 6) = 0, (3, 7) = 0, (3, 8) = 0, (3, 9) = 0, (3, 10) = 0, (3, 11) = 0, (3, 12) = 0, (3, 13) = 0, (3, 14) = 0, (3, 15) = 0, (3, 16) = 0, (3, 17) = 0, (3, 18) = 0, (3, 19) = 0, (3, 20) = 0, (3, 21) = 0, (3, 22) = 0, (3, 23) = 0, (3, 24) = 0, (3, 25) = 0, (4, 1) = 0, (4, 2) = 0, (4, 3) = 0, (4, 4) = 0, (4, 5) = 0, (4, 6) = 0, (4, 7) = 0, (4, 8) = 0, (4, 9) = 0, (4, 10) = 0, (4, 11) = 0, (4, 12) = 0, (4, 13) = 0, (4, 14) = 0, (4, 15) = 0, (4, 16) = 0, (4, 17) = 0, (4, 18) = 0, (4, 19) = 0, (4, 20) = 0, (4, 21) = 0, (4, 22) = 0, (4, 23) = 0, (4, 24) = 0, (4, 25) = 0, (5, 1) = 0, (5, 2) = 0, (5, 3) = 0, (5, 4) = 0, (5, 5) = 0, (5, 6) = 0, (5, 7) = 0, (5, 8) = 0, (5, 9) = 0, (5, 10) = 0, (5, 11) = 0, (5, 12) = 0, (5, 13) = 0, (5, 14) = 0, (5, 15) = 0, (5, 16) = 0, (5, 17) = 0, (5, 18) = 0, (5, 19) = 0, (5, 20) = 0, (5, 21) = 0, (5, 22) = 0, (5, 23) = 0, (5, 24) = 0, (5, 25) = 0, (6, 1) = 0, (6, 2) = 0, (6, 3) = 0, (6, 4) = 0, (6, 5) = 0, (6, 6) = 0, (6, 7) = 0, (6, 8) = 0, (6, 9) = 0, (6, 10) = 0, (6, 11) = 0, (6, 12) = 0, (6, 13) = 0, (6, 14) = 0, (6, 15) = 0, (6, 16) = 0, (6, 17) = 0, (6, 18) = 0, (6, 19) = 0, (6, 20) = 0, (6, 21) = 0, (6, 22) = 0, (6, 23) = 0, (6, 24) = 0, (6, 25) = 0, (7, 1) = 0, (7, 2) = 0, (7, 3) = 0, (7, 4) = 0, (7, 5) = 0, (7, 6) = 0, (7, 7) = 0, (7, 8) = 0, (7, 9) = 0, (7, 10) = 0, (7, 11) = 0, (7, 12) = 0, (7, 13) = 0, (7, 14) = 0, (7, 15) = 0, (7, 16) = 0, (7, 17) = 0, (7, 18) = 0, (7, 19) = 0, (7, 20) = 0, (7, 21) = 0, (7, 22) = 0, (7, 23) = 0, (7, 24) = 0, (7, 25) = 0, (8, 1) = 0, (8, 2) = 0, (8, 3) = 0, (8, 4) = 0, (8, 5) = 0, (8, 6) = 0, (8, 7) = 0, (8, 8) = 0, (8, 9) = 0, (8, 10) = 0, (8, 11) = 0, (8, 12) = 0, (8, 13) = 0, (8, 14) = 0, (8, 15) = 0, (8, 16) = 0, (8, 17) = 0, (8, 18) = 0, (8, 19) = 0, (8, 20) = 0, (8, 21) = 0, (8, 22) = 0, (8, 23) = 0, (8, 24) = 0, (8, 25) = 0, (9, 1) = 0, (9, 2) = 0, (9, 3) = 0, (9, 4) = 0, (9, 5) = 0, (9, 6) = 0, (9, 7) = 0, (9, 8) = 0, (9, 9) = 0, (9, 10) = 0, (9, 11) = 0, (9, 12) = 0, (9, 13) = 0, (9, 14) = 0, (9, 15) = 0, (9, 16) = 0, (9, 17) = 0, (9, 18) = 0, (9, 19) = 0, (9, 20) = 0, (9, 21) = 0, (9, 22) = 0, (9, 23) = 0, (9, 24) = 0, (9, 25) = 0, (10, 1) = 0, (10, 2) = 0, (10, 3) = 0, (10, 4) = 0, (10, 5) = 0, (10, 6) = 0, (10, 7) = 0, (10, 8) = 0, (10, 9) = 0, (10, 10) = 0, (10, 11) = 0, (10, 12) = 0, (10, 13) = 0, (10, 14) = 0, (10, 15) = 0, (10, 16) = 0, (10, 17) = 0, (10, 18) = 0, (10, 19) = 0, (10, 20) = 0, (10, 21) = 0, (10, 22) = 0, (10, 23) = 0, (10, 24) = 0, (10, 25) = 0, (11, 1) = 0, (11, 2) = 0, (11, 3) = 0, (11, 4) = 0, (11, 5) = 0, (11, 6) = 0, (11, 7) = 0, (11, 8) = 0, (11, 9) = 0, (11, 10) = 0, (11, 11) = 0, (11, 12) = 0, (11, 13) = 0, (11, 14) = 0, (11, 15) = 0, (11, 16) = 0, (11, 17) = 0, (11, 18) = 0, (11, 19) = 0, (11, 20) = 0, (11, 21) = 0, (11, 22) = 0, (11, 23) = 0, (11, 24) = 0, (11, 25) = 0, (12, 1) = 0, (12, 2) = 0, (12, 3) = 0, (12, 4) = 0, (12, 5) = 0, (12, 6) = 0, (12, 7) = 0, (12, 8) = 0, (12, 9) = 0, (12, 10) = 0, (12, 11) = 0, (12, 12) = 0, (12, 13) = 0, (12, 14) = 0, (12, 15) = 0, (12, 16) = 0, (12, 17) = 0, (12, 18) = 0, (12, 19) = 0, (12, 20) = 0, (12, 21) = 0, (12, 22) = 0, (12, 23) = 0, (12, 24) = 0, (12, 25) = 0, (13, 1) = 0, (13, 2) = 0, (13, 3) = 0, (13, 4) = 0, (13, 5) = 0, (13, 6) = 0, (13, 7) = 0, (13, 8) = 0, (13, 9) = 0, (13, 10) = 0, (13, 11) = 0, (13, 12) = 0, (13, 13) = 0, (13, 14) = 0, (13, 15) = 0, (13, 16) = 0, (13, 17) = 0, (13, 18) = 0, (13, 19) = 0, (13, 20) = 0, (13, 21) = 0, (13, 22) = 0, (13, 23) = 0, (13, 24) = 0, (13, 25) = 0, (14, 1) = 0, (14, 2) = 0, (14, 3) = 0, (14, 4) = 0, (14, 5) = 0, (14, 6) = 0, (14, 7) = 0, (14, 8) = 0, (14, 9) = 0, (14, 10) = 0, (14, 11) = 0, (14, 12) = 0, (14, 13) = 0, (14, 14) = 0, (14, 15) = 0, (14, 16) = 0, (14, 17) = 0, (14, 18) = 0, (14, 19) = 0, (14, 20) = 0, (14, 21) = 0, (14, 22) = 0, (14, 23) = 0, (14, 24) = 0, (14, 25) = 0, (15, 1) = 0, (15, 2) = 0, (15, 3) = 0, (15, 4) = 0, (15, 5) = 0, (15, 6) = 0, (15, 7) = 0, (15, 8) = 0, (15, 9) = 0, (15, 10) = 0, (15, 11) = 0, (15, 12) = 0, (15, 13) = 0, (15, 14) = 0, (15, 15) = 0, (15, 16) = 0, (15, 17) = 0, (15, 18) = 0, (15, 19) = 0, (15, 20) = 0, (15, 21) = 0, (15, 22) = 0, (15, 23) = 0, (15, 24) = 0, (15, 25) = 0, (16, 1) = 0, (16, 2) = 0, (16, 3) = 0, (16, 4) = 0, (16, 5) = 0, (16, 6) = 0, (16, 7) = 0, (16, 8) = 0, (16, 9) = 0, (16, 10) = 0, (16, 11) = 0, (16, 12) = 0, (16, 13) = 0, (16, 14) = 0, (16, 15) = 0, (16, 16) = 0, (16, 17) = 0, (16, 18) = 0, (16, 19) = 0, (16, 20) = 0, (16, 21) = 0, (16, 22) = 0, (16, 23) = 0, (16, 24) = 0, (16, 25) = 0, (17, 1) = 0, (17, 2) = 0, (17, 3) = 0, (17, 4) = 0, (17, 5) = 0, (17, 6) = 0, (17, 7) = 0, (17, 8) = 0, (17, 9) = 0, (17, 10) = 0, (17, 11) = 0, (17, 12) = 0, (17, 13) = 0, (17, 14) = 0, (17, 15) = 0, (17, 16) = 0, (17, 17) = 0, (17, 18) = 0, (17, 19) = 0, (17, 20) = 0, (17, 21) = 0, (17, 22) = 0, (17, 23) = 0, (17, 24) = 0, (17, 25) = 0, (18, 1) = 0, (18, 2) = 0, (18, 3) = 0, (18, 4) = 0, (18, 5) = 0, (18, 6) = 0, (18, 7) = 0, (18, 8) = 0, (18, 9) = 0, (18, 10) = 0, (18, 11) = 0, (18, 12) = 0, (18, 13) = 0, (18, 14) = 0, (18, 15) = 0, (18, 16) = 0, (18, 17) = 0, (18, 18) = 0, (18, 19) = 0, (18, 20) = 0, (18, 21) = 0, (18, 22) = 0, (18, 23) = 0, (18, 24) = 0, (18, 25) = 0, (19, 1) = 0, (19, 2) = 0, (19, 3) = 0, (19, 4) = 0, (19, 5) = 0, (19, 6) = 0, (19, 7) = 0, (19, 8) = 0, (19, 9) = 0, (19, 10) = 0, (19, 11) = 0, (19, 12) = 0, (19, 13) = 0, (19, 14) = 0, (19, 15) = 0, (19, 16) = 0, (19, 17) = 0, (19, 18) = 0, (19, 19) = 0, (19, 20) = 0, (19, 21) = 0, (19, 22) = 0, (19, 23) = 0, (19, 24) = 0, (19, 25) = 0, (20, 1) = 0, (20, 2) = 0, (20, 3) = 0, (20, 4) = 0, (20, 5) = 0, (20, 6) = 0, (20, 7) = 0, (20, 8) = 0, (20, 9) = 0, (20, 10) = 0, (20, 11) = 0, (20, 12) = 0, (20, 13) = 0, (20, 14) = 0, (20, 15) = 0, (20, 16) = 0, (20, 17) = 0, (20, 18) = 0, (20, 19) = 0, (20, 20) = 0, (20, 21) = 0, (20, 22) = 0, (20, 23) = 0, (20, 24) = 0, (20, 25) = 0, (21, 1) = 0, (21, 2) = 0, (21, 3) = 0, (21, 4) = 0, (21, 5) = 0, (21, 6) = 0, (21, 7) = 0, (21, 8) = 0, (21, 9) = 0, (21, 10) = 0, (21, 11) = 0, (21, 12) = 0, (21, 13) = 0, (21, 14) = 0, (21, 15) = 0, (21, 16) = 0, (21, 17) = 0, (21, 18) = 0, (21, 19) = 0, (21, 20) = 0, (21, 21) = 0, (21, 22) = 0, (21, 23) = 0, (21, 24) = 0, (21, 25) = 0, (22, 1) = 0, (22, 2) = 0, (22, 3) = 0, (22, 4) = 0, (22, 5) = 0, (22, 6) = 0, (22, 7) = 0, (22, 8) = 0, (22, 9) = 0, (22, 10) = 0, (22, 11) = 0, (22, 12) = 0, (22, 13) = 0, (22, 14) = 0, (22, 15) = 0, (22, 16) = 0, (22, 17) = 0, (22, 18) = 0, (22, 19) = 0, (22, 20) = 0, (22, 21) = 0, (22, 22) = 0, (22, 23) = 0, (22, 24) = 0, (22, 25) = 0, (23, 1) = 0, (23, 2) = 0, (23, 3) = 0, (23, 4) = 0, (23, 5) = 0, (23, 6) = 0, (23, 7) = 0, (23, 8) = 0, (23, 9) = 0, (23, 10) = 0, (23, 11) = 0, (23, 12) = 0, (23, 13) = 0, (23, 14) = 0, (23, 15) = 0, (23, 16) = 0, (23, 17) = 0, (23, 18) = 0, (23, 19) = 0, (23, 20) = 0, (23, 21) = 0, (23, 22) = 0, (23, 23) = 0, (23, 24) = 0, (23, 25) = 0, (24, 1) = 0, (24, 2) = 0, (24, 3) = 0, (24, 4) = 0, (24, 5) = 0, (24, 6) = 0, (24, 7) = 0, (24, 8) = 0, (24, 9) = 0, (24, 10) = 0, (24, 11) = 0, (24, 12) = 0, (24, 13) = 0, (24, 14) = 0, (24, 15) = 0, (24, 16) = 0, (24, 17) = 0, (24, 18) = 0, (24, 19) = 0, (24, 20) = 0, (24, 21) = 0, (24, 22) = 0, (24, 23) = 0, (24, 24) = 0, (24, 25) = 0, (25, 1) = 0, (25, 2) = 0, (25, 3) = 0, (25, 4) = 0, (25, 5) = 0, (25, 6) = 0, (25, 7) = 0, (25, 8) = 0, (25, 9) = 0, (25, 10) = 0, (25, 11) = 0, (25, 12) = 0, (25, 13) = 0, (25, 14) = 0, (25, 15) = 0, (25, 16) = 0, (25, 17) = 0, (25, 18) = 0, (25, 19) = 0, (25, 20) = 0, (25, 21) = 0, (25, 22) = 0, (25, 23) = 0, (25, 24) = 0, (25, 25) = 0})
2, true, [`?`]
3, true, [`?`]
Download Using_basic_linear_algebra.mw
Hello! I need to write some text (a string) and some data in a file on the hard drive. Something like
"Hello, it is me"
3.1415
These two things written in two different consecutives lines in a file called /home/PNL/test_file.txt
I have tried WriteString, WriteFile but I failed miserably. Thank you very much!
How to specify the number of digits shown in the output of CrossProduct?  I've tried specifying the number of digits with Digits:=5: but CrossProduct seems to ignore that. I thought maybe setting the CrossProduct datatype to float might help, but it didn't.
What do I need to do?
I don't know if this is a false memory, but I think that I saw once a command in Maple that make a list of all the assumptions that have been done i the output space. A command that could be named "ListAssumption()" and you would get that list. In fact, I was wondering if this list could be shown in the palettes "Variables." There could be, below the variables, another table with the first row the name of the letter that you made an assume on, and the second row (the value) would show the assumption.  Like this maybe:
Just to get an idea.  Do you think it would be a great idea?
Hello Everyone,
I am wondring if I can  find the StandardRepresentation of a subalgebra of simple Lie algebra?
For example I have this code:
with(DifferentialGeometry);
with(LieAlgebras);
with(Library);
with(LinearAlgebra);
G := SimpleLieAlgebraData("sl(6)", sl6);
DGsetup(G);
StandardRepresentation(sl6);
M3 := MinimalSubalgebra([e30, e35, e20]);
B3 := LieAlgebraData(M3, p62);
Query("Jacobi");
DGsetup(B3);
StandardRepresentation(p62);
Error, (in DifferentialGeometry:-LieAlgebras:-StandardRepresentation) expected a Lie algebra constructed by the procedure SimpleLieAlgebraData
For the first StandardRepresentation(sl6); it works becouse of the definition. Now what I want the same idea for the subalgebra. How can I do that?
Any idea why Maple returns empty string when asked for the latex of the Laplace of x(t)?  Am I doing anything wrong here? I do not see it
`The "Physics Updates" version in the MapleCloud is 1828 and is the same as the version installed in this computer, created 2024, November 18, 7:25 hours Pacific Time.`
libname;
e:=inttrans:-laplace(x(t),t,s)
laplace(x(t), t, s)
latex(e,'output'='string')
Download latex_of_laplace_nov_21_2024.mw
I was expecting something like this using another software
Did Maple always behave this way for Laplace? I do not have earlier version now to check.  Any workaround?
Is this a known error when using PDEtools:-Solve? I get no error using solve on same input, so thought to ask, just in case it should not happen.
For now, I will change my code to use solve for this.
I am basically solving two equations in Laplace domain for Y1(s) and Y2(s). But since there are initial conditions x(0) and y(0) in the equations, and Laplace has L(x(t),t,s)  then PDEtools:-Solve is not happy, as it sees x(t) and x(0) in same input.
But solve has no problem with this. Who is correct? solve or Solve?
libname;
sys:=[s*laplace(x(t),t,s)-x(0) = -3*laplace(x(t),t,s)+4*laplace(y(t),t,s)+1/(s^2+1), s*laplace(y(t),t,s)-y(0) = -2*laplace(x(t),t,s)+3*laplace(y(t),t,s)+1/s^2];
Ys:=[laplace(x(t),t,s), laplace(y(t),t,s)];
[s*laplace(x(t), t, s)-x(0) = -3*laplace(x(t), t, s)+4*laplace(y(t), t, s)+1/(s^2+1), s*laplace(y(t), t, s)-y(0) = -2*laplace(x(t), t, s)+3*laplace(y(t), t, s)+1/s^2]
[laplace(x(t), t, s), laplace(y(t), t, s)]
solve(sys,Ys);
[[laplace(x(t), t, s) = (x(0)*s^5+4*y(0)*s^4-3*x(0)*s^4+x(0)*s^3+4*y(0)*s^2-3*x(0)*s^2+s^3+s^2+4)/((s^4-1)*s^2), laplace(y(t), t, s) = (y(0)*s^5+3*y(0)*s^4-2*x(0)*s^4+y(0)*s^3+3*y(0)*s^2-2*x(0)*s^2+s^3+s^2+s+3)/((s^4-1)*s^2)]]
PDEtools:-Solve(sys,Ys)
Error, (in PDEtools:-Solve) found functions with same name but depending on different arguments in the given DE system: x(0), x(t). Specification of the dependent variables is required
Download differenece_between_solve_and_Solve_nov_20_2024.mw
I have an irreducible polynomial f (over the rationals) with degree n. When I ask for the roots (using solve(f=0)), Maple outputs a sequence of roots, and somehow distinguishes between them. How does it do this? I had assumed that, when working with a RootOf, Maple would just figure out it was supposed to work in Q[x]/< f >, the quotient of the polynomials with rational coefficients by the principle ideal generated by f. In this field, it doesn't matter which of the n roots of f is represented by x + < f >, since all the roots satisfy the same algebraic relations (from this field).
Given this, I'm really interested to know how Maple can somehow distinguish between the roots, enough to be able to use them to recover distinct solutions to a polynomial system (by substituting in the different roots of f). Does it somehow "choose" an embedding of Q[x]/< f > into the complex numbers?
Thanks in advance!
First 90 91 92 93 94 95 96 Last Page 92 of 2463
