I've just discover something quite surprising for me... It turns out like if Maple didn't take in account the linearity of the integral.
In the middle of a calculation, I need to compute the following integral
int(3628800 / (y * (1 / 2 + y)^11) - 3628800 / (y * (39 / 2 + y)^11), y = 39 / 2..infinity);
Maple 17 is not able to instantly answer me, and I'm not so patient... (I've waited more than 30s)
Nevertheless, if I ask Maple 17 to compute
3628800 * int(1 / (y * (1 / 2 + y)^11) - 1 / (y * (39 / 2 + y)^11), y = 39 / 2..infinity);
as well as
int(3628800/(y*(1/2+y)^11), y = 39/2..infinity)-int(3628800/(y*(39/2+y)^11), y = 39/2..infinity);
Maple 17 answer me instantly... which turn out to be quite surprising!
Is there someone, here, who has some ideas of what is happening in this calculation? Why Maple17 has this strange behaviour?
Many thanks for all your answers,
Tolliob
Dear friends!
Hope you would be fine. I want to solve the following system of ODEs
restart; L := 1; with(plots); Digits := 30;
a[1] := 0; a[2] := 1; a[3] := 2; a[4] := .2; a[5] := 4; a[6] := 6;
S := 1; Pr := 6.2; a := 1; a1 := 1; a2 := 1; lambda := 1; delta := 1; Bi := 1; A := 1; B := 1;
HA := [a[1], a[2], a[3]];
Eq1 := diff(F(eta), eta, eta, eta)+a*(a1*((F(eta)+G(eta))*(diff(F(eta), eta, eta))-(diff(F(eta), eta))^2)-M1*(diff(F(eta), eta))) = 0;
Eq2 := diff(G(eta), eta, eta, eta)+a*(a1*((F(eta)+G(eta))*(diff(G(eta), eta, eta))-(diff(G(eta), eta))^2)-M1*(diff(G(eta), eta))) = 0;
Eq3 := (A+B)*(diff(H(eta), eta, eta))+a2*Pr*(F(eta)+G(eta))*(diff(H(eta), eta)) = 0;
IC1 := F(0)+G(0)=0, (D(F))(0) = 1+delta*((D@@2)(F))(0), (D(G))(0) = lambda+delta*((D@@2)(G))(0), (D(H))(0) = -Bi*(1-H(0)), (D(F))(L) = 0, (D(G))(L) = 0, H(L) = 0;
params := {B111 = .2};
associated with the above (mentioned as red) boundary conditions. The problem which I faced in first condition i.e., F(0)+G(0)=0 because its combine condition for F(eta) and G(eta) which should be use for both function. The rest part of my program is below:
for k to nops(HA) do;
P || k := plots:-odeplot(dsolve(eval({Eq1, Eq2, Eq3, IC1}, `union`(params, {M1 = .5, phi = HA[k]})), numeric), [[eta, diff(F(eta), eta)]], linestyle = [solid, solid, solid, solid][k], color = [red, green, blue, red][k], labels = [eta, f], thickness = 3) end do;
f1 := plots:-display(P || (1 .. nops(HA)));
display(f1, axes = boxed, size = [380, 310], title = "Ethylene glycol/Cu: M = 2, S = -5", titlefont = ["Arial", 12, bold]);
Please fix my problem ASAP. I also attach the maple file. Thanks in advance.
Help.mw
I am tasked with making a table in Maple that gives the Taylor approximation of sin(x) from 0 degrees to 45 degrees accurate to four digits. The order selected is supposed to give an error from 0 to pi/4 less than 0.00005. I can't seem to create a table with a recurring task. Is there anyone that knows how to do this? Thank you!
Tristan
Hello everybody
I have a variable U of type set, made of index names name[expression sequence]
One example is
U := {A[1], A[2], B[2]}
I want to build the set of all the expression sequence  ; in the example above this is {1, 2}
op~(U) does the job ... although I do not really understand why
I also want to buid the set of all the name ;  ( {A, B} in the example)
Here I have written something that performs correctly  ... but it is very uggly
parse~(substring~(convert~(U, string), 1..1));  # works only for names with a single character !!!
I do not know how to isolate the names ?
Is it possible to write something smarter ?
There are 13214 days between these two dates.
with(Finance): DayCount("Jan-01-1981", "MAR-7-2017");
But how can I find the end date, given the beginning date and the days between?
This doesn't work (of course, because the date is not a number):
fsolve(DayCount("Jan-01-1981", x)=13214)
is there a direct way? in excel i would do it indirectly using Goal Seek
Maple has had object-oriented features since about version 15, implemented with modules and records and the ability to define exports of these. Methods can be defined and called using module:-Method() and properties in a similar way including hierarchical constructs. Overloading of functions is possible, although I have run into trouble trying to overload build-in function. While this mechanism is not fully oo, I have found it enormously helpful for larger projects and a distinguishing feature of Maple.
More recently, the option object was added to modules. What are the true new functionalities? I see that the syntax for methods has changed (Method(object,arguments) rather than module:-method(arguments)) but I do not see how that is an improvement. I guess there are also now bona-fide constructors, doing what used to be done with a module factory (a proc that returns an instance of a module). And Object(object) seems to do what copy(module) does.
I am conceptualizing a larger package that will make use of the oo features of modules. I know I can write this using the established :- syntax using modules. Are there any benefits to using the newer objects rather than modules and records (& I know that all these are essentially modules)?
TIA,
M.D.
Why does
5103*`Ω`*(5*sqrt(7)+16)/((1+2*sqrt(7))^(3/2)*(7+2*sqrt(7))*(-2+sqrt(7))*(14+sqrt(7))*(2*sqrt(7)-1)*(4+sqrt(7)))
not simplify to
sqrt(1+2*sqrt(7))*`Ω`
Can I get help with equations, need to use the metrics.
1.  2*(3+4)-2*(4-3)
2.  (6+4):2+(4-5+2)*3-2
3.  -5*(-2+5)*(2-5)-3*(-2)
4.  7*(2-6*3+4)-5*8:2
5.  2*(6+4):4
6.  14+2*(5+23):2+4
7.  2*(9+3)+3*(6*(-2)-2:(6-2)*(-3)-10
It would be nice to have asymptotics for hypergeom that are valid around abs(z)=infinity for any value of argument(z):
limit(hypergeom([1, 1], [2, 2], I*z), z = infinity); # zero
      limit(hypergeom([1, 1], [2, 2], I z), z = infinity)
series and asympt can give the expansions for +infinity or -infinity, not necessarily valid for other directions. FunctionAdvisor gives only the expansion at +infinity (which in this case is valid for Re(z)>0). Changes of variables like z->-z or z->1/z seem to never work in FunctionAdvisor(asymptotic_expansion, ...).
Also the expansions around z=1:
limit(hypergeom([1, 1, 1], [1/2, 2], z)*(z-1), z = 1); # zero
          /         /           [1   ]   \               \
     limit|hypergeom|[1, 1, 1], [-, 2], z| (z - 1), z = 1|
          \         \           [2   ]   /               /
And on the branch cuts:
limit(hypergeom([1/3, 1/3], [1/2], 2+I*a), a = 0); # the directional limits are different
                            /[1  1]  [1]   \
                   hypergeom|[-, -], [-], 2|
                            \[3  3]  [2]   /
I have a big 1000*1000 symbolic matrix (some of its diagonal entries are function of x variable), how to calclulate closed form inverse of a such matrices in Maple?
Is any package or algorithm which enable me to compute constraint structure of a singular Lagrangian in physical phenomena?
i would be very thankfull if someone help me in thisway please :)
g3 := tanh(x+1);
a:=eval(diff(g3,x$n)/n!, x=0) assuming n>=0:
tanhx := sum(a*x^n, n=0..infinity):
tanhx2 := subs(x^n=subs(_C1=0, subs(t=n!, g2))*x^n, tanhx):
diff(tanhx2, x) - tanhx2;
would like to find a operator to make it equalt to itself , a new differential operator for new transcendental function tanhx2
in reference to the definition prescribed in the maple help interface and the attached worksheet, i cant understand how hypergeom(n,d,z) handles empty values of the lists n,d eg hypergeom([],[],pi)
hypergeom([n[1], n[2], n[3], () .. (), n[p]], [d[1], d[2], d[3], () .. (), d[q]], z) = sum(z^k*(product(GAMMA(k+n[i])/GAMMA(n[i]), i = 1 .. p))/(factorial(k)*(product(GAMMA(k+d[j])/GAMMA(d[j]), j = 1 .. q))), k = 0 .. infinity)
Download maplePRIMEShypergeomQ.mw
I am struggling to obtain solutions for two bi-variate euqations numerically. A command line that I am currently using (for a dummy problem) is as follows:
soln := {solve({f(x,y)=0, g(x,y)=0}, {x,y})};
There are mainly two issues:
1. For some reasons, Maple 2017 takes ages to obtain solutions for certain parameter values. At times, it does not provide any solution which should not happen. I am assuming that this is to do with the "solve" command.
2. Also, I am not sure how to limit search procedure within feasible ranges for variables. In this case, how do I incorporate conditions 0 <= x, y <=1? If I can incorporate these constraints in the "solve" (or any better) command, then I can automatically get rid of complex solutions as they are not relevant for me.
I would appreciate inputs in this regard. Thank you,
Omkar
Is there a simple way to reverse the handedness of the axes? I have the following figure:
shadebetween(0, 2-x-y, x = 0 .. 1, y = x^2 .. sqrt(x), scaling = unconstrained, color = yellow, axes = normal, labels = [Z, Y, X], transparency = .9)
and I want the X and Y-axes reversed from a left-handed orientation to a right-handed orientation.
First 969 970 971 972 973 974 975 Last Page 971 of 2459
