Lets say we have to vectors u := Vector(3,[0,a_2,a_3]) and v :=Vector(3,[a_1,a_2,a_3]), in which a_1, a_2 and a_3 are arbitrary constants. It is clear that if we set a_1=0 we could see that u is contained in the vector space of v. Is there a function in Maple like isSubspace(u,v) which returns a boolean true or false?
An alternative interpretation could be that the image of u is a subset of the image of v.
Thank you alot for reading my question.
When I try to use CodeTools:-Profiling:-Profile() (with no arguments), I get "kernel connection lost" after about a minute. Has anyone used this sucessfully, with no arguments? If so, would you please post a worksheet? I'm using Windows 8, if that makes a difference.
I think that I'll need to revert to the older kernelopts(profile= true).
In Maple V, Release 4 (1996):
_EnvX:=0; b:=0; proc() global b; print(_EnvX, b); assign('_EnvX=1, b=1'); print(_EnvX, b); end();
_EnvX:=0: b:=0: proc() global b; print(_EnvX, b); _EnvX:=1; b:=1; print(_EnvX, b); end();;
gives:
                                 0, 0
                                 0, 1
In newer Maple:
_EnvX:=0; b:=0; proc() global b; print(_EnvX, b); assign('_EnvX=1, b=1'); print(_EnvX, b); end proc();
_EnvX:=0: b:=0: proc() global b; print(_EnvX, b); _EnvX:=1; b:=1; print(_EnvX, b); end proc();
I'm trying to plt something, I can't see why Maple isn't multiplying these two rows as it should.
Can anyone see the problem?
This preamble is loaded:
with(Units[Standard]);
with(ArrayTools);
with(LinearAlgebra);
with(Statistics);
with(CurveFitting);
asd := [3.5400000*10^5, 3.4700000*10^5, 3.3700000*10^5, 3.2700000*10^5, 3.1700000*10^5, 3.0900000*10^5, 3.0300000*10^5, 2.9600000*10^5, 2.9200000*10^5, 2.8900000*10^5, 2.8600000*10^5, 2.8500000*10^5, 2.8200000*10^5, 2.8100000*10^5, 2.7900000*10^5, 2.7800000*10^5, 2.7800000*10^5, 2.7700000*10^5, 2.7600000*10^5]:
asf := [0.2866400798e-1, 0.6112772793e-1, 0.9946549241e-1, .1349950150, .1645923341, .1877395591, .2054364684, .2189514789, .2293646837, .2374847679, .2439099369, .2490583805, .2532402792, .2566744211, .2595269747, .2619197962, .2639470478, .2656751966, .2671596322]:
asd*asf;
[354000.0000, 347000.0000, 337000.0000, 327000.0000, 317000.0000, 309000.0000, 303000.0000, 296000.0000, 292000.0000, 289000.0000, 286000.0000, 285000.0000, 282000.0000, 281000.0000, 279000.0000, 278000.0000, 278000.0000, 277000.0000, 276000.0000]*[0.2866400798e-1, 0.6112772793e-1, 0.9946549241e-1, .1349950150, .1645923341, .1877395591, .2054364684, .2189514789, .2293646837, .2374847679, .2439099369, .2490583805, .2532402792, .2566744211, .2595269747, .2619197962, .2639470478, .2656751966, .2671596322]
Download maple_what.mw
I did not understand fully some of the notation used in 2D when I had the tools->options->Display->Output display->2D. So I thought if I change it to Maple notation. I might see what the symbol actually mean.  But when I did so, the result was even more confusing. Full of typesetting:-mrow commands and hard to read.
Here is the output in 2D
int(1/( (x-a)*(x-b)),x=-infinity..infinity  );
And here is the output when I switched to Maple output:
I was expecting to see "normal" looking Maple commands, which I can understand. Even the Latex is easier to read than the above mumple jumple code:
Does this mean one should forget about using Maple notation for output from now on? Why is it the output so complicated?
I have a dataset:
NMP:=<0.530,0.555,0.572,0.592>:
ETOH:=<0.136,0.153,0.163,0.170>:
For these four data points [NMP,ETOH] I want to find the least square function in form of:
ln(ETOH/(1-ETOH-NMP))=a*ln(NMP/(1-ETOH-NMP))+b
also I need to find appropriate a,b constant values.
This function is implicite so I cannot use with(Statistics):NonlinearFit.
Can you help me how to determine a,b constants?
friend i want fit a curve regarding some data and fnction and how we can find the values of a,b,c and d for the following
f=1-(8*a*b+6*c*d/(b*k*x))/(2*a*b+c*b*(1/(b*k*x)))
X := Vector([200, 210, 220, 230, 240, 250, 260, 270, 280, 290])
Y := Vector([.4172, .3030, .4668, .3317, .1276, .1303, .1733, .1451, .3466, .4125])
Code & result:
> map((a::uneval,b)->'args',[a,b,c,d],1..4,x);
['a, 1 .. 4, x', 'b, 1 .. 4, x', 'c, 1 .. 4, x', 'd, 1 .. 4, x']
> map((a,b::uneval)->'args',[a,b,c,d],1..4,x);
[a, 1 .. 4, x, b, 1 .. 4, x, c, 1 .. 4, x, d, 1 .. 4, x]
Why is the output not:
['a', 1 .. 4, x, 'b', 1 .. 4, x, 'c', 1 .. 4, x, 'd', 1 .. 4, x]
[a, '1 .. 4', x, b, '1 .. 4', x, c, '1 .. 4', x, d, '1 .. 4', x]
In the process of simplification I have the following multi-variable polynomial:
y:=-8*C*d1^2*(-2+d1)*(-1+d1)^3*r*L*R^3+(d1^4*(-2+d1)^2*L^2-4*C*(-2+d1)*(4*d1^3-13*d1^2+16*d1-8)*(-1+d1)^2*r^2*L+4*C^2*(-2+d1)^2*(-1+d1)^4*r^4)*R^2+(2*d1^4*(-2+d1)^2*r*L^2-2*C*(-2+d1)*(5*d1^3-24*d1^2+32*d1-16)*(-1+d1)^2*r^3*L+4*C^2*(-2+d1)^2*(-1+d1)^4*r^5)*R+d1^4*(-2+d1)^2*r^2*L^2-2*C*(-2+d1)*(d1^3-6*d1^2+8*d1-4)*(-1+d1)^2*r^4*L+C^2*(-2+d1)^2*(-1+d1)^4*r^6
This polynomial contains several (-2+d1), (-1+d1) terms with varying powers in each term. My question here is how to take out common terms and then form compact multi-variable polynomial (without having physical inspection).
Thank you for your help.
MVC
Hello people in Mapleprimes,
I have an expression which I want to modify with another equation.
They are simple, and looks easy to simplify.
nb:=(k-sigma+1)*lambda*L*(gamma*upsilon-delta__1122^k*tau)*upsilon*tau*v/(f__F*sigma*(-tau^2+upsilon^2)*k);
hh := (L*lambda*(k-sigma+1)*upsilon*tau*v)/(f__F*sigma*(-tau^2+upsilon^2)*k)=rho;
I want to express nb with hh as
(gamma*upsilon-delta__1122^k*tau)*rho;
With the next code, that modification can be done.
isolate(hh,f__F);subs(%,nb);simplify(%);
But, this isolates hh for f__F, which does not look intuitive.
On the other hand, the outcome of the substitution looks so simple, which you find with executing  the codes of
nb, and hh.
But, algsubs, and subs, and simplify/siderel won't work properly.
What I want to ask is this. Isn't there any nice way to substitute hh into nb other than isolating f__F, so that the result is expressed with rho?
I will be very glad if you will give me answers.
Best wishes.
taro
I am solving "Fx=0" for geting "roots:x" using "solve(Fx,x)". Solution is in the form of "a+sqrt(b)", "a-sqrt(b)". One solution "f1" is given below.
f1:=1/2*(-8*R*d1^2*r^2*C+10*d1*r^2*C*R+5*d1*r^3*C+2*r*L*d1^2-2*C*r^3+2*R*L*d1^2-R*L*d1^3-r*L*d1^3-4*C*r^2*R+2*R*d1^3*r^2*C-4*r^3*d1^2*C+r^3*d1^3*C+sqrt(26*r^6*d1^4*C^2+41*r^6*d1^2*C^2-44*r^6*d1^3*C^2-20*C^2*r^6*d1+16*C^2*r^5*R-16*C*r^4*L-176*r^5*d1^3*C^2*R+164*r^5*d1^2*C^2*R-74*r^4*d1^4*C*L+136*r^4*d1^3*C*L-136*r^4*d1^2*C*L-80*C^2*r^5*d1*R+72*C*r^4*L*d1-64*C*r^3*R*L+104*R^2*d1^4*r^4*C^2-176*R^2*d1^3*r^4*C^2+164*R^2*d1^2*r^4*C^2-8*r^6*d1^5*C^2+r^2*L^2*d1^6-4*R^2*L^2*d1^5+104*r^5*d1^4*C^2*R+40*r*L*R^3*d1^5*C-72*r*L*R^3*d1^4*C+56*r*L*R^3*d1^3*C-16*r*L*R^3*d1^2*C+R^2*L^2*d1^6+20*r^4*L*C*d1^5-32*r^4*d1^5*C^2*R^2+2*R*L^2*d1^6*r-2*r^4*L*d1^6*C+4*R^2*d1^6*r^4*C^2+4*R*d1^6*r^5*C^2-306*r^3*d1^4*C*R*L+548*r^3*d1^3*C*L*R-544*r^3*d1^2*C*R*L+288*C*r^3*L*d1*R+16*C^2*r^4*R^2+4*R^2*L^2*d1^4-16*R^2*L*d1^6*r^2*C-10*R*L*d1^6*r^3*C+r^6*d1^6*C^2-32*r^5*d1^5*C^2*R-4*r^2*d1^5*L^2-352*R^2*d1^4*r^2*C*L+580*R^2*d1^3*r^2*C*L-552*R^2*d1^2*r^2*C*L-80*d1*r^4*C^2*R^2-8*R^3*d1^6*L*C*r+88*r^3*L*C*d1^5*R+116*r^2*L*R^2*d1^5*C+4*C^2*r^6-8*r*R*L^2*d1^5+288*d1*r^2*C*R^2*L-64*C*r^2*R^2*L+8*r*L^2*d1^4*R+4*r^2*L^2*d1^4)^(1/2))/(-3*r^2*d1*L*C-6*R*d1*L*C*r+2*L*C*r^2+r^2*d1^2*L*C+4*L*C*r*R+2*R*d1^2*L*C*r);
I used the following Maple syntax
patmatch(f1,XT::algebraic+sqrt(YT::algebraic),'q1');
the answer is "false"
Is there any modification in the syntax "patmatch" is required.
Here, my question is how to separate "a" and "b" in "a+sqrt(b)" (a, b are big expressions involving many variables).
Thanking you advance for your help.
  In attached file I need to plot (R/R0 )^3  versus t for diffrent of (s) for example  s=0.01,0.005,0.003   plot.mwplot.mw
Dear Maple users
I have done some experiments with the new Workbook feature in Maple 2016. It is a very welcome addition, indeed. Earlier I have created Maple files in which data from an external Excel file was imported and being used for certain calculations. In order to make recalculations work properly, one need to let the Excel file follow the Maple file. That's where a Workbook come in handy! I tried placing those two files in a Workbook. It didn't work completely as advertised, I think. I moved the Workbook to another location on the harddrive to make sure it wouldn't interfere with the original files outside the Workbook. Then I recalculated the Maple document inside the Workbook. The good thing: The data from the Excel file was still present. The bad thing: If I changed some data in the Excel file inside the Workbook, it didn't register in the Maple file when updating it!
Maybe I should explain that I did import data from the Excel file into Maple via the menu: Tools > Assistants > Import Data... The data was retrieved as a matrix within the Maple file and assigned to a variable and used for plots ...
Why doesn't the above procedure work properly? I hope one don't need to use the Workbook URI to reference files within the workbook. It is not that userfriendly!
Erik
I have this function:
Z := (cos((1/2)*x)-I*sin((1/2)*x))*A0/r^(1/2)+(cos((1/2)*x)+I*sin((1/2)*x))*r^(1/2)*A1+(cos(3*x*(1/2))+I*sin(3*x*(1/2)))*r^(3/2)*A2;
I wanna to obtain another function Y which equal to
Y:=f1*(Re(Z)+Re(Z'))+f2*(Im(Z)+Im(Z'));
where: f1 and f2 are constant
Here my question is how to extract "a", "b" separately (a, b are complex and very big expressions).
First 1111 1112 1113 1114 1115 1116 1117 Last Page 1113 of 2459
