Howdy all,
I am trying to fit an exponential and logistical model to a set of population data i've been given using the NonlinearFit function in the statistics toolbox. When try to find the fit for the exponential function I get an error saying "SVD of estimated Jacobian could not be computed". Furthermore, when I display the regression over the set of data points all it shows is a horizontal line. I'm not sure how to go about fixing this. My data set is only 17 points and my input function is about as simple as it gets.
When I run the program to solve for logisitcal model I do not get the error but the displayed plot still shows just a horizontal line dispite the function being non-linear.
So far I have...
regE := NonlinearFit(a*exp(b*x),year,population,x)
regLog := NonlinearFit(a/(1+b*exp(-c*x)),year,population,x)
expon := plot((regE), x = 1850..2020):
logi := plot((regLog), x = 1850..2020):
display({data,logi,expon});
I have not tried using optimization yet but I will soon although I'm not sure if it will improve my results since my undertanding is that they both use the same process to estimate the parameters.
Anyways, Thanks for the help in advance!!
EDIT: Here is the data I am using.
year := [1850,1860,1870,1880,1890,1900,1910,1920,1930,1940,1950,1960,1970,1980,1990,2000,2010]:
population :=[4668,9070,17375,27985,37249,63786,115693,186667,359328,528961,806701,1243158,1741912,2049527,2818199,3400578,4092459]:
I have a problem using variables values that were read form Maple library file (*.mla) with units.
For example:
In the first file called "calculations.mw" I calculate a variable with units and save value to "lib1.mla" file
A__1 := Units:-Standard:-`*`(2, Unit('m'))
2*Units:-Unit('m')
A1 := Units:-Standard:-Unit('m')
Units:-Unit('m')
savelib('A__1', 'A1', cat(interface(worksheetdir), "\\lib1.mla"))
Download calculations.mw
In the second file called "document.mw" I can read the value of a variable, but can't use it in expressions:
libname := cat(interface(worksheetdir))
"D:\TEMP\MTest"
A__1
2*Units:-Unit('m')
A__1
2*Units:-Unit('m')
2*A__1
Error, (in Units:-Standard:-*) invalid subscript selector
A1
Units:-Unit('m')
A1
Units:-Unit('m')
2*A1
Download document.mw
Where I made a mistake?
I look for a maple function / or a piece of code which enable to do repeated substitutions. In other words, repeat substitutions until there is no more possible substitution.
How can I do to make repeated substitutions ?
Here a example I would like to solve with maple
Equation on which I would like to conduct variables changements:
Code:
eq := sin(psi[1](t)+gamma0(t))*cf+sin(gamma0(t)+theta[1](t)+psi[1](t))*mf-sin(gamma0(t))*hf-cos(gamma0(t))*lf+xp[1](t) = sin(psi[2](t)+gamma0(t))*cf+sin(gamma0(t)+theta[2](t)+psi[2](t))*mf-sin(gamma0(t))*hf-cos(gamma0(t))*lf+xp[2](t)
Definition of variables changement :
Code:
ChgtVariables:=psi[1](t)=Psi[1](t) - theta[1](t) + gamma[1](t),psi[2](t)=Psi[2](t) - theta[2](t) + gamma[2](t);psi[3](t)=Psi[3](t) - theta[3](t) + gamma[3](t),psi[4](t)=Psi[4](t) - theta[4](t) + gamma[4](t),theta[1](t)=Theta[1](t)+gamma[1](t),theta[2](t)=Theta[2](t)+gamma[2](t),theta[3](t)=Theta[3](t)+gamma[3](t),theta[4](t)=Theta[4](t)+gamma[4](t);
Application of subs function:
Code:
subs(ChgtVariables,eq);
The problem is that only one step of substitutions is conducted.
Here the expected result :
(sin(theta[1](t))-theta[2](t))*cf - (sin(gamma[1](t)-sin(gamma[2](t)))*mf  + xp[2](t) - xp[1](t) = 0
Thanks a lot for your hemp
sorry, i`m learning of thermaldynamics and want to make a graph of that x-axis  is number of spin-up and y-aixs is number of configuraions when there are atoms could only have spin-up and down.
if the atoms are 10, what is the formular in maple 17
how about 100 ?
please let me know, thank you
I have 101 point with very low value
and I'm trying to get the best curve that fits that points. I have tryed with a polynomial interpolator but the curve is not very good. I have also tried with an exponential but an error ocurrs.
Error, (in Statistics:-ExponentialFit) dependent values must evaluate to positive numbers
Can anyone help me? Any ideas? How can I find the best curve fitting?
I try to simplify a system of 6 trigonometric equations and then to extract the 3 first equations.
When I conduct my calculations, It seems that that I have some troubles with some index.
There is a term with "table" which is not evaluated.
Do you have ideas why the last equations in my code have a table inside and consequently can not be evaluated?
I attached my code
example.mw
Thank you for your help.
Hi all
How can I make maple to write the values of each contour plot on the graph?
I have a 3d graph and want to have a contour plot in which each line have the associated value on it. I know I can use legends and input the values for each line by hand but I dont know those values. I just need maple to calculate the values and write them on the contour plot.
Many thanks for helping me
Hi Maple People,
My question is, "How can I combine the two plots shown in the attachment into one plot?".
Download plot_real_example_5_Exact_Curve_Fit_questiion_for_MaplePrimes.mw
Matt
I have to use the optimization package.
- The objective function is non linear,
- I have constrains and bounds,
- The constrains are not linear.
I have reading the help page on maplesoft.com
My question are:
Can you confirm me that the only algorithm I can use is : NLPSolve with method ''sqp''?
And if I would like to use the gradient method how can I do?
This is somehow an old problem which came back and I decided to post it. So, I have some code which runs in Grid framework locally. Each node saves data directly to hard disk and there is no need to return anything at the end to the node of ID 0. Nevertheless, I noticed that memory usage on one instance of the mserver is very huge.  Moreover, this instance is all the time in S state, namely sleeping. Below you can see dump from top. I deny this is caused by some particular procedures called in my code since in this case I should rather observe more uniform memory usage. I am not sure if for this moment I could share some code with you which demonstrate this behavior. I will try to write some toy example because my productive code cannot be posted here.
%MEM     TIME+ COMMAND
49.1 17:00.19 mserver
0.1 12:43.70 mserver
0.1 12:32.15 mserver
0.1 13:54.02 mserver
0.1 14:45.45 mserver
0.1 12:35.22 mserver
0.1 13:50.77 mserver
0.1 14:14.85 mserver
0.1 8:58.82 mserver
0.1 12:58.48 mserver
0.1 8:51.00 mserver
0.1 10:35.92 mserver
0.1 12:58.13 mserver
0.1 9:34.39 mserver
0.1 10:10.13 mserver
0.1 12:07.77 mserver
0.0 8:21.17 mserver
0.0 11:41.42 mserver
0.0 5:07.27 mserver
0.0 8:31.88 mserver
0.0 6:30.12 mserver
hi.please see attached file below and help me for gain real or complex answer
with out show answer in root of manner
thanksroot_of....mw
What is the maximal independent set of monomial ideal$<c^4a^3b>$ in $K[a,b,c]$?
(Some) prime reciprocals have an interesting property. the repeating sequence has length p-1.
eg 7, has repeats after 6.
1/7=0.142857142857......
17 has repeats after 16
1/17=0.05882352941176470588235294117647059.........
of course some primes don''t have this property....
So what I need the experts here is for some code
myproc(17)=16, (and the sequence) 0588235294117647
my go:pinched from
http://199.71.183.11/questions/39621-Pattern-Matching-In-A-Sequence-Of-Digits
PriDigits := "" || (op(1, evalf(1/17, 50)));
reps := StringTools[Repeats](PriDigits);
lngth := seq(op(3, A), A in [reps]);
the leading 0 (which is part of the sequence)  is a problem.....
hi every one, i would like to know if it is possible to implement the following recursive sequence in Maple :
q(1)       = q(0)        +q_dot(0)
q_dot(1)  = q_dot(0)  +q_ddot(0)
q_ddot(1) = q_ddot(0)+q_dddot
q(2)       = q(1)        +q_dot(1)   = (q(0)+q_dot(0)) + (q_dot(0)+q_ddot(0)) = q(0)+2q_dot(0)+q_ddot(0)
q_dot(2)  = q_dot(1)  +q_ddot(1)
q_ddot(2) = q_ddot(1)+q_dddot
q(3)      = q(2)        +q_dot(2)=(q(0)+2q_dot(0)+q_ddot(0))+(q_dot(1)+q_ddot(1))= q(0)+3q_dot(0)+q_ddot(0)+q_dddot
q_dot(3) = q_dot(2)  +q_ddot(2)
q_ddot(3)= q_ddot(2)+q_dddot
I would like every q(n) to be expressed as following : q(n)=q(0)+n_1*q_dot(0)+n_2*q_ddot(0)+n_3*q_dddot.
By computing manually some sequences i am now sure that :
n_1=n
n_2=(n²-n)/2
n_3=?? (I would like to find this one)
The sequence can be written in a more general way as following :
q(n)        = q(n-1) + q_dot(n-1)
q_dot(n)   = q_dot(n-1) + q_ddot(n-1)
q_ddot(n) =q_ddot(n-1)+q_dddot
Can you guys please show me how this can be implementes in Maple ?
say I have defined some (very simple, acting on a finite set M) functions f,g,h. I want to evaluate certain permutations, so I want to make a for loop that goes through possible combinations of functions in my array A=Array([f,g,h]). (In reality my array is a little larger.) No I don't understand how I can use the elements of this array as actual functions. Even if f is defined and I can evaluate, say, f(m), I cannot use A(1)(m) to evaluate m. The output is just "f(m)". How can I make maple recognize that we are having a function here?
Thanks it advance.
First 1178 1179 1180 1181 1182 1183 1184 Last Page 1180 of 2459
