say I have defined some (very simple, acting on a finite set M) functions f,g,h. I want to evaluate certain permutations, so I want to make a for loop that goes through possible combinations of functions in my array A=Array([f,g,h]). (In reality my array is a little larger.) No I don't understand how I can use the elements of this array as actual functions. Even if f is defined and I can evaluate, say, f(m), I cannot use A(1)(m) to evaluate m. The output is just "f(m)". How can I make maple recognize that we are having a function here?
Thanks it advance.
I'm not sure that I mean datatable component corectly.
I also consider that I was done somthing wrong
Thank you for advanced for any help.
with(DocumentTools):
Oryginaly DataTable was inserted as a 3 x 3. I will traing to push maple to obtain 4 x 4 with specific row and column name.
SetProperty("DataTable0", visibleRows, 4);
DocumentTools:-SetProperty("DataTable0", visibleColumns, 4);
DocumentTools:-SetProperty("DataTable0", columnWidths, [20, 40, 80, 80]);
DocumentTools:-SetProperty("DataTable0", rowNames, [r1, r2, r3, r4]);
DocumentTools:-SetProperty("DataTable0", columnNames, [c1, c2, c3, c4]);
DocumentTools:-SetProperty("DataTable0", update)
wzel
Download datatable_problem.mw
Is there a way in Maple to convert a list into a string of numbers?
So [1,2,3,4,5] -> 12345
I have tried Maple help, but there are too many convert commands to try them all.
And the ones I have tried didn't work.
In the creation of a list, I would like to use the assume function twice.
Here it is a print screen of my issue.
The second part of the list is not taken into account.
Do you have ideas so that my list takes into account the second term ?
Thanks a lot for your feedback
Hello! Hope every is fine. I want to expand all expression of exp of the attached file like this
exp(c[1]*t+d[1]*n-d) = exp(c[1]*t+d[1]*n)*exp(-d)
waiting your kind response.
Help.mw
Mob #: 0086-13001903838
Hello! Hope everything fine with you. Please share the command to find the max and min values of the attached function, I had tried but I was only for one variable. I am waiting your quick response.
Examples.pdf
I would like to solve this equation :
tan(gamma0(t)) = tan(gamma[1](t)-theta[1](t)-psi[1](t)
I would like to select the solution of arctan by assuming the domain of variation of some variables. In my case, if -Pi/2 < gamma[1](t) - theta[1](t) - psi[1](t) < Pi/2, the arctan gives only one solution.
Can you help me to solve this equation ?
eq:=tan(gamma0(t)) = tan(gamma[1](t)-theta[1](t)-psi[1](t))
solve(eq,gamma0(t)) assuming -Pi/2 < gamma[1](t) - theta[1](t) - psi[1](t) < Pi/2
I guess that I don't use properly the "assume" function.
The result that I would like to obain is quiet simple :
gamma0(t)) = gamma[1](t)-theta[1](t)-psi[1](t)
Thanks a lot for your help
Here is my Maple 16 code:
 I expected to get outuput
a [a,b,c]
a [a,c,b]
But I get no output.
Why?
2*t*exp(t) + 2*t
would like to apply op recurively
and output list
[2,t,exp(t),2,t]
not the same ordering every time of monomials after determinant and map sign positive and op in maple 15
sometimes i need to use Reverse or Rotate List to adjust.
why ordering is different in list of monomials?
is it caused by virus?
I wonder how is it possible to numerically evaluate two-dimensional sum, something like this:
sum
Hi my dear friends, I am haunted by a problem of how to convert a very very very long equation to Latex or Word properly?
Thank you for taking a look at the following 'long and boring' equation and sharing your brilliant idea.
"1/12*R^2*h^3*rho*diff(diff(alpha(t),t),t)*cos(beta(t))^2*Pi+1/2*R^4*h*rho*sin(gamma(t))*diff(diff(phi(t),t),t)*Pi-1/4*R^4*h*rho*Pi*cos(beta(t))^2*diff(diff(alpha(t),t),t)-1/4*R^4*h*rho*cos(alpha(t))*diff(beta(t),t)*diff(gamma(t),t)*Pi-1/12*R^2*h^3*rho*cos(alpha(t))*diff(beta(t),t)*diff(gamma(t),t)*Pi+1/2*R^4*h*rho*diff(gamma(t),t)*cos(gamma(t))*diff(phi(t),t)*Pi+1/12*R^2*h^3*rho*sin(gamma(t))*cos(beta(t))^2*diff(diff(phi(t),t),t)*Pi+1/2*R^4*h*rho*cos(gamma(t))*diff(diff(theta(t),t),t)*cos(phi(t))*Pi-1/4*R^4*h*rho*Pi*sin(gamma(t))*cos(beta(t))^2*diff(diff(phi(t),t),t)+1/2*R^4*h*rho*sin(gamma(t))*diff(diff(psi(t),t),t)*sin(theta(t))*Pi-1/12*R^2*h^3*rho*cos(beta(t))^2*cos(gamma(t))*diff(diff(psi(t),t),t)*cos(theta(t))*sin(phi(t))*Pi-1/4*R^4*h*rho*cos(beta(t))^2*sin(alpha(t))*diff(beta(t),t)*cos(gamma(t))*diff(phi(t),t)*Pi+1/4*R^4*h*rho*cos(alpha(t))*cos(beta(t))^2*diff(beta(t),t)*diff(theta(t),t)*sin(phi(t))*Pi-1/12*R^2*h^3*rho*cos(alpha(t))*cos(beta(t))^2*diff(beta(t),t)*diff(theta(t),t)*sin(phi(t))*Pi+1/4*R^4*h*rho*cos(alpha(t))*cos(beta(t))*sin(beta(t))*diff(diff(theta(t),t),t)*sin(phi(t))*Pi-1/4*R^4*h*rho*cos(alpha(t))*diff(beta(t),t)*sin(beta(t))^2*diff(theta(t),t)*sin(phi(t))*Pi-1/12*R^2*h^3*rho*cos(alpha(t))*cos(beta(t))*sin(beta(t))*diff(diff(theta(t),t),t)*sin(phi(t))*Pi+1/12*R^2*h^3*rho*cos(alpha(t))*diff(beta(t),t)*sin(beta(t))^2*diff(theta(t),t)*sin(phi(t))*Pi-1/6*R^2*h^3*rho*sin(gamma(t))*cos(beta(t))*diff(phi(t),t)*Pi*diff(beta(t),t)*sin(beta(t))+1/2*R^4*h*rho*Pi*sin(gamma(t))*cos(beta(t))*diff(phi(t),t)*diff(beta(t),t)*sin(beta(t))-1/12*R^2*h^3*rho*cos(beta(t))^2*diff(gamma(t),t)*sin(gamma(t))*diff(theta(t),t)*cos(phi(t))*Pi-1/4*R^4*h*rho*cos(beta(t))*sin(alpha(t))*sin(beta(t))*cos(gamma(t))*diff(diff(phi(t),t),t)*Pi+1/4*R^4*h*rho*diff(beta(t),t)*sin(beta(t))^2*sin(alpha(t))*cos(gamma(t))*diff(phi(t),t)*Pi+1/12*R^2*h^3*rho*cos(beta(t))*sin(alpha(t))*sin(beta(t))*cos(gamma(t))*diff(diff(phi(t),t),t)*Pi-1/12*R^2*h^3*rho*diff(beta(t),t)*sin(beta(t))^2*sin(alpha(t))*cos(gamma(t))*diff(phi(t),t)*Pi-1/12*R^2*h^3*rho*cos(alpha(t))^2*cos(beta(t))^2*diff(gamma(t),t)*cos(gamma(t))*diff(psi(t),t)*sin(theta(t))*Pi-1/12*R^2*h^3*rho*cos(alpha(t))^2*cos(beta(t))^2*cos(gamma(t))*diff(theta(t),t)*diff(phi(t),t)*sin(phi(t))*Pi-1/12*R^2*h^3*rho*cos(alpha(t))*cos(beta(t))^2*diff(beta(t),t)*diff(psi(t),t)*cos(phi(t))*cos(theta(t))*Pi+1/4*R^4*h*rho*sin(gamma(t))*cos(beta(t))^2*sin(alpha(t))*diff(beta(t),t)*diff(theta(t),t)*cos(phi(t))*Pi-1/4*R^4*h*rho*cos(beta(t))^2*sin(alpha(t))*diff(beta(t),t)*cos(gamma(t))*diff(psi(t),t)*sin(theta(t))*Pi+1/12*R^2*h^3*rho*cos(beta(t))^2*diff(gamma(t),t)*sin(gamma(t))*diff(psi(t),t)*cos(theta(t))*sin(phi(t))*Pi+1/12*R^2*h^3*rho*cos(beta(t))^2*cos(gamma(t))*diff(psi(t),t)*diff(theta(t),t)*sin(theta(t))*sin(phi(t))*Pi-1/12*R^2*h^3*rho*cos(beta(t))^2*cos(gamma(t))*diff(psi(t),t)*cos(theta(t))*diff(phi(t),t)*cos(phi(t))*Pi-1/6*R^2*h^3*rho*cos(beta(t))*cos(gamma(t))*diff(theta(t),t)*cos(phi(t))*Pi*diff(beta(t),t)*sin(beta(t))-1/12*R^2*h^3*rho*sin(gamma(t))*cos(beta(t))*cos(alpha(t))*sin(beta(t))*cos(gamma(t))*diff(phi(t),t)^2*Pi+1/4*R^4*h*rho*diff(theta(t),t)*Pi*sin(gamma(t))*cos(beta(t))^2*cos(alpha(t))^2*diff(psi(t),t)*cos(theta(t))+1/4*R^4*h*rho*sin(gamma(t))*sin(alpha(t))*diff(beta(t),t)*diff(psi(t),t)*cos(theta(t))*sin(phi(t))*Pi-1/4*R^4*h*rho*diff(theta(t),t)*Pi*sin(gamma(t))*cos(beta(t))^2*sin(alpha(t))^2*diff(psi(t),t)*cos(theta(t))+1/12*R^2*h^3*rho*sin(alpha(t))^2*cos(beta(t))^2*cos(gamma(t))*diff(theta(t),t)*diff(phi(t),t)*sin(phi(t))*Pi+1/12*R^2*h^3*rho*sin(gamma(t))*sin(alpha(t))^2*cos(beta(t))^2*diff(psi(t),t)*diff(theta(t),t)*cos(theta(t))*Pi+1/12*R^2*h^3*rho*sin(alpha(t))^2*cos(beta(t))^2*diff(gamma(t),t)*cos(gamma(t))*diff(psi(t),t)*sin(theta(t))*Pi-1/12*R^2*h^3*rho*sin(gamma(t))*sin(alpha(t))^2*cos(beta(t))^2*diff(gamma(t),t)*diff(theta(t),t)*cos(phi(t))*Pi-1/4*R^4*h*rho*diff(theta(t),t)*Pi*cos(beta(t))^2*sin(alpha(t))^2*sin(phi(t))*diff(phi(t),t)*cos(gamma(t))+1/12*R^2*h^3*rho*sin(gamma(t))*cos(alpha(t))^2*cos(beta(t))^2*diff(theta(t),t)^2*cos(phi(t))*sin(phi(t))*Pi+1/4*R^4*h*rho*diff(theta(t),t)*Pi*cos(beta(t))^2*cos(alpha(t))^2*sin(phi(t))*diff(phi(t),t)*cos(gamma(t))+1/12*R^2*h^3*rho*sin(gamma(t))*cos(alpha(t))^2*cos(beta(t))^2*diff(gamma(t),t)*diff(theta(t),t)*cos(phi(t))*Pi+1/4*R^4*h*rho*sin(gamma(t))*cos(beta(t))*cos(alpha(t))*sin(beta(t))*cos(gamma(t))*diff(phi(t),t)^2*Pi+1/12*R^2*h^3*rho*sin(gamma(t))*sin(alpha(t))*diff(beta(t),t)*diff(psi(t),t)*cos(theta(t))*sin(phi(t))*Pi-1/12*R^2*h^3*rho*sin(gamma(t))*cos(alpha(t))^2*cos(beta(t))^2*diff(psi(t),t)*diff(theta(t),t)*cos(theta(t))*Pi+1/6*R^2*h^3*rho*cos(alpha(t))*cos(beta(t))*sin(beta(t))*diff(psi(t),t)*cos(phi(t))*diff(theta(t),t)*sin(theta(t))*Pi+1/2*R^4*h*rho*diff(gamma(t),t)*cos(gamma(t))*cos(beta(t))*sin(alpha(t))*sin(beta(t))*diff(theta(t),t)*cos(phi(t))*Pi+1/2*R^4*h*rho*cos(beta(t))*sin(alpha(t))*sin(beta(t))*diff(gamma(t),t)*sin(gamma(t))*diff(psi(t),t)*sin(theta(t))*Pi-1/2*R^4*h*rho*cos(beta(t))*sin(alpha(t))*sin(beta(t))*cos(gamma(t))*diff(psi(t),t)*diff(theta(t),t)*cos(theta(t))*Pi-1/6*R^2*h^3*rho*cos(beta(t))*cos(alpha(t))*sin(beta(t))*cos(gamma(t))^2*diff(theta(t),t)*cos(phi(t))*diff(phi(t),t)*Pi-1/2*R^4*h*rho*sin(gamma(t))*cos(beta(t))*cos(alpha(t))*sin(beta(t))*cos(gamma(t))*diff(psi(t),t)^2*cos(theta(t))^2*Pi+1/4*R^4*h*rho*sin(alpha(t))*cos(beta(t))*sin(beta(t))*cos(gamma(t))*diff(theta(t),t)^2*cos(phi(t))*sin(phi(t))*Pi-1/2*R^4*h*rho*diff(theta(t),t)*Pi*sin(gamma(t))*cos(beta(t))^2*cos(alpha(t))^2*diff(psi(t),t)*cos(phi(t))^2*cos(theta(t))-1/12*R^2*h^3*rho*cos(alpha(t))^2*cos(beta(t))^2*cos(gamma(t))*diff(psi(t),t)*diff(theta(t),t)*sin(theta(t))*sin(phi(t))*Pi+1/6*R^2*h^3*rho*sin(gamma(t))*cos(alpha(t))^2*cos(beta(t))^2*diff(psi(t),t)*diff(theta(t),t)*cos(phi(t))^2*cos(theta(t))*Pi-1/12*R^2*h^3*rho*cos(alpha(t))^2*cos(beta(t))^2*cos(gamma(t))*diff(psi(t),t)*cos(phi(t))*cos(theta(t))*diff(phi(t),t)*Pi-1/12*R^2*h^3*rho*cos(alpha(t))^2*cos(beta(t))^2*cos(gamma(t))*diff(psi(t),t)^2*sin(theta(t))*cos(phi(t))*cos(theta(t))*Pi-1/12*R^2*h^3*rho*sin(gamma(t))*cos(alpha(t))^2*cos(beta(t))^2*diff(gamma(t),t)*diff(psi(t),t)*cos(theta(t))*sin(phi(t))*Pi+1/12*R^2*h^3*rho*diff(theta(t),t)^2*sin(beta(t))*Pi*sin(gamma(t))*cos(beta(t))*cos(alpha(t))*cos(phi(t))^2*cos(gamma(t))+1/6*R^2*h^3*rho*sin(gamma(t))*cos(beta(t))*cos(alpha(t))*sin(beta(t))*cos(gamma(t))*diff(psi(t),t)^2*cos(theta(t))^2*Pi+1/2*R^4*h*rho*sin(gamma(t))*cos(beta(t))*sin(alpha(t))*sin(beta(t))*diff(psi(t),t)*diff(theta(t),t)*sin(theta(t))*sin(phi(t))*Pi+1/6*R^2*h^3*rho*diff(gamma(t),t)*cos(gamma(t))*cos(beta(t))*sin(alpha(t))*sin(beta(t))*diff(psi(t),t)*cos(theta(t))*sin(phi(t))*Pi-1/6*R^2*h^3*rho*sin(gamma(t))*cos(beta(t))*sin(alpha(t))*sin(beta(t))*diff(psi(t),t)*diff(theta(t),t)*sin(theta(t))*sin(phi(t))*Pi+1/12*R^2*h^3*rho*sin(beta(t))*Pi*cos(beta(t))*diff(psi(t),t)^2*sin(phi(t))*cos(phi(t))*sin(alpha(t))*cos(theta(t))^2*cos(gamma(t))+1/2*R^4*h*rho*diff(theta(t),t)*Pi*sin(gamma(t))*cos(beta(t))^2*cos(phi(t))*diff(phi(t),t)*cos(alpha(t))*cos(gamma(t))*sin(alpha(t))-1/2*R^4*h*rho*cos(beta(t))*cos(alpha(t))*sin(beta(t))*cos(gamma(t))^2*diff(psi(t),t)^2*sin(theta(t))*cos(theta(t))*sin(phi(t))*Pi+1/2*R^4*h*rho*sin(alpha(t))*cos(beta(t))*sin(beta(t))*cos(gamma(t))*diff(psi(t),t)*diff(theta(t),t)*cos(phi(t))^2*cos(theta(t))*Pi+1/2*R^4*h*rho*sin(gamma(t))*cos(beta(t))*cos(alpha(t))*sin(beta(t))*cos(gamma(t))*diff(psi(t),t)*sin(theta(t))*diff(phi(t),t)*Pi+1/4*R^4*h*rho*sin(gamma(t))*sin(alpha(t))*cos(beta(t))*sin(beta(t))*diff(psi(t),t)^2*sin(theta(t))*cos(phi(t))*cos(theta(t))*Pi-1/6*R^2*h^3*rho*diff(theta(t),t)*Pi*sin(gamma(t))*cos(beta(t))^2*cos(phi(t))*diff(phi(t),t)*cos(alpha(t))*cos(gamma(t))*sin(alpha(t))+1/2*R^4*h*rho*cos(beta(t))*cos(alpha(t))*sin(beta(t))*cos(gamma(t))^2*diff(psi(t),t)*diff(theta(t),t)*sin(theta(t))*cos(phi(t))*Pi-1/2*R^4*h*rho*cos(beta(t))*cos(alpha(t))*sin(beta(t))*cos(gamma(t))^2*diff(psi(t),t)*cos(theta(t))*diff(phi(t),t)*sin(phi(t))*Pi-1/6*R^2*h^3*rho*sin(alpha(t))*cos(beta(t))*sin(beta(t))*cos(gamma(t))*diff(psi(t),t)*diff(theta(t),t)*cos(phi(t))^2*cos(theta(t))*Pi-1/12*R^2*h^3*rho*sin(gamma(t))*sin(alpha(t))*cos(beta(t))*sin(beta(t))*diff(psi(t),t)^2*sin(theta(t))*cos(phi(t))*cos(theta(t))*Pi-1/6*R^2*h^3*rho*cos(beta(t))*cos(alpha(t))*sin(beta(t))*cos(gamma(t))^2*diff(psi(t),t)*diff(theta(t),t)*sin(theta(t))*cos(phi(t))*Pi+1/6*R^2*h^3*rho*cos(beta(t))*cos(alpha(t))*sin(beta(t))*cos(gamma(t))^2*diff(psi(t),t)*cos(theta(t))*diff(phi(t),t)*sin(phi(t))*Pi-1/12*R^2*h^3*rho*sin(beta(t))*Pi*sin(gamma(t))*cos(beta(t))*cos(alpha(t))*diff(psi(t),t)^2*cos(phi(t))^2*cos(theta(t))^2*cos(gamma(t))-1/6*R^2*h^3*rho*sin(gamma(t))*cos(beta(t))*cos(alpha(t))*sin(beta(t))*cos(gamma(t))*diff(psi(t),t)*sin(theta(t))*diff(phi(t),t)*Pi-1/2*R^4*h*rho*diff(gamma(t),t)*cos(gamma(t))*cos(beta(t))*sin(alpha(t))*sin(beta(t))*diff(psi(t),t)*cos(theta(t))*sin(phi(t))*Pi+1/2*R^4*h*rho*diff(diff(alpha(t),t),t)*Pi-1/2*R^4*h*rho*cos(gamma(t))*diff(diff(psi(t),t),t)*cos(theta(t))*sin(phi(t))*Pi-1/4*R^4*h*rho*Pi*sin(gamma(t))*cos(beta(t))^2*sin(theta(t))*diff(diff(psi(t),t),t)-1/4*R^4*h*rho*diff(diff(theta(t),t),t)*Pi*cos(beta(t))^2*cos(phi(t))*cos(gamma(t))+1/12*R^2*h^3*rho*sin(gamma(t))*cos(beta(t))^2*diff(diff(psi(t),t),t)*sin(theta(t))*Pi-1/12*R^2*h^3*rho*cos(alpha(t))*cos(beta(t))^2*diff(beta(t),t)*diff(gamma(t),t)*Pi+1/4*R^4*h*rho*cos(alpha(t))*cos(beta(t))^2*diff(beta(t),t)*diff(gamma(t),t)*Pi+1/4*R^4*h*rho*Pi*cos(beta(t))^2*diff(gamma(t),t)^2*cos(alpha(t))*sin(alpha(t))+1/4*R^4*h*rho*diff(theta(t),t)^2*Pi*cos(beta(t))^2*cos(alpha(t))*sin(alpha(t))-1/12*R^2*h^3*rho*diff(theta(t),t)^2*Pi*cos(beta(t))^2*cos(alpha(t))*sin(alpha(t))-1/12*R^2*h^3*rho*cos(alpha(t))*diff(beta(t),t)*diff(theta(t),t)*sin(phi(t))*Pi+1/12*R^2*h^3*rho*sin(alpha(t))*diff(beta(t),t)*cos(gamma(t))*diff(phi(t),t)*Pi-1/4*R^4*h*rho*cos(alpha(t))*diff(beta(t),t)*diff(theta(t),t)*sin(phi(t))*Pi+1/4*R^4*h*rho*sin(alpha(t))*diff(beta(t),t)*cos(gamma(t))*diff(phi(t),t)*Pi-1/12*R^2*h^3*rho*Pi*cos(beta(t))^2*diff(gamma(t),t)^2*cos(alpha(t))*sin(alpha(t))+1/2*R^4*h*rho*Pi*cos(beta(t))*diff(alpha(t),t)*diff(beta(t),t)*sin(beta(t))-1/6*R^2*h^3*rho*diff(alpha(t),t)*cos(beta(t))*Pi*diff(beta(t),t)*sin(beta(t))+1/12*R^2*h^3*rho*diff(gamma(t),t)*cos(gamma(t))*cos(beta(t))^2*diff(phi(t),t)*Pi-1/2*R^4*h*rho*diff(gamma(t),t)*sin(gamma(t))*diff(theta(t),t)*cos(phi(t))*Pi-1/2*R^4*h*rho*cos(gamma(t))*diff(theta(t),t)*diff(phi(t),t)*sin(phi(t))*Pi-1/4*R^4*h*rho*Pi*diff(gamma(t),t)*cos(gamma(t))*cos(beta(t))^2*diff(phi(t),t)+1/2*R^4*h*rho*diff(gamma(t),t)*cos(gamma(t))*diff(psi(t),t)*sin(theta(t))*Pi+1/2*R^4*h*rho*sin(gamma(t))*diff(psi(t),t)*diff(theta(t),t)*cos(theta(t))*Pi+1/12*R^2*h^3*rho*cos(beta(t))^2*cos(gamma(t))*diff(diff(theta(t),t),t)*cos(phi(t))*Pi-1/12*R^2*h^3*rho*cos(alpha(t))*cos(beta(t))*sin(beta(t))*diff(diff(gamma(t),t),t)*Pi+1/12*R^2*h^3*rho*cos(alpha(t))*diff(beta(t),t)*sin(beta(t))^2*diff(gamma(t),t)*Pi+1/4*R^4*h*rho*cos(alpha(t))*cos(beta(t))*sin(beta(t))*diff(diff(gamma(t),t),t)*Pi-1/4*R^4*h*rho*cos(alpha(t))*diff(beta(t),t)*sin(beta(t))^2*diff(gamma(t),t)*Pi+1/2*R^4*h*rho*cos(beta(t))*cos(alpha(t))*sin(beta(t))*cos(gamma(t))^2*diff(theta(t),t)*cos(phi(t))*diff(phi(t),t)*Pi+1/4*R^4*h*rho*Pi*sin(gamma(t))*cos(beta(t))^2*cos(alpha(t))^2*diff(psi(t),t)^2*sin(phi(t))*cos(phi(t))*cos(theta(t))^2+1/4*R^4*h*rho*diff(theta(t),t)*Pi*cos(beta(t))^2*sin(theta(t))*cos(alpha(t))^2*diff(psi(t),t)*sin(phi(t))*cos(gamma(t))+1/4*R^4*h*rho*cos(beta(t))*cos(alpha(t))*sin(beta(t))*diff(psi(t),t)^2*sin(theta(t))*cos(theta(t))*sin(phi(t))*Pi-1/4*R^4*h*rho*diff(theta(t),t)*Pi*cos(beta(t))^2*sin(theta(t))*sin(alpha(t))^2*diff(psi(t),t)*sin(phi(t))*cos(gamma(t))-1/4*R^4*h*rho*Pi*sin(gamma(t))*cos(beta(t))^2*sin(alpha(t))^2*diff(psi(t),t)^2*sin(phi(t))*cos(phi(t))*cos(theta(t))^2-1/4*R^4*h*rho*Pi*sin(gamma(t))*cos(beta(t))^2*diff(gamma(t),t)*sin(alpha(t))^2*diff(psi(t),t)*sin(phi(t))*cos(theta(t))-1/4*R^4*h*rho*Pi*cos(beta(t))^2*sin(theta(t))*sin(alpha(t))^2*diff(psi(t),t)^2*cos(phi(t))*cos(theta(t))*cos(gamma(t))-1/4*R^4*h*rho*Pi*cos(beta(t))^2*sin(alpha(t))^2*diff(psi(t),t)*cos(phi(t))*diff(phi(t),t)*cos(theta(t))*cos(gamma(t))-1/12*R^2*h^3*rho*sin(alpha(t))*cos(beta(t))*sin(beta(t))*cos(gamma(t))*diff(theta(t),t)^2*cos(phi(t))*sin(phi(t))*Pi+1/4*R^4*h*rho*Pi*cos(beta(t))^2*cos(alpha(t))^2*diff(psi(t),t)*cos(phi(t))*diff(phi(t),t)*cos(theta(t))*cos(gamma(t))+1/4*R^4*h*rho*Pi*cos(beta(t))^2*sin(theta(t))*cos(alpha(t))^2*diff(psi(t),t)^2*cos(phi(t))*cos(theta(t))*cos(gamma(t))+1/4*R^4*h*rho*Pi*sin(gamma(t))*cos(beta(t))^2*diff(gamma(t),t)*cos(alpha(t))^2*diff(psi(t),t)*sin(phi(t))*cos(theta(t))-1/12*R^2*h^3*rho*Pi*sin(gamma(t))*cos(beta(t))^2*cos(alpha(t))^2*diff(psi(t),t)^2*sin(phi(t))*cos(phi(t))*cos(theta(t))^2+1/6*R^2*h^3*rho*Pi*cos(beta(t))^2*sin(theta(t))*diff(psi(t),t)*diff(phi(t),t)*cos(alpha(t))*cos(gamma(t))^2*sin(alpha(t))-1/2*R^4*h*rho*Pi*cos(beta(t))^2*sin(theta(t))*diff(psi(t),t)*diff(phi(t),t)*cos(alpha(t))*cos(gamma(t))^2*sin(alpha(t))+1/12*R^2*h^3*rho*Pi*cos(beta(t))^2*diff(psi(t),t)^2*cos(phi(t))^2*cos(alpha(t))*cos(theta(t))^2*cos(gamma(t))^2*sin(alpha(t))-1/6*R^2*h^3*rho*Pi*cos(beta(t))^2*diff(gamma(t),t)*diff(psi(t),t)*cos(phi(t))*cos(alpha(t))*cos(theta(t))*sin(alpha(t))-1/4*R^4*h*rho*Pi*cos(beta(t))^2*diff(psi(t),t)^2*cos(phi(t))^2*cos(alpha(t))*cos(theta(t))^2*cos(gamma(t))^2*sin(alpha(t))-1/2*R^4*h*rho*cos(alpha(t))*cos(beta(t))*sin(beta(t))*diff(psi(t),t)*cos(phi(t))*diff(theta(t),t)*sin(theta(t))*Pi-1/6*R^2*h^3*rho*cos(beta(t))*sin(alpha(t))*sin(beta(t))*diff(gamma(t),t)*sin(gamma(t))*diff(psi(t),t)*sin(theta(t))*Pi+1/6*R^2*h^3*rho*cos(beta(t))*sin(alpha(t))*sin(beta(t))*cos(gamma(t))*diff(psi(t),t)*diff(theta(t),t)*cos(theta(t))*Pi-1/6*R^2*h^3*rho*diff(gamma(t),t)*cos(gamma(t))*cos(beta(t))*sin(alpha(t))*sin(beta(t))*diff(theta(t),t)*cos(phi(t))*Pi-1/4*R^4*h*rho*diff(theta(t),t)^2*sin(beta(t))*Pi*sin(gamma(t))*cos(beta(t))*cos(alpha(t))*cos(phi(t))^2*cos(gamma(t))-1/12*R^2*h^3*rho*cos(beta(t))*cos(alpha(t))*sin(beta(t))*diff(psi(t),t)^2*sin(theta(t))*cos(theta(t))*sin(phi(t))*Pi+1/2*R^4*h*rho*Pi*cos(beta(t))^2*diff(gamma(t),t)*diff(psi(t),t)*cos(phi(t))*cos(alpha(t))*cos(theta(t))*sin(alpha(t))+1/12*R^2*h^3*rho*Pi*sin(gamma(t))*cos(beta(t))^2*sin(alpha(t))^2*diff(psi(t),t)^2*sin(phi(t))*cos(phi(t))*cos(theta(t))^2+1/12*R^2*h^3*rho*sin(gamma(t))*sin(alpha(t))^2*cos(beta(t))^2*diff(gamma(t),t)*diff(psi(t),t)*cos(theta(t))*sin(phi(t))*Pi+1/12*R^2*h^3*rho*sin(alpha(t))^2*cos(beta(t))^2*cos(gamma(t))*diff(psi(t),t)^2*sin(theta(t))*cos(phi(t))*cos(theta(t))*Pi+1/12*R^2*h^3*rho*sin(alpha(t))^2*cos(beta(t))^2*cos(gamma(t))*diff(psi(t),t)*cos(phi(t))*cos(theta(t))*diff(phi(t),t)*Pi+1/12*R^2*h^3*rho*sin(alpha(t))^2*cos(beta(t))^2*cos(gamma(t))*diff(psi(t),t)*diff(theta(t),t)*sin(theta(t))*sin(phi(t))*Pi-1/6*R^2*h^3*rho*sin(gamma(t))*sin(alpha(t))^2*cos(beta(t))^2*diff(psi(t),t)*diff(theta(t),t)*cos(phi(t))^2*cos(theta(t))*Pi+1/2*R^4*h*rho*diff(theta(t),t)*Pi*sin(gamma(t))*cos(beta(t))^2*sin(alpha(t))^2*diff(psi(t),t)*cos(phi(t))^2*cos(theta(t))-1/4*R^4*h*rho*sin(gamma(t))*cos(beta(t))^2*sin(alpha(t))*diff(beta(t),t)*diff(psi(t),t)*cos(theta(t))*sin(phi(t))*Pi+1/12*R^2*h^3*rho*sin(gamma(t))*cos(beta(t))^2*sin(alpha(t))*diff(beta(t),t)*diff(psi(t),t)*cos(theta(t))*sin(phi(t))*Pi+1/4*R^4*h*rho*sin(gamma(t))*diff(beta(t),t)*sin(beta(t))^2*sin(alpha(t))*diff(psi(t),t)*cos(theta(t))*sin(phi(t))*Pi+1/12*R^2*h^3*rho*sin(gamma(t))*cos(beta(t))*sin(alpha(t))*sin(beta(t))*diff(diff(psi(t),t),t)*cos(theta(t))*sin(phi(t))*Pi-1/12*R^2*h^3*rho*sin(gamma(t))*diff(beta(t),t)*sin(beta(t))^2*sin(alpha(t))*diff(psi(t),t)*cos(theta(t))*sin(phi(t))*Pi+1/6*R^2*h^3*rho*cos(beta(t))*cos(gamma(t))*diff(psi(t),t)*cos(theta(t))*sin(phi(t))*Pi*diff(beta(t),t)*sin(beta(t))-1/4*R^4*h*rho*sin(gamma(t))*cos(beta(t))*sin(alpha(t))*sin(beta(t))*diff(diff(psi(t),t),t)*cos(theta(t))*sin(phi(t))*Pi-1/2*R^4*h*rho*Pi*cos(beta(t))*diff(psi(t),t)*sin(phi(t))*cos(theta(t))*cos(gamma(t))*diff(beta(t),t)*sin(beta(t))-1/6*R^2*h^3*rho*Pi*cos(beta(t))^2*diff(psi(t),t)^2*cos(phi(t))^2*cos(alpha(t))*cos(theta(t))^2*sin(alpha(t))-1/6*R^2*h^3*rho*diff(theta(t),t)*Pi*cos(beta(t))^2*diff(gamma(t),t)*sin(phi(t))*cos(alpha(t))*sin(alpha(t))+1/12*R^2*h^3*rho*cos(beta(t))^2*sin(alpha(t))*diff(beta(t),t)*cos(gamma(t))*diff(psi(t),t)*sin(theta(t))*Pi-1/12*R^2*h^3*rho*sin(gamma(t))*cos(beta(t))^2*sin(alpha(t))*diff(beta(t),t)*diff(theta(t),t)*cos(phi(t))*Pi+1/2*R^4*h*rho*Pi*cos(beta(t))^2*diff(psi(t),t)^2*cos(alpha(t))*cos(theta(t))^2*cos(gamma(t))^2*sin(alpha(t))-1/12*R^2*h^3*rho*diff(theta(t),t)^2*Pi*cos(beta(t))^2*cos(phi(t))^2*cos(alpha(t))*cos(gamma(t))^2*sin(alpha(t))-1/6*R^2*h^3*rho*Pi*cos(beta(t))^2*diff(psi(t),t)^2*cos(alpha(t))*cos(theta(t))^2*cos(gamma(t))^2*sin(alpha(t))+1/4*R^4*h*rho*Pi*cos(beta(t))^2*diff(gamma(t),t)*sin(theta(t))*cos(alpha(t))^2*diff(psi(t),t)*cos(gamma(t))+1/4*R^4*h*rho*sin(gamma(t))*cos(beta(t))*cos(alpha(t))*sin(beta(t))*cos(gamma(t))*diff(psi(t),t)^2*Pi-1/12*R^2*h^3*rho*sin(gamma(t))*sin(alpha(t))^2*cos(beta(t))^2*diff(theta(t),t)^2*cos(phi(t))*sin(phi(t))*Pi+1/4*R^4*h*rho*diff(theta(t),t)*Pi*sin(gamma(t))*cos(beta(t))^2*diff(gamma(t),t)*sin(alpha(t))^2*cos(phi(t))+1/4*R^4*h*rho*diff(theta(t),t)^2*Pi*sin(gamma(t))*cos(beta(t))^2*sin(alpha(t))^2*sin(phi(t))*cos(phi(t))-1/4*R^4*h*rho*Pi*cos(beta(t))^2*diff(gamma(t),t)*sin(theta(t))*sin(alpha(t))^2*diff(psi(t),t)*cos(gamma(t))+1/2*R^4*h*rho*Pi*cos(beta(t))^2*diff(psi(t),t)^2*cos(phi(t))^2*cos(alpha(t))*cos(theta(t))^2*sin(alpha(t))+1/2*R^4*h*rho*diff(theta(t),t)*Pi*cos(beta(t))^2*diff(gamma(t),t)*sin(phi(t))*cos(alpha(t))*sin(alpha(t))+1/4*R^4*h*rho*diff(theta(t),t)^2*Pi*cos(beta(t))^2*cos(phi(t))^2*cos(alpha(t))*cos(gamma(t))^2*sin(alpha(t))-1/4*R^4*h*rho*diff(theta(t),t)^2*Pi*sin(gamma(t))*cos(beta(t))^2*cos(alpha(t))^2*sin(phi(t))*cos(phi(t))-1/4*R^4*h*rho*diff(theta(t),t)*Pi*sin(gamma(t))*cos(beta(t))^2*diff(gamma(t),t)*cos(alpha(t))^2*cos(phi(t))-1/12*R^2*h^3*rho*sin(gamma(t))*cos(beta(t))*cos(alpha(t))*sin(beta(t))*cos(gamma(t))*diff(psi(t),t)^2*Pi+1/4*R^4*h*rho*Pi*cos(beta(t))^2*diff(psi(t),t)*diff(phi(t),t)*cos(phi(t))*cos(theta(t))*cos(gamma(t))-1/4*R^4*h*rho*Pi*cos(beta(t))^2*diff(psi(t),t)*sin(phi(t))*diff(theta(t),t)*sin(theta(t))*cos(gamma(t))-1/4*R^4*h*rho*Pi*cos(beta(t))^2*diff(psi(t),t)*sin(phi(t))*cos(theta(t))*diff(gamma(t),t)*sin(gamma(t))+1/2*R^4*h*rho*cos(beta(t))*sin(alpha(t))*sin(beta(t))*diff(gamma(t),t)*sin(gamma(t))*diff(phi(t),t)*Pi-1/6*R^2*h^3*rho*cos(beta(t))*sin(alpha(t))*sin(beta(t))*diff(gamma(t),t)*sin(gamma(t))*diff(phi(t),t)*Pi-1/4*R^4*h*rho*cos(beta(t))*sin(alpha(t))*sin(beta(t))*cos(gamma(t))*diff(diff(psi(t),t),t)*sin(theta(t))*Pi+1/4*R^4*h*rho*diff(beta(t),t)*sin(beta(t))^2*sin(alpha(t))*cos(gamma(t))*diff(psi(t),t)*sin(theta(t))*Pi-1/12*R^2*h^3*rho*cos(alpha(t))*cos(beta(t))*sin(beta(t))*diff(diff(psi(t),t),t)*cos(phi(t))*cos(theta(t))*Pi+1/12*R^2*h^3*rho*cos(alpha(t))*diff(beta(t),t)*sin(beta(t))^2*diff(psi(t),t)*cos(phi(t))*cos(theta(t))*Pi+1/4*R^4*h*rho*sin(gamma(t))*cos(beta(t))*sin(alpha(t))*sin(beta(t))*diff(diff(theta(t),t),t)*cos(phi(t))*Pi-1/4*R^4*h*rho*sin(gamma(t))*diff(beta(t),t)*sin(beta(t))^2*sin(alpha(t))*diff(theta(t),t)*cos(phi(t))*Pi-1/4*R^4*h*rho*cos(alpha(t))*diff(beta(t),t)*sin(beta(t))^2*diff(psi(t),t)*cos(phi(t))*cos(theta(t))*Pi+1/12*R^2*h^3*rho*cos(beta(t))*sin(alpha(t))*sin(beta(t))*cos(gamma(t))*diff(diff(psi(t),t),t)*sin(theta(t))*Pi-1/12*R^2*h^3*rho*diff(beta(t),t)*sin(beta(t))^2*sin(alpha(t))*cos(gamma(t))*diff(psi(t),t)*sin(theta(t))*Pi-1/12*R^2*h^3*rho*sin(gamma(t))*cos(beta(t))*sin(alpha(t))*sin(beta(t))*diff(diff(theta(t),t),t)*cos(phi(t))*Pi+1/12*R^2*h^3*rho*sin(gamma(t))*diff(beta(t),t)*sin(beta(t))^2*sin(alpha(t))*diff(theta(t),t)*cos(phi(t))*Pi+1/2*R^4*h*rho*Pi*sin(gamma(t))*cos(beta(t))*sin(theta(t))*diff(psi(t),t)*diff(beta(t),t)*sin(beta(t))+1/2*R^4*h*rho*diff(theta(t),t)*Pi*cos(beta(t))*cos(phi(t))*cos(gamma(t))*diff(beta(t),t)*sin(beta(t))-1/6*R^2*h^3*rho*sin(gamma(t))*cos(beta(t))*diff(psi(t),t)*sin(theta(t))*Pi*diff(beta(t),t)*sin(beta(t))+1/4*R^4*h*rho*cos(alpha(t))*cos(beta(t))*sin(beta(t))*diff(diff(psi(t),t),t)*cos(phi(t))*cos(theta(t))*Pi+1/4*R^4*h*rho*cos(alpha(t))*cos(beta(t))^2*diff(beta(t),t)*diff(psi(t),t)*cos(phi(t))*cos(theta(t))*Pi-1/6*R^2*h^3*rho*sin(gamma(t))*cos(beta(t))*cos(alpha(t))*sin(beta(t))*cos(gamma(t))*diff(psi(t),t)*diff(theta(t),t)*cos(phi(t))*cos(theta(t))*sin(phi(t))*Pi+1/2*R^4*h*rho*sin(gamma(t))*cos(beta(t))*cos(alpha(t))*sin(beta(t))*cos(gamma(t))*diff(psi(t),t)*diff(theta(t),t)*cos(phi(t))*cos(theta(t))*sin(phi(t))*Pi+1/12*R^2*h^3*rho*cos(beta(t))^2*sin(alpha(t))*diff(beta(t),t)*cos(gamma(t))*diff(phi(t),t)*Pi+1/4*R^4*h*rho*diff(theta(t),t)*Pi*cos(beta(t))^2*diff(phi(t),t)*sin(phi(t))*cos(gamma(t))+1/4*R^4*h*rho*diff(theta(t),t)*Pi*cos(beta(t))^2*cos(phi(t))*diff(gamma(t),t)*sin(gamma(t))+1/12*R^2*h^3*rho*diff(gamma(t),t)*cos(gamma(t))*cos(beta(t))^2*diff(psi(t),t)*sin(theta(t))*Pi+1/12*R^2*h^3*rho*sin(gamma(t))*cos(beta(t))^2*diff(psi(t),t)*diff(theta(t),t)*cos(theta(t))*Pi-1/12*R^2*h^3*rho*cos(beta(t))^2*cos(gamma(t))*diff(theta(t),t)*diff(phi(t),t)*sin(phi(t))*Pi+1/2*R^4*h*rho*diff(gamma(t),t)*sin(gamma(t))*diff(psi(t),t)*cos(theta(t))*sin(phi(t))*Pi+1/2*R^4*h*rho*cos(gamma(t))*diff(psi(t),t)*diff(theta(t),t)*sin(theta(t))*sin(phi(t))*Pi-1/2*R^4*h*rho*cos(gamma(t))*diff(psi(t),t)*cos(theta(t))*diff(phi(t),t)*cos(phi(t))*Pi-1/4*R^4*h*rho*Pi*diff(gamma(t),t)*cos(gamma(t))*cos(beta(t))^2*sin(theta(t))*diff(psi(t),t)-1/4*R^4*h*rho*Pi*sin(gamma(t))*cos(beta(t))^2*diff(theta(t),t)*cos(theta(t))*diff(psi(t),t)-1/12*R^2*h^3*rho*sin(gamma(t))*sin(alpha(t))*diff(beta(t),t)*diff(theta(t),t)*cos(phi(t))*Pi-1/4*R^4*h*rho*Pi*cos(beta(t))^2*diff(phi(t),t)^2*cos(alpha(t))*cos(gamma(t))^2*sin(alpha(t))-1/2*R^4*h*rho*diff(theta(t),t)^2*Pi*cos(beta(t))^2*cos(phi(t))^2*cos(alpha(t))*sin(alpha(t))+1/12*R^2*h^3*rho*Pi*cos(beta(t))^2*diff(psi(t),t)^2*cos(alpha(t))*cos(theta(t))^2*sin(alpha(t))+1/12*R^2*h^3*rho*Pi*cos(beta(t))^2*diff(psi(t),t)^2*cos(alpha(t))*cos(gamma(t))^2*sin(alpha(t))-1/4*R^4*h*rho*Pi*cos(beta(t))^2*diff(psi(t),t)^2*cos(alpha(t))*cos(theta(t))^2*sin(alpha(t))-1/4*R^4*h*rho*Pi*cos(beta(t))^2*diff(psi(t),t)^2*cos(alpha(t))*cos(gamma(t))^2*sin(alpha(t))+1/12*R^2*h^3*rho*Pi*cos(beta(t))^2*diff(phi(t),t)^2*cos(alpha(t))*cos(gamma(t))^2*sin(alpha(t))+1/6*R^2*h^3*rho*cos(alpha(t))*cos(beta(t))^2*diff(theta(t),t)^2*cos(phi(t))^2*Pi*sin(alpha(t))+1/4*R^4*h*rho*Pi*cos(beta(t))^2*diff(gamma(t),t)*cos(alpha(t))^2*diff(phi(t),t)*cos(gamma(t))-1/12*R^2*h^3*rho*cos(alpha(t))*diff(beta(t),t)*diff(psi(t),t)*cos(phi(t))*cos(theta(t))*Pi+1/12*R^2*h^3*rho*sin(alpha(t))^2*cos(beta(t))^2*diff(gamma(t),t)*cos(gamma(t))*diff(phi(t),t)*Pi-1/4*R^4*h*rho*Pi*cos(beta(t))^2*diff(gamma(t),t)*sin(alpha(t))^2*diff(phi(t),t)*cos(gamma(t))-1/12*R^2*h^3*rho*cos(alpha(t))^2*cos(beta(t))^2*diff(gamma(t),t)*cos(gamma(t))*diff(phi(t),t)*Pi-1/4*R^4*h*rho*sin(gamma(t))*sin(alpha(t))*diff(beta(t),t)*diff(theta(t),t)*cos(phi(t))*Pi+1/4*R^4*h*rho*sin(alpha(t))*diff(beta(t),t)*cos(gamma(t))*diff(psi(t),t)*sin(theta(t))*Pi-1/4*R^4*h*rho*cos(alpha(t))*diff(beta(t),t)*diff(psi(t),t)*cos(phi(t))*cos(theta(t))*Pi+1/12*R^2*h^3*rho*sin(alpha(t))*diff(beta(t),t)*cos(gamma(t))*diff(psi(t),t)*sin(theta(t))*Pi+1/4*R^4*h*rho*Pi*cos(beta(t))^2*diff(diff(psi(t),t),t)*sin(phi(t))*cos(theta(t))*cos(gamma(t))-1/3*R^2*h^3*rho*cos(alpha(t))*cos(beta(t))^2*diff(psi(t),t)*diff(theta(t),t)*cos(phi(t))*cos(theta(t))*sin(phi(t))*Pi*sin(alpha(t))+1/4*R^4*h*rho*sin(beta(t))*Pi*sin(gamma(t))*cos(beta(t))*cos(alpha(t))*diff(psi(t),t)^2*cos(phi(t))^2*cos(theta(t))^2*cos(gamma(t))-1/4*R^4*h*rho*sin(beta(t))*Pi*cos(beta(t))*diff(psi(t),t)^2*sin(phi(t))*cos(phi(t))*sin(alpha(t))*cos(theta(t))^2*cos(gamma(t))+1/6*R^2*h^3*rho*cos(beta(t))*cos(alpha(t))*sin(beta(t))*cos(gamma(t))^2*diff(psi(t),t)^2*sin(theta(t))*cos(theta(t))*sin(phi(t))*Pi+R^4*h*rho*diff(theta(t),t)*Pi*cos(beta(t))^2*diff(psi(t),t)*sin(phi(t))*cos(phi(t))*cos(alpha(t))*cos(theta(t))*sin(alpha(t))+1/6*R^2*h^3*rho*Pi*sin(gamma(t))*cos(beta(t))^2*sin(theta(t))*diff(psi(t),t)^2*sin(phi(t))*cos(alpha(t))*cos(theta(t))*cos(gamma(t))*sin(alpha(t))-1/2*R^4*h*rho*diff(theta(t),t)*Pi*cos(beta(t))^2*diff(psi(t),t)*sin(phi(t))*cos(phi(t))*cos(alpha(t))*cos(theta(t))*cos(gamma(t))^2*sin(alpha(t))-1/2*R^4*h*rho*Pi*sin(gamma(t))*cos(beta(t))^2*sin(theta(t))*diff(psi(t),t)^2*sin(phi(t))*cos(alpha(t))*cos(theta(t))*cos(gamma(t))*sin(alpha(t))-1/2*R^4*h*rho*Pi*sin(gamma(t))*cos(beta(t))^2*diff(psi(t),t)*sin(phi(t))*diff(phi(t),t)*cos(alpha(t))*cos(theta(t))*cos(gamma(t))*sin(alpha(t))+1/2*R^4*h*rho*diff(theta(t),t)*Pi*sin(gamma(t))*cos(beta(t))^2*sin(theta(t))*diff(psi(t),t)*cos(phi(t))*cos(alpha(t))*cos(gamma(t))*sin(alpha(t))-1/6*R^2*h^3*rho*diff(theta(t),t)*Pi*sin(gamma(t))*cos(beta(t))^2*sin(theta(t))*diff(psi(t),t)*cos(phi(t))*cos(alpha(t))*cos(gamma(t))*sin(alpha(t))+1/6*R^2*h^3*rho*Pi*sin(gamma(t))*cos(beta(t))^2*diff(psi(t),t)*sin(phi(t))*diff(phi(t),t)*cos(alpha(t))*cos(theta(t))*cos(gamma(t))*sin(alpha(t))+1/6*R^2*h^3*rho*diff(theta(t),t)*Pi*cos(beta(t))^2*diff(psi(t),t)*sin(phi(t))*cos(phi(t))*cos(alpha(t))*cos(theta(t))*cos(gamma(t))^2*sin(alpha(t)) = 0"
I was trying to make a function (or procedure) that uses the simplify command and outputed all the different types of simplify that are in the right click menu.  I never know which one to chose so until I get the hang of what they are, I wanted to see all of them at once.  Can someone set me off on the right path?
I would like to simplify a trigonometric equation that I obtain with a vectorial closure (in mechanics)
Here the equation that I would like to simplify
eq_liaison :=(-sin(p(t)+g(t))*cos(a(t))-sin(b(t))*sin(a(t))*cos(p(t)+g(t)))*l2[1]+((-sin(p(t)+g(t))*cos(a(t))-sin(b(t))*sin(a(t))*cos(p(t)+g(t)))*cos(th(t))+(-cos(p(t)+g(t))*cos(a(t))+sin(a(t))*sin(b(t))*sin(p(t)+g(t)))*sin(th(t)))*l3[1] = 0
Do you have ideas so as to simplify again this expression ?
This expression can still be simplified. You can find here the result expected :
I find surprising that I have so many difficulties to make trigonometric simplications with the trigonometric functions.
Thank you for your help
PS : Sorry for duplicating posts. As I didn't receive any answer, I have tried to simplified my post to isolate the difficulty.
First 1179 1180 1181 1182 1183 1184 1185 Last Page 1181 of 2459
