with(Student[LinearAlgebra]);
example1 := Matrix([[1, 2, 3], [4, 5, 6], [6, 7, 8]]);
whattype(example1);
testproc := proc (A) print(whattype(A)) end proc;
testproc(example1);
The whattype() calls output:
Matrix
proc() ... end proc
I don't understand why what is a Matrix type outside the procedure seems to change into this unrelated type? This is really bizarre. I feel like it may be something outside my code? Thank you.
I'm trying to use Maple to plot a dependence, but Maple says there is a singularity.
Attached is the Maple file I'm using (Equation 2 and the 2 graphs pertaining to it are the problem)
They should look like the attached graph, but since Maple claims it hits unity, it won't plot any further points.
Is there a way to override this to force Maple to plot after reaching a singularity?
Any help or advice would be very much appreciated
Plotting_Gamma_v_F_Disaster.mw
Dear maple users,
I have a lengthy formulation of function f(x) which contains some constant coefficients (A1, A2, A3 ...). I would like to simplify f(x) for functions of same above mentioned coefficients as following:
f(x) = f1(x) A1 + f2(x) A2 + ... + fn(x) An
I tried the following command:
collect(simplify(f(x)), [A1, A2, A3 ...])
Maple returns the expected form of functions but the problem is that Maple did not simplify f1(x), f2(x)... Obviously, I do not want to simplify manually : simplify(f1(x)) ... again
How can I solve this problem?
Thankyou.
I have a function f(x) and want to know at which x-value it attains its supremum.
Tried this, but it doesn't work (or at least hasn't been able to solve the equation in 10+ min):
M := maximize(f, x = 0 .. 1);
solve(f = M, x);
Does anyone know a way to do this?
Paul
a := 1; w0 := 1; w1 := 3; K := 10; h0 := .25; A := 3; alpha := .7; b := .6; c := .2
f := A*x^(b*alpha)*(alpha*A*x^(b*alpha)/(a+w0*h0+(x-h0)*w1))^(alpha/(1-alpha))-(alpha*A*x^(b*alpha)/(a+w0*h0+(x-h0)*w1))^(1/(1-alpha))
16.94206235*x^.42*(x^.42/(.50+3*x))^2.333333333-11.85944364*(x^.42/(.50+3*x))^3.333333333
.8295280335
solve(f = M, x)
plot(f, x = 0 .. 1)
Download maximum.mw
I would like to animate solid of revolution for a region bounded by y=x^2+1, y=x, x=0 and x=2;
(a) about x=-1
(b) about y=6
Could anyone please help?
I've got a parametric curve of the form f(x),h(x) x=0..1, and want to make an animation of this curve when changing an exogenous variable h0.
My attempt was to do it like this:
plots[animate](plot, [f(x), h(x), x = 0 .. 1], h0 = 0 .. 1)
but it doesn't work.
Does anyone know if/how this can be done?
Paul
I want to solve the Falkner-Skan equation numbercally using maple. The Falkner-Skan equation is
f′′′ + ff′′ + (1 − (f′)^2)=0 ,
with subject to the boundary conditions,
f(0) =0 ; f′(0) = 0,
f′(∞) = 1.
could you  please help me to have loop to solve this problem from t=0..30.
And then save the data in DATfile in order to plot using Gnuplot?
the program is not recognized kthe program is not recognized the k
I have a set of differential equations on 3 variables, B[1],B[2] and C. Its not physically meaningful for B[1]+B[2]>0.5 so i would ideally like to replace the cube that the solutions are displayed on (the axis take the limits B[1]=0...0.5,B[2]=0...0.5,C=0...100 ) with a triangular prism (the axis take the limits B[1]=0...0.5,B[2]=0...0.5,B[1]+B[2]<0.5,C=0...100 ).
Failing that i'd like the plot to display a plane showing where the meaningful values for the variables end.
here is the code I use to put the ODEplot together
Model := [diff(B[1](t), t) = k[a1]*C(t)*(R-B[1](t)-B[2](t))-k[d1]*B[1](t), diff(B[2](t), t) = k[a2]*C(t)*(R-B[1](t)-B[2](t))-k[d2]*B[2](t), diff(C(t), t) = (-(k[a1]+k[a2])*C(t)*(R-B[1](t)-B[2](t))+k[d1]*B[1](t)+k[d2]*B[2](t)+k[m]*((I)(t)-C(t)))/h];
DissMod := subs((I)(t) = 0, Model);
AssMod := subs((I)(t) = C[T], Model);
Pars1a := [k[a1] = 6*10^(-4), k[d1] = 7*10^(-3), k[a2] = 6*10^(-4), k[d2] = (7/5)*10^(-3), R = .5, k[m] = 10^(-4), C[T] = 100, h = 10^(-6)];
Pars := Pars1a; thing11 := subs(Pars, AssMod[1]), subs(Pars, AssMod[2]); thing12 := diff(C(t), t) = piecewise(t <= 100, subs(Pars, rhs(AssMod[3])), subs(Pars, rhs(DissMod[3]))); sol := dsolve({thing11, thing12, C(0) = 0, B[1](0) = 0, B[2](0) = 0}, {C(t), B[1](t), B[2](t)}, numeric, output = listprocedure, maxstep = 2, maxfun = 1000000); ParsPlot1a := odeplot(sol, [B[1](t), B[2](t), C(t)], t = 0 .. 700, color = blue, view = [0 .. .5, 0 .. .5, 0 .. 100], tickmarks = [[0 = 0, .5 = R], [0 = 0, .5 = R], [0 = 0, 25 = (1/4)*C[T], 50 = (1/2)*C[T], 100 = C[T]]]);
But I can't see a way of either making the plane or making the ODEplot axis into something other than a cube.
Could someone explain, in layman terms, what dilog and polylog are?
I don't seem to understand them from the Help and I cannot find anything on the web.
I am trying to use a simple sum ( f:=t,n->sum(MyFunction(k,t),k=1..n) ), but the sum function doesn't "work" :
Error, (in MTM:-sum) invalid input: ArrayTools:-AddAlongDimension expects its 2nd argument, DimToAdd, to be of type posint, but received k = 1 .. n
As far as I can understand, I have loaded the package MTM, and now, the sum has been redefined to do something else, and now I can't use a "normal" sum anymore. Or can I ?
Does someone know how to use the "normal" sum without unloading the MTM package ?
Consider, say, the following third order derivative:
expr := diff(f(x,y),x,y$2);
Does there in Maple exist some built-in functions for extracting from such an expression 1.) the function being differentiated, and 2.) the coordinates being differentiated with respect to? Using op(expr) is of no immediate avail as it returns only a second order derivative (as the first operand), and one of the coordinates being differentiated with respect to (as the second operand).
It is, of course, possible to make ones own function for extracting these two quantities, a crude example being
splitDeriv := proc(expr,coords::expects(list) := [])
   if PDETools:-difforder(expr) > 0 then
      splitDeriv(op(1,expr),[coords[],op(2,expr)])
      expr,coords
   end if
for which
splitDeriv(expr);
But it would be much nicer to use built-in functions. And perhaps such functions do exist. If so, I am unable to locate them. Perhaps I am just being stupid, for the problem seems rather elementary.
I have just noticed that solving a nonhomogeneous linear ode using maple dsolve gives a different solution when compared to hand calculation by method of undetermined coefficient. For instance, this equation equation is
has the solution
Using dsolve for the same function give something completely different. Any assistance on how I can resolve this will be highly appreciated
I have the mathematica code given below. I am using Wolfram Mathematica Online.
I am very new to Mathematica. When I put this code, I do not get any output.
It just does not show me anything.
\[Alpha] = 3; F[s_] := Exp[-A*s^(2/\[Alpha])]; integral = Re[Assuming[{A > 0, t > 0, {t, A} \[Element] Reals}, Integrate[F[s]*Exp[s*t] /. s -> I*y, {y, 0, Infinity}]/Pi]]
Can some help me?
I have problem related to collection of coefficient of differtials in differential expression containing multiple dependent variables and we want to collect coefficient wrt to selected dependent variables. Please see attached Maple file for details.
with(PDEtools):
DepVars := [u(x, t), v(x, t), a[1](t), a[2](t), a[3](t), b[1](t), b[2](t), b[3](t), r(x, t), s[1](x, t), p[1](x, t), s[2](x, t), p[2](x, t)]
alias(u = u(x, t), v = v(x, t), a[1] = a[1](t), a[2] = a[2](t), a[3] = a[3](t), b[1] = b[1](t), b[2] = b[2](t), b[3] = b[3](t), r = r(x, t), s[1] = s[1](x, t), p[1] = p[1](x, t), s[2] = s[2](x, t), p[2] = p[2](x, t))
u, v, a[1], a[2], a[3], b[1], b[2], b[3], r, s[1], p[1], s[2], p[2]
Suppose we differential expression like:
a[1]*(diff(u, x))*s[1]*u-2*a[1]*u*(diff(r, x))*(diff(u, x))+2*a[2]*(diff(v, x))*s[2]*v-2*a[2]*v*(diff(r, x))*(diff(v, x))-(diff(a[3], t))*r*(diff(u, x))/a[3]+diff(p[1], t)+a[3]*(diff(p[1], x, x, x))+(diff(r, t))*(diff(u, x))+(diff(s[1], t))*u-(diff(a[3], t))*s[1]*u/a[3]-s[1]*a[2]*v*(diff(v, x))-(diff(a[3], t))*a[1]*u*(diff(u, x))/a[3]-(diff(a[3], t))*a[2]*v*(diff(v, x))/a[3]-3*(diff(r, x))*p[1]+(diff(a[1], t))*u*(diff(u, x))+(diff(a[2], t))*v*(diff(v, x))+a[2]*(diff(v, x))*p[2]+a[2]*v^2*(diff(s[2], x))+a[2]*v*(diff(p[2], x))+a[1]*u*(diff(p[1], x))+a[1]*(diff(u, x))*p[1]+a[1]*u^2*(diff(s[1], x))+3*a[3]*(diff(s[1], x))*(diff(u, x, x))+3*a[3]*(diff(s[1], x, x))*(diff(u, x))+a[3]*(diff(r, x, x, x))*(diff(u, x))-(diff(a[3], t))*p[1]/a[3]-3*r*(diff(r, x))*(diff(u, x))-3*(diff(r, x))*s[1]*u+a[3]*(diff(s[1], x, x, x))*u+3*a[3]*(diff(r, x, x))*(diff(u, x, x)) = 0
3*a[3]*(diff(diff(r, x), x))*(diff(diff(u, x), x))+3*a[3]*(diff(s[1], x))*(diff(diff(u, x), x))+3*a[3]*(diff(diff(s[1], x), x))*(diff(u, x))+a[3]*(diff(diff(diff(r, x), x), x))*(diff(u, x))+a[3]*(diff(diff(diff(s[1], x), x), x))*u+diff(p[1], t)+(diff(r, t))*(diff(u, x))+(diff(s[1], t))*u-3*(diff(r, x))*p[1]+a[3]*(diff(diff(diff(p[1], x), x), x))-(diff(a[3], t))*a[1]*u*(diff(u, x))/a[3]-(diff(a[3], t))*a[2]*v*(diff(v, x))/a[3]+a[1]*(diff(u, x))*s[1]*u-2*a[1]*u*(diff(r, x))*(diff(u, x))+2*a[2]*(diff(v, x))*s[2]*v-2*a[2]*v*(diff(r, x))*(diff(v, x))-(diff(a[3], t))*r*(diff(u, x))/a[3]-(diff(a[3], t))*s[1]*u/a[3]-s[1]*a[2]*v*(diff(v, x))+(diff(a[1], t))*u*(diff(u, x))+a[1]*u*(diff(p[1], x))+a[2]*v*(diff(p[2], x))+a[2]*v^2*(diff(s[2], x))+a[2]*(diff(v, x))*p[2]+a[1]*(diff(u, x))*p[1]+a[1]*u^2*(diff(s[1], x))-(diff(a[3], t))*p[1]/a[3]-3*r*(diff(r, x))*(diff(u, x))-3*(diff(r, x))*s[1]*u+(diff(a[2], t))*v*(diff(v, x)) = 0
We can collect coefficients of differential like u[x], u[x, x], v[x], u, vin following manner:
The Procedure
Now how can we collect coefficents with respect to u[x], u[x, x], v[x], u, vso that differential expression (3) appear as
"(......)*u+(.......)*v+(......)*u[x]+(........)*uu[x]+(.........)vv[x]+(........)u[xx]  =0....................."????????""
Download Collecting_Coefficients_in_Differential_Expression.mw
First 1192 1193 1194 1195 1196 1197 1198 Last Page 1194 of 2459
