Hey,
I have an expression like this:
a:= b(t)+diff(b(t),t)+diff(b(t),t$2)+diff(b(t),t$3)+...:
I want to substitute diff(b(t),t) with b_symbol_diff. I dont know how many more differentials are in the expression.
If I use subs(diff(b(t),t)=b_symbolic_diff,a)
maple also substitutes in diff(b(t),t$2). Because b_symbol_diff is not a function of t the higher order differentials are zero.
Is there a way to tell maple not to substitute those expressions that are enclosed in diff()?
I need this because I want to calculate the Jacobian of a vector and VectorCalculus[Jacobian]() does not accept functions.
Thanks in advance!
I am having difficulty helping someone series expand an eigenvector solution.  I can expand the eigenvalues easily but get a numeric exception divide by zero when I attempt to expand a component of an eigenvector.  Mathematica seems to have no problem solving this problem.  Any help would be appreciated.
assume(varepsilon > 0)
H := Matrix(3, 3, {(1, 1) = 0, (1, 2) = -epsilon, (1, 3) = epsilon, (2, 1) = -epsilon, (2, 2) = 2-2*epsilon, (2, 3) = 0, (3, 1) = epsilon, (3, 2) = 0, (3, 3) = 2+2*epsilon})
Matrix(%id = 18446744078100429630)
evals, evecs := Eigenvectors(H):
e1 := convert(simplify(series(evals[1], varepsilon = 0, 4)), polynom)
2+2*varepsilon+(1/2)*varepsilon^2-(7/16)*varepsilon^3
e2 := convert(simplify(series(evals[2], varepsilon = 0, 4)), polynom)
-varepsilon^2
e3 := convert(simplify(series(evals[3], varepsilon = 0, 4)), polynom)
2-2*varepsilon+(1/2)*varepsilon^2+(7/16)*varepsilon^3
simplify(series(evecs[1][1], epsilon = 0, 4))
Error, (in simplify/sqrt/local) numeric exception: division by zero
Download CourseraOpticsEigenvalues.mwCourseraOpticsEigenvalues.mw
How can i get whether a radio box is checked or not through another button action window. I have attached a picture of my question. Could you please help me to solve it.
We are running Maple16 in a virtual lab setup using Citrix, when exporting to PDF and saving the file to the local machine the PDF comes out as a 0kb file and the PDF is corrupt.  Has anyone else had an issue like this before?
without _Y(t) and DESol?
f := diff(u(t), t$2) + (2/t-1/t^2*p(1/t))*diff(u(t),t) + 1/t^4*q(1/t)*u(t) = 0;
dsolve(f,u(t));
u(t) = DESol({q(1/t)*_Y(t)/t^4+(2/t-p(1/t)/t^2)*(diff(_Y(t), t))+diff(_Y(t), t, t)}, {_Y(t)})
just would like to find u1 and u2 solution
how to transform this differential equation with a substitution?
f := diff(u(x),x$2) + p(x)*diff(u(x),x)+q(x)*u(x)=0;
transformed := subs(x=1/t, f);
f := diff(u(x),t$2)*diff(t,x$2) + p(x)*diff(u(x),t)*diff(t,x)+q(x)*u(x)=0;
diff(1/t,t);
diff(1/t,t$2);
x = 1/t
dx/dt = -1/t^2
d2x/dt2 = 2/t^3
d2u/dt2*dt2/dx2
du/dt*dt/dx
diff(u(t),t$2)*1/(2/t^3) + p(t)*diff(u(t),t)*1/(-1/t^2)+q(t)*u(t)
f := u2*1/(2/t^3) + p(t)*u1*1/(-1/t^2)+q(t)*u;
f2 := collect(f/t^3*2, {u2, u1, u});
subs(u2 = diff(u(t),t$2), subs(u1 = diff(u(t), t), subs(u=u(t), f2)));
but not equal to below which is in book, is this equation wrong in book?
I would like to generate a table with expansions of the formula p[t]=1/(1-psi*(beta-1))*m[t]-psi*(beta-1)/(1-psi*(beta-1))*p[t-1] for different values of t, perhaps with an Explore function over t. How could I achieve this?
I am trying to extract the coefficients of z from its series expansion. In two cases I succeed in finding the coefficients, but in the last one I fail to get the correct coefficients. Some garbage value is obtained. What is the reason behind this? I have attached my maple program.
test.mw
I need help to classify my output. If somebody can help me to do that. I want to write the procedure MipEq where
I am interested to extract the first entries for every lists and categorize them. If the second entries are the same, then I want to classify the first entries into one output. Say, I have this output:
>MipEq(10);
{[0,[1,4,2,1]],[1,[2,1,4,2]],[2,[3,6,4,3]],[3,[3,6,4,3]],[4,[4,2,1,4]],[5,[4,3,6,4]],[6,[4,3,6,4]],[7,[5,8,6,5]],[8,[5,8,6,5]],[9,[5,8,6,5]],[10,[6,4,3,6]]}.
The bold output, its second entries are the same. Therefore I want to classify all the first entries so that it doesnt repeat.
I would like to have the new output:
{[0,[1,4,2,1]],[1,[2,1,4,2]],[[2,3],[3,6,4,3]],[4,[4,2,1,4]],[[5,6],[4,3,6,4]],[[7,8,9],[5,8,6,5]],[[10,[6,4,3,6]]}.
If the output is quite complicated to obtain, I can provide the procedures that involved in MipEq.
There are:
for parameter a,b:=3,1;
The function F:
> Fp := proc (x) local Up, up; global a, b; Up := simplify((1/2)*(2*b-a+sqrt((2*b-a)^2+8*a*x))/a); if type(Up, integer) then up := Up+1 else up := ceil(Up) end if; return x+2*up*b-a*up^2 end proc;
> Fm := proc (x) local Um, um; global a, b; Um := simplify((1/2)*(-2*b-a+sqrt((2*b+a)^2-8*a*x))/a); um := ceil(Um); return x+2*um*b+a*um^2 end proc;
> F := proc (x) global Fp, Fm; Fm(Fp(x)); return % end proc;
The orbitPeriodic:
>OrbitPeriodic := proc (Map, ic) local orbit, t, z; z := ic; orbit[0] := z; for t while z <> ic or t = 1 do orbit[t] := z; z := Map(z); orbit[t] := z end do; return [seq(orbit[t], t = 0 .. t-1)] end proc;
The code:
>C := proc (x, Intvl) local i, n; n := nops(Intvl); if x = 0 then return 1 else for i from 2 to n do if x < Intvl[i] and Intvl[i-1] < x then return i-1 end if; if x = Intvl[i] then return i end if end do end if; "ERROR! YOU HAVE TO ADD THE INTERVALS" end proc;
Intervals:
> X := proc (m::integer) local D; D := (1/2)*a*m^2-b*m+(1/2)*a*m; return % end proc;
> Xp := proc (m::integer) local d; if 2*b < a then d := (1/2)*a*m^2-3*b*m+(3/2)*a*m-2*b+a else d := (1/2)*a*m^2+(7/2)*a*m-3*b*m+4*a-4*b end if; return % end proc;
>E := {seq(X(m), m = 0 .. 200)}; H := {seq(Xp(m), m = 0 .. 200)}; Intvl := `union`(E, H);
Equivalence Classes:
MipEq := proc (N) local Used, MinPts, IcCode, AllCodes, Codes, AC, q, ic, x, z, RT, AllPoints, Extract, EqClasses, EqClasses1; global F, C, OrbitPeriodic; Used := array(0 .. N); MinPts := array(0 .. N); IcCode := array(0 .. N); for ic from 0 to N do MinPts[ic] := true; for x in OrbitPeriodic(F, ic) do if x <= N then Used[x] := true end if end do end do; for ic from 0 to N do OrbitPeriodic(F, ic); IcCode[ic] := [ic, map(C, %, Intvl)] end do; Codes := {seq(IcCode[ic], ic = 0 .. N)}; AC := {seq(IcCode[ic][2], ic = 0 .. N)}; AllCodes := convert(AC, 'list'); RT := select(proc (x) options operator, arrow; `in`(x[1], AllCodes) end proc, Codes); return Codes, AllCodes end proc;
I hope somebody can help me.
Thank you very much for the help!
I have use a ''for cycle'' in order to get a series of points. I would like to save those points in a vector in order to use it for the ''PolynomialFit'' comand. The problem is that the points that I save are sort randomly. How can I take the value of the vector A in the right sequence? in the underline string you can plot the walue of A over t (which is not sorted). I can not use the sort command as I used for t even for A because the points are not increasing.
This is my code:
Atot := 0:
for ii from 0 by 0.01 to 2 do
PtotFkt := ii->  ii^2 :
Ptot := PtotFkt(ii):
Atot := Atot+0.01*Ptot:
A[ii] := Atot: #Save points in a Table
t[ii] := ii: #Save point in a table
AV := convert(A, list): #conversion from table to list
nops(AV);  #number of points
timme := convert(t, list): #conversion from table to list
nops(timme); #number of points
with(Statistics); #PolynomialFit
X := Vector(AV, datatype = float);
Y := Vector(sort(timme), datatype = float);
plot(Y, X, style = point, symbol = asterisk, color = blue);
regress := PolynomialFit(10, X, Y, time);
curve1 := plot(regress, time = 0 .. 2);
In Mathematica I've a function which allows me to send a mail. I use it when I run some long time computations and I want to get an information that they are finished, etc. Is there any way to do the same thing in maple?
Hi!I am running some grid computations and I found that I could speed up my computations if my nodes could share some partial results. It seems that Grid:-Send and Grid:-Receive is almost perfect. The problem is that Grid:-Receive blocks the computations where I cannot ensure that a message will ever be send. I've tried to run Grid:-Receive on a thread in an possible infinite loop but it still blocks.
Some pieces of code below:
SignatureReciever:=proc(SigContainer::uneval,stopValue::uneval)
  while eval(stopValue) do
    SigContainer := eval(SigContainer) union {convert(Grid:-Receive(),string)};
SendMessage:=proc(message::string, id::integer)
  Threads[Seq](proc(i) if i <> id then Grid:-Send(i,message) end if end proc,i=0..Grid:-NumNodes()-1);
In the main procedure run on a node I have
Threads:-Create(SignatureReciever('Signatures','stopValue'));
SendMessage(signature,id);
stopValue := false;
Do you have any suggestions how to solve my problem?
in this code count.mw the error is about the dsolve between do and end do  but the dsolve actually works and can give me the value I want if there is no cycle outside like this count......mw , there is no big difference between two code about the dsolve funtion except the one in cycle is writen together not in several lines, why it happens and how to fix it?
Hello dears! Hope everything going fine with you. I have faced problem while solving the system of equations using fsolve command please find the attacment and fixed my problem.
I am very thankful to you for this favour.
VPM_Help.mw
Mob #: 0086-13001903838
can we solve analytically a system of non-linear algebraic equation? my system is like:
b1 = a x + b y + c z
b2 = d x2 + e y2 + f z2
b3 = g x3 + h y3 + k z3
First 1193 1194 1195 1196 1197 1198 1199 Last Page 1195 of 2459
