How can I get maple to express the end result more compact/dense. Like for example in the picture, why can the program not just sum up all the fractions and everything in one number?
 when send email to technical support of maple?
i would like to encrypt email content with maple public key in gmail
Hi, I need help finding the index of a given element in a list?
Say I have A:=[2,4,6,8,10,12], I want something that can do something like this:
index(A,6)
EDIT:
Thanks, and sorry if my questions are trivial but I'm (clearly) not great with maple.
Now say I had two lists:
A:=[5,10,15,20,25,30,35,40,45,50]
B:=[7,14,21,28,35,42]
How would I get maple to return the index of the first element in list B that matches an element in list A, and the index of said element in list A?
So something (remotely) like:
FirstMatch(B,A)
                        B[5], A[7]
(So I'm not looking for the first case of A[i]=B[i]. I just want i, j where A[i]=B[j])
So I want to create an image of the cusp catastrophe that looks like this
but instead I have been getting this image where the discontinuity is plotted out to infinity
I have tried to split up the surfaces on either side of this but I haven't been able to display both on the same plot whilst using implicitplot3d.
This is the line of code for the image, there't not much too it
implicitplot3d(x^4+x^2*z+x*y, x = -7 .. 7, y = -50 .. 50, z = -10 .. 5, axes = boxed, style = surfacecontour, grid = [60, 60, 60], orientation = [180, 8, 175], 'transparency' = .1);
If anyone could help or point me in the right direction that would be great.
Cheers,
Darryl A.M.
using the code generator assistant I entered the following function
p := proc (z::(float[8]))
local a::integer, accm::(float[8]), k::integer, k1::(float[8]), c;
c := Array([0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0], order = C_order, datatype = float[8]);
k1 := 1;
c[1] := evalf(sqrt(2*Pi));
a := 12;
for k to a-1 do c[k+1] := evalf(exp(a-k)*(a-k)^(k-1/2)/k1); k1 := -k1*k end do;
accm := c[1];
for k to a-1 do accm := accm+evalf(c[k+1]/(z+k)) end do;
accm := accm*evalf(exp(-z-a)*(z+a)^(z+1/2));
return accm/z
end proc
the code-generated julia code follows
function input(z)
c = [0,0,0,0,0,0,0,0,0,0,0,0]
k1 = 1
c[0] = (sqrt(2 * pi))
a = 12
for k = 1:a - 1
c[k] = (exp(a - k) * (a - k) ^ (k - 1//2) / k1)
k1 = -k1 * k
accm = c[0]
for k = 1:a - 1
accm = accm + (c[k] / (z + k))
accm = accm * (exp(-z - a) * (z + a) ^ (z + 1//2))
return(accm / z)
end
two things are wrong
1: no end after loop end
2: array index starts at 0, it should be 1 and of course the array references should reflect that
btw, it would be nice to be able to enter code tags like [code] code here [/code]
Hello everyone.  Let n be a positive number; I seek how to write the matrix Z\in M_{2^n,n} that is defined as follows:
for every i,j, Z_{ij}\in \{-1,1\}.
When I consider the 2^n rows of Z, I want to find ALL the possible sequences of length n with the entries +-1. A toy example, when n=2, is Z=\begin{pmatrix}1&1\\1&-1\\-1&1\\-1&-1\end{pmatrix}.
Thanks in advance;
Write a Maple procedure which takes any cubic polynomial [−3, 3] p −→ R and returns the following:
How i can plot of p and its tangent lines illustrating the nature of each critical point.
Demonstrate this in the instance that p(x) = 1/3 x^ 3 − 6/10 x^ 2 − 187/100 x + 1.
Any ideas how i can solve this?
I wonder if there is any way to sort expressions like
 to
also:
how to sort  to
I'm sorry to bother you but I have a problem with the numeric resolution of a system of 3 differential equations. The system is as follows  : sysdif :=
As you can see the system is composed of 3 differential equations, and I enter initial conditions in the object "sysd". Then I try a numeric resolution by executing the following command (I give a value to parameters before)  :
Then Maple's answer is : Error, (in dsolve/numeric/process_input) missing differential equations and initial or boundary conditions in the first argument: sysdif.
I can't see where I'm wrong, does anyone notice something that could explain this error message ? There's no help page about this error so I ask the question here.
Thank you very much for your time if you answer this,
Louis
I noticed that Maple 2016 did not add entry in the start menu->All programs, after installing it on window 7, as all the other Maple releases did.  I looked everywhere and do not see it. This is very strange. Only time I had problem like this, where I install Maple but it does not show up in the start menu.
I did not have problem installing 2016, and I can use it fine.  But each time I need to start it now, I have to do start menu->Search and type Maple 2016, to find Maple 2016.
Is there a way to make it show in the start menu? Should I uninstall it and install again? Any one else had this problem on windows?
Using Maple 2016, windows 7, 64 bit. I see 2 problems allready. One is that long display do not wrap around as it does with Maple 2015. Second problem, I see strange characters inside the numbers displayed on the screen.  Here is 2 screens shots, same computation, one from Maple 2015 and one from Maple 2016. Both on same PC. Windows 7.
Notice also the result for 2016 do not wrap. I had to scroll to the right to see the full result.
Here is the code in plain text. Can someone verify if they get the same problem on Maple 2016?
V:=(m,n)->binomial(m-floor(1/2*(n+1)),m-n)+binomial(m-floor(1/2*(n+2)),m-n);
r:=V(2000,500):
r:=r/10^6:
r:=r/(60*60*24*365);
@Markiyan Hirnyk
Thanks for helping.
(1) But how to find period using code?
(2) how did you determine n=29 ?
(3) I don't need sequence of numbers, but would like to extract the coefficients of exp(..) terms. For example in the follwoing expression, how to extract the coefficients: (note that the expression is missing one more term and i don't know how to fix?)
.123456789*.123456789;
                                               0.01524157875
i need Maple to respond   0.015241578750190521 by adjusting Digits number dynamically. I don't want to adjust  the Digits Number to a fixed value.
OnesM:=Matrix(`%id`=119376536)
Anyone can solve this??
Many thanks!
Hi guys,
I want to import symbolic matrix from matlab to Maple, How I can do that ?
First 1197 1198 1199 1200 1201 1202 1203 Last Page 1199 of 2472
