Dear friends,
I have a huge differential equation which I am trying to solve.
However, even solving it numerically, maple keeps evaluating it for a long time and then stops working! So there is no solution.
I just want to check if there is any solution to this differential equation at all!
Do you know a way with which maple can check if the differential equation is solvable?
I need export a r-matrix 300x300 and i received this:
Error, (in ExcelTools:-Export) Export failed. Verify that the exported table does not contain more than 255 columns and 65535 rows.
How can I export this matrix?
How can I plot this one?
I try to find all the twinprimes in a certain range of numbers. I made a mistake, but a don't know which one. Wjo can help me?
I solve a linear system of equations which is rank deficient. Naturally, when Maple solves it symbolically, it chooses some of its variables to use them as a basis to express the solution.
In a specific problem I'm solving, the basis chosen by Maple is -very- smart, showing a good exploitation of the problem structure.
I'm curious as to what kind of factorization is used by default, or if there's a lot of by hand "black magic" involved, what are its general characteristics.
Best regards
Claudio
How to solve the inequality
assuming a::real ?
Of course, with Maple. I'd like to demonstrate the difficulties, solving
>solve(log[2*abs(x-a)](abs(x+a)+abs(x-a)) < 1, x) assuming a > 0, a < 1/2
The correct answer under the above restrictions is
{x  > 0, x  <  a} union {a  <  x, x <  a + 1/2} union { -infinity < x, x < a - 1/2}.
This is a problem from Lviv math school olympiad '2016.
I was using Maple18 for the Ideal Membership Problem. While checking it I got the following error
Error, (in F4:-GroebnerBasis) argument `[0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,-48,-48,48,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0]/A1[119295][119295]` is incorrect or out of order
Please tell me, how can I resolve this error ?.
Thank You.
I have the following expression.
What I want to do is take the derivative of this expression with respect to,
Where L is somewhere between 1 and n.
Using the diff operator, I would like to get something like,
But I don't.  Instead, I get zero.  I want to leave n undefined so that the summation isn't automatically expanded out to alot of terms, thereby making it much more difficult to read.  This is especially true as my formulas become more complicated.
Thanks!!
Hello I have this assignment. I will translate it (because it is not english)
This is the assignment: [IMG]http://i68.tinypic.com/2cgoby9.jpg[/IMG]
(if u cant click on the above link, then u can see it here http://tinypic.com/view.php?pic=2cgoby9&s=9)
So it says:
In an examination of young pigs' birth weight 853 newborn pigs were weighted. The weighting is shown in the table down below.
[0,5-0,7] [0,7-0,9] [0,9-1,1] [1,1-1,3] [1,3-1,5] [1,5-1,7] [1,7-1,9] [1,9-2,1] [2,1-2,3] -> WEIGHT in kg
[26]            [43]       [102]       [145]        [171]      [196]     [119]       [42]          [9]      --> number of pigs
Draw a cumulative frequency curve of the weighting and determine the kvartils.
SO I usually do this in Maple, but this time I did a matrix but nothing happened.. I dont know how I should draw this curve? Help please.
do not know why Basis got error in this case.
how to calculate this Basis?
prej := Matrix([[diff(eq2,a),diff(eq2,b),diff(eq2,c)],[diff(eq3,a),diff(eq3,b),diff(eq3,c)],[diff(eq4,a),diff(eq4,b),diff(eq4,c)]]);
jaco := Determinant(prej);
jaco := -a*b*c^2+c^2;
g3 := [diff(jaco,a),diff(jaco,b),diff(jaco,c)];
K := [r-g3[1],u-g3[2],v-g3[3]];
G := Basis(K, 'tord', degrevlex(r,u,v));
Error, (in LinearAlgebra:-Basis) invalid input: LinearAlgebra:-Basis expects its 1st argument, V, to be of type {Vector, {list(Vector), set(Vector)}} but received [b*c^2+r, a*c^2+u, 2*a*b*c-2*c+v]
i find that Suzuki group is very large,
and finding subrgoup is still not solved
and when find subgroup of suzuki group that is very slow
i would like to find two subgroup which are not isomorphric and then
prove a normaliser that make them isomorphric
with(GroupTheory):
G := SuzukiGroup();
IsFinite(G);
gorder := GroupOrder(G);
ifactor(gorder);
spg := SylowSubgroup(2, G);
IsAbelian(spg);
Elements(spg);
lprint(%);
H := Subgroup(Elements(G), spg);
N := Normaliser(G, spg);
#N := Normaliser(spg, G);
Elements(N);
lprint(%);
Elements(G);
H2 := Subgroup({[[5,2],[3,4]]}, G);
H2 := Subgroup(Elements(G), G);
elements2 := convert(Elements(G), 'list');
generators := map(ListTools:-Search, [Perm([[1,2,3]])], elements2);
H2 := Subgroup([52], G);
SubgroupMembership(H2, G);
H2 := Subgroup([3], G);
elist := Elements(H2);
AreConjugate(elist[2], elist[3], N); #N*elist[1]*N^(-1) = elist[2]
for ii from 1 to nops(elist) do
for jj from ii+1 to nops(elist) do
if AreIsomorphic(Group(elist[ii]),Group(elist[jj])) = false then
print("noniso");
print(ii);
print(jj);
end if:
AreConjugate(elist[8], elist[22], N); #N*elist[1]*N^(-1) = elist[2]
I would like to understand this code which has been discussed in the forum a moment ago.
http://www.mapleprimes.com/posts/120138-Exact-Cubic-Hermite-Spline
Here the Maple code :
alec_modified_hermit.mw
Does somebody know the theoric developpements to this code ?
May you help me to add comments so as to facilitate the link with the theory ? One line in front of each procedure should be enough for me to understand. For the moment, I didn't manage to match it with the theory.
When I would understand this code, I would like in a second step compare the result with Catmull-Rom splines.
Thanks a lot for your help.
 @acer : I think this subject may interest you
how to calculate the polynomial map for a system of  polynomials
assume system of polynomial is in terms of a,b,c
how to find polynomial map
(r - something in terms of a,b,c)
(u - something in terms of a,b,c)
(v - something in terms of a,b,c)
Would anyone know how to customize the CompleteSquare function. Reason is I am trying to extend it to complex numbers. Examples below. (Unfortunately the text editor is playing up but if you could copy and paste the text below in your Maple you should be able to see it more clearly).
eqn1 := x__1^2+4*x__1*x__2+2*x__2^2;
with(Student[Precalculus]):
CompleteSquare(eqn1, [x__1, x__2]);
This gives the answer below which is correct.
2*(x__2+x__1)^2-x__1^2
However consider the complex function below:
x__1*conjugate(x__1)-conjugate(x__1)*x__2+3*conjugate(x__1)*x__3-conjugate(x__2)*x__1+2*x__2*conjugate(x__2)+3*conjugate(x__3)*x__1+14*x__3*conjugate(x__3)
I am trying to factorize this into the following:
(x__1-x__2+3*x__3)*(conjugate(x__1)-conjugate(x__2)+3*conjugate(x__3))+(x__2+3*x__3)*(conjugate(x__2)+3*conjugate(x__3))-4*x__3*conjugate(x__3)
The technique I am trying is to first try to come up with a generalized form of the CompleteSquare function and then try to extend it to complex factorization but so far haven't been successful.
Any useful comments appreciated.
I have some differential equations that I want to plot on the same axis (as i have below), but would like to plot with a log scale to illustrate the fact that one is simply a logarithmic decay (solid line) and all the others are not.
I had used deplot and display to make the above graph,
but if you want more detail, here is a worksheet with the relevant differntial equations:
MaplePrimesGraphUpload.mw
First 1199 1200 1201 1202 1203 1204 1205 Last Page 1201 of 2459
