I would like to build a periodic function based on the function x-->x².
For x belonging to [0,2], the function is defined like this :
And for the rest of the domain in R, the function should be periodic with a period of 2.
In other words, I would like to define a function which permits me to obtain this plot :
Sorry, for my picture which is very ugly, but it should enable to explain what I'm looking for.
1) Is a new piecewise function based on f function is the better solution to create this kind of periodic function ?
2) I didn't find or understand with the help how i can create "infinite" piecewise function. May you help me to define this kind of piecewise function ?
Thanks a lot for your help.
P.S: With the term "nested" in my title I only want to say that I want to apply another piecewise function (for example g) on a already created function (for example f). this term may be not very appropriated.
i have run higer order nonlinear ode bvp
but cant solve the error
please help me
with(plots)
Pr := .71; beta := .5; alpha := .1; S := .1; Du := .1; Nb := .1; Nt := .1; Sc := .67; Sr := .1; omega := 1.0; Lb := 1.0; Pe := 1.0; delta := 1.0; Nc := 1.0; p := .1; q := 5; r := 5; s := 5; a := 1; b := 2; epsilon := .1
Eq1 := (101-100*lambda)*(diff(f(eta), `$`(eta, 3)))-theta(eta)*beta*(diff(f(eta), `$`(eta, 2)))/(1+theta(eta)*beta)+(1+theta(eta)*beta)*f(eta)*(diff(f(eta), `$`(eta, 2)))-(1+theta(eta)*beta)*(diff(f(eta), eta))^2-(M-alpha)*(1+theta(eta)*beta)*(diff(f(eta), eta))
(101-100*lambda)*(diff(diff(diff(f(eta), eta), eta), eta))-.5*theta(eta)*(diff(diff(f(eta), eta), eta))/(1+.5*theta(eta))+(1+.5*theta(eta))*f(eta)*(diff(diff(f(eta), eta), eta))-(1+.5*theta(eta))*(diff(f(eta), eta))^2-(M-.1)*(1+.5*theta(eta))*(diff(f(eta), eta))
Eq2 := (1+epsilon*theta(eta))*(diff(theta(eta), `$`(eta, 2)))+f(eta)*(diff(theta(eta), eta))+epsilon*(diff(theta(eta), eta))^2+Pr*S*theta(eta)+Pr*Du*(diff(phi(eta), `$`(eta, 2)))+Pr*Nb*(diff(theta(eta), eta))*(diff(phi(eta), eta))+Pr*Nt*(diff(theta(eta), eta))^2
(1+.1*theta(eta))*(diff(diff(theta(eta), eta), eta))+f(eta)*(diff(theta(eta), eta))+.171*(diff(theta(eta), eta))^2+0.71e-1*theta(eta)+0.71e-1*(diff(diff(phi(eta), eta), eta))+0.71e-1*(diff(theta(eta), eta))*(diff(phi(eta), eta))
Eq3 := (diff(phi(eta), `$`(eta, 2)))/Sc+f(eta)*(diff(phi(eta), eta))-omega*(diff(theta(eta), eta))*(diff(phi(eta), eta))-omega*(diff(theta(eta), `$`(eta, 2)))*phi(eta)-delta*phi(eta)+omega*Nc*(diff(theta(eta), `$`(eta, 2)))+Sr*(diff(theta(eta), `$`(eta, 2)))
1.492537313*(diff(diff(phi(eta), eta), eta))+f(eta)*(diff(phi(eta), eta))-1.0*(diff(theta(eta), eta))*(diff(phi(eta), eta))-1.0*(diff(diff(theta(eta), eta), eta))*phi(eta)-1.0*phi(eta)+1.10*(diff(diff(theta(eta), eta), eta))
Eq4 := diff(chi(eta), `$`(eta, 2))+Lb*f(eta)*(diff(chi(eta), eta))-Pe*(diff(phi(eta), eta))*(diff(chi(eta), eta))-Pe*(diff(phi(eta), `$`(eta, 2)))*chi(eta)
diff(diff(chi(eta), eta), eta)+1.0*f(eta)*(diff(chi(eta), eta))-1.0*(diff(phi(eta), eta))*(diff(chi(eta), eta))-1.0*(diff(diff(phi(eta), eta), eta))*chi(eta)
VM := [0., .5, 1.0]
etainf := 9
bcs := f(0) = 0, (D(f))(0) = p*(D@@2)(f)*0, theta(0) = 1+q*(D(theta))(0), phi(0) = 1+r*(D(phi))(0), chi(0) = 1+s*(D(chi))(0), D(f)*etainf = b/a, theta(etainf) = 0, phi(etainf) = 0, chi(etainf) = 0
f(0) = 0, (D(f))(0) = 0., theta(0) = 1+5*(D(theta))(0), phi(0) = 1+5*(D(phi))(0), chi(0) = 1+5*(D(chi))(0), 9*D(f) = 2, theta(9) = 0, phi(9) = 0, chi(9) = 0
dsys := {Eq1, Eq2, Eq3, Eq4, bcs}
for i to 3 do M := VM[i]; dsol[i] := dsolve(dsys, numeric, continuation = lambda); print(M); print(dsol[i](0)) end do
I would like to build this piecewise function :
I try this manner :
f:=x->piecewise(x=>0 and x <= 1, x^2,x > 1 and x<=2, (2-x)^2);
But, it doesn't work. I receive the following error message :
Error, `>` unexpected
Do you have some ideas about my mistake?
Thank you for your help.
Hello;
I need some help to compute the series approximation of the modulus and argument of hankel function for large x. The code display
 Error, (in asympt) unable to compute series
Thanks  for helping me.
#We define the hankel function as
#HankelH1(v,x) = BesselJ(v,x) + I*BesselY(v,x), where BesselJ and BesselY are bessel function.
#In this question the parameter "v " is  fixed. "
# Code
with(MTM):
HankelH1(v, x);
# The modulus of Hankel function
Mn:=x->abs(HankelH1(v, x));
thetan:=x->argument(HankelH1(v, x));
phin:=x->argument(diff(HankelH1(v, x),x));
dervthetan:=x->diff(thetan(x),x);
dervphin:=x->diff(phin(x),x);
# Compute series
series(thetan(x),x=infinity,7);
series(phin(x),x=infinity,7);
series(Nn(x),x=infinity, 7);
series(Mn(x),x=infinity,7);
# I define the following function
f:=x->(Nm(x)/Mn(x))*exp(I*(phin(x)-thetan(x)));
# Series approximation
series(f(x),x=infinity, 7);
Dear all;
Hello everybody, I need your help to dispaly some values obtained using my function f. When I run the code there is no results obtained. Many thanks.
# The vectors e(i) satify the folowing conditions
e(0)*e(1)=e(n-1) assuming  1<n;
e(0)*e(0)=e(2):
e(1)*e(1)=e(n-1) assuming  1<n: :
e(2)*e(1)=e(n) assuming  1<n:
for i from 1  to n-1 do
e(i)*e(0)=e(i+1);
# We define the function f
f:=e(0)->e(0)+(n-3)*e(1);
f:=e(1)->(n-2)*e(1);
for i from 2  to 3 do
f:=e(i)->(n+i-3)*e(i)+(i-1)*(n-3)*e(n-3+i);
for i from 4 to n do
# We define the two vectors
x:=sum(alpha(k)*e(k),k=0..n);
y:=sum(beta(k)*e(k),k=0..n);
#Question : I would like to compute the following  but there is no display of the solution.
(x*y);
f(x*y);
f(x);
f(y);
x*f(y);
f(x)*y;
f(x*y)- f(x)*y-x*f(y);
After manually working out answer for problem 4-4 in Mathews & Walker's Mathematical Methods of Physics , I tried to check my solution with maple2015. Briefly the problem involves inputs periodic with period T, being transformed into outputs, through a kernal G.  The net result is that all input frequencies omega periodic in T are multiplied by (omega_0/omega)^2, except for constant frequency which transforms to zero.  The problem asks to evaluate the kernal G.
Maple2015 correctly evaluated the integral for a constant input, a cosine input, and a sine input, but gave undefined when I tried an exponential(i*x) input which is just a linear combination of the two previous inputs.  I found this interesting because the integral is finite, well defined, and only has an absolute function (in the kernal), which may cause Maple problems, as it correctly evaluated integral when I split it into two regions.  Interestingly if instead of working with a period of T, I used 2*pi, and redfined my G function accordingly, Maple evaluated the exp input integral without any problems.  So the problem appears to be with the T variable, but I correctly used assumptions of T>0, and 0<t<T, so I am not sure why it would work correctly when I use T=2*pi, but failed when using a general period T.  Any help would be welcome.
assume(T > 0)
assume(0 < t and t < T)
about(T)
Originally T, renamed T~:
  Involved in the following expressions with properties
    T-t assumed RealRange(Open(0),infinity)
  is assumed to be: real
  also used in the following assumed objects
  [T-t] assumed RealRange(Open(0),infinity)
about(t)
Originally t, renamed t~:
  is assumed to be: RealRange(Open(0),infinity)
assume(n::integer, n > 0)
about(n)
Originally n, renamed n~:
  is assumed to be: AndProp(integer,RealRange(1,infinity))
G := proc (x) options operator, arrow; (1/2)*omega0^2*T^2*((1/6)*Pi^2-(1/2)*Pi*abs(2*Pi*x/T)+Pi^2*x^2/T^2)/Pi^2 end proc
(int(G(t-tp), tp = 0 .. T))/T
(int(G(t-tp)*sin(2*Pi*n*tp/T), tp = 0 .. T))/T
(1/2)*T^2*omega0^2*cos(t*Pi*n/T)*sin(t*Pi*n/T)/(Pi^2*n^2)
(int(G(t-tp)*cos(2*Pi*n*tp/T), tp = 0 .. T))/T
(1/4)*T^2*omega0^2*(2*cos(t*Pi*n/T)^2-1)/(Pi^2*n^2)
(int(G(t-tp)*exp((I*2)*Pi*n*tp/T), tp = 0 .. T))/T
undefined/T
(int(G(t-tp)*(cos(2*Pi*n*tp/T)+I*sin(2*Pi*n*tp/T)), tp = 0 .. T))/T
undefined/T
simplify((int(G(t-tp)*exp((I*2)*Pi*n*tp/T), tp = 0 .. t))/T+(int(G(t-tp)*exp((I*2)*Pi*n*tp/T), tp = t .. T))/T)
(1/4)*omega0^2*exp((2*I)*t*Pi*n/T)*T^2/(Pi^2*n^2)
assume(0 < t and t < 2*Pi)
G2 := proc (x) options operator, arrow; 2*omega0^2*((1/6)*Pi^2-(1/2)*Pi*abs(x)+(1/4)*x^2) end proc
(int(G2(t-tp)*exp(I*n*tp), tp = 0 .. 2*Pi))/(2*Pi)
omega0^2*exp(I*n*t)/n^2
Download MathewsWalkerProblem4-4.mwMathewsWalkerProblem4-4.mw
I'm trying to insert $(x_0,y_0)$ into a Maple plot (that's how LaTeX would be written). I want to do this with a Maple command rather than creating the plot then hand-tailoring with mouse clicks. This is what I've tried without success:
p1:=plot(sin, -Pi..Pi,-1..1):
t1:=textplot(Pi/2,0.9,something):
display(p1,t1)
For *something* I've tried such as
Typesetting:-typeset(try)
typeset(try)
where try is something like (x[0],y[0]) and [(x[0],y[0])] and similar forms.
No joy! Any help appreciated.
I have the following function
where A,B,Ψ, K1,K2,K3,α,β are all constants.
How to find the value of m for which the above expression is 0 or approximate to 0 for different values fo the constants.
e.g., Fixing all the parameters except A, I want to find the values of m for different values of A. How to do that in maple?
I hoped that Maple would return the value of 1 in all commands (see below). However, introducing a scaling parameter, sigma, yields the unevaluated expression. Why? I still think it should evaluate to the value of 1.
kind regards,
Harry (not a mathematician, but a psychologist)
integral.mw
Can anybody where I can find collection of third party Maple packages?
One site that I know is
http://cpc.cs.qub.ac.uk/
we have positive number from 1 to 1000. how many time we write number 3?
How to increase the size of toolbar icons in Maple 2015 32-bit Classic on Windows?
Hello everyone! I got some trouble in process a list. Hope you can help:
Assume i got a list like this:
{{k = k, l = RootOf(_Z^2+_Z*k+k^2-1), o = -k-RootOf(_Z^2+_Z*k+k^2-1)}, {k = k, l = RootOf(_Z^2+_Z*k+k^2+1), o = -k-RootOf(_Z^2+_Z*k+k^2+1)}, {k = 0, l = 1, o = -1}, {k = 0, l = -1, o = 1}, {k = 1, l = 0, o = -1}, {k = 1, l = -1, o = 0}, {k = -1, l = 0, o = 1}, {k = -1, l = 1, o = 0}, {k = RootOf(_Z^2+1), l = 0, o = -RootOf(_Z^2+1)}, {k = RootOf(_Z^2+1), l = -RootOf(_Z^2+1), o = 0}}
Now all i want is remove Complex and RootOf from this list, how can i do that?
Thank for your reading adn your help!
I have the following expression
f=u/(sqrt(u*(u-1)))
and I want to simplify it. Eventhough that I tell Maple that u is real and greater than 1 but it does not simplify the expression. What is wrong? Please see the attached file.
Radical.mw
How I can sketch the helix with parametric equations x=2cost  y=sint  z=t  and the line with parameric equation x=-2t  y=1  z=(pi/2)+t   on a three-dimensional coordinate system?
First 1202 1203 1204 1205 1206 1207 1208 Last Page 1204 of 2459
