I have an SEIR model.
Equation 5 is for disease death but I would like to plot the cumulative numbers of disease death which will be the integral of Equation 5. I added the integral inside odeplot but it is not working. Any idea  about  how to compute the integral ?
Maple code is attached
code.mw
Found a strange behaviour in Mapke 2015 of the sqrt-function after loading the GRTensor package:
the square-root of a non-square integer, e.g. sqrt(5), does not terminate. 5^(1/2) instead works fine.
Can be reproduced with Maple 18, but not with Maple 11.
I consider this a serious bug, as it makes any expressions containing such roots useless.
As it worked with Maple 11 I am inclined to see it as your fault.
Let's say I've got somehow a result of the product:
exp(k*t)*cos(t*omega)
as series expression and I want to factor out the series of
exp(k*t)
in order to get
cos(t*omega)
How can I do that with Maple?
In PDEtools, suppose to I wish assign zero value to certain first order partial derivative such that higher order derivatives automatically vanish in subsequent excutions, how I can do that?
with(PDEtools):
alias(u = u(x, y, t))
u
Suppose we wish following derivative equal to zero,
diff(u, x) = 0
diff(u, x) = 0
If we use ":=" for value assignment we will get error. Under above assuption how can we make following derivatives zero?
diff(u, x, x); 1; diff(u, x, y); 1; diff(u, x, x, x, y)
diff(diff(u, x), x)
diff(diff(u, x), y)
diff(diff(diff(diff(u, x), x), x), y)
Download Assiging_Derivative.mw
I tried to load my document containing some notes, but then I got the message "There were problems during the loading process, Your worksheet may become incomplete", and as the message said my worksheet were incomplete. Is there a way to restore the document? I have tried following this and added the line it suggested:
http://www.maplesoft.com/support/help/Maple/view.aspx?path=worksheetmaybeincomplete
But it didn't work.
I have attached the file.
Noter.mw
I never expected that the reflected light direction of sun from moon in the sky would be so dificult to imagine ...
at the following article mentioned :
we derive an equation for the magnitude of the moon tilt illusion that can be applied to all con gurations of sun and moon in the sky.
THE MOON TILT ILLUSION
since the calculations contains many steps and high level mathematical formula , there is no way rather to recourse to maple (powerful math assistant )
I hope there was adaptations between a lots of functions and predefined schema of maple and this problem so that the calculations and visualization facilitated several times ?
your effort will be a graet present for all the people of the world that look to the moon crescent everytime !
hi.i trust that attached equation has more answer but fsolve only gain some of them!!! how i can gain another that i know value of them?
another root  that i known, are : 0.165237712988657e-1    and     .103583272213766    and    .290071279318035
root.mw
I am comptuing the eigenvalues and the characteristic polynomial of a 8 by 8 symmetric matrix, say M. Thus, we define the matrix M, and compute its charast. plynm. by
and its eigenvalues with the command
Well, Maple returns the charast. polynm. an dthe eigenvalues. But, if we compute p(E[k]), for k=1,...,8, thats is, the values of the polynomial p(x) in the eingenvalues, Maple not turns cero!!! I'm really confused ... anyone know what could be happening?
Maple attached file with this example. Thank very much for your help!!
Download exam_eigenvalues.mw
hi .how i can calculate eigenvector associated with the eigenvalue of the matrix.for example according attached file below
what are  eigenvector associated with the eigenvalue of matrix q which  determined as (2646.408147, 3142.030259, 6621.757707) respectively??
thanks...
eign.mw
I would like to learn to use Maple to develop applications of math, physics, astronomy ecc.. . The problem is that I do not know where to start. Could you help me ? Thank you.
Blustar
I have some preferences for viewing. Specially, I prefer atomic variables to be showed with a different color. So I check mark the related option for this in the view menu. But every time I close and reopen the Maple, it just restore my setting for atomic variables. Suprisingly, this does not happen for other viewing options in the view menu! What should I do? Why is it like this?
plots[implicitplot3d](max(-x+y+z, x-y+z, x+y-z) = 1.0, x = 0 .. 1, y = 0 .. 1, z = 0 .. 1);
The help page for max does not explain or show an example of max(sequence of expressions)= a constant.
hi.after calculate Determinant of matrix  and gain value omega'' ω'' by fsolve rule ,when substuting result (ω) in matrix (q) and calculate Determinant again, this value is not zero!!!! may i use LUDecomposition?determinan.mw
PLEASE..!! CAN ANYONE HELP ME IN CODING ON MAPPLE 13 TO CHANGE PDE INTO ODE??
MY FUNCTION IS THIS
U[t, t]-U[t, t, x, x]-(aU[]-b*U[]^3)[x, x] = 0
Should restart always be in separate execution group? I noticed when I write something like
>restart;
  foo:=proc()
  local sys;
  with(DynamicSystems):
  sys := TransferFunction(25/(s^2+4*s+25)):
  print(ResponsePlot(sys, Step(),duration=4));
then type foo(); in the next execution group, it does not work. The plot is not generated. No matter how many times I evaluate the execution group. The proc() does not seem to be fully defined. But if I do this:
>restart;  #hit return
>foo:=proc()
  local sys;
>#hit another return
and now calling foo(); then it works, and the proc() returns the plot. Only difference is that restart was in separate group. But also I had to call foo() once, then evaluate the execution group where foo() is defined two times ! for it to work (why two times?) why one time did not work? is it becuase I am loading package inside the proc()?
What are the rules for putting the restart() call? Should it always be in separate group? I put it in the same group, so that I do not have to hit return 2 times, being a lazy person. But it seems to cause problem sometimes.
And related question, why did I have to hit return 2 times in the execution group to have proc() work in the second case above?
First 1205 1206 1207 1208 1209 1210 1211 Last Page 1207 of 2459
