    The following code displays values of the subscripted variables slf[], a positive integer, and a string variable filler[] which is just a set of spaces depending on how big the corresponding value of slf[] s.  This is to make the printout lined up nicely.
printf("%s%d%s%d%s%d%s%d%s%d%s%d%s%d%s%d%s%d%s%d\n", filler[1],slf[1],filler[2],slf[2],filler[3],slf[3],filler[4],slf[4],filler[5],slf[5],filler[6],slf[6],filler[7],slf[7],filler[8],slf[8],filler[9],slf[9],filler[10],slf[10]);
   This works fine,but thought there might be a better way.  I tried:
printf("%s%d%s%d%s%d%s%d%s%d%s%d%s%d%s%d%s%d%s%d\n",seq(filler[k],slf[k],k=1..10));
but this came up with an error message.  Is there  a way of doing this more efficiently?
thanks,   David
guys,i computed a tensorial expression by maple but i think i made mistake.
tensorial.mw
separable form should be (x - something in terms of x1,x2,x3,x4)*(x- something in terms of x1,x2,x3,x4)*(x -something in terms of x1,x2,x3,x4 )*(x - something in terms of x1,x2,x3,x4)
factor(f, x);
Error, (in factor) 2nd argument, x, is not a valid algebraic extension
how to factor into separable form?
ferrai := -x1^3*x2*x3*x4-x1^2*x2^2*x3^2-x1^2*x2^2*x4^2-x1^2*x3^2*x4^2-x1*x2^3*x3*x4-x1*x2*x3^3*x4-x1*x2*x3*x4^3-x2^2*x3^2*x4^2+x1^2*x2*x3*y+x1^2*x2*x4*y+x1^2*x3*x4*y+x1*x2^2*x3*y+x1*x2^2*x4*y+x1*x2*x3^2*y+x1*x2*x4^2*y+x1*x3^2*x4*y+x1*x3*x4^2*y+x2^2*x3*x4*y+x2*x3^2*x4*y+x2*x3*x4^2*y-x1*x2*y^2-x1*x3*y^2-x1*x4*y^2-x2*x3*y^2-x2*x4*y^2-x3*x4*y^2+y^3;
coeff(ferrai, y^3);
coeff(ferrai, y^2);
coeff(ferrai, y);
res := simplify(ferrai - coeff(ferrai, y^3)*y^3 - coeff(ferrai, y^2)*y^2 - coeff(ferrai, y)*y);
c2 := -coeff(ferrai, y^2)/coeff(ferrai, y^3);
sys1 := c1*c3 - 4*c4 = coeff(ferrai, y)/coeff(ferrai, y^3);
sys2 := -c3^2-(c1^2)*c4+4*c2*c4 = res/coeff(ferrai, y^3);
diff(lhs(sys1),c1) = diff(rhs(sys1),c1);
diff(lhs(sys1),c3) = diff(rhs(sys1),c3);
diff(lhs(sys1),c4) = diff(rhs(sys1),c4);
diff(lhs(sys2),c1) = diff(rhs(sys2),c1);
diff(lhs(sys2),c3) = diff(rhs(sys2),c3);
diff(lhs(sys2),c4) = diff(rhs(sys2),c4);
c1sol := solve(diff(lhs(sys2),c4) = diff(rhs(sys2),c4), c1)[1];
indets(subs(c1=c1sol,sys1));
indets(subs(c1=c1sol,sys2));
indets([subs(c1 = c1sol, sys1), subs(c1 = c1sol, sys2)]);
result := solve({subs(c1 = c1sol, sys1), subs(c1 = c1sol, sys2)},{c3,c4}, explicit);
c2sol := -coeff(ferrai, y^2)/coeff(ferrai, y^3);
c3sol := rhs(result[1][1]);
c4sol := rhs(result[1][2]);
f := x^4-c1sol*x^3+c2sol*x^2-c3sol*x+c4sol;
aa := factor(f);
aa := factor(f,x);
As an exercise, I'm trying to replicate the table shown at the end of section 10.3 (Creating Embedded Components) of the Maple User Manual, the table on page 308 of the PDF, reproduced here:
I create a 6 x 3 table, and merge cells of columns 1 and 2 in each of rows 1, 2, 5 and 6, and proceed to enter the text and components from the Embedded Components example 2 to look as above. In column 3, I merge the cells in rows 2, 3, 4, 5 in order to place the plot component as shown. The new cell seems to be considered as in the same row as its top merged cell, in this case, row 2.
I can't control vertical positioning in the plot cell in column 3. If I select the vertical alignment for the plot cell (which sets the same vertical alignment for all of row 2), to Centre or Bottom or Baseline, the alignment is to the centre or bottom or baseline of row 2, not of the plot cell. So when I paste the plot into the cell it extends up from the Centre or Bottom or Baseline of row 2, to well above the table's top border.
If instead I set the vertical alignment to Top, then the pasted plot fits into the cell since the top of the plot now aligns with the top of row 2. But that can be an annoying restriction. Also, I am no longer allowed to set the vertical alignment in rows 3, 4 or 5 because of the merged cell in column 3.
Maple document tables need to have two improvements:
  1. The ability to adjust vertical centring in a single cell (merged or not), instead of just across a row.
  2. The ability to resize row height. Currently it looks like document tables only allow resizing column width.
I guess my question is mainly, is there a better way to go about setting up a document table in order to control fairly precisely how it appears? And to get around some of these formatting restrictions?
sqrt(5) gives sqrt(5)
sqrt(1+sqrt(5)) gives "You have entered an invalid Maple expression"
sqrt(u) gives sqrt(u)
sqrt(1+u); gives "You have entered an invalid Maple expression"
when using the Maple Math icon. How can I get the correct input for the two expressions?
Can Maple simplify these DE's by eliminating the d/dt VL(t) by taking the derrivative of the bottom equation and substituting in the first one?
Hi, does anyone know how to choose the variables that populate the DAE Variables box when you use "equation extraction"?
I want the result to be in terms of the voltage source and the voltage drop across the capacitor for a RLC circuit.  I want to be able to choose the input-output variables for the final equation.
In this question, I asked for a way to simplify an expression containing radicals. The discussion led us to that as default field for simplicfication is the Complex number system we should use assume or assuming command to simplify the radicals. However, the mothod suggested there seems to not work in this new case that I have. For details please see the attached file. The terms sqrt{u} and sqrt{u-1} should cancel in denominator.
 What Maple Does
`ϕ` := (1+sqrt(5))*(1/2)
1/2+(1/2)*5^(1/2)
f := (1/2)*sqrt(-(u-1)*(u+1)*(u^2-u-1))*u*(4*u-3)/sqrt(u*(u-1))
(1/2)*(-(u-1)*(u+1)*(u^2-u-1))^(1/2)*u*(4*u-3)/(u*(u-1))^(1/2)
`assuming`([combine(f)], [1 < u and u < `&varphi;`])
(1/2)*u*(4*u-3)*((u+1)*(-u^2+u+1)/u)^(1/2)
`assuming`([simplify(f)], [1 < u and u < `&varphi;`])
(1/2)*(-u^2+u+1)^(1/2)*(u^2-1)^(1/2)*u^(1/2)*(4*u-3)/(u-1)^(1/2)
`assuming`([combine(f, radical)], [1 < u and u < `&varphi;`])
`assuming`([simplify(f, radical)], [1 < u and u < `&varphi;`])
(1/2)*((u-1)*(u+1)*(-u^2+u+1))^(1/2)*u*(4*u-3)/(u*(u-1))^(1/2)
Radical.mw
 Remark by Markiyan Hirnyk. The below content is added by the questionner on 08.02.2016 .
What Mathematica Does
I have downloaded the zip file for CalcP7, unzipped it, and can access its commands in a worksheet after issuing the command with(CalcP7), but "No Matches Found" displays when entering the command ?CalcP7. The download included a file named "aplication" (one "p") of type HDB, but Maple15 can't seem to access its contents.
Are CalcP7's help pages displayable? If so, what is necessary to access them?
I have had no trouble downloading the user package DirectSearch and accessing both its commands and its help pages.
It's been a couple of years since I last used the Excel add-in for Maple 17. It was working before, but now it isn't.
When I click any of the Maple icons in the Excel Add-Ins -> Custom Toolbars tab, I get a Visual Basic run-time error 453, "Can't find DLL entry point vbLoadMapleCursor in WMIMPLEX". The only choice in the dialogue is End, after which none of the Maple icons respond.
When I quit Excel after trying this, I get the same error dialogue except the message refers to vbMapleQuit. I select End, and then Excel exits. (If I don't touch the Maple icons during an Excel session, then of course no VB error dialogue referring to Maple pops up.)
An answer to a ten year old MaplePrimes question on the Excel add-in suggests editing the Excel 2010 32-bit path registry entry. Indeed my HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\App Paths\Excel.exe Path key has no reference to Maple. However that info is so old, for Maple 9.5, that I hesitate to use it. I tried though. As suggested in that question, updated for Maple 17, I tried adding ";C:\Program Files (x86)\Maple 17\Excel\" to the end of the existing Path key entry, but I still get the same VB error. I also tried adding ";C:\Program Files (x86)\Maple 17\bin.win\", and both: "C:\Program Files (x86)\Maple 17\bin.win\;C:\Program Files (x86)\Maple 17\Excel\". I tried disabling and reloading the add-in from the Excel Add-Ins menu. Interestingly, even when I disable the add-in, the toolbar icons still show.
Anyway I'm at a loss how to proceed. Any help is appreciated. --Graham
I have just discovered the existence of element-wise operators which uses the symbol tilde
In the help, I saw this exemple
sin~(<1,2,3>);
Vector[column](%id = 18446744073926346622)
which is identic to a result that I can find with map function :
map(sin,<1,2,3>);
Vector[column](%id = 18446744073926346982)
What can Element-wise operators bring more than the map function ?
Do you often use this symbol ?
Thanks a lot for your information.
I'm using Turkish windows on my pc. When I try to calculate some basic problem I encounter some problem on maple.
I searched on forum and I found one solution about this problem.
Solution is that "reach launch.ini file and put 'language=en' in it".
I tried this one but I couldnt manage to solve problem.
So in this point I have some question,
1.Is it matter where is I put this comment on the launch.ini file?
2.Is there any options doşng this?
Thanks in advance...
I'd like to have an algorithm for computing the ring of invariants of a reductive group (i.e. G acts on V, compute C[V]^G). I know that there are algorithms in existance for this, e.g. see http://www.math.lsa.umich.edu/~hderksen/Publications/invar1999.pdf. Does anyone know if this has been implemented in Maple, or where to find code in another language? Any ideas on what sort of data structure would be appropriate
The scale of vertical axis is logarithmic and function in each interval must be linear. When I use the command " mode=log " the shape of lines are deformed into curves, however when I use the command " curve ", the shape of lines remains straight. I can use right-click for changing mode to logarithmic scale but is it possible to use label font for vertical axis as well as size, resolution and other options in the command "curve" ?
Thanks alot
restart; with(plottools):
SN := curve([[3, (4.566256-4.544647)/(4.544647)], [4, (4.544933-4.544647)/(4.544647)], [5, (4.544653-4.544647)/(4.544647)], [6, (4.544649-4.544647)/(4.544647)], [7, 0]]): PLOT(SN);
for m to 5 do
x[m] := m+2 end do:
y[1, 1] := (4.566256-4.544647)/(4.544647):y[2, 1] := (4.544933-4.544647)/(4.544647): y[3, 1] := (4.544653-4.544647)/(4.544647): y[4, 1] := (4.544649-4.544647)/(4.544647): y[5, 1] := 0:
for j to 1 do for i to 4 do
L[i, j] := (y[i+1, j]-y[i, j])*(x-x[i])+y[i, j] end do:
PW[j] := piecewise(`and`(x >= x[1], x < x[2]), L[1, 1], `and`(x >= x[2], x < x[3]), L[2, 1], `and`(x >= x[3], x < x[4]), L[3, 1], `and`(x >= x[4], x < x[5]), L[4, 1]) end do:
plot(PW[1], x = x[1] .. x[5], color = black, axes = framed, font = [Times, 13], size = [650, 550], resolution = 1200, legendstyle = [location = top], legend = ['gamma' = -.4], linestyle = solid, thickness = 2, labels = [Number*of*Basis, '(P-P[min])/P[min]'], labelfont = [Times, 13], axis[2] = [mode = log]);
Hi friends! I have a problem with Random Variable. I don't understand why theoretical Mean differs from sample's Mean
restart; with(Statistics);
r := RandomVariable(NegativeBinomial(3, .1));
Mean((3-1)/(3+r-1));
0.1000000000
S := Sample(r, 10000);
d := map(unapply((3-1)/(3+t-1), t), S);
Mean(d);
0.04703520901756091
But !!
For example if p=0.2 then all is well
First 1209 1210 1211 1212 1213 1214 1215 Last Page 1211 of 2472
