Nonzero complex numbers a, b, and c are such that every pair of the polynomials ( in x )
a*x^11+b*x^4+c, b*x^11+c*x^4+a, c*x^11+a*x^4+b has a common root. How to prove or disprove with Maple that all the three polynomials have a common root? I am aware of the resultant command in Maple.
http://www.mapleprimes.com/posts/38019-Calling-Out-To-C-From-Maple#
if i can use maple to call c# function such as AForge.QLearning
how to set some tasks for it to guess some system of polynomials to fit hibert series criteria?
how to set a game for it to run itself to discover itself?
I have a worksheet that makes 38 Mo. I find it a bit huge because my code is only composed by 20 code lines. I guess that Maple has saved a important volume of data which makes the file very heavy.
I would like to reduce the size of my worksheet so as to be able to send it to colleagues.
How can I remove all the data save in a file?
I find how to display only the inputs but the data in term of size seems to be still present.
Thanks a lot for your help
what is the reason for negative value is displayed on the table?
thank you for helping>>>>>mapel_prime.mw
Good evening,
I am trying to solve the following sum equation:
sum((factorial(n)/factorial(2*n))^n, n = 1 .. infinity)
but I require the step-by-step solution as to how it is done, but can't seem to find that option.
If anone could help me out, that would be great.
Kind regards,
A
Dear, need help about Implicit finite difference method
plz reply as soon as possible
Need help in plotting the function in the attached file. m, h and k are parameters.
Bessel_Function.mw
> restart;
> u := -3*sqrt(mu)*tanh*(A+sqrt(-mu)*(x-(1/2)*mu*t))/sqrt(6*a)+3*sqrt(mu)*sech*(A+sqrt(-mu)*(x-(1/2)*mu*t))/sqrt(-6*a);
> mu := .5;
0.5
> lambda := 1;
> a := 0.5e-1;
0.05
> A := 1.5;
1.5
> plot3d([abs(u)], x = -3 .. 3, t = -3 .. 3);
Hello guys and gals!
I'm not strong enough with maple to get what the result I want.
It seems that it's because I'm asking for two lenths, and not a lenth and an angle, but I have no Idea how to tackle it diferently.
If you know a trick, please share it!
Here's an image:
http://imgur.com/xavAUoB
And here's the maple file attached (I think)
 complex_problem_from_the_internet.mw
Happy new year!
  I think similar question has been asked by several people, but I did not find a suitable thread. My question is, suppose I have a probablity distirubtion function like
  p(x,y) = exp(-alpha (x+y) ) x^2 y^2 / |x-y|  , alpha>0
 x,y goes from - \infty to + \infty. This function is normalizable but unbounded, which makes the rejection algorithm a bit difficult(?).
  How to generate samping points from this type of probability distribution function?
Thank you very much!
hi. i am tottaly new to the maple and i have a problem.
consider function f with variables x & y which are not independent. x & y are functions of t and the relation is unknown.
for example i wanna to the below job:
define f as f=x^2+y^2
differentiate it with respect to t : diff(f,t) which should give me 2(dx/dt)x+2(dy/dt)y
i've googled it alot and i couldn't find anything usefull.
(the problem is how to set x as a function of t with unknown relation and use it in another function and then differentiate it with respect to t)
thanks alot :)
has anybody experienced issues with Maple connectiong to Solidworks?  There doen't seem to be much info ion trouble shooting a failed "OpenConnection" call.
thanks,
Bill
From a Maple Primes answer two years ago:
f(x,y) is the equation of a line through point [m,n]. The solve command finds values of a and b for which f(x,y) are lines through [m,n] and tangent to x^2 + y^2 = r^2.
f := proc (x, y) options operator, arrow; a*(x-m)+b*(y-n) end proc
solve([f(0, 0) = r, a^2+b^2 = 1], [a, b])
These commands are far from the conventional solution. Why do they provide the correct answers?
Thank you for helping me  to generate a table of values of f(x) starting with x=0 to 100 in steps of 1, that is for x=0,1,2,3,...,100.
I tried:
f:=x->2*sqrt(3)*a1*a2*(sum(pochhammer(1/3,k)*3^k*x^(3*k)/(3*k)! ,k=0..infinity)*sum(pochhammer(2/3,k)*3^k*x^(3*k+2)/(3*k+2)!  ,k=0..infinity)-sum(pochhammer(2/3,k)*3^k*x^(3*k+1)/(3*k+1)!  ,k=0..infinity)*sum(pochhammer(1/3,k)*3^k*x^(3*k+1)/(3*k+1)!  ,k=0..infinity));
tab_values:=[evalf(simplify(seq(Ni1(xx),xx=0..100)))];
But I the result is amazing.... I don't understand the problem.
I would like to plot gait diagrams (the lines you can see on the picture belowà from the solutions obtained with a NL oscillator (composed with 8 coupled odes). Here the result that I would like to obtain.
Initial plot:
Desired plot
I would like to obtain 4 lines corresponding to the 4 elliptic trajectories obtained with the NL oscillator. The four lines should be done like this. When the trajectory is above 0, the line should be colored in green. When the trajectory is below 0, the line should be colored in black.
May you help me to define this kind of graph called gait diagrams from the solution of the NL oscillator ?
Here you can find my maple code:
K:=Matrix([<0, -1, 1, -1>,<-1, 0, -1, 1>,<-1, 1, 0,-1>,<1, -1, -1,0>]);
for i to 4
do
r[i]:=sqrt((u[i](t))^2+(v[i](t))^2):
omega[i]:=omega[sw]/(1+exp(b*v[i](t)))+omega[st]/(1+exp(-b*v[i](t))):
Equ[i]:=diff(u[i](t),t)=Au*(1-r[i]^2)*u[i](t)-omega[i]*v[i](t):
Eqv[i]:=diff(v[i](t),t)=Av*(1-r[i]^2)*v[i](t)+omega[i]*u[i](t)+MatrixVectorMultiply(K,<seq(v[i](t),i=1..4)>)[i]:
EqSys[i]:=[Equ[i],Eqv[i]]:
paramsCycle:=omega[st]=4*2*Pi,omega[sw]=2*Pi,Au=5,Av=50,b=100;
params:=paramsCycle;
Differential system
sys:=map(op,eval([seq(EqSys[i],i=1..4)],[params]));
ic:=[u[1](0)=0, v[1](0)=0,u[2](0)=0, v[2](0)=-0.1,u[3](0)=0, v[3](0)=0.1,u[4](0)=0, v[4](0)=0.1];
Résolution1
res:=dsolve([sys[],ic[]],numeric):
Initial boundaries
tcalc:=4;
ic2:=[seq(u[i](0)=eval(u[i](t), res(tcalc)),i=1..4),seq(v[i](0)=eval(v[i](t), res(tcalc)),i=1..4)];
Résolution2
res:=dsolve([sys[],ic2[]],numeric):
tmax:= 40:
numpts:=100*tmax:
plots:-odeplot(res,[t,v[1](t)],0..tmax,thickness=2, view=[0..5, -1.5..1.5],numpoints = numpts);
plots:-odeplot(res,[t,v[2](t)],0..tmax,thickness=2, view=[0..5, -1.5..1.5],numpoints = numpts);
plots:-odeplot(res,[t,v[3](t)],0..tmax,thickness=2, view=[0..5, -1.5..1.5],numpoints = numpts);
plots:-odeplot(res,[t,v[4](t)],0..tmax,thickness=2, view=[0..5, -1.5..1.5],numpoints = numpts);
plots:-odeplot(res,[seq([t,v[i](t)+i*5],i=1..4)],0..tmax,thickness=2,view=[0..5,0..25], numpoints = numpts);
First 1210 1211 1212 1213 1214 1215 1216 Last Page 1212 of 2459
