Dear all;
Thank you for helping me to solve this  question.
I solve an ode, but I have an error when I would like to plot the solution.
uanble to achieve continuous solution with requested accuracy of 0.1e-5 with maximum 128 point mesh (was able to get 0.14e-5), consider increasing `maxmesh` or using larger `abserr`
I try to increase the point mesh or take a large abserr but always I have the same problem.
ode := diff(y(x), x, x) = x*y(x)+sqrt(x);
ics := y(0) = 0, y(1) = 1;
sol:=dsolve({ode,ics}, numeric):
odeplot( sol,[x, y(x)], x=0..1, maxmesh=1000);
I'm not really an expert in maple. I'm stuck with a problem that could be related to the precision of the computational engine...
I defined a function which is relatively complicated as follows:
m := proc (x, l, T) options operator, arrow; (exp(l*(x-T)/(1-exp(-l*T)))*exp(l*T/(1-exp(-l*T)))*(1-exp(-l*T))+(2-exp(-l*T)-exp(l*T))*exp(l*(x-T)/(1-exp(-l*T))))/(exp(l*T)-1)-(l*(x-T)*exp(l*(x-T)/(1-exp(-l*T)))-2*exp(-l*T)+4-2*exp(l*T))/(exp(l*T)-1) end proc
whenever i simplify the equation or factor some of the terms, I get completely different results.
As an example, you can define this function as follows
m := proc (x, l, T) options operator, arrow; (exp(x*l/(1-exp(-l*T)))*(1-exp(-l*T))+(2-exp(-l*T)-exp(l*T))*exp(l*(x-T)/(1-exp(-l*T))))/(exp(l*T)-1)-(l*(x-T)*exp(l*(x-T)/(1-exp(-l*T)))-2*exp(-l*T)+4-2*exp(l*T))/(exp(l*T)-1) end proc
By drawing the function, you can see how things get messy.
plot(m(450, (1/250)*x, 250), x = 0 .. 100)
I know the problem occurs as a results of computation round-off. How could I ameliorate that? I have already increase the precision in the option menu, but that didn't help. By the way, how can I be sure that the anwers maple gives me is correct, except using my intuition?
I've tried to find the solution to my problem, but none of my attempts was succesful.
I have a function which is one-to-one in a particular domain which I am interested in. I would like to get the inverse function of it only in this domain. Here is my function and plot for xp=0..10000:
x := xp-> (-1)*720.5668720*sinh(0.2043018094e-3*xp-0.8532729286)+84952.59423+4.014460003*10^5*arcsinh(0.1219272144e-1*sinh(0.2043018094e-3*xp-0.8532729286)-0.2032498888)
I would appreciate any help,
Iza
I am tryng to write and solve within Maple the equations of movement for a single body subject to a gravitatinal field, F_=-GMm/r2
But I get an error message when trying to define the Angular Momentum which doesn't make sense for me.
Thank you for any help on this topíc.
restart; with(Physics[Vectors]); conventions, Setup(mathematicalnotation = true);
conventions, [mathematicalnotation = true]
r_ := rho*_rho;
r_ := rho _rho
_rho(t);
_rho(t)
rho(t);
rho(t)
v_ := diff(rho(t)*_rho(t), t);
/ d \ / d \
v_ := |--- rho(t)| _rho(t) + rho(t) |--- phi(t)| _phi(t)
\ dt / \ dt /
a_ := diff(%, t);
/ 2 \
| d | / d \ / d \
a_ := |---- rho(t)| _rho(t) + 2 |--- rho(t)| |--- phi(t)| _phi(t)
| 2 | \ dt / \ dt /
\ dt /
/ 2 \ 2
| d | / d \
+ rho(t) |---- phi(t)| _phi(t) - rho(t) |--- phi(t)| _rho(t)
| 2 | \ dt /
\ dt /
eq[1] := -G*M*_rho(t)/r^2-a_ = 0;
/ / 2 \ 2\
| G M | d | / d \ |
eq[1] := _rho(t) |- --- - |---- rho(t)| + rho(t) |--- phi(t)| |
| 2 | 2 | \ dt / |
\ r \ dt / /
/ / 2 \
| / d \ / d \ | d |
+ _phi(t) |-2 |--- rho(t)| |--- phi(t)| - rho(t) |---- phi(t)|
| \ dt / \ dt / | 2 |
\ \ dt /
| = 0
Eq[1, 2] := seq(Component(lhs(eq[1]), n) = 0, n = 1 .. 2);
/ 2 \ 2
G M | d | / d \
Eq[1, 2] := - --- - |---- rho(t)| + rho(t) |--- phi(t)| = 0,
2 | 2 | \ dt /
r \ dt /
/ 2 \
/ d \ / d \ | d |
-2 |--- rho(t)| |--- phi(t)| - rho(t) |---- phi(t)| = 0
\ dt / \ dt / | 2 |
\ dt /
NULL;
L_ := `&x`(r_, m*v_);
Error, (in Physics:-Vectors:-&x) found the unit vector _rho present also as a function _rho(t); either one form or the other - not both - can be present in an algebraic expression
HI, I am trying to solve two PDEs but in boundry conditions there is arising an error plz help.
Nazi.mw
I have many tests to conduct on a MapleSim model. At each test simulations, I would like to change slightly some parameters.
As I have many tests to do (with different parameters), I would like to use a script so as to do like this :
Parameters test1
Launch MapleSim simulation
Store results of test 1
And so on ...
How can I do this kind of script ?
Is it possible to store the 3D animation results ?
Thank you for your help.
I recently noticed that Maple 2015 has become irresponsive on mac (macbook pro) with the latest java release (Java 8 update 66). Did anywone experience the same problem ?
I have a first order differential eq. for some variable say $r(x)$, where $x$ is the independent variable.
After solving this differential equation numerically, I want to use its solution in other expression for $r(x)$ and plot the expession with $x$.
Please let me know how to do it.
I'm trying to use the CodeGeneration package to generate code for a series expansion. I'd like to wrap it in a function that specifies the arguments, so that the code generation package can generate a complete function definition along with definitions for all the temporary variables.
with(CodeGeneration):
f := proc(r): x->r end proc:
to_translate := f(convert(series(sin(x),x,20),polynom));
to_translate := proc (x) options operator, arrow; x-(1/6)*x^3+(1/120)*x^5-(1/5040)*x^7+(1/362880)*x^9-(1/39916800)*x^11+(1/6227020800)*x^13-(1/1307674368000)*x^15+(1/355687428096000)*x^17-(1/121645100408832000)*x^19 end proc
CodeGeneration['C']( to_translate );
Warning, procedure/module options ignored
double to_translate (double x)
  return(r);
Instead of using the value for 'r' passed in, CodeGenerate is producing a function which returns the bare symbol 'r' which is treated as a double. It shouldn't be an issue with lazy evalution because 'to_translate' is evaluated on the statement before the call to CodeGeneration, and to_translate has the full expression that I want to generate code for. How do I get CodeGeneration to produce the intented result?
psi = x^(4/5)*f(x, eta)/(1+x)^(1/20)
eta = y/(x^(1/5)*(1+x)^(1/20))
how can i (diff(psi, x))
how can i (diff(psi, y))
Has anyone solved this problem from an older Putnam paper?
An ellipse sitting in the first quadrant with its major axis parallel to the x axis is tangent to the positive x and y axes.
It slides clockwise within the first quadrant while maintaining tangency to both positive axes until its major axis is parallel to the y axis.
Prove that the locus of its centre is the arc of a circle.
I have crudely animated this motion by sliding the axes around the stationary ellipse. Is there a more elegant animation which slides the ellipse against stationary axes?
I have functions like
g := (y, t)->sin(y(t))
diff(g(y, t), t) # ok
How to determine the derivative below with maple :
diff(g(y, t), y(t))
Hi everyone,
Can anybody help me to write a programme in maple? I want to do a loop that iterate from an integer from 0 to N where I want to write a prodedure, say, MEC(N). Then I want to organise the output into a list of three lists  [[min points],[escape],[capture]], which, if correct, should include all integers from 0 to N exactly once.
> MEC := proc (N)
local IsEmpty, Escape, escape, capture, minpoints, Capture, z, MinPts, ic;
IsEmpty := array(0 .. 2*N);
Escape := array(0 .. 2*N);
Capture := array(0 .. 2*N);
MinPts := array(0 .. N);
IsEmpty := true;
Escape := true;
Capture := true;
MinPts := true;
for ic from 0 to N do
if IsEmpty then
z := ic;
MinPts[ic] := true;
z := ic;
while z <= 2*N and F(z) <= 2*N do
z := F(z);
IsEmpty[z] := true;
Escape[z] := true
z := ic;
while z <= 2*N and Finv(z) <= 2*N do
z := Finv(z);
IsEmpty[z] := true;
Capture[z] := true end do fi;
return [MinPts(z), Escape(z), Capture(z)]
There are two operations involved in the program which is the function F and F inverse called Finv.
i need to produce the output which contain the list of integers exactly once.
I could not figure out which logical expression that I do wrong.
Thank you for your help!
How to find the value of alpha and beta?
u := proc (x) options operator, arrow; sin(x)+cos(x)-4*x+(alpha-4)*x end proc; v := proc (x) options operator, arrow; sin(x)-cos(x)+beta end proc; `assuming`([solve({alpha = int(u(t)+v(t), t = 0 .. Pi), beta = int(u(t)-v(t), t = 0 .. Pi)}, {alpha, beta})], [alpha <> 0, beta <> 0])
{alpha = 4+beta*Pi+(1/2)*alpha*Pi^2-4*Pi^2, beta = -beta*Pi+(1/2)*alpha*Pi^2-4*Pi^2}
thank you for helping
Download Qu_3.mw
How evaluate system of two integral equation by laplace transform ?
with(inttrans):
L := laplace((1/2)*x^2+(1/2)*x^3+(1/12)*x^4 = int(u(t)*(-1+x-t)+v(t)*(1+x-t), t = 0 .. x), x, s);
(s^2+3*s+2)/s^5 = laplace(int(u(t)*(-1+x-t)+v(t)*(1+x-t), t = 0 .. x), x, s)
(3*s^2-s+2)/s^5 = laplace(int((1+x-t)*u(t)+(-1+x-t)*v(t), t = 0 .. x), x, s)
Download Qu_2_mapel.mwQu_2_mapel.mw
First 1211 1212 1213 1214 1215 1216 1217 Last Page 1213 of 2459
