Hi everyone
I've come across a RAM-issue.
My program creates a lot of plots using millions of variables-values and it eats up my computers memory since I use the plots to make an animation.
The plots are simple 3d plots created using the surfdata function.
How do I save plots into a single file as the program creates them concurrently such that after the program has terminated I can use the plots to create an animation?
and how do I efficiently delete variables I dont not need anymore?
Dear Friends
            Hope everything going fine with you. I want the numerical solution of nonlinear system of ordinary differential equations using RK method. The system of ODEs and their required results are present in attached file. I am waiting your quick response.
Help.docx
With my best regards and sincerely.
Mob #: 0086-13001903838
how to round all coefficients for a polynomial in short code way?
Does [Length of output exceeds limit of 1000000] mean that the function couldn't be solved and I have to modify the mathematical model?
If the results are just too long to be displayed, how can I see the results?
I am a new guys for Maple. I want know how can I compute this equation.   (x2)0.5=x.
I think it's simple. But I'm not sure how to impepment in Maple. If you know how to deal with it . Contact me. Thanks
how to make physical quantities graphs from RK45 ode bvp convective boundary layer flow rather than using lines
i use lines command copy one by one yje data from the solution
are they any simplest way to sketch graphs for physical quantities like f'', thetha prime versus 3 parameters?
I want to separate strings into substrings for example
input is "6,3,A,n,k,L,+,-" then the procedure breaks this string into substrings like
if a member numeric b:="6,3",or if lowercase c:="n", if uppercase l:="A,L" else m:="+,-"
I try to find the exact (symbolic) value of
(-2*sqrt(7)-4)*EllipticK((1/8)*sqrt(2)*(-3+sqrt(7)))^2+4*EllipticE(-(1/8)*sqrt(2)*(-3+sqrt(7)))*sqrt(7)*EllipticK((1/8)*sqrt(2)*(-3+sqrt(7)))
I tried 'simplify' with different options and 'convert'. It would be pi=3.141... as numerical approximation suggests.
Many thanks.
I think Simpson's rule for integration is very simple and it is just function evaluation over a few points on the interval of integration. So we expect it to be fast.
When I use it as a summation command (using Simpson's formula) it is really fast but when I use the command ApproximateInt with Simpson method it is sometimes really slow. For example
f := unapply(x^2/(sin(x)+x+1), x);
with(Student[Calculus1]);
evalf(ApproximateInt(f(x), x = 1 .. 2, method = simpson, partition = 20));
or even with partition=10 you must wait for a long time.
Please help.
In the running of an example I faced to computation of radical ideal of the following ideal:
<-c*m*u+d*c*n+m*b*v+m*c*t>
I used from Radical command in PolynomialIdeals package. But I dno't now why it's computation is very hard and Time-consuming?
What I have to do? I think there is a bug, since this ideal is simple, apparently.
Maybe an easy question, but which command do I have to use to calculate the difference between e and a list of fractions?
App.mw
Hi all
I don't know why it doesn't work correctly? I want the final answer be in the form of De, U, UN not as beta1 and beta2
Please help me...
Hello Please, I was wondering if I can get this equation solve either in closed form or approximate form:
mu = theta*beta^a*(int(t^a*exp(-beta*t)/(-lambda*t+1), t = 0 .. infinity))/Gamma(a)
Many thanks
I have a set of data that I have imported in Maple.  When I plot the data, I can see that there are two sine waves in it.  It is a plot of radial velocity of a star versus time.  This is about a reflex motion of a star with an orbiting planet.  We will set that there is only one planet.
I would like to extract those two sine waves.  I am including that *.csv file that I imported in Maple that you can download at this address.
https://www.dropbox.com/s/4f4j5xm565je30x/Tyr_rv9_Maple.csv?dl=0
This is not for an exam but it is for a course in February and this will be very helpful and I want to share this file.  I can predict that there will be more than one planet but it is the idea that is important.
Mario Lemelin
Maple 2015 Ubuntu 14.04 - 64 bits
Maple 2015 Win 10 Pro - 64 bits messagerie : mario.lemelin@cgocable.ca téléphone :  (819) 376-0987
Is there a way to permanent change the color of the output in maple?
First 1215 1216 1217 1218 1219 1220 1221 Last Page 1217 of 2459
