My function is shown below:
f:=(x,y)->evalf[5](2*x*Int(sqrt(1+y^2*(t*x-1)^2/(1-(t*x-1)^2)), t = 0 .. 1)):
printf(" x     y     f(x,y)\n");
for x from 0.1 to 1.9 by 0.1 do
for y from 0.1 to 0.9 by 0.1 do
printf("%g   %g   %g\n",x,y,f(x,y));
od; od;
I want a relationship as follows to be fitted values of x,y, f(x,y)
f(x,y)=a1*x*sqrt(1+y^2*((a2*x-a3)^2/(1-(a4*x-1)^2)))
a1,a2,a3,a4=Coefficients that must be determined
There are dozens of indefinite integral expressions in my worksheet. Everytime I execute the entire worksheet, the cursor always rests beside one indefinite integral expreesion and Maple stays in "Evaluating...". Even 30 minutes passed, the result of the integral couldn't come out. What bothers me is that the cursor would rest beside different indefinite integral expressions. For example, I write 4 indefinite integral expressions A, B, C and D one by one. First time, the results of A, B and C come out and the cursor rests beside D with "Evaluating...". Next time, the results of A and B come out and the cursor rests beside C with "Evaluating...".
Before the indefinite integral expressions, I wrote dozens of lines of codes aiming at assigning values to variables. As I typed more and more indefinite integral expressions into the worksheet, even evaluating the codes aiming at assigning values would spend more and more time.
Does Maple evaluate the codes line by line from the top to the end of a worksheet? If it is true, why evaluating the codes before the indefinite integral expressions becomes slowly?
How to evaluate the entire worksheet without stuck in one indefinite integral expression?
Hi everyone, this is my situation:
I've created a program inside a "Code editor region" within "Document mode" which I execute by pressing CTRL+E within the code editor region.
The program outputs an animation of the solution to the heat equation.
The thing is, the program contains some for-loops and I want to print some text in the end of each iteration within the for-loops so as to track the progress, e.g. I want to have printed        "The equations for time level k out of m were set up"
The problem is that in document mode you will get a huge amount of text added to your document which you'll have to delete, if you print about 1000 times.
So my question is:   Is it possible to use the "Command-line Maple 2015"-tool and/or modify the way I've set up my program such that the print statements are outputted to the terminal AND the animation pops up in a seperate window?
I've tried to run some simple commands in the maple-terminal such as:
        plot(x^2,x=-1..1);
but somehow the terminal displays it using regular text-symbols and stuff. I thought that it would just open up some seperate window, displaying a graph-plot as you would normally see in maple.
Hi. I want to solve this system of equations by varying the value of n. I managed to aolve and plot for n=1, 1.1 and 1.2 but it happens to be a problem when I let n=1.3.
>restart;
>Digits := 15;
>with(plots):n:=1.3: mu(eta):=(diff(U(eta),eta)^(2)+diff(V(eta),eta)^(2))^((n-1)/(2)):
>Eqn1 := 2*U(eta)+(1-n)*eta*(diff(U(eta), eta))/(n+1)+diff(W(eta), eta) = 0;
>Eqn2 := U(eta)^2-(V(eta)+1)^2+(W(eta)+(1-n)*eta*U(eta)/(n+1))*(diff(U(eta), eta))-mu(eta)*(diff(U(eta), eta, eta))-(diff(U(eta), eta))*(diff(mu(eta), eta)) = 0;
>Eqn3 := 2*U(eta)*(V(eta)+1)+(W(eta)+(1-n)*eta*U(eta)/(n+1))*(diff(V(eta), eta))-mu(eta)*(diff(V(eta), eta, eta))-(diff(V(eta), eta))*(diff(mu(eta), eta)) = 0;
>bcs1 := U(0) = 0, V(0) = 0, W(0) = 0;
>bcs2 := U(20) = 0, V(20) = -1;
>R1 := dsolve({Eqn1, Eqn2, Eqn3, bcs1, bcs2}, {U(eta), V(eta), W(eta)}, initmesh = 30000, output = listprocedure, numeric);
Error, (in dsolve/numeric/bvp) precision is insufficient for required absolute error, suggest increasing Digits to approximately 23 for this problem
>for l from 0 by 2 to 20 do R1(l) end do;
>plot1 := odeplot(R1, [eta, U(eta)], 0 .. 20, numpoints = 2000, color = red);
I have tried increasing the Digits as suggested to 23, 25, 30, 31 up untill 500 yet still same error occur suggesting to increase the Digits. Is there any other way to solve this kind of error? Can someone help me? Thank you in advance.
Hi. I want to solve a system of equations. But I got this type of error.
>restart;
>Digits := 15;
>with(plots):n:=0.7:Pr=1: mu(eta):=(diff(U(eta),eta)^(2)+diff(V(eta),eta)^(2))^((n-1)/(2)):
>Eqn1 := 2*U(eta)+(1-n)*eta*(diff(U(eta), eta))/(n+1)+diff(W(eta), eta) = 0:
>Eqn2 := U(eta)^2-(V(eta)+1)^2+(W(eta)+(1-n)*eta*U(eta)/(n+1))*(diff(U(eta), eta))-mu(eta)*(diff(U(eta), eta, eta))-(diff(U(eta), eta))*(diff(mu(eta), eta)) = 0:
>Eqn3 := 2*U(eta)*(V(eta)+1)+(W(eta)+(1-n)*eta*U(eta)/(n+1))*(diff(V(eta), eta))-mu(eta)*(diff(V(eta), eta, eta))-(diff(V(eta), eta))*(diff(mu(eta), eta)) = 0:
>Eqn4 := (W(eta)+(1-n)*eta*U(eta)/(n+1))*(diff(theta(eta), eta))-(mu(eta)*(diff(theta(eta), eta, eta))+(diff(mu(eta), eta))*(diff(theta(eta), eta)))/Pr = 0:
>bcs1 := U(0) = 0, V(0) = 0, W(0) = 0, theta(0) = 1:
>bcs2 := U(20) = 0, V(20) = -1, theta(20) = 0:
>R1 := dsolve({Eqn1, Eqn2, Eqn3, Eqn4, bcs1, bcs2}, {U(eta), V(eta), W(eta), theta(eta)}, initmesh = 20000, output = listprocedure, numeric);
Error, (in dsolve/numeric/bvp/convertsys) too few boundary conditions: expected 8, got 7
>plot1 := odeplot(R1, [eta, theta(eta)], 0 .. 20, numpoints = 2000, color = red);
What is the problem actually because based on the paper that I refer to, there is only 7 bc.
Can anyone help me?
Thankyou in advance.
Is there any option for impoting MATLAB's variables eith struct format (*.mat)?
Could you please to help me!
In Mathematica 10.0 were introduced regions with functions like TransformedRegion, ReginIntersection, etc. Moreover, it is easy to check if a point is inside a region, etc.
I would like to ask if in Maple I could use some API with similar functionality?. For instance, I would like to get integer points which lay inside an intersection of two cubes. How I could do this in Maple?
How to get the approximation of definite integral if explicit integral could not be found?
explicit_integral_could_not_be_found.mw
If explicit integral could not be found, is there any function or method to get the approximation of a definite integral?
how to answer of materix export to Excel.
Digits:=5;
f:=(x,y)->2*x*evalf(Int(sqrt(1+y^2*(t*x-1)^2/(1-(t*x-1)^2)), t = 0 .. 1)):
for i to 20 do
for j to 11 do
a[i,j]:=f(0.1*i, 0.1*(j-1));
od: od:
interface(rtablesize=infinity):
A:=Matrix(20,11, (i,j)->a[i,j]):
V:=<seq(i,i=0.1..2,0.1)>:
W:=Vector[row]([cat(x,` \\ `,y),seq(i,i=0..1,0.1)]):
<W, <V|A>>;
I want Positive values of Arcsin but maple give to me Negative values of Arcsin?
my function is f=arcsin(1-x), 0<x<2 and f>0. and f(2)=3 pi/2 but in maple f(2)=-pi/2.
I want positive values of f Without adding anything to f.
Of course it's easy to write a procedure to compute the ith Horner polynomial of a polynomial but I'm carious to know if there is any built-in command for doing this, I searched in help of Maple and found several ways but they convert or rewrite the input polynomial in Horner form so the output is last Horner polynomial which is equal to the input polynomial with this difference that it is written in a kind of factorization form which shows the Horner structure and ofcourse with looking at it you can read other Horner polynomials too but why not having exactly the ith Horner for the output? So is there any other command with output being the ith Horner?
arcsin(-1);
-pi/2
but I want Positive values of Arcsin Namely:
arcsin(-1)=3 pi/2
For the following Maple 2015 procedure and funtion call
 f := proc(x,y) local a; global b;
    if x < y then
        a := x; b := y + a;
        a := y; b := x + a;
    a + b + x + y
stopat(f);
                              [f]
f(2, 3);
Maple help topic "The Maple Debugger" shows the following example:
 f:
    1*   if x < y then
 DBG> stopwhen b
 [b]
 f:
    1*   if x < y then
 DBG> cont
 b := 5
 f:
    6    a+b+x+y
 DBG> showstat
 f := proc(x, y)
 local a;
 global b;
    1*   if x < y then
    2      a := x;
    3      b := y+a
    4      a := y;
    5      b := x+a
    6 !  a+b+x+y
 end
 DBG> quit
 Warning, computation interrupted
However, when I run the procedure in Maple Notation (1D) the Interactive Maple Debugger pops up with syntax quite different from the example.  How can I turn the Interactive Debugger off and use commands such as DBG> stopwhen b in the command-line version?
Thanks!  Les
hi .how i can clarify expression in maple that in running dont asked me again..
for example attached file
2)how i can deleted one parameter of
Memory in maple or
Restart it??
Hello, I'm trying to enumerate matrices, each P [j] with j = 1,2,3 ... n-1. , and also can also the value of its elements with P [j] (r, k) for example.
n:=4;
for j from 1 to n-1 do
P[j]:=Matrix(n);
for l from 1 to n do
P[j](l,l):=1;
Error, invalid operator parameter name
Regards.
First 1216 1217 1218 1219 1220 1221 1222 Last Page 1218 of 2459
