using FDM or FEM rather than dsolve?
ode.docxode.docx
Hello everyone! I'm currently trying to plot the effective potential for Sun-Jupiter system, to show the lagrangian points in this system. I've converted to a system of units where G=1, m_sun+m_jupiter=1 and R=1, whereby I get the following equation describing the effective potential of a third mass m in the system:
U(x,y)=-1 * 0.999047/abs(sqrt((x-(-0.000953))^2 +y^2 ))-1 * 0.000953/abs(sqrt((x-0.999047)^2 +y^2 ))
However, when I plot this in Maple, I don't get a contour plot that matches up with what I would [expect](https://upload.wikimedia.org/wikipedia/commons/thumb/e/ee/Lagrange_points2.svg/2000px-Lagrange_points2.svg.png), but [this](http://imgur.com/oZLE3gV). Is there possibly anyone here who could point out a mistake I've done, or give me some advice? Thanks in advance!
Occasionally I have need to import 1D Maple expressions into Mathematica, because I believe mma has superior simplify functionality (sorry Maple). Mathematica has its own syntax which (of course) differs to maple.  eg sin(x) in maple is Sin[x] in mma ; ln(x)=Log[x] ;....... I'm aware of the package MmaTranslator, but I think it only converts mma to maple.
so i need some code pls.
(i have bolded the functions which need to be converted)
eg: i/p:
(1/365)*(365*B21*EP*ln(1+i)*(1+i)^B21*hr*kw*p-365*EP*hr*kw*p*(1+i)^(-1+B21)*i-365*EP*hr*kw*p*(1+i)^(-1+B21)+365*EP*hr*kw*p+SC*i)/(hr*kw*(EP*ln(1+i)*(1+i)^B21*p-FIT*i*p+cos(omega)))
o/p:
(1/365)*(365*B21*EP*Log[1+i]*(1+i)^B21*hr*kw*p-365*EP*hr*kw*p*(1+i)^(-1+B21)*i-365*EP*hr*kw*p*(1+i)^(-1+B21)+365*EP*hr*kw*p+SC*i)/(hr*kw*(EP*Log[1+i]*(1+i)^B21*p-FIT*i*p+Cos[omega]))
I ran into a problem with define that I traced to the 'linear' option in the define statement, and I would like to know whether this is my lack of understanding define, or a bug.
I want to define a function called avg(parm) (which I never will need to use explicitly but  I need to be able to manipulate). This function has the property of being linear, and terms not depending on x can be pulled out. Also, avg(parm)=parm unless parm depends on x. (Yes, it stands for a kind of averaging, but that is not relevant here).
So I programmed it in this way:
define(avg,'linear','conditional'(avg(a::algebraic) = a, _type(a, freeof(x))),\
'conditional'(avg(a::(nonunit(algebraic))*b::(nonunit(algebraic))) = a*avg(b), _type(a, freeof(x))));
For the heck of it I could not get it to work. Basically, none of the equations in the definition were ever used, except that constant numeric factors were pulled out, as they should.
Eventually I found that the 'linear' option was the culprit. Once I got rid of that, the definition of avg did what I wanted it to do (like avg(a*x) => a*avg(x); avg(a) => a). The reason a constant numeric factor was pulled out before is because the 'linear' option does that; it never gets to my definitions (one can see that when printing avg).
Am I missing something fundamental here, or is define not working right?
For the record, I did this in Maple 15 on a PPC Mac. I don't have my Maple 2015 handy to test on that version.
Any insights?
Mac Dude
I'm null in statistic. I'm doing a calculation to calculate a set of parameter. By example:
I have to calculate 5 parameters x1,x2,x3,x4,x5 from 7 equations f1,f2,f3,f4,f5,f6,f7. Because it is difficult to calculate directly 5 parameters, I used chisquare to minimize the difference between experimental and theorical data. Then, I can get the results. After that, I used these 5 parameters to back-calculate the data using 7 equations above. My question is about how to calculate the error bar (or standard error) of the back-calculate datato add to the plot.
Thank you  for helping me,
Best regards.
a := Matrix(2, 2, {(1, 1) = 1, (1, 2) = 2, (2, 1) = 3, (2, 2) = 4})with(LinearAlgebra)
a.a^T = (Matrix(2, 2, {(1, 1) = 1, (1, 2) = 2, (2, 1) = 3, (2, 2) = 4})).(Matrix(2, 2, {(1, 1) = 1, (1, 2) = 2, (2, 1) = 3, (2, 2) = 4}))^TNULL
I am not getting the answer.
I want to get the answer for this product of matrix and its tranport.
I do not want to create transport matrix again for this calculation.
The transporse matrix b is
b := Matrix(2, 2, {(1, 1) = 1, (1, 2) = 3, (2, 1) = 2, (2, 2) = 4}) = Matrix([[1, 3], [2, 4]])
a.a^T is equal to a.b = Matrix([[5, 11], [11, 25]])NULL
For large matrices i cannot do this. Hence this request.Any one please send the code. Thanks.
Download transpose_doubt_1.mwtranspose_doubt_1.mw
Ramakrishnan V
rukmini_ramki@hotmail.com
I don't know if I am doing it right or not because Maple isn't solving the equation. The equation solution is x=2^(1/2).
Here I let a picture of which equation I want to solve and Maple's response.
Trigonometric Equation
In Maple 15 it seems that plottools:-transform only accepts this form of conditional statement:
`if`(conditional expression, true expression, false expression).
Is there any way to have plottools:-transform process more than one condition? Do later versions of Maple permit this?
Hi, Im now trying to run my code. But it took like years to even getting the results. may I know any solutions on how to get faster results? Because I have run this code for almost 4 hours yet there is still 'Evaluating...' at the corner left. And when I tried to stop the program, it will stop at 'R1...'.
Digits := 18;
with(plots):n:=1.4: mu(eta):=(diff(U(eta),eta)^(2)+diff(V(eta),eta)^(2))^((n-1)/(2)):
Eqn1 := 2*U(eta)+(1-n)*eta*(diff(U(eta), eta))/(n+1)+diff(W(eta), eta) = 0;
Eqn2 := U(eta)^2-(V(eta)+1)^2+(W(eta)+(1-n)*eta*U(eta)/(n+1))*(diff(U(eta), eta))-mu(eta)*(diff(U(eta), eta, eta))-(diff(U(eta), eta))*(diff(mu(eta), eta)) = 0;
Eqn3 := 2*U(eta)*(V(eta)+1)+(W(eta)+(1-n)*eta*U(eta)/(n+1))*(diff(V(eta), eta))-mu(eta)*(diff(V(eta), eta, eta))-(diff(V(eta), eta))*(diff(mu(eta), eta)) = 0;
bcs1 := U(0) = 0, V(0) = 0, W(0) = 0;
bcs2 := U(4) = 0, V(4) = -1;
R1 := dsolve({Eqn1, Eqn2, Eqn3, bcs1, bcs2}, {U(eta), V(eta), W(eta)}, initmesh = 30000, output = listprocedure, numeric);
Warning, computation interrupted
for l from 0 by 2 to 4 do R1(l) end do;
plot1 := odeplot(R1, [eta, U(eta)], 0 .. 4, numpoints = 2000, color = red);
Thankyou in advance :)
Hi there, I am a new user of Maple. I am trying to use intsolve for a course project requiring solving an integral equation. I saw Maple has the intsolve function, then I bought it. However, it didn't seem to work for me.
I typed s(x) and r(y) in and try to solve this problem.
It took 20 minutes; it's still evaluating... what should I do?
I am currently trying to solve a geometric problem where I have to calculate angles in two connected four bar linkages parallel to a serial chain of rotatory joints (closed-loop kinematic chain).
The angle is calculated with
 > alpha:=arctan(exp_y, exp_x):
The expressions exp_y and exp_x contain long products of sines and cosines of 6 other time-dependant angles, square roots of these products, constant geometric lengths (not time-dependant) and constant geometric angles (not time-dependant).
The lenghts are already assumed positive
 > assume (l1>0): # similar for all lengths l2, l3, ...
The time dependant angles are defined as
> qJ_t := Matrix(6, 1, [qJ1(t), qJ2(t), qJ3(t), qJ4(t), qJ5(t), qJ6(t)]): # generalized coordinates of the system in the sense of technical mechanics
Other assumptions are not set, since the angles can be positive as well as negative.
Calculating this expression takes up to two days on a fast computer. In my opinion this takes much too long compared to other calculations with similar amount of variables (more complex robotic structures).Also, the arctan function does not "calculate" a result, it just writes down "arctan(...)".
Is there a way to speed up this calculation e.g. by using more assumptions?
On the arctan help page, the examples suggest that Maple is trying to already simplify the solution e.g. by drawing Pi out of the solution.
i have attchassignment.mwsassignment.pdf
I tried to fit a sin function to some data using Statistics[Fit] however the result either didn't work properly or worked differently from the way I expected it to work.
a2 is the calculated function from Statistics[Fit] and a3 is some quickly inserted values that provides a more satisfying result.
Why is a better fitting line not found?
restart; gc()
X := [73, 74, 75, 76, 77, 78, 79, 80, 81, 82, 83, 84, 85, 86, 87, 88, 89, 90, 91]:
Y := [35, 35, 36, 41, 47, 42, 43, 37, 34, 28, 28, 30, 27, 33, 35, 38, 42, 42, 40]:
with(Statistics):
a1 := pointplot(zip(`[]`, X, Y)):
f := Statistics:-Fit(a*sin(b*x+c)+d, X, Y, x)
HFloat(2.1212360930685046)*sin(HFloat(1.0274743698606499)*x-HFloat(2.6022740116723866))+HFloat(36.46562486953954)
a2 := plot(f, x = 72 .. 92):
display(a1, a2)
f1 := 8*sin(.5*x-5.5)+36
8*sin(.5*x-5.5)+36
a3 := plot(f1, x = 72 .. 92):
plots:-display(a1, a3)
Download Fitting-Sine-off.mw
To check one of the MythBusters TV episodes, i.e., the fall of a mannequin (80 Kg) from a plane at an altitude of 1200 m in 31 s, with Maple13 (Windows Vista) I solved the following differential equation with initial conditions:
> de:= m*(D@@2)(x)(t) = m*g - k*(D(x)(t))^2:
> ini:= (x(0) = 0, D(x)(0) = 0):
> X:= unapply(rhs(expand(dsolve({de,ini}))),t);
     X := proc (t) options operator, arrow; -m^(1/2)*g^(1/2)*t/k^(1/2)-m*ln(2)/k+m*ln(exp(2*g^(1/2)*k^(1/2)*t/m^(1/2))+1)/k end proc
1) Posing: V0 = sqrt(m * g / k),  T = sqrt(m/(g*k)) one has  V0*T = m/k. I want to have:
   > Xxb:= t -> V0*(- t + T * ln((exp(2*t/T) + 1)/2) ); # m.
 How to obtain this equivalent equation  Xxb(t), without retyping the equation of  X(t) ? With subs , convert or simplify  applied to  X(t), Maple 13 gives error messages.
2) Taking the derivative of  Xxb(t), one find :
     V := proc (t) options operator, arrow; V0*(exp(2*t/T)-1)/(exp(2*t/T)+1) end proc.
How to transform it to V = V0 tanh(t/T) ?
Again, subs , convert or simplify  seem not working, even with  assume(t, real), assume(T, real) ! I know simplify is a difficult task, but Maple should recognize a tanh !
Thank you in advance for any suggestion.
( Note that with m = 80 Kg, g = 9.81 m/s^2 and k = 0.267482 Kg/m, which correspond to a speed limit of V0 =195 km/h, on find t(1200m) = 26 s, instead of 31 s ).
Hi everyone
I am going to add a continious time white guassian noise n(t) to a function f(t), and plot g(t)=f(t)+n(t). Any suggestion?
Also, I am going to filter this white noise, and analysis colored noise. How can I apply a frequency-domain rectangular window to a function?
Thank for your kind answers
First 1214 1215 1216 1217 1218 1219 1220 Last Page 1216 of 2459
