Hi, friends!
I'm not a math =) but it is interesting
How can i solve this equation like the gambler's ruin with Maple's function rsolve
f(n)=0.5*f(n-1)+0.5*f(n+1), f(0)=1, f(6)=0
rsolve({f(n)=0.5*f(n-1)+0.5*f(n+1), f(0)=1, f(6)=0}, {f});
it returns this
{f(n) = 7 f(5) - f(5) (n + 1)}
I don't understand :(
for example Wolfram Alpha return the true result
Sorry for the uninformative title. I've never used Maple, but I'm willing to buy a student license and learn it. But before spending too much effort and money I need to know if it suits my needs.
Basically what I need to do is:
1) I have a positive definite symmetric matrix of size nxn, where n can range from 2 to inf. I don't know the elements, except the fact that the diagonal has ones everywhere. All I know is that the elements out of the diagonal are in the range [0,1)
2) I have to compute the lower triangular cholesky decomposition of this matrix, lets call it L.
3) I need to subtract from each element of L the mean of the elements in the respective column. Lets call this matrix L*
4) Then I need to evaluate another nxn matrix computed from the elements of L* following a simple pattern.
5) Finally I need to find the eigenvalues of this last matrix.
What I would ideally want is to get a symbolic representation of the n eigenvalues as symbolic functions of the (unknown) elements of the matrix at point 1.
I can drop the assumption of n being unknown, i.e. fix n=3 and get the 3 functions that, after replacing the right values, give me the eigenvalues, then fix n=4 and get 4 functions, etc.
Is this possible to do in maple?
I try to use a Catmull-Rom spline which has to match on several points.
I use a code extracted from the book "Geometry and curves with maple".
Here you can find an extract which is visible from google book :
I have slightly modified the initial procedure crom_2d. I didn't find the error in my procedure. May you help me to find the blocking point of my procedure ?
Here I attached my code:
CalculSplineMatmull-Rom.mw
Thank you for your help.
Compute the following multiple integral exactly and/or with 10 correct significant digits
Int(  exp( - add(x[i],i=1..10)^3),  seq(x[i]=0..1, i=1..10) );
  The problem is suggested by a previous post.
Hello everyone !
I have a problem when I want to calculate the following multiple integration numerically:
>evalf(Int(exp(sum(x[i],i=1..6)^2),[seq(x[i]=-1..1,i=1..6)]));
  value(%);
It doesn't work. But when I replace sum(x[i],i=1..6)^2 with sum(x[i],i=1..6), it works. Is there any feasible solution to my problem ?
Thank you for reading !
Dear Friends
In differential expressions(See Maple file) how to find coefficiets of dependent variable "u(x,t)" and "v(x,t)" and of their differentials ? There is command "dcoeffs(function)", but that work for single dependent variable only but in our case there are two dependent variables in consideration. There are other options like "indets", "specindex" but those do not work.
with(PDEtools):
DepVars; -1; [u(x, t), v(x, t), r[1](t), r[2](t), s[1](t), s[2](t), p[1](t), p[2](t), alpha[1](x, t), beta[1](x, t), beta[2](x, t), delta[1](x, t), delta[2](x, t)]
alias(u = u(x, t), v = v(x, t), r[1] = r[1](t), r[2] = r[2](t), s[1] = s[1](t), s[2] = s[2](t), p[1] = p[1](t), p[2] = p[2](t), alpha[1] = alpha[1](x, t), beta[1] = beta[1](x, t), beta[2] = beta[2](x, t), delta[1] = delta[1](x, t), delta[2] = delta[2](x, t))
u, v, r[1], r[2], s[1], s[2], p[1], p[2], alpha[1], beta[1], beta[2], delta[1], delta[2]
(diff(r[1], t))*(-s[1]*u*(diff(u, x))-p[1]*((diff(u, x))*v+u*(diff(v, x)))-alpha[1]*(diff(u, x))-beta[1]*u-delta[1])/r[1]+r[1]*(diff(alpha[1]*(diff(u, x))+beta[1]*u+delta[1], x, x))+(diff(s[1], t))*u*(diff(u, x))+s[1]*(alpha[1]*(diff(u, x))+beta[1]*u+delta[1])*(diff(u, x))+s[1]*u*(diff(alpha[1]*(diff(u, x))+beta[1]*u+delta[1], x))+(diff(p[1], t))*((diff(u, x))*v+u*(diff(v, x)))+p[1]*((diff(alpha[1]*(diff(u, x))+beta[1]*u+delta[1], x))*v+(diff(u, x))*(alpha[1]*(diff(v, x))+beta[2]*v+delta[2])+(alpha[1]*(diff(u, x))+beta[1]*u+delta[1])*(diff(v, x))+u*(diff(alpha[1]*(diff(v, x))+beta[2]*v+delta[2], x)))+(diff(alpha[1], t))*(diff(u, x))+alpha[1]*(diff(alpha[1]*(diff(u, x))+beta[1]*u+delta[1], x))+(diff(beta[1], t))*u+beta[1]*(alpha[1]*(diff(u, x))+beta[1]*u+delta[1])+diff(delta[1], t)
(diff(r[1], t))*(-s[1]*u*(diff(u, x))-p[1]*((diff(u, x))*v+u*(diff(v, x)))-alpha[1]*(diff(u, x))-beta[1]*u-delta[1])/r[1]+r[1]*((diff(diff(alpha[1], x), x))*(diff(u, x))+2*(diff(alpha[1], x))*(diff(diff(u, x), x))+alpha[1]*(diff(diff(diff(u, x), x), x))+(diff(diff(beta[1], x), x))*u+2*(diff(beta[1], x))*(diff(u, x))+beta[1]*(diff(diff(u, x), x))+diff(diff(delta[1], x), x))+(diff(s[1], t))*u*(diff(u, x))+s[1]*(alpha[1]*(diff(u, x))+beta[1]*u+delta[1])*(diff(u, x))+s[1]*u*((diff(alpha[1], x))*(diff(u, x))+alpha[1]*(diff(diff(u, x), x))+(diff(beta[1], x))*u+beta[1]*(diff(u, x))+diff(delta[1], x))+(diff(p[1], t))*((diff(u, x))*v+u*(diff(v, x)))+p[1]*(((diff(alpha[1], x))*(diff(u, x))+alpha[1]*(diff(diff(u, x), x))+(diff(beta[1], x))*u+beta[1]*(diff(u, x))+diff(delta[1], x))*v+(diff(u, x))*(alpha[1]*(diff(v, x))+beta[2]*v+delta[2])+(alpha[1]*(diff(u, x))+beta[1]*u+delta[1])*(diff(v, x))+u*((diff(alpha[1], x))*(diff(v, x))+alpha[1]*(diff(diff(v, x), x))+(diff(beta[2], x))*v+beta[2]*(diff(v, x))+diff(delta[2], x)))+(diff(alpha[1], t))*(diff(u, x))+alpha[1]*((diff(alpha[1], x))*(diff(u, x))+alpha[1]*(diff(diff(u, x), x))+(diff(beta[1], x))*u+beta[1]*(diff(u, x))+diff(delta[1], x))+(diff(beta[1], t))*u+beta[1]*(alpha[1]*(diff(u, x))+beta[1]*u+delta[1])+diff(delta[1], t)
In above differential expressions how to find coefficiets of dependent variable "u(x,t)" and "v(x,t)" and of their differentials ? There is command "dcoeffs(expr,u(x,t))", but that work for single dependent variable only but in our case there are two dependent variables in consideration. There are other options like "indets", "specindex" but those do not work.
Download Coefficients_in_differential_expression.mw
I have an SEIR model.
Equation 5 is for disease death but I would like to plot the cumulative numbers of disease death which will be the integral of Equation 5. I added the integral inside odeplot but it is not working. Any idea  about  how to compute the integral ?
Maple code is attached
code.mw
Found a strange behaviour in Mapke 2015 of the sqrt-function after loading the GRTensor package:
the square-root of a non-square integer, e.g. sqrt(5), does not terminate. 5^(1/2) instead works fine.
Can be reproduced with Maple 18, but not with Maple 11.
I consider this a serious bug, as it makes any expressions containing such roots useless.
As it worked with Maple 11 I am inclined to see it as your fault.
Let's say I've got somehow a result of the product:
exp(k*t)*cos(t*omega)
as series expression and I want to factor out the series of
exp(k*t)
in order to get
cos(t*omega)
How can I do that with Maple?
In PDEtools, suppose to I wish assign zero value to certain first order partial derivative such that higher order derivatives automatically vanish in subsequent excutions, how I can do that?
with(PDEtools):
alias(u = u(x, y, t))
u
Suppose we wish following derivative equal to zero,
diff(u, x) = 0
diff(u, x) = 0
If we use ":=" for value assignment we will get error. Under above assuption how can we make following derivatives zero?
diff(u, x, x); 1; diff(u, x, y); 1; diff(u, x, x, x, y)
diff(diff(u, x), x)
diff(diff(u, x), y)
diff(diff(diff(diff(u, x), x), x), y)
Download Assiging_Derivative.mw
I tried to load my document containing some notes, but then I got the message "There were problems during the loading process, Your worksheet may become incomplete", and as the message said my worksheet were incomplete. Is there a way to restore the document? I have tried following this and added the line it suggested:
http://www.maplesoft.com/support/help/Maple/view.aspx?path=worksheetmaybeincomplete
But it didn't work.
I have attached the file.
Noter.mw
I never expected that the reflected light direction of sun from moon in the sky would be so dificult to imagine ...
at the following article mentioned :
we derive an equation for the magnitude of the moon tilt illusion that can be applied to all con gurations of sun and moon in the sky.
THE MOON TILT ILLUSION
since the calculations contains many steps and high level mathematical formula , there is no way rather to recourse to maple (powerful math assistant )
I hope there was adaptations between a lots of functions and predefined schema of maple and this problem so that the calculations and visualization facilitated several times ?
your effort will be a graet present for all the people of the world that look to the moon crescent everytime !
hi.i trust that attached equation has more answer but fsolve only gain some of them!!! how i can gain another that i know value of them?
another root  that i known, are : 0.165237712988657e-1    and     .103583272213766    and    .290071279318035
root.mw
I am comptuing the eigenvalues and the characteristic polynomial of a 8 by 8 symmetric matrix, say M. Thus, we define the matrix M, and compute its charast. plynm. by
and its eigenvalues with the command
Well, Maple returns the charast. polynm. an dthe eigenvalues. But, if we compute p(E[k]), for k=1,...,8, thats is, the values of the polynomial p(x) in the eingenvalues, Maple not turns cero!!! I'm really confused ... anyone know what could be happening?
Maple attached file with this example. Thank very much for your help!!
Download exam_eigenvalues.mw
hi .how i can calculate eigenvector associated with the eigenvalue of the matrix.for example according attached file below
what are  eigenvector associated with the eigenvalue of matrix q which  determined as (2646.408147, 3142.030259, 6621.757707) respectively??
thanks...
eign.mw
First 1217 1218 1219 1220 1221 1222 1223 Last Page 1219 of 2472
