I try his code:
for i to 6 do u[i, j] := (u[i-1, j]+u[i+1, j]+lambda*(u[i, j-1]+u[i, j+1])+sigma(h, r[i+1])*(u[i+1, j]-u[i-1, j]))/mu end do;
Error, too many levels of recursion.
I want to the  results of the analytic equations, for example:
 u[1,j]= (u[0, j] + u[2, j] + lambda (u[1, j - 1] + u[1, j + 1])
      + sigma(h, r[2]) (u[2, j] - u[0, j]))/mu
Regards.
Suppose that we have the following curve on a unit sphere
r^2+z^2=1
phi=pi/3
-1<=z<=1
which is the implicit equation of a circle in "cylindrical coorinates" (r,phi,z) on the sphere.
How can I plot this curve without solving the implicit equation for r or z ?
Also, I don't want to make any parameterization.
See attached file and code
0. This is the differential equation I'm trying to do:
http://www.intmath.com/differential-equations/6-rc-circuits.php
https://i.imgur.com/zlVIisR.png
1. After you look at the above imgur link, could you help me with this error
Error, (in Units:-Standard:-+) the units ``&Omega;`` and `1/F` have incompatible dimensions
2. Why does my solve ODE fail?
See my code:
test_maple.mw
Spiral on the cone.
Yes, of course, in Maple.  The same source
I have Maple package "DESOLVE" having two different types of files namely in format .mpl and .mws, where code is written in .mpl file and .mws is just a example worksheet, this package is available at following link;
http://cpc.cs.qub.ac.uk/summaries/ADYZ_v1_0.html
My problem is how to work with package?
One thing that I able to do is that I have opened the file type .mpl  in Maple worksheet and after executing whole whorsheet I able to to start working with package using with(desolv).
But when I type with(desolv) in new worksheet an error shows up.
How I can store this .mpl file in Maple library so as to use this package using "with(desolv)" in new worksheets
Desolv_worksheet_paper.mws?
Remark by Markiyan Hirnyk:
The part of the body of this question disappears after my edit of its title only.
I want to have a matrix such that
Crosslinking surfaces by a spiral.
My fantasy is a source.
eq1 := z = y*log(x): eq2 := z = y+x*log(x):
DispIntersecting := implicitplot3d([eq1, eq2], x = 0 .. 10, y = -30 .. 30, z = -40 .. 40, color = [blue, green]):
solve({eq1, eq2}, [x, y, z]);
assign(%):
DispIntersection := spacecurve([x, y, z], x = 0.1e-2 .. 10, color = red, view = [0 .. 10, -30 .. 30, -40 .. 40]):
display(DispIntersecting, DispIntersection, axes = boxed, scaling = constrained);
This is really weird.
eq:=phi(f(x,y(x),diff(y(x),x)),g(x,y(x),diff(y(x),x)));
Does any one see a "||" in the above? I do not. Then why Maple shows this:
r := cat("dsolve(",eq,",y(x))");
       r:="dsolve("||phi(f(x,y(x),y'(x)),g(x,y(x),y'(x)))||",y(x))"
This is Maple 2015 on windows. Running in worksheet mode
Here is screen shot
This problem does not show up all the time. For example, this works ok:
No "||" added. The problem with all the above, is that I can't make it all as a string in the first example above. I am trying to make a string of   "dsolve(" + ode + "),y(x)"
Here is the display options
thank you
Can somebody help me to find the solution?
I think there is something wrong with the definition of bvw1. If I use dsolve (in soln) with only bvw as Initial Condition,
I get a solution but if I also insert bvw1 as an Initial condition soln won't appear.
Here's what's written in the image:
'Imagine the course of a planet around a star with L=0.5 and e=0.7'
Solve Keppler's differential equation with Initial Conditions:'
pendulums
Of course, in Maple. Source http://www.mmf.lnu.edu.ua/
I am making a mpl file which looks like below:
font_size := thickness = 4, font = [bold, "TimesNewRoman", 30], labelfont = [bold, "TimesNewRoman", 30], axis[1] = [thickness = 3], axis[2] = [thickness = 3], captionfont = [bold, "TimesNewRoman", 30], legendstyle = [font = [bold, "TimesNewRoman", 30]];
I  export it as mpl, but when I want to read it in a worksheet, I get the error below:
Error, on line 1, syntax error, character `?` unexpected:
<?xml version="1.0" encoding="UTF-8"?>
Error, while reading ``/Users/..../font_size.mpl``
This is just a simple mpl, I get this error for all mpl s that I want to read!
Can somebody help me with this please? It is really annoying :(
Remark from Markiyan Hirnyk.
The body of this question disappeared when I was editing its title only.
abc
bca
if starting position is at first position,
i have to write a very long substitution, and need a temporary variable t and t2
subs(t2=c,subs(t=a,subs(a=b,subs(b=t2,subs(c=t,a*b*c+a*b)))));
if starting position is at second position, it will be
abc
acb
is there any simple method to do this circular shift of variables for a polynomial
First 1208 1209 1210 1211 1212 1213 1214 Last Page 1210 of 2459
