I use Maple T.A. 10. I try to use StringTools[Search] in algorithm variables but have not succeeded. Any help would be appreciated.
Algorithm Variable definitions
$pattern1=maple('"sin(1/2*Pi)"');
$text1=maple('"sin(1/2*Pi)"');
$test1=maple("StringTools[Search]($pattern1,$text1)");
$test2=maple('StringTools[Search]($pattern1,$text1)');
give us the following result, whereas I expect the return value 1.
pattern1 "sin(1/2*Pi)"
text1 "sin(1/2*Pi)"
test1 com.maplesoft.server.router.MapleSyntaxException: on line 116, syntax error, `,` unexpected:
test2 module () local Testing, Bitmap, BF, SuffixArray, LyndonFactorPositions, CheckMaximalRepeat, slowLyndonFactors, SerialCorrelationCoefficient, ChiSquared, LongestCommonSubSequenceLength, PrintSentences, `difficult?`, matchMatrix2, _randperm, _permute, _config, trampoline, Sequitur, passign, defun, compressImpl, uncompressImpl; export Length, IsUpper, IsLower, IsAlpha, IsDigit, IsAlphaNumeric, IsControlCharacter, IsSpace, IsPunctuation, IsGraphic, IsIdentifier, IsIdentifier1, IsPrintable, IsASCII, IsHexDigit, IsOctalDigit, IsBinaryDigit, IsVowel, HasUpper, HasLower, HasAlpha, HasDigit, HasAlphaNumeric, HasControlCharacter, HasSpace, HasPunctuation, HasGraphic, HasIdentifier, HasIdentifier1, HasPrintable, HasASCII, HasHexDigit, HasOctalDigit, HasBinaryDigit, HasVowel, Has, ExpandCharacterClass, Random, Randomize, IndexOfCoincidence, Entropy, ArithmeticMean, Kasiski, Repeats, Explode, Implode, Chop, Chomp, Fence, MatchFence, PadLeft, PadRight, Centre, Center, Trim, TrimRight, TrimLeft, Squeeze, DeleteSpace, Reverse, Insert, Delete, IsPrefix, IsSuffix, CommonPrefix, CommonSuffix, LongestCommonSubString, LongestCommonSubSequence, Soundex, Metaphone, Levenshtein, HammingDistance, EditDistance, PrefixDistance, SuffixDistance, DifferencePositions, Compare, CompareCI, CamelCase, UpperCase, LowerCase, OtherCase, Capitalize, FirstFromLeft, FirstFromRight, Take, Drop, Snarf, CharacterMap, LeftFold, RightFold, Map, AndMap, OrMap, Char, Ord, SubString, Select, Remove, SelectRemove, Group, Split, CaseSplit, LengthSplit, StringSplit, Readability, Sentences, Words, WordStart, WordEnd, WordContaining, NGrams, SimilarityCoefficient, WordCount, Join, CaseJoin, RegMatch, RegSub, RegSubs, RegSplit, ApproximateSearch, ApproximateSearchAll, HammingSearch, HammingSearchAll, Search, SearchAll, Substitute, SubstituteAll, PatternDictionary, FormatMessage, FormatTime, ParseTime, Fill, Repeat, Iota, Visible, Escape, Encode, Decode, Compress, Uncompress, WildcardMatch, NumbOccur, CountCharacterOccurrences, Shift, Rotate, Exchange, Stem, Permute, SortPermutation, Sort, Unique, Hash, IsSorted, IsAnagram, Anagrams, SyllableLength, Generate, NthWord, Support, IsBalanced, IsSubSequence, IsPalindrome, IsEodermdrome, IsPermutation, IsDerangement, IsMonotonic, IsPrimitive, PrimitiveRoot, Border, BorderLength, BorderArray, Overlap, IsConjugate, MinimumConjugate, Period, IsPeriod, Fibonacci, ThueMorse, MonotonicFactors, LyndonFactors, LexOrder, ShortLexOrder, RevLexOrder, ShortRevLexOrder, LeftRecursivePathOrder, RightRecursivePathOrder, ToByteArray, FromByteArray, CharacterFrequencies, MaximalPalindromicSubstring, MinChar, MaxChar, Tabulate, StringBuffer, ExpandTabs, WrapText, Indent, PatternEquivalent, PatternCanonicalForm, GenerateIdentifier, _pexports; options package, noimplicit, `Copyright (c) Maplesoft, a division of Waterloo Maple Inc. 2005`; description "a package of string manipulation utilities"; end module(Search)("sin(1/2*Pi)","sin(1/2*Pi)")
I confirmed that one can use StringTools[Search] in the question source code as explained in http://www.maplesoft.com/support/help/MapleTA10/MapleTAInstructor/ch06s04.aspx#Chapter06_UsingMapleCodetoPreventCheatinginMapleSyntaxQuestions
maple=evalb(0=StringTools[Search]("factor","$RESPONSE")) and evalb($RESPONSE=factor(x^2-1))
I note that searchtext or SearchText procedures could be used instead in algorithm variables.
How I can sketch a line with equation (x-2)/3 = (y-1)/4 = (z-3)/3 in three dimentional space?
Hi experts,
attached the following code,, but i dont know what is the wrong with it, looking forward for helpful advise.
dsys :={diff(u(t),t)=-(N1+M*cos(2*I*omega*t))*u(t)-1+v(t)*exp(-2*I*omega*t)+w(t)*exp(2*I*omega*t), diff(v(t),t)=-(N1+I*Delta-2*M*exp(2*I*omega*t))*v(t)-(N1+u(t))*exp(2*I*omega*t)-2*M, diff(w(t),t)=-(N1-I*Delta-2*M*exp(-2*I*omega*t))*w(t)-(N1+u(t))*exp(-2*I*omega*t)-2*M}:
res:=dsolve(dsys union {u(0)=-1,v(0)=0,w(0)=0},numeric,output=listprocedure,maxfun=0):
plots[odeplot](res,[[t,(Re(w(t)))]],0..10,axes=boxed,titlefont=[SYMBOL,14],font=[1,1,18],color=black,linestyle=1,tickmarks=[3, 4],font=[1,1,14],thickness=2,titlefont=[SYMBOL,12]);
Warning, computation interrupted
Consider the following two functions:
f := (theta) -> (x) -> theta*x;
g := unapply(unapply(theta*x,x),theta);
I would have expected f and g to behave identically. Apparently I am wrong, though:
f(phi)(x),
g(phi)(x);
But why? If the functions were alternatively defined as
f := (theta,x) -> theta*x;
g := unapply(theta*x,theta,x);
using unapply only once, then they would behave identically. But that is not quite what I want: I would like to have parameter-valued procedures of a single parameter, not (parameter-less) procedures of two parameters.
Can anyone please suggest a way to set the zoom factor for a 3D plot from the plot commands or using DocumentTools or in some other way that doesn't involve the interactive tools?
What I'm trying to achieve is the following:
I'm developing MapleCloud worksheets for a course I'm teaching and want to give my students several 3D plots to interact with through their web browser.  When I make the plots, Maple determines the scaling so that boxed axes with labels will fit in the area of the plot component.  However, I'm making plots with axes=none that look better at a higher zoom factor (the corners of the unseen boxed axes would be out of the plot area but all the plot components still fit) and I'm keen to create the plots that look like this if possible.
My ideal solution would be for there to be a zoomfactor option for the plots[display] command or to be able to use some code like SetProperty("Plot0",zoomfactor,1.25) but I haven't been able to find a way to achieve this.  The closest I found was setting the viewpoint option, but that locked the view, preventing rotation, and I want to just set the initial view.  Is there some other method I haven't found?
Thank you for your help,
Alex
In order to improve the readability of a worksheet, I would like to insert in text lines the equations that I calculate after with a input maple.
Question:
Is it possible to add in a text line equations and symbols as we can make with Latex or MathType ? For example, i would be interested to write vectors in a text line.
Thank you for your help.
I get the maple result as a product and sum off terms
x= (a+b*c)/d
i want to convert it to
x= a/d+b*c/d
i try to use convert(x,?)
I am trying to find a general solution to the 1D-wave equation
Eq1:=diff(u(x,t),t$2)=diff(u(x,t),x$2);
pdsolve(Eq1,HINT=f(x)*g(t)); # Hinting pdsolve gives general solution using separation of variables
pdsolve({Eq1,u(x,0)=f(x),D[2](u)(x,0)=g(x)}); # without HINT and using intial conditions, I get travelling wave solution
pdsolve({Eq1,u(x,0)=f(x),D[2](u)(x,0)=g(x)},HINT=f(x)*g(t)); # Now when I try to use hint and ICs both, pdsolve return nothing.
I want to use separation of variables to find solution to the wave equation.
Any comment?
A := Vector([1, 2, 3])
solve(2*A = 5+x, {x})
can anyone help me why i am having proble to solve for x?
It returns unevaluated.  The solution is x=-ln(3),y=0.  In fact it doesn't give a solution even if the solution is provided as the initial point.  The value of Digits doesn't seem to make a difference.
(Tested Maple 2015.2 Macintosh and Maple 2015.1 Linux)
I am new to maple. If i have a vector from 0 to 1000 every 10 step (in matlab it is sth like this x=0:10:1000) can anyone help me how to do this in maple?
Salut j'ai fait un programme avec maple   pour minimiser une fonction à deux variable avec la méthode de fletcher reevers car la fonction minimize ne marche pas avec les fonction plus compliqué.
SP veuillez voir mon programmme et essayer de le corriger car la boucle while ne marche pas:
test.mwtest.mw
Cordialement:
Hi everyone
When I solve these nonlinear ODEs, there is this problem i.e. Highlighted in yellow, in my solution. How can I solve it?
thanks a million!
nonlinear_ODE.mw
Does any one know if you can extract the linear graph from a Maple Sim model?  And by linear graph I mean the alternative to a a bond graph, not a type of plot.
First 1191 1192 1193 1194 1195 1196 1197 Last Page 1193 of 2459
