How can I compute F from G according to the following text? (I implemented this but I need a more efficient implementation.)
Given a set G of polynomials which are a subset of k[U, X] and a monomial order with U << X, we want to comput set F from G s.t.
1. F is subset of G and for any two distinct f1, f2 in F , neither lpp (f1) is a multiple of lpp (f2) nor lpp (f2) is a multiple of lpp (f1).
2. for every polynomial g in G, there is some polynomial f in F such that lpp (g) is a multiple of
lpp (f ), i.e. ⟨lpp (F )⟩ = ⟨lpp (G)⟩,
It is worth nothing that F is not unique.
Example:  Let us consider G = {ax^2 − y, ay^2 − 1, ax − 1, (a + 1)x − y, (a + 1)y − a} ⊂ Q[a, x, y], with the lexicographic order on terms with a < y < x.
Then F = {ax − 1, (a + 1)y − a} and F ′ = {(a + 1)x − y, (a + 1)y − a} are both considered set.
please not that K[U,X] is a parametric polynomial ring (U is e sequence of parameters and X is a sequence of variables).
lpp(f) is leading monomial of f w.r.t. variables X. For example lpp(a*x^2+b*y)= x^2.
Is there any Maple command for computing the product of two set A and B?
For example if A={a,b,c} and B={x,y} then we have A*B={ax,ay,bx,by,cx,cy}.
I have two regimes. Each regime is characterized by system of state differential equations (diff(S(t), t), diff(K(t), t)) and co-state differential equations (diff(psi[S](t), t), diff(psi[Iota](t), t)) as follows:
diff(S(t), t) = -eta*K(t)*S(t)/(w*N*(S(t)+K(t))), diff(K(t), t) = eta*K(t)*S(t)/(w*N*(S(t)+K(t)))-upsilon
diff(psi[S](t), t) = eta*K(t)^2*(psi[S](t)-psi[Iota](t))/(w*N*(S(t)+K(t))^2), diff(psi[Iota](t), t) = eta*S(t)^2*(psi[S](t)-psi[Iota](t))/(w*N*(S(t)+K(t))^2)
The first regime is employed from 0 to t1 (where t1 is unknown) and then regime 2, from t1 to T. I know the initial values for the state variables of the first system at t=0, that is, S(0)=S0 and K(0)=K0, as well as boundary conditions for the co-state variables for regime 2 at t=T, that is, psi_S(T)=a and psi_I(T)=b.
I also know that my unknown t1 should satisfy the algebraic equation: -c - psi_S(t1)=0, where psi_S(t1) is the solution of the co-state diff equation of the regime 2 at t=t1.
My question is: If I assume that the systems have not analytical solution, how can I found unknown t1 numerically? Moreover, asssume that all other parameters, such as T, eta, upsilon and others are given.
I’m using Maple 2015.2 to plot irregular spaced data using the surfplot command. The shape of the plot is as expected, however I’ve been unsuccessful in changing the color of the surface. I would like the surface to be a consistant color instead of the “rainbow” color scheme. I’ve tried both the color and colorscheme options to no avail.  I’m sure I’m making a very basic mistake, however I’m having difficulty finding it.
See attached worksheet
 feildstrength.mw
Best regards,
Ron
[EDIT]: Worksheet didn't attach the first time
why is simplify is making errors - me or maple?
Ec := (1/2)*Kc*(2*Pi*h0/Pi(a0^2+h0^2)-2*Pi*h/Pi(a^2+h^2))^2;
1 / 2 Pi h0 2 Pi h \
- Kc |------------- - -----------|
2 | / 2 2\ / 2 2\|
\Pi\a0 + h0 / Pi\a + h //
simplify(%);
2 Kc (-h0 + h)
Simplify is erasing the varibles a0 and a. Is there a secret to using simplify?
In Maple 2015.1 we have
solve([sin(2*x)/cos(x+3*Pi/2)=1,  x>-4*Pi, x<-5*Pi/2], x, allsolutions, explicit);
solve([sin(2*x)/cos(x+3*Pi/2)=1, x>0, x<2*Pi], x, allsolutions, explicit);
In the first example, the error message is not clear (actually there exists a unique root  x=-11*Pi/3), in the second example, one root  (x=5*Pi/3) is lost.
I am trying to write
D= d/dx + y1*d/dy + y*y1/x*d/dy1
So that I can apply D to some function L(x,y)
But I don't know how to write the derivative like this without them operation on a function. Can somebody help me?
I've got this huge chunk of code which leads to an optimiazation at the very last line (Bestangles:=minimize(maximize()-minimize))). This minization is taking a very long time (havent solved it yet) and I would very much like to reduce that time. As I've understood maple does optimization by differentiating and then finding all extremes and comparing. Would this mean that since I minimize and optimize within a minimization command, it differentiates a ton of times? And if this is the case, can I somehow do the differentiation beforehand, since it is the same function being differentiate all the time? Or is there some other way I can improve the code?
Thanks alot!
Heres the full code:
I am very beginner about Maple. How to get the general solution from the follwoing equations by Maple. Please help me. Its Urgent. Please help me out.
why the the software can't plot the function like x^(4/3)*sin(1/x) or x^(1/3)
it could only plot where x>0,but the value is does exist where x<0.
Thanks in advance for your help.
If I have an N-dimensional vector V and a polytope defined as the set of solutions to the equation A*x = b, where A is a d X N matrix, and b is a d X 1 vector, how can I project V onto the surface defined as above?
Consider a taper steel plate of uniform thickness t := 25mm as shown in the Fig. In addition to its self weight, the plate is subjected to a point load P := 100N at its mid point. Find the global force vector [F] , global stiffness matrix [K] , displacement in each element (1 and 2) , stresses in each element  (1 and 2) and reaction force at the support.Take E := 2*10^5N/mm2; rho := 8.2*10^(-5)kg/m3;
t__1 := 150:
t__3 := 75:
w := 25:
l := 600:
t__2 := (t__1-t__3)/l*((1/2)*l)+t__3 = 225/2
A__1 := t__1*w = 3750``
A__2 := t__2*w = 5625/2``
A__3 := t__3*w = 1875``
Revised areas:
A__1e := (A__1+A__2)*(1/2) = 13125/4``
A__2e := (A__2+A__3)*(1/2) = 9375/4``
  E := 2*10^11:m2; F__1 := R__1:is support reaction N; F__2 := 100:N;``
rho__1 := 82*10^(-6) = 41/500000  N/mm2
rho__2 := 82*10^(-6) = 41/500000 N/mm2
l := 600:``
Number of elements,
n__e := 2:
l__e := 300 = 300````
q__0 := 100:N/m ; l := 1: m; n__e := 4:  elementsl  l__e := l/n__e: m;
We shall consider a two element system as shown in the Fig.
For element 1 Stiffness matrix K is
                                           Vector[row](2, {(1) = 1, (2) = 2})
K__1 := A__1e*E/l__e.(Matrix(2, 2, {(1, 1) = 1, (1, 2) = -1, (2, 1) = -1, (2, 2) = 1})) = Matrix([[2625000000000000, -2625000000000000], [-2625000000000000, 2625000000000000]])  Vector(2, {(1) = 1, (2) = 2})
For element 2 Stiffness matrix K is
                                         Vector[row](2, {(1) = 2, (2) = 3})
K__2 := A__2e*E/l__e.(Matrix(2, 2, {(1, 1) = 1, (1, 2) = -1, (2, 1) = -1, (2, 2) = 1})) = Matrix([[1875000000000000, -1875000000000000], [-1875000000000000, 1875000000000000]])  Vector(2, {(1) = 2, (2) = 3})
Global stiffness matrix obtained by adding all the elemental stiffness matrices and given b
           Vector[row](3, {(1) = 0, (2) = 0, (3) = 0})
K__g := Matrix(3, 3, {(1, 1) = K__1[1, 1], (1, 2) = K__1[1, 2], (1, 3) = 0, (2, 1) = K__1[2, 1], (2, 2) = K__1[1, 2]+K__2[1, 1], (2, 3) = K__2[1, 2], (3, 1) = 0, (3, 2) = K__2[2, 1], (3, 3) = K__2[2, 2]}) = Matrix([[K__1[1, 1], K__1[1, 2], 0], [K__1[2, 1], K__1[1, 2]+K__2[1, 1], K__2[1, 2]], [0, K__2[2, 1], K__2[2, 2]]])  Vector(3, {(1) = 0, (2) = 0, (3) = 0})
For element 1 Load matrix F is
  F__1e := (1/2)*`&rho;__1`*A__1e*l__e*(Vector(2, {(1) = 1, (2) = 1})) = Vector[column]([[861/25600], [861/25600]]) Vector(2, {(1) = 1, (2) = 2})
For element 2 Load matrix F isNULL
F__2e := (1/2)*A__2e*l__e*`&rho;__2`*(Vector(2, {(1) = 1, (2) = 1})) = Vector[column]([[123/5120], [123/5120]])
Download wrong_answers.mwwrong_answers.mwwrong_answers.mw
Ramakrishnan V
rukmini_ramki@hotmail.com
Greetings all,
I was wondering if any Maple users out there are using the lastest Microsoft tablet, the Surface Pro 4 with Maple?
I would be interested in any opinions and specifically if the pen is effective when used as an input device with Maple
hello everyone
can any one tell me what is this anti reduction method. In the paper of serdal palmuk,the link is given bellow
http://www.hindawi.com/journals/mpe/2009/202307/
in this paper question #4 is first solved by anti reduction method for  exact solution.
but i dont understand this method,
if anybody know this then please also tell me how to solve this,
and in the next  (6 & 7 ) examples "in the pourus media equation" they first find its particular exact solution.i also dont understand this,so please tell me
actually i know how to solve ODE to find its exact solution but  i dont know how we find exact solutions of partial differtial equations,
so please help me to solve this problem
First 1233 1234 1235 1236 1237 1238 1239 Last Page 1235 of 2472
