hi all
i have a plot and i want  make it symmetry into axes y.
I5:=Int((x^2)/((x^4-2*x0*x^2+x0^2+1)^(3/2)),x=0..infinity);
I6:=(1/2)*Int(1/(x^4-2*x0*x^2+x0^2+1)^(1/2),x=0..infinity);
f:=((-4/Pi)*((x0*I6-I5)/(x0*I5+I6)^(1/3)));
A:=1/(x0*I5+I6)^(2/3): #A:=Delta/eF
plot(A,x0=-3..5);
I am trying to find the roots of Hankel function H1(2, z)?
j := 1;
for i from 0 to 10 do z0 := i*step+z_min; x[j] := fsolve(f = 0, z = z0, complex) end do;
for p to 10 do for j from p+1 to 9 do if `and`(Re(x[j])-Re(x[p]) < 0.1e-4, Im(x[j])-Im(x[p]) < 0.1e-4) then for i from j to 10 do x[i] := x[i+1] end do; p := p-1; break end if end do end do;
the first of these two processes works fine however the second does not. The second on is to get rid of same value solutions! I am not sure if I have missed anything and also is there a way to determine a max value in the complex domain and use it in a for loop?
any help would be great
hi all
i have tow plots and i want to display them together, but i cant, plz help me
B:=x0/(x0*I5+I6)^(2/3): #B:=mu/eF
C:=B/((16/Pi^2)*((x0*I6-I5)^2/(x0*I5+I6)^(2/3))): #C:=mu/epsilon0/2
p1:=plot(B,x0=0..4):
p2:=plot(C,x0=-3..0):
display({p1,p2},x0=-3..4);
After reading
http://math.stackexchange.com/questions/674535/avoid-dividing-by-zero-with-just-variables-and-basic-operators
I tried to check this 'trick' in maple, but see what happens in Maple 2015:
 what is the correct solution for 0^0?
Here the code for those who hate typing:
x := 0; 0^(x^2);
for x from -1 to 1 do print(x, evalf(0^(x^2), 20)) end do;
-1, 0.
0, 1.
1, 0.
for x from -1 by .1 to 1 do print(x, evalf(0^(x^2), 20)) end do;
-1, 0.
-0.9, 0.
-0.8, 0.
-0.7, 0.
-0.6, 0.
-0.5, 0.
-0.4, 0.
-0.3, 0.
-0.2, 0.
-0.1, 0.
0., Float(undefined)
0.1, 0.
0.2, 0.
0.3, 0.
Harry
Hello all! How to create this plot in Maple?
hi all
how can i solve this program?
I5:=evalf(int((x^2)/((x^4-2*x0*x^2+x0^2+1)^(3/2)),x=0..infinity)):
I6:=evalf((1/2)*int(1/(x^4-2*x0*x^2+x0^2+1)^(1/2),x=0..infinity)):
A:=f-evalf((-4/Pi)*((x0*I6-I5)/(x0*I5+I6)^(1/3))):
B:=solve(A,x0);
I am attempting to write a Gaussian elimination routine to solve a system Ax = b using loops, but I have been having trouble.  Any help would be mcuh appreciated.  Thanks!
I'm writing a code and I seem to have an issue when trying to implement a procedure. Here is the code:
Z := 75; A := 189; k := 14.6; Rm := 8*R; r0 := 10^(-8)*R; c := 137.036; ms := 105.66/(.51100)
fmtoau := 10^(-15)/(0.529177e-1*10^(-9)):
R := 1.1*fmtoau*A^(1.0/(3.0)):
f := proc (x) options operator, arrow; 1/(1+exp(k*(x-1))) end proc:
n0 := 3*Z*k^2/(4*Pi*(Pi^2+k^2)*R^3):
n := proc (r) options operator, arrow; 4*Pi*n0*f(r/R) end proc:
int(r^2*n(r), r = 0 .. Rm);
73.00000007
plot(n/n0, 0 .. 2*R);
v1 := unapply(int(x^2*f(x), x), x):
Vfermi := proc (r) options operator, arrow; -4*Pi*n0*R^2*(R*(v1(r/R)-v10)/r+v2Rm-v2(r/R)) end proc:
Vuniform := proc (r) options operator, arrow; piecewise(r < R, -Z*(3/2-(1/2)*r^2/R^2)/R, -Z/r) end proc:
plot([Vuniform(r), Vfermi(r), -Z/r], r = r0 .. 2*R, V = 1.2*Vfermi(r0) .. 0, legend = ["uniform charge", "Fermi distribution", "point charge"]);
plotsol1s := proc (E, K, r0, S, col) local Eqns, ICs, fnl, gnl, r, soln; global ms, c; Eqns := diff(fnl(r), r) = gnl(r)*[E+2*ms*c^2-Vuniform(r)]/c-(K+1)*fnl(r)/r, diff(gnl(r), r) = -fnl(r)*[E-Vuniform(r)]/c-(1-K)*fnl(r)/r; ICs := fnl(r0) = 1, gnl(r0) = 0; soln := dsolve({Eqns, ICs}, numeric); plots:-odeplot(soln, [r, fnl(r)], r0 .. S, color = col) end proc:
plotsol1s(-3*10^5, -1, 10^(-10), Rm, red)
Error, (in f) unable to store '[HFloat(0.0)]' when datatype=float[8]
Any help would be greatly appreciated.
Gambia Man
i got UI interface error when i install maple 15 into intel compute stick in window 8.1
It seem absurd that in Maple 18, why int(f(t),t) do not work instead one have to write Int(f(t),t) for indefinite integration?
I'm from Vietnamese. My English is not very good :D I have a question about tubeplot in maple. Can you give me a form of tubeplot? I read it in the MapleHelp, but I don't really understand. Example:
y:=x^2+x-1. tubeplot y. create a plot, limit by y, x=1,y=5,around Oy .
Can you hepl me? Thanhks you so much!
I have a problem, to which I think the solution is to make ln(x) inert.  I'd like to be able to enter the following
diff(1.5^x,x);
and get back
ln(1.5)1.5^x
But of course Maple returns
It seems to me that if I could make ln(x) inert for that might work, but I don't really know much about the ToInert command.  Or maybe this isn't the right approach.
Please help me to solve EQ in attached file.
I need amount of P.
Is there a command in Maple that directly divides one equation by another and produce the result as one equation directly? I wanted to verify the text book, where it says
      x^2-y^2 = a*z^2   ----- (1)
      x-y          = a*z       ------(2)
dividing (1) by (2) gives
      x+y = z  ---(3)
So I typed this in Maple:
eq1:=x^2-y^2=a*z^2;
eq2:=x-y=a*z;
But now what to do? I can see the answer in book is correct by doing
   solve( {eq1,eq2}, {x,y} );
And adding the solution given above, which shows it is z indeed.  But I'd like to get Maple to generate equation (3) above automatically.  Is this possible?
Maple 2015, windows 7
I was looking for help on polynomial division using Maple via google. But I am having hard time deciphering this web page on quo command. Is this syntax supposed to work on some Maple version?
http://www.maplesoft.com/support/help/Maple/view.aspx?path=Task/QuoAndRemOfPolynomialDivision
I also do not understand how the polynomial and the divisor are "entered" without it being assigned to variables like this. I thought it was the browser, but  I tried both Chrome and Firefox and they both show the same page.
Is the above using some new Maple product? I am using Maple 2015 on windows and I get an errors trying to type the above on my Maple worksheet.
First 1239 1240 1241 1242 1243 1244 1245 Last Page 1241 of 2459
