Hey.
I just got this document and can't seem to open it as a .mv file - I tried to attatch it here, but it wouldn't let me for some reason, so I saved it as a .txt and attatched it instead. Is my file broken, and if so, is there any sort of tool to fix it?
Let x and y be 4-digit integers such that the last digit of x is 7 and the last digit of y is 1. That is, x = abc7 and y = rst1, where a,b,c,r,s,t all run from 0 to 9. There are 1000 possibilities for x and  1000 for y. What are all possible products x*y? I would like all possible products listed in increasing order. The first element of the list should be 7*1 = 7 (since 0007*0001 = 7). The last should be 9997*9991 = 99880027. Thank you!
hi all
i have a plot in maple. how can i print the maximum point of my plote?
hi friends
i have a question and i could find the answer in existing questions but it was not clear at all!!!
i want to label my contours and i know that i should use lebelledcontourplot command.
But how?!
i could find an answer:
"1- First download the files located on his webpage.  Advisor6.zip    It should be zipped with 3 files in it.
2 - Unzip them and copy them into a directory which you name, probably somewhere in the maple directory named advisor.  c:\maple12\advisor
3 - Then create a maple.ini in the maple12 directory with the following line to match your directory location
libname:= `c:/maple12/advisor`, libname:  just like on the instruction installation page."
these are my questions:
1-how can i create a maple.ini?!
2-what should i do with the file i will create?
please explain more about the third phrase and explain exactly what should i do step by step.
thanks a lot
Let B=be a list.
How can I sort B as BB=?
I need to solve the Bending Vibration of Euler-Bernouli Beam Problem and I keep getting stuck. I start with a fairly straight forward fourth order differential eq. Using the dsolve command gives me the general solution
Y(x)=A*sin(a*x)+B*cos(a*x)+C*sinh(a*x)+D*cosh(a*x)
Maple insist on using e^(x)+e^(-x) instead on sinh and cosh - but it's the same. So far so good.
My specific problem is a clamped-pinned beam of length l - so my boundary conditions are (correct me if I'm wrong here):
In the clamped end at x=0: Y(0)=0, Y'(0)=0
In the pinned end at x=l: Y(L)=0, Y''(0)=0
Using both the dsolve(ode,ics) and a dsolve(ode) and then solve(ics) both results in the trivial solution Y(x)=0 - which is wrong - I know there is a tan(a*l)-tanh(a*l) solution.
To get a easier and well documented example to solve by hand, I also tried with a simply supported beam. Boundary conditions are then:
Y(0)=Y(l)=0
Y''(0)=Y''(l)=0
Same result - only the trivial solution Y(x)=0 and If you solve it by hand you get a sin(a*l) solution.
What am I doing wrong? Is it syntax error on my part or what?
I have attached both my maple doc and a pdf with a walkthrough of the correct solution.
Beam_vibration.mw Transverse_vibration_of_beams.pdf
Any help would be appreciated
Kind regards
Jacob
and plot  function I? This I is the area which I wrote at the paper.
Could you give me the code which can be used to solve the ODE by numerical method and plot I with respect to t?
I think I have write down everything clearly but if you feel confused please ask me.
I am eager to know the code. Thanks very much!
Hi all
I want to analysis this beam  (a simple and a tip rotational spring) in Maple to find the first four Frequencies...
Please help me
Need help for manipulating tensor with the physics package.
I ask some questions about this.  But each time, I am refer to the help pages.  If I ask again some help, it is because I can't not start with the information on the help file.  It is written for people that already know General Relativity (GR).
So this time, I have created a document (attach to this post) where I ask specific queations on manipulations.  My goal is to ccrreate a document that I will put on the Applications Center.  I promess that those who will help me on this will be cited in the document.  This way, I hope to create an introduction on how to use tensors for beginner like me.
Then, with this help, I am sure I will be able to better understand the help page of the packages.  I am doing this as someone who is starting to learn GR and have to be able to better understand the manipulations of tensor and getting the grasp of teh meaning of all those tensor.  For exemple, the concept of parallel transport on a curve surface.
Thank you in advance for all the troubling I give you with this demand.
Regards,Parallel_Transport.mw
Mario Lemelin
Maple 2015 Ubuntu 14.04 - 64 bits
Maple 2015 Win 7 - 64 bits messagerie : mario.lemelin@cgocable.ca téléphone :  (819) 376-0987
I using Maple 18.
I write below procedure,
Eqplot:=proc(a,b)
local y,x;
y:=a*x+b;
y,plot(y,x);
when I use Eqplot(2,3) , then I will expect the result for both of equation 2x+3 and sketch y=2x+3, but unfortunately the result is only sketch y=2x+3.
please hint me about that how I can write a proc that result be both of 2x+3 and sketch 2x+3 in maple 18?
This may sound funny, but I cannot put the ruler on the sides of my worksheet!
I need t so change the size of my plots.
Does anybody know in which menu is the ruler ?
I'm relatively new to using Maple.
I'm looking for information on how the "factor" function works. I printed its definition, and it refers to "factor/factor" and I can't find any more information on this. I'd like to know so that I could have more trust that it works correctly. Specifically, I'd like to be able to believe that if it does not factor a cubic, then the cubic is irreducible.
I'm specifically looking for rational roots of cubic polynomials. The "solve" function seems to work, and gives me the roots in terms of square roots, cubic roots and rationals. I have no idea why I should believe that "type(x,rational)" would work when the description of "x" is quite complicated.
Does anyone know anything about how "factor" works, or how "type" works when testing whether an expression evaluates to a rational number? Any information would be much appreciated.
Matt
How would you apply a permutation to a list?
So, with permutation [[1,3],[2,4]], given in disjoint cycles,
how would you apply it to [1,2,3,4] to obtain [3,4,1,2]?
Perhaps the question is trivial, but I could not find the solution.
I am solving numerically an ODE (e.g., a simple harmonic oscillator) with the righthand side that contains a random part. For example it is
eq:=diff(a(t),t,t) + a(t) = (1+0.01*R(t))*cos(5*t);
where R(t) is a random function of t. How can I make such a function?
The naive attempt:
eq:=diff(a(t),t,t) + a(t) = 3.*(1+0.1*rand()/1000000000000.)*cos(5.*t);
gave me a fixed (while random) value, e.g.
But, I need this coefficeint to be random each time step.
Any suggestions are very welcome!
First 1240 1241 1242 1243 1244 1245 1246 Last Page 1242 of 2459
