Hi. I have this strange error.
Whenever I type D(f)(x) into the maple prompt, the program adds a whitespace between D(f) and (x), so I get the wrong output. I have to go back and delete the space manually. Here is a picture. http://prntscr.com/8vji4k
I type 'D(f)(x)'  and the software displays 'D(f) (x) ' in the prompt, with the extra space.
I am using maple 2015 if that helps, but I think I had the same error with Maple 18
I did not add a space. I literally just entered f:=x->x^2 -3*x + 2; D(f)(x)
but the computer adds a space as I type D(f)(x).
Also I'm not sure why the space ruins the expression
What i am supposed to get is  ' 2x - 3 '
I used to convert the expression to latex code and copy the code to MathType, the insert the expression.
Is there any easier way?
I want the expression I inserted is modifiable, so copy from Maple and paste to Word is not what I want.
Are there any examples of network solutions such as mine systems in Maple.
I wrote in the Maple system of partial differential equations describing the process of filtration combustion.
I'm a novice. I do not quite understand how to solve it.
Online a lot of "simple" examples. I need something very similar to my case.
Model03.mw
How I can write a procedure in Maple that return a equation of line that passes of two points (a,f(a)) and (b,f(b)) on the curve y=f(x) and the final plot y=f(x) and secant line in the same screen?
How I can highlight p(1,1) and Q(2,4) on the curve f(x)=x^2?
I´ve got 2-dimensional array (100x100) of values, which I'd like to plot as 3d graph, where x,y axis would be coords in the array and z-axis would be the value there.
Values are formed by procedure, not by function, so I can't use standard 3d plot, that plots a 3d surface. I think the best is to use the pointplot3d function, but you have to assign each point separately.
I tried to create a list of pointplot3d plots, one for each row of the array, and then display these plots all in one, but I just received GLException error.
Do you have any ideas?
hi all
how can i solve these contemporaneous:
eq1:=(1-Pi*x/2)*(f/2/E)*yc-1/3=Int(t^4/sqrt((t^2-(f/2/E)*yc)^2+ya^2),t=0..1);
eq2:=x^2*yc*(1-Pi*x/2)-1/3=Int(t^4/sqrt((t^2-x^2*yc)^2+ya^2),t=0..1);
for like x=-3.  and f,E are concern.
thank you
Social Golfer Problem
So we have 8 golfers : 2 golfers per group and 4 groups.Over several golfing days, how can they be arranged so no golfer plays with the same player twice.
turns out they can play for 7 days.
So my attempt in maple....golfing.mw
For 3 players per group and 4 groups this is the arrangement over 4 days:
(these was done in wolfram demonstrations project but the code appears to be obfuscated)
have eroror when run command below
animate(dualaxisplot(plot(sin(x+A), x=0..5), plot(cos(x+A), x=0..5), style = line, gridlines = false), A = 0 .. 5);
Dear collagues
I write a code to solve a system of ODE. It solve the ODES in a wide range of parameters but as I decrease NBT below 0.5, it doesnt converge. I do my best but I couldn't find the answer. Would you please help me? Thank you
Here is my code and it should be run for 0.1<NBT<10. the value of NBT is input directly in res1.
EPSILONE:=1000:
Digits:=15:
a[mu1]:=5.45:
b[mu1]:=108.2:
a[k1]:=1.292:
b[k1]:=-11.99:
rhop:=4175:
rhobf:=998.2:
mu1[bf]:=9.93/10000:
k1[bf]:=0.597:
rhost(eta):=1-phi(eta)+phi(eta)*rhop/rhobf;
k:=unapply(k1[bf]*(1+a[k1]*phi(eta)+b[k1]*phi(eta)^2),eta);
eq1:=(diff(u(eta), eta))*a[mu1]*(diff(phi(eta), eta))+2*(diff(u(eta), eta))*b[mu1]*phi(eta)*(diff(phi(eta), eta))+((diff(u(eta), eta))+(diff(u(eta), eta))*a[mu1]*phi(eta)+(diff(u(eta), eta))*b[mu1]*phi(eta)^2)/(eta+EPSILONE)+diff(u(eta), eta, eta)+(diff(u(eta), eta, eta))*a[mu1]*phi(eta)+(diff(u(eta), eta, eta))*b[mu1]*phi(eta)^2+1-phi(eta)+phi(eta)*rhop/rhobf:
eq2:=(1+a[k1]*phi(eta)+b[k1]*phi(eta)^2)*(diff(T(eta), eta))/(eta+EPSILONE) + (a[k1]*(diff(phi(eta), eta))+2*b[k1]*phi(eta)*(diff(phi(eta), eta)))*(diff(T(eta), eta))+(1+a[k1]*phi(eta)+b[k1]*phi(eta)^2)*(diff(T(eta), eta, eta));
eq3:=diff(phi(eta),eta)+phi(eta)/(N_bt*(1+gama1*T(eta))^2)*diff(T(eta),eta):
eq2:=subs(phi(0)=phi0,eq2):
eq3:=subs(phi(0)=phi0,eq3):
eval(dsolve({eq3,phi(1)=phiv},phi(eta)),(T)(1)=1):
Phi:=normal(combine(%)):
Teq:=isolate(eval(eq2,Phi),diff(T(eta),eta)):
ueq1:=eval(eq1,Phi)=0:
ueq2:=subs(Teq,ueq1):
lambda:=0;
Ha:=0;
N_bt:=cc*NBT+(1-cc)*0.8;
kratio:=k1[p]/k1[bf]:
GUESS:=[T(eta) =0.0001*eta, u(eta) =0.1*eta, phi(eta) = 0.3*(eta-1)^4];
res1 := dsolve(subs(NBT=0.48,gama1=0.2,phiv=0.06,{eq1,eq2,eq3,u(0)=lambda*D(u)(0),D(u)(1)=0,T(0)=0,phi(1)=phiv,T(1)=1}), numeric,method=bvp[midrich],maxmesh=4000,approxsoln=GUESS, output=listprocedure,continuation=cc):
G0,G1,G2:=op(subs(subs(res1),[phi(eta),u(eta),diff(T(eta),eta)])):
masst:=evalf(int((1-G0(eta)+G0(eta)*rhop/rhobf)*G1(eta), eta = 0..1));
heatt:=(1+a[k1]*G0(0)+b[k1]*G0(0)^2)*G2(0);
plots:-odeplot(res1,[[eta,T(eta)]],0..1,legend=[T],color=["Black"],linestyle=Solid,axes=boxed,thickness=3);
plots:-odeplot(res1,[[eta,u(eta)]],0..1,legend=[u],color=["Black"],linestyle=Solid,axes=boxed,thickness=3);
plots:-odeplot(res1,[[eta,phi(eta)]],0..1,legend=[phi],color=["Black"],linestyle=Solid,axes=boxed,thickness=3);
Amir
I know this has been dealt with before here, but I have forgotten the proper way to trim a small imaginary round-off from a result. I cannot locate the proper answer in MaplePrimes; and the Mapledocs are either quiet about it or it is hidden in a difficult-to-find place.
What I want is to ignore ny imaginary part below a certain threshold. Ideally, it takes the threshold in relation to the real part but I am not particular about this.
Thanks in advance,
Mac Dude
Thanks to help me to plot my result of dsolve for different values of a parameter.
With plots:-animate, I get one curve according to one value of the parameter. But, I need all curves in the same figure.
ws1.mw
If for example I type :
`assuming`([dsolve({-7 = a(x)^2*b(x), a(x) = 3*b(x)}, {a(x), b(x)})], [(b(x))::real])
It gives out this :
I want dsolve to know I'm using real numbers so it gives out something like :
[{a(x) = -21^(1/3)}, {b(x) = (-21^(1/3))*(1/3)}]
I tried some assumptions and stuff like assume(a,real), but I didn't manage to figure it out.
If that matters, I'm using Maple 18 student.
EDIT : I know dsolve is not necessary for this particular example, but I want to know if it's possible with dsolve or maybe an other tool that can handle ODE.
Thank you in advance !
 Maple code when open saved maple sheet?
and keep it can run code and show latest result after open
i mean user can not extend or find code or display code in maple sheet , just can run result
Hello all
I am trying to write  a tutorial about systems of linear equations, and I want to demonstrate the idea that when you have a system of 3 euqtions with 3 unknowns, the solution is the intersection point between these planes. Plotting 3 planes in Maple 2015 is fairly easy (you plot one and just drag the others in), but I don't know how to plot the intersection point. Can you help please ?
My equations are:
x-2y+z=0
2y-8z=8
-4x+5y+9z=-9
The intersection point is (29,16,3)
Thank you !
First 1244 1245 1246 1247 1248 1249 1250 Last Page 1246 of 2459
