with(RegularChains);
with(ConstructibleSetTools);
source1 := PolynomialRing([a, b, c, d]);
target1 := PolynomialRing([e1, e2, e3, e4]);
source1list := [eq2a, eq3a, eq4a, 0];
target1list := [eq2b, eq3b, eq4b, eq5b];
cs := PolynomialMapPreimage(target1list, source1list, source1, target1)
return
cs := constructible_set
then i type
Elements(constructible_set)
it return
 since source has less number of variables, in order to use this function
i add a dummy variable d to this and use 0 for the fourth equation
dsol := dsolve([eq2=diff(s(t),t), eq3=diff(s(t),t), eq4=diff(s(t),t)], [a(t),b(t),c(t)]);
eval(subs(t(t)=t,subs(_C1(t) = _C1, subs(_C2(t) = _C2, subs(_C3(t) = _C3, sol1)))));
after subs t(t) = t , it still  have t(t)
hello all
i have two equations
(1-pi*x/2)*(f/2/E)*yc-1/3=int(t^4/sqrt((t^2-(f/2/E)*yc)^2+ya^2),t=0..1);
x^2*yc*(1-pi*x/2)-1/3=int(t^4/sqrt((t^2-x^2*yc)^2+ya^2),t=0..1);
i want to plot ya and yc vs. x that x change beetwin -3..3 in some steps like 100 steps. and another members like E can be any number.
i think maby i shoud use loop! but i dont know how!
plz help me
I want to plot two density functions of norm(1,1) and norm(4,1) in one figure.
But it appears the function DensityPlot can only plot one at a time.
The downloaded worksheet below displays 3 points on the unit sphere which define a solid angle with a triangular face. The sides of the solid angle's are red arcs on the surface of the sphere and red radii which outline the planar sides within the sphere.
Three questions:
1. Is there a way to make the surfaces of the solid triangle more apparent by filling them with color?
2. Is there a way to calculate the area of the face on the surface of the sphere?
3. Is there a way to calculate the volume of the solid triangle?
Download Mechanics;_irregular_solid_angle.mw
I am trying to solve system of partial differential equation, but i got some trouble. This is system of heat equations
Here are the equations:
restart;with(PDEtools):
U1 := diff_table(u1(x,t)):
pde[1] := (1/kappa1)*U1[t]=U1[x,x];
bc[1]:=u1(-L, t)=V;
U2 := diff_table(u2(x,t)):
pde[2] := (1/kappa2)*U2[t]=U2[x,x];
bc[2]:=u2(a, t)=0;
sys:=[pde[1],bc[1],pde[2],bc[2], u1(x=0,t)=u2(x=0,t),
D[2](u1)(x,0)=D[2](u2)(x,0)
pdsolve(sys);
a and L is arbitrary constanta
anyone can help? The last boundary conditions I mean du1/dx=du2/dx at x=0
How can i solve this problem?
So given a list [ [ [1,2], [2,1] ], [ [3,4], [4,3] ], [ [5] ] ],
I would like to produce a list
[ [1,2,3,4,5], [1,2,4,3,5], [2,1,3,4,5], [2,1,4,3,5] ]
so it makes a combination of sublist of every lists in the given list
is there a way to do it ?
Hi all
Assume that we have a cost functional, namely J, which we want to be minimized but we have to set of constraint CC1 and CC2.
what should we do it?
The code which I have written is attached(Minimize J under CC1[i]=0 and CC2[i]=0)
 any suggestion or guide is praiseworthy.
ExNew.mws
Mahmood   Dadkhah
Ph.D Candidate
I'm having trouble defining a Maple procedure containing for loops. I have one outer for loop which I terminate at the end and two separate for loops of which the first one get's terminated before the second one starts. Nethertheless Maple complains, that my outer loop doesn't get terminated and points to to a point before the second inner for loop starts. I based this procedure on a procedure I defined in another worksheet and the latter one is working just fine, although the structure ist the same in both procedures. As far as I can see, the structure is
for n from 0 to T do
for i from 1 to J do
for i from J-2 to 1 by -1 do
I have several if statements in the procedure, too, but as far as I can see, everything is terminated fine. Perhaps there is something else wrong with my procedure and I'm just getting a strange error? I would really appreciateit, if somebody could take a short look at the problem. Since the procedure takes up several pages I'm uploading my Maple work sheet. The relevant procedure is the one defined just after the red comment "#  actual code" which is about 60% through the work sheet.
Thank you all.
BD_collapse_2.mw.
Dear Collagues
I wrote a code to solve a system of ode numerically. When the equations have been solved, I want to find the value of MTE which is in integral form. I check and see that the value of MTE is calculated wrong. I dont know why?
I calculated the values of MTE twice (another variable is masst below res1). Two different answers!!
I would be most grateful if you could help me.
Here is my code
EPSILONE:=1:
#Digits:=10:
a[mu1]:=39.11:
b[mu1]:=533.9:
a[k1]:=7.47:
b[k1]:=0:
rhop:=5180:
rhobf:=998.2:
#gama1:=0.2;
mu1[bf]:=9.93/10000:
k1[bf]:=0.597:
rhost(eta):=1-phi(eta)+phi(eta)*rhop/rhobf;
#mu:=unapply(mu1[bf]/(1-phi(eta))^2.5,eta);
mu:=unapply(mu1[bf]*(1+a[mu1]*phi(eta)+b[mu1]*phi(eta)^2),eta);
#mu1[bf]:=9.93/10000:
k:=unapply(k1[bf]*(1+a[k1]*phi(eta)+b[k1]*phi(eta)^2),eta);
mu(eta)/mu1[bf];
#eq1:=diff((mu(eta)/mu1[bf])*diff(u(eta),eta),eta)+rhost(eta)-Ha^2*u(eta);
eq1:=(a[mu1]*(diff(phi(eta), eta))+2*b[mu1]*phi(eta)*(diff(phi(eta), eta)))*(diff(u(eta), eta))+(1+a[mu1]*phi(eta)+b[mu1]*phi(eta)^2)*(diff(u(eta), eta, eta))+rhost(eta)-Ha^2*u(eta);
eq2:=diff((k(eta)/k1[bf])*diff(T(eta),eta),eta);
eq3:=diff(phi(eta),eta)+phi(eta)/(N_bt*(1+gama1*T(eta))^2)*diff(T(eta),eta):
eq2:=subs(phi(0)=phi0,eq2);
eq3:=subs(phi(0)=phi0,eq3);
eval(dsolve({eq3,phi(1)=phiv},phi(eta)),(T)(1)=1);
Phi:=normal(combine(%));
Teq:=isolate(eval(eq2,Phi),diff(T(eta),eta));
ueq1:=eval(eq1,Phi)=0:
ueq2:=subs(Teq,ueq1):
Agama1:=<<0.1>,<0.2>,<0.3>>:
ANBT:=<<0.2>,<1>,<10>>:
Aphiv:=<<0.02>,<0.06>,<0.1>>:
lambda:=0;
Ha:=0;
#NBT:=0.5:
N_bt:=cc*NBT+(1-cc)*10;
#phiv:=0.02:
kratio:=k1[p]/k1[bf];
eq1;
eq2;
eq3;
res1 := dsolve(subs(NBT=1,gama1=0.3,phiv=0.06,{eq1,eq2,eq3,u(0)=lambda*D(u)(0),D(u)(1)=0,T(0)=0,phi(1)=phiv,T(1)=1}), numeric,method=bvp[midrich],output=listprocedure,continuation=cc):
G0,G1,G2:=op(subs(subs(res1),[phi(eta),u(eta),diff(T(eta),eta)])):
masst:=evalf(int((1-G0(eta)+G0(eta)*rhop/rhobf)*G1(eta), eta = 0..1));
heatt:=(1+a[k1]*G0(0)+b[k1]*G0(0)^2)*G2(0);
for iNBT from 1 to 3 do
for iphi from 1 to 3 do
for igamma from 1 to 3 do
res := dsolve(subs(NBT=ANBT(iNBT),gama1=Agama1(igamma),phiv=Aphiv(iphi),{eq1,eq2,eq3,u(0)=lambda*D(u)(0),D(u)(1)=0,T(0)=0,phi(1)=phiv,T(1)=1}), numeric,method=bvp[midrich],output=listprocedure,continuation=cc):
F0,F1,F2:=op(subs(subs(res),[phi(eta),u(eta),diff(T(eta),eta)])):
MTE[iNBT,iphi,igamma]:=evalf(Int((1-F0(eta)+F0(eta)*rhop/rhobf)*F1(eta), eta = 0..1)):
HTC[iNBT,iphi,igamma]:=(1+a[k1]*F0(0)+b[k1]*F0(0)^2)*F2(0):
print (convert(HTC[iNBT,iphi,igamma],float,9));
print (convert(MTE[iNBT,iphi,igamma],float,9));
Amir
I want to add text to the left of the vertical axis so I need more background space such that the full text fits to the left
As it is now it will appear truncated. I do not want to change the graph itself but I want to increase the background area around the axes so I can enter a text block using the drawing tools.
_C1, _C2, _C3 are constant, how to set them constant, to make diff(_C2) = 0 etc
eval(simplify(subs(a=_C1,subs(b=1/(diff(c(t), t)),subs(c=_C2+_C3*exp(-t),eq2)))));
(diff(_C2(t), t)+(diff(_C3(t), t))*(exp(-t))(t)+_C3(t)*(diff((exp(-t))(t), t)))*(-(diff(_C1(t), t))*(diff(diff((c(t))(t), t), t))/(diff((c(t))(t), t))^2+(diff(s(t), t))/(diff((c(t))(t), t)))
a
Assume the inequality xA,2+xB,2+xC,2 ≤ 110 has to be entered as "symbolic entry only".
How can I check that in Maple T.A.?
It seems that there are type conversions necessary. I attempted to use the MathML package without any luck.
  1. Tried to transform $ANSWER within the answer field using MathML[ExportPresentation]( x[A,2]+x[B,2]+x[C,2] <= 110) and compare it with evalb(($ANSWER)=($RESPONSE)) in the grading code field
  2. Tried to transform $RESPONSE in the grading code: evalb(($ANSWER)=( MathML[ImportContent] ($RESPONSE)))
What’s the format of a symbolic entry? Is it really MathML!?
What is the correct way to do it?
  1. answer: ?
  2. grading code: ?
  3. expression type: Maple syntax?!
  4. Text/Symbolic entry: Symbolic entry only
Dear Collegues
I have a system of odes as follows
#gama1:=0.2:
#rhop:=5180:
#rhobf:=998.2:
#a[mu1]:=39.11:
#b[mu1]:=533.9:
#a[k1]:=7.47:
#b[k1]:=0:
Teq := N_bt*T(eta)^2*(exp(-(T(eta)-1)/(N_bt*(1+gama1)*(1+gama1*T(eta)))))^2*(diff(T(eta), eta, eta))*gama1^2*b[k1]+N_bt*T(eta)^2*exp(-(T(eta)-1)/(N_bt*(1+gama1)*(1+gama1*T(eta))))*(diff(T(eta), eta, eta))*gama1^2*a[k1]+2*N_bt*T(eta)*(exp(-(T(eta)-1)/(N_bt*(1+gama1)*(1+gama1*T(eta)))))^2*(diff(T(eta), eta, eta))*gama1*b[k1]+N_bt*T(eta)^2*(diff(T(eta), eta, eta))*gama1^2;
UEQ:=(a[mu1]*(-(diff(T(eta), eta))/(N_bt*(1+gama1)*(1+gama1*T(eta)))+(T(eta)-1)*gama1*(diff(T(eta), eta))/(N_bt*(1+gama1)*(1+gama1*T(eta))^2))*exp(-(T(eta)-1)/(N_bt*(1+gama1)*(1+gama1*T(eta))))+2*b[mu1]*(exp(-(T(eta)-1)/(N_bt*(1+gama1)*(1+gama1*T(eta)))))^2*(-(diff(T(eta), eta))/(N_bt*(1+gama1)*(1+gama1*T(eta)))+(T(eta)-1)*gama1*(diff(T(eta), eta))/(N_bt*(1+gama1)*(1+gama1*T(eta))^2)))*(diff(u(eta), eta))+(1+a[mu1]*exp(-(T(eta)-1)/(N_bt*(1+gama1)*(1+gama1*T(eta))))+b[mu1]*(exp(-(T(eta)-1)/(N_bt*(1+gama1)*(1+gama1*T(eta)))))^2)*(diff(u(eta), eta, eta))+1-exp(-(T(eta)-1)/(N_bt*(1+gama1)*(1+gama1*T(eta))))+exp(-(T(eta)-1)/(N_bt*(1+gama1)*(1+gama1*T(eta))))*rhop/rhobf;
I want to solve them with the following boundary conditions
T(0)=0, T(1)=1
u(0)=L*D(u)(0), D(u)(1)=0
However I tried, I cannot find the solution in a closed form. I want to know that is there a closed form solution for the above odes?
Amir
First 1246 1247 1248 1249 1250 1251 1252 Last Page 1248 of 2459
