why can not draw graph in maple in this case and how to plot graph with matlab in maple
with(StringTools);
with(FileTools);
with(Matlab);
openlink();
evalM(sprintf("load fisheriris;X = meas(:,3:4);figure;plot(X(:,1),X(:,2),'k*','MarkerSize',5);"));
closelink();
Dear, I want to the expression for any r and s. Please help I am waiting your quick responce
Help.mw
With my best regards and sincerely.
Govt. Degree College Taxila
Dear, I am facing a problem which I run the attached file it this answer [Length of output exceeds limit of 1000000]. Please help to overcome this problem.
ytsf3.mw
Hi, I solved some equations those days and get a group of data, namely, Data1. Then I want to get the function of the data, so I use the CurveFitting package of maple, and get the function easily (the function seems as a*x^3+b*x^2+c*x+d). But the function is not the one I really wanted, because it is hard to generate the complex curve (even the function is known) in some software.
As I know, it is easily to generate some arcs in the software, so is there any way to fit a group of data with some piecewise of arcs?
 Best regards.
Data1:= [[.690499054221957, .109364306247567], [.679584570047867, 0.955093827253927e-1], [.668476295825779, 0.820785684569687e-1], [.657171143364362, 0.690714704619819e-1], [.645665768347822, 0.564884351571898e-1], [.633956566493958, 0.443305616055764e-1], [.622039668654294, 0.325997176601303e-1], [.609910934797136, 0.212985591645471e-1], [.597565946804089, 0.104305524003572e-1], [.585, 0], [.572208093323944, -0.998792942142104e-2], [.559184918035503, -0.195271676259796e-1], [.545924844835652, -0.286107087732754e-1], [.532421909264435, -0.372305667237386e-1], [.518669795218710, -0.453777271949494e-1], [.504661816411590, -0.530420942817277e-1], [.490390895570740, -0.602124307834357e-1], [.475849541144774, -0.668762917052363e-1], [.461029821255068, -0.730199502124052e-1]]
1. how to eliminate the diff(*(x,y,z),x) terms in an expression, "*" means any function which have independent variables x,y,z?
2. how to get the gradient of a vector, which should be a tensor?
I'm trying to create the 3D animation which can show the idea of rotating 2D function plot, such as:
display(seq(surfdata([seq([seq([x, cos(2*p*Pi*(1/25))*x^(1/2), -sin(2*p*Pi*(1/25))*x^(1/2)], x = 0 .. 4, .1)], p = 0 .. t)]), t = 1 .. 25), insequence = true);
But it's too inconvenient because of too many seq functions in this commond, is there any easier way to plot this animatiton?
I need to sort a list of vectors according to the alternating order defined as such:
x <_alt y if x and y differ first in the ith place and
i is even and x_i > y_i or i is odd and x_i < y_i
(so that in even positions, the order is "flipped", and in odd positions, the order is the standard order).
In this way, we arrive at
0101 <_alt 0110 <_alt 0001 <_alt 1101 <_alt 1001
Below is an attempt...
L:= [[ 0, 1, 0, 1], [0, 1, 1, 0], [0, 0, 0, 1], [1, 1, 0, 1], [1, 0, 0, 1]]
(in my actual code, my vectors will need to be of length 20).
 Thank you for all of your help.
I'm trying to solve system of ODE but it return this Error, (in fproc) unable to store 'YP[4]' when datatype=float[8]
How can this be corrected, see the worksheet YP.mw
I am experiencing some problems with the plot3d command. It does not return a nice 3d-graph, but just a bunch of dashed lines. I have entered something like this:
plot3d(x*y,x=-1..1,y=-1..1);
I am using maple 17 on windows 7
Int(ln(1+sqrt((x+1)/x)),x);
value(%);
Does not work.
Int(ln(2+sqrt((x+1)/x)),x);
value(%);
Works.
But with some effect,
Could this possibly be improved in the next release?
Why does maple do this? For example:
>Digits := 4
>.67*((6918*(.856*11+1.08))/(42.2*2600^.36))^5;
=7.216 10^9
But with the Digit set to default it gives me:
=7.204144575 10^9
thanks!
I want to solve the int((y4+by2+c)-1/2,y)-x and find y=h(x), where b and c are constants s.t. c>b2/4. Maple gives me complex Jacobi elliptic function as a result. But I am not sure that this integral has complex value. Am I doing something wrong or the result is really a complex valued function? Thanks.
Indeed my main question is: Plot y=y(u) where we have these two relations: int((y4+by2+c)-1/2,y)=x and find y=h(x). Then evaluate int((h(x)-B)-1/2,x)=u and find x=g(u). By using these relations plot y=y(u). :)
Here B is an arbitrary constant, but if necessary we can define a value for it. All the variables and constants are real.
I hope I manage to express myself. Thanks again.
Ok guys this is the problem i have a matrix wich is really the result of a semivariogram so it is like this
plot([[0, 0], [1, 1], [2, 3], [3, 5], [4, 7], [5, 8], [6, 9], [7, 10], [8, 10.5], [9, 10], [10, 9.8], [11, 9.8], [12, 10.5], [13, 10.89], [14, 11.2], [15, 10.6], [16, 9.85], [17, 9.45], [18, 9.77], [19, 10.15], [20, 10.7], [21, 10.04], [22, 10], [23, 10.85], [24, 10.7], [25, 10.94], [26, 10.81], [27, 10.33]])thi is my semivariogram so i have to find the best model and fit it to it, i can't just throw a polynomial it has to be
spherical= h:= C((3/2)*x/a-(1/2)*x^3/a^3)
expotencial=Upsilon := C(1-exp(-x/a))
Lineal= y:= p*x
or y:=p*x^a
so i want the maple to show me the variogram plot and the i select wich one of the models i will apply.
the problem is that i don't know how to apply the models so started something that could maybe lead to the values of C and A for the spherical and the xpotencial becouse the others too are easy.
with(CurveFitting);
m3 := Matrix([[0, 0], [1, 2], [2, 5], [3, 7], [4, 10], [5, 14], [6, 15], [7, 15.4], [8, 15.8], [9, 16], [10, 16.4]]);
plot(m3);
Upsilon := C(1-exp(-x/a));
Upsilon := C((3/2)*x/a-(1/2)*x^3/a^3);
for C to 16 do
for a to 100 do
for x to 11 do
H := m3(x, 2);
R[C, a, x] := abs(Upsilon-H)
end do
end do
for r to 16 do
for j to 100 do
N[r, j] := sum(R[r, j, X], X = 1 .. 11);
if N[r, j] < 55 then
print(r, j)
end if
end do
k := 14*(3/2*((1/16)*xx)-(1/2)*xx^3/16^3);
multiple(plot, [m3, color = "Green"], [k, xx = 0 .. 11, color = "Blue"])
so in this code i rest the values of the model and the values of the matrix for differents C and a so i pick the min of the Sum to see wich C and a give me the min value but i didn't work quite well first is difficult to get the C and a and sometimes the new curve is just not similir to the semivariogram (Matrix) please help i tried
k := NonlinearFit(C((3/2)*x/a-(1/2)*x^3/a^3), X, Y, x)
k:=LeastSquares`(m3, v, curve = C*(1-exp(-x/a)))
but they don't let me because they aint linear on the parameters
please help
if you are interested in this topic here is what i am trying to do but explained really well is for geological matters
http://www.kriging.com/PG1979/index.htm#Chapter_2+Part1
if want to help me use this matrix
m3:= Matrix([[0, 0], [1, 1], [2, 3], [3, 5], [4, 7], [5, 8], [6, 9], [7, 10], [8, 10.5], [9, 10], [10, 9.8], [11, 9.8], [12, 10.5], [13, 10.89], [14, 11.2], [15, 10.6], [16, 9.85], [17, 9.45], [18, 9.77], [19, 10.15], [20, 10.7], [21, 10.04], [22, 10], [23, 10.85], [24, 10.7], [25, 10.94], [26, 10.81], [27, 10.33]])
for that matrix the spherical model is the best i know
goodbye
Very simple procedure:
Restart;
global a:=0.0065, R0:=1.225, T0:=273.16, gamma:=1.4, R:=287.04;
Spd :=proc(H, T1, IAS);
T:=T1+T0;
rho:=R0*(1-((a)/(T)*1000)^(4.26));
sigma:=T0/(T)*(1-(a/(T0)*H)^(5.26));
EAS:=sqrt((rho*IAS^(2))/(R0));
TAS:=EAS*sqrt(R0/(rho));
SpdSnd:=sqrt(gamma*R*T);
M:=TAS/(SpdSnd);
return M;
Entering Spd(5000, 15, 400); with return I get
Spd(5000, 15, 400) in blue and not a numeric rsult.
Where am I wrong?
Martina
I have a table whose indices and entries are strings, as in:
    T := table(["green" = "gruen", "red" = "rot", "blue" = "blau"]);
Thus, T["green"] evaluates to "gruen" but T["asdf"] evaluates to T"asdf".
What is a good way to detect that "green" is a predefined index into the table but "asdf" is not?  I do it in a somewhat clumsy way, as in:
> has("green", [indices(T, 'nolist')]);
> has("asdf", [indices(T, 'nolist')]);
I suspect that there ought to be a less elaborate way of doing that.
First 1297 1298 1299 1300 1301 1302 1303 Last Page 1299 of 2459
