How can I stop this text from appearing in the worksheet output?
What is the purpose of this text as it's a GIANT DISTRACTION from my perspective?
SAMPLE EXECUTED WORKSHEET OUTPUT:
> with(plots);
> with(geom3d);
outputs lots of blue text...
[Archimedean, AreCollinear, AreConcurrent, AreConjugate,
  AreCoplanar, AreDistinct, AreParallel, ArePerpendicular,
  AreSkewLines, DefinedAs, DirectionRatios, Equation, FindAngle,
  FixedPoint, GlideReflect, GlideReflection, GreatDodecahedron,
  GreatIcosahedron, GreatRhombicuboctahedron,
  GreatRhombiicosidodecahedron, GreatStellatedDodecahedron,
  HarmonicConjugate, HexakisIcosahedron, HexakisOctahedron,
  InRadius, IsArchimedean, IsEquilateral, IsFacetted, IsOnObject,
  IsQuasi, IsRegular, IsRightTriangle, IsStellated, IsTangent,
  MidRadius, NormalVector, OnSegment, ParallelVector,
  PentagonalHexacontahedron, PentagonalIcositetrahedron,
  PentakisDodecahedron, QuasiRegularPolyhedron, RadicalCenter,
  RadicalLine, RadicalPlane, RegularPolyhedron,
  RhombicDodecahedron, RhombicTriacontahedron, RotatoryReflect,
  RotatoryReflection, ScrewDisplace, ScrewDisplacement,
  SmallRhombicuboctahedron, SmallRhombiicosidodecahedron,
  SmallStellatedDodecahedron, SnubCube, SnubDodecahedron,
  StereographicProjection, StretchRotate, TangentPlane,
  TetrakisHexahedron, TrapezoidalHexecontahedron,
  TrapezoidalIcositetrahedron, TriakisIcosahedron,
  TriakisOctahedron, TriakisTetrahedron, TruncatedCuboctahedron,
  TruncatedDodecahedron, TruncatedHexahedron,
  TruncatedIcosahedron, TruncatedIcosidodecahedron,
  TruncatedOctahedron, TruncatedTetrahedron, altitude, area,
  center, centroid, coordinates, cube, cuboctahedron, detail,
  dilate, distance, dodecahedron, draw, dsegment, duality, faces,
  facet, form, gtetrahedron, hexahedron, homology, homothety,
  icosahedron, icosidodecahedron, incident, intersection,
  inverse, inversion, line, midpoint, octahedron, parallel,
  parallelepiped, plane, point, polar, pole, powerps, projection,
  radius, randpoint, reflect, reflection, rotate, rotation,
  schlafli, segment, sides, sphere, stellate, tetrahedron, tname,
  transform, translate, translation, transprod, triangle,
  vertices, volume, xcoord, xname, ycoord, yname, zcoord, zname] [animate, animate3d, animatecurve, arrow, changecoords,
  complexplot, complexplot3d, conformal, conformal3d,
  contourplot, contourplot3d, coordplot, coordplot3d,
  densityplot, display, dualaxisplot, fieldplot, fieldplot3d,
  gradplot, gradplot3d, implicitplot, implicitplot3d, inequal,
  interactive, interactiveparams, intersectplot, listcontplot,
  listcontplot3d, listdensityplot, listplot, listplot3d,
  loglogplot, logplot, matrixplot, multiple, odeplot, pareto,
  plotcompare, pointplot, pointplot3d, polarplot, polygonplot,
  polygonplot3d, polyhedra_supported, polyhedraplot, rootlocus,
  semilogplot, setcolors, setoptions, setoptions3d, spacecurve,
  sparsematrixplot, surfdata, textplot, textplot3d, tubeplot]
Hello those who are in this maple primes.
I downloaded maple2015 for Mac, the newest version of the software, and tried to use it to draw a simple figure with plot3d.
But, in the end, I used gnuplot which I had happened to install though it was my first time of using it.
The problem of using my Maple was that it was too heavy and with my macbook, I found it impossible
to have it work properly. So, I am writing my question now.
I used terminal, but as I think it  might be easy to deal with to use editor not terminal itself
though I use the editor from the terminal, I want to know how I can use maple from the editor and what things I
can do when I do so. In my image, I want to use it like using TeX from the editor.
As for coloring the code, is the best tool one for Maple V yet? And, how can I do after I wrote the code of Maple?
What can I do with emacs and Maple? Can I use emacs like IDE of TeXshop or TeXworks in LateX?
I am glad to hear from you the general concept or procedures of using it if I use emacs and Maple.
Colud you please tell me how to obtain the answer f(b)-f(a), by manipulating the following expression in maple:
int(diff(f(x), x), x = a .. b)
Thank you very much. Best regards, Jand
Hello, I have a similary issue with the following post :
http://www.mapleprimes.com/questions/200835-Algsubs-With-Subscripts-And-Powers
In a constraint equation (in mechanics), I need to make these algebraic substitutions :
--> sqrt(xA1² + yA1²) =rF1
--> arctan(abs(yA1)/abs(xA1)) = aF1
--> sqrt(xC1^2+yC1^2) = rBTP
--> arctan(abs(yC1)/abs(xC1))=a1
I try to do it with this code :
ListAlgsubs:={sqrt(xA1^2+yA1^2)=rF1,sqrt(xA2^2+yA2^2)=rF2,sqrt(xA3^2+yA3^2)=rF3, sqrt(xA4^2+yA4^2)=rF4,arctan(abs(yA1)/abs(xA1))=aF1,-arctan(abs(yA2)/abs(xA2))=aF2,pi+arctan(abs(yA3)/abs(xA3))=aF3,pi-arctan(abs(yA4)/abs(xA4))=aF4,sqrt(xC1^2+yC1^2)=rBTP,arctan(abs(yC1)/abs(xC1))=a1};
for i from 1 to nops(ListAlgsubs)
do Branch1Cons:=applyrule(op(i,ListAlgsubs),Branch1Cons)
Branch1Cons:= simplify(Branch1Cons);
I have tried with algsubs or applyrule but it wasn't successfull in both cases.
Do you have an idea how can I do to simplify my expressions ? and namely conduct a good use of applyrule function
I join an extract of my code in order to facilitate the troubleshooting.
example.mw
Thanks a lot for your help.
How can I extract the coefficients of all monomials in a multivariate polynomial?
For example if f=ax^2+bxy^3+2 then I want
coeff(f,x^2)=a
coeff(f,xy^3)=b
coeff(f,1/2)=4
coeff(f,1/10)=20 and...
Dears, When I run calculation in Maple I found an error in matrices. See the file
Hi, I have 10 equation system and 10 unknown variables. I however, want to reduce the equations to 2 with two unknowns. I'm wondering how this could be done in maple. The variables are Y, q, yd, y*, yx, H,  pd, w, P and Pv. I intend to solve the equations for Y and w.
Thanks in advance for your help. The maple file has also been attached.
Small_Open_Economy.mw
restart; Digits := 10; F[0] := 0; F[1] := 0; F[2] := (1/2)*A; T[0] := 1; T[1] := B; M := 2; S := 1; Pr := 1
for k from 0 to 12 do F[k+3] := (-3*(sum((k+1-r)*(k+2-r)*F[r]*F[k+2-r], r = 0 .. k))+2*(sum((r+1)*F[r+1]*(k+1-r)*F[k+1-r], r = 0 .. k))+M*(k+1)*F[k+1]-T[k])*factorial(k)/factorial(k+3); T[k+2] := (-3*Pr*(sum((k+1-r)*F[r]*T[k+1-r], r = 0 .. k))-S*T[k])*factorial(k)/factorial(k+2) end do:
(1/630)*x^7*A*B+(1/8064)*x^9*A*B-(121/1209600)*x^10*A^2*B+(19/369600)*x^11*A*B-(11/725760)*x^12*A^2*B+(97/19958400)*x^12*A*B^2+(1/12)*x^4*A-(1/24)*x^4*B+(1/120)*x^5*A^2+(1/180)*x^6*A-(1/720)*x^6*B-(1/630)*x^7*A^2-(13/40320)*x^8*A^3+(11/20160)*x^8*A-(11/40320)*x^8*B-(19/60480)*x^9*A^2-(1/45360)*x^9*B^2+(391/3628800)*x^10*A+(37/604800)*x^10*A^3-(23/1814400)*x^10*B-(41/39916800)*x^11*B^2+(229/13305600)*x^11*A^4-(439/7983360)*x^11*A^2+(197/21772800)*x^12*A-(883/159667200)*x^12*B+(29/1520640)*x^12*A^3+(1/2)*A*x^2-(1/6)*x^3-(1/120)*x^5-(1/1680)*x^7-(11/362880)*x^9-(23/2661120)*x^11
print(expand(t)):
1-(20747/79833600)*x^12*A*B+(29/1680)*x^7*A^2*B-(451/241920)*x^10*A^3*B-(2507/14515200)*x^12*A^3*B+(2921/13305600)*x^11*A*B^2-(33/4480)*x^8*A*B+(761/403200)*x^10*A*B+(1/48)*x^6*A*B-(1/8)*x^4*A*B+(977/887040)*x^11*A^2*B+(1349/4838400)*x^12*A^2*B^2-(1/1152)*x^9*A^2*B-(11/7560)*x^9*A*B^2-(37/44800)*x^10*A^2+(223/604800)*x^10*B^2+(47/633600)*x^11*A-(7913/19958400)*x^11*B+(193/6652800)*x^11*B^3+(1409/1478400)*x^11*A^3-(4813/53222400)*x^12*B^2-(167/221760)*x^12*A^2+(3/40)*x^5*A+(1/30)*x^5*B+(1/240)*x^6*B^2-(1/560)*x^7*A-(23/2520)*x^7*B-(43/4480)*x^8*A^2-(1/896)*x^8*B^2+(61/13440)*x^9*A+(31/22680)*x^9*B-(1/6)*B*x^3+B*x+(2573/95800320)*x^12-(1/2)*x^2+(1/24)*x^4-(13/720)*x^6+(11/8064)*x^8-(2143/3628800)*x^10
solve({limit(numapprox:-pade(t, x, [2, 2]), x = infinity) = 0., limit(numapprox:-pade(diff(f, x), x, [2, 2]), x = infinity) = 1}, {A, B});
{A = -.7359903327, B = 1.324616408}, {A = -0.7307377025e-1+2.009578912*I, B = .3744177908+.5971332133*I}, {A = .6936483785+.1660915631*I, B = .1622123331+.9257041678*I}, {A = -2.182873922*I, B = .8203849935*I}, {A = .3431199285*I, B = 1.783825109*I}, {A = -.6936483785+.1660915631*I, B = -.1622123331+.9257041678*I}, {A = 0.7307377025e-1+2.009578912*I, B = -.3744177908+.5971332133*I}, {A = .7359903327, B = -1.324616408}, {A = 0.7307377025e-1-2.009578912*I, B = -.3744177908-.5971332133*I}, {A = -.6936483785-.1660915631*I, B = -.1622123331-.9257041678*I}, {A = 2.182873922*I, B = -.8203849935*I}, {A = -.3431199285*I, B = -1.783825109*I}, {A = .6936483785-.1660915631*I, B = .1622123331-.9257041678*I}, {A = -0.7307377025e-1-2.009578912*I, B = .3744177908-.5971332133*I}
solve({limit(numapprox:-pade(t, x, [3, 3]), x = infinity) = 0., limit(numapprox:-pade(diff(f, x), x, [3, 3]), x = infinity) = 1}, {A, B});
{A = 4.154051132, B = 17.13248053}, {A = .5466914672+.2697341397*I, B = .1291930705+.9494499975*I}, {A = .4506017673+.3824137679*I, B = -.2437153257+1.192091322*I}, {A = .5458260296+.5776530367*I, B = .3085138074+1.260130057*I}, {A = .3007754662+.5799020019*I, B = 0.8347381159e-1+1.033103936*I}, {A = .3916946210+1.036293227*I, B = .9202208108+1.239552889*I}, {A = .1349186305+.5994923360*I, B = 1.926737919+1.099451808*I}, {A = .5141206762+2.582294380*I, B = -.7917198503+.5287783790*I}, {A = 1.669898274*I, B = 1.659206265*I}, {A = 3.170666197*I, B = -.6372670837*I}, {A = -.5141206762+2.582294380*I, B = .7917198503+.5287783790*I}, {A = -.1349186305+.5994923360*I, B = -1.926737919+1.099451808*I}, {A = -.3916946210+1.036293227*I, B = -.9202208108+1.239552889*I}, {A = -.3007754662+.5799020019*I, B = -0.8347381159e-1+1.033103936*I}, {A = -.5458260296+.5776530367*I, B = -.3085138074+1.260130057*I}, {A = -.4506017673+.3824137679*I, B = .2437153257+1.192091322*I}, {A = -.5466914672+.2697341397*I, B = -.1291930705+.9494499975*I}, {A = -4.154051132, B = -17.13248053}, {A = -.5466914672-.2697341397*I, B = -.1291930705-.9494499975*I}, {A = -.4506017673-.3824137679*I, B = .2437153257-1.192091322*I}, {A = -.5458260296-.5776530367*I, B = -.3085138074-1.260130057*I}, {A = -.3007754662-.5799020019*I, B = -0.8347381159e-1-1.033103936*I}, {A = -.3916946210-1.036293227*I, B = -.9202208108-1.239552889*I}, {A = -.1349186305-.5994923360*I, B = -1.926737919-1.099451808*I}, {A = -.5141206762-2.582294380*I, B = .7917198503-.5287783790*I}, {A = -1.669898274*I, B = -1.659206265*I}, {A = -3.170666197*I, B = .6372670837*I}, {A = .5141206762-2.582294380*I, B = -.7917198503-.5287783790*I}, {A = .1349186305-.5994923360*I, B = 1.926737919-1.099451808*I}, {A = .3916946210-1.036293227*I, B = .9202208108-1.239552889*I}, {A = .3007754662-.5799020019*I, B = 0.8347381159e-1-1.033103936*I}, {A = .5458260296-.5776530367*I, B = .3085138074-1.260130057*I}, {A = .4506017673-.3824137679*I, B = -.2437153257-1.192091322*I}, {A = .5466914672-.2697341397*I, B = .1291930705-.9494499975*I}
Download D.T.M.mw
with(student):
Digits := 19:
inf := 28.5:
equ1 := diff(f(eta), eta, eta, eta)+3*(diff(f(eta), eta, eta))*f(eta)-2*(diff(f(eta), eta))^2-M*(diff(f(eta), eta))+theta(eta) = 0;
diff(diff(diff(f(eta), eta), eta), eta)+3*(diff(diff(f(eta), eta), eta))*f(eta)-2*(diff(f(eta), eta))^2-M*(diff(f(eta), eta))+theta(eta) = 0
equ2 := diff(theta(eta), eta, eta)+3*Pr*f(eta)*(diff(theta(eta), eta))+S*theta(eta) = 0;
diff(diff(theta(eta), eta), eta)+3*Pr*f(eta)*(diff(theta(eta), eta))+S*theta(eta) = 0
FNS := f(eta), theta(eta);
f(eta), theta(eta)
s := 0:
BC := f(0) = s, (D(f))(0) = 0, (D(f))(inf) = 1, theta(0) = 1, theta(inf) = 0;
f(0) = 0, (D(f))(0) = 0, (D(f))(28.5) = 1, theta(0) = 1, theta(28.5) = 0
CODE := [M = 2, Pr = 1, S = 1]:
S1 := dsolve({BC, subs(CODE, equ1), subs(CODE, equ2)}, {f(eta), theta(eta)}, type = numeric):
S1(0)
[eta = 0., f(eta) = 0., diff(f(eta), eta) = 0., diff(diff(f(eta), eta), eta) = .7424080874401649594, theta(eta) = 1.000000000000000000, diff(theta(eta), eta) = .9438662130843066161]
Download shooting_method.mw
Thank you so much for your time. Here's the real problem
f'''(η) + 3f(η)f''(η) - 2[f'(η)] 2 + θ(η) - m*f'(η) = 0
θ''(η) + 3*Pr*f(η)θ'(η) + s*θ(η) = 0
Boundary conditions are:
at η=0: f(η)=f'(η)=0; θ(η)=1;
as η→∞ f'(η)=1; θ(η)=0;
Where m = magnetic parameter (in this case taken as 2)
S = shrinking parameter (in this case taken as 1)
Pr = taken as 1 too
I haven't been able to solve this using differential transforms method (i.e getting the values of f''(0) and θ'(0) denoted by A and B respectively) but shooting method works just fine. :( I seriously need help with this. Thanks you in advance.
I've attached my codes above and i'm hoping someone helps me out real soon. thanks very one.
I am planning on getting Maple 18 Student Editon and I am wondering if the calculus palette is in Maple 18 student edition.
Nick
sorry for that question, i'm a beginner in maple but i think my question is not as simple.
So, i want to solve numerically this first equation :
but the second term is present only if k*(U*t-x)>μc*m*g  (stick-slip problem)
initial conditions : U=1m/s; x=0m; k=10 for example
My problem is simple, i don't know how to use conditional statement for such an ode in maple.
I've tried > Xr := U*t-x;
> k := 10; m := 1; g := 10; mu := .2;
> if k*Xr > mu*m*g then ode1 := m*(diff(x(t), t, t)) = k.Xr-mu*m*g else ode1 := m*(diff(x(t), t, t)) = k.Xr end if;
But, of course, too optimistic.
Thank to anyone who will solve that (isuppose) simple problem
Philippe
How do I convert a hardware float to a software float? I have a procedure that is passed floats as arguments. They could be hardware or software floats. I need to set an attribute on these floats (with setattribute). Trying to use setattribute on a hardware float produces utterly bizarre results, although, strangely, not an error. But I'd be happy converting them to software floats and then setting the attribute. I tried (separately)
UseHardwareFloats:= false;
convert(x, float, 16);
SFloat(op(x));
And, FWIW, here's the procedure, although I doubt that it'll provide any more useful information than I've already given. Note that in this procedure I've redefined log to be the base-10 logarithm. (Not that that makes the slightest difference wrt my Question.)
LogView:= proc(viewspec::{range, identical(DEFAULT)}, Range::range)
local aV, bV, aP, bP, aL, bL;
     (aP,bP):= op(map(x-> 10^x, Range)); # The actual range of the ORIGINAL plot structure
     if viewspec = 'DEFAULT' then
          setattribute(op(1,Range), aP) .. setattribute(op(2,Range), bP)
          (aV,bV):= op(viewspec); #The user-specified view in the pre-log units
          if bV <= 0 then error "upper view limit must be positive; received %1.", bV fi;
          (aL,bL):= op(Range); #Actual range of the log plot structure
          setattribute(`if`(aV >= aP, log(aV), aL - (aP-aV)/(min(bP,bV)-aP)*(log(min(bP,bV))-aL)), aV)
          .. setattribute(`if`(bV <= bP, log(bV), bL + (bV-bP)/(bP-max(aP,aV))*(bL-log(max(aP,aV)))), bV)
     end if
In the specific use instance that I'm dealing with, the first parameter, viewspec, is DEFAULT, and the second, Range, is HFloat(-43.42...)..HFloat(43.42...).
I think the ideal solution would be to use parameter coercion to convert the arguments.
Hi, I have a function as following:
50*tan(8*Pi/180)=(a1/(d2-d1))*ln(d2/d1)+(a2/(d3-d2))*ln(d3/d2)+((0.6-a1-a2)/(d4-d3))*ln(d4/d3)
where d1=0.01..0.06, d2>=d1, d3>=d2, d4>=d3, a1>0,a2>0, a1+a2<0.6.
I want to get  all the solutions of d1,d2,d3,d4,a1,a2, which satify the equation and the constrains, is there any way to solve this problem by using maple?
Maybe a bit strange question (just exploring Maple and a new topic), but is there a way to use CylindricalAlgebraicDecompose with a rational functions, eg 1/x, where eg is x an integer? I tried to use it but always ended up with:
Error, invalid input: RegularChains:-SemiAlgebraicSetTools:-CylindricalAlgebraicDecompose expects its 1st argument, F, to be of type Or(list(list(Or(polynom(rational), polynom(rational) = polynom(rational), polynom(rational) <> polynom(rational), polynom(rational) <= polynom(rational), polynom(rational) < polynom(rational)))), list(polynom(rational))), but received [1/x = x, polynom(rational)]
Hello, i got the following problem. I have a function, say u(h,e) whith multiple exponents ((u(h,e))^(1/a))^a. As long as Maple does not know that u(h,e) is positiv it won't make the simplification and return u(h,e) as expected. From my view i have two possibilites to solve this problem:
1) Define u(h,e) to be positive. Sounds intuitive, but i didn't manage to find the right definition
2) Give maple the function e.g. u:=e+h^2 and simplify the epression in uneval quotes with assumption positive for e and h.
Whereas I have solution 2, the problem is that i would need excessive amounts of uneval quotes '' at the start of my worksheet, not to run out of them.
I definitly need my epressions in unevaluated forms and would be happy to hear any ideas.
Greetings, Fabian
Hi! I just started to use Maple and I play with some of its functions. I have seen in examples related to RegularChain package an output like  [regular_chain, [[-1, -1], [0, 0]]] and I wonder how I should read it. Thanks for any help and sorry if my question is very basic.
First 1300 1301 1302 1303 1304 1305 1306 Last Page 1302 of 2472
