Consider the equation
eqn1:=5^(2*abs(y-1)+2) = (1/15625)*625^abs(y-1);
and note that
eval( eqn1, y=-3);
eval( eqn1, y=5);
both return valid solutions. So why does
testeq(eqn1);
throw a numeric exception.
Given the manual description of testeq(), I would expect it to return either true or FAIL - but not a numeric exceprion!!!!
Any ideas?
Hi there,
I've created some nice 3D-plots. I want to export them and insert them in LaTex. Exporting to EPS gives me a zero-byte-file but no printable data.
I've already read that I'm not the first to have this issue and there is obviously a work-around by enabling the Classic-Worksheet-mode. Unfortanely this mode appears to be not available in Maple 17 under MAC OSX.
Is there another way to solve the problem?
Would help me a lot.
Hi there,
I used to work with Maple 15. In Maple 15 the input-font-color was a beautiful plain red. Now I have to work with Maple 17, where the font-color was changed to a way darker red.
I found a way to change the color in a single worksheet with Format-->Character-->Color. But I want to change it globally and permanently, so that every time I create a new worksheet the color is automatically red.
Do you have any ideas how to get this managed?
Thanks a lot!
Hi, is it possible to instantly start the display of plot animations after they are generated in maple? I searched for answers in the documentation and on the internet but couldn't find a solution. I would like to skip the step of manually clicking the plot and the "play animation" button.
  Suppose I have a file, 1.mw, which includes a subroutine
aver:=proc(a,b)
  local res;
  res:=(a+b)/2;
  return res;
   Now I am writing another file, 2.mw. I would like to load the subroutine, aver, in 1.mw. How shall I write in 2.mw to use that subroutine in 1.mw?
Thank you very much
PS,
PiFast43 is freely available at,
http://numbers.computation.free.fr/Constants/PiProgram/pifast.html
i dont know what`s wrong with it help me guys
I want to inseret a text arrow in the graph obtained by plot command to show increasing or decreasing trends of the graph, but I could not find any option to insert the textarrow or textbox in the graph.
Dear's, I am facing some problem to find the particular solution please find the attachment.
Help-1.mw
PhD (Scholar)
Department of Mathematics
I'm trying to add a label to a plot and need the derivative to be represented as a dot. My typesetting rules are set to extended, and it works in a worksheet but not in the plot. See attached image. The code to generate it is:
#the output is shown with a dot over phi
diff(phi(t),t);
#derivative in label not shown as a dot
plot(sin( t), t=0..10, labels=["t", typeset(diff(phi(t),t))], labeldirections=[horizontal, vertical]);
any ideas?
EDIT:
this seems to work... ( i will leave this question here as it might come in handy to someone else).
plot(sin( t), t=0..10, labels=["t", Typesetting:-Typeset(diff(phi(t),t))], labeldirections=[horizontal, vertical]);
Is it a bug that using the first variant does not work? any ideas from the experts?
hi,
I am trying to implement some data-intensive algorithms like: comuting similarity scores, clustering etc. How efficient Maple is in doing these operations? I mean is it comparable to MATLAB in these operations? What toolboxes are useful in these? I am trying to build a recommender system.
I am using Maple18 and not sure if Maple has any advantage in implementing these type of algorithms over MATALB??
siba
Please consider this code:
with(DEtools):
test:=(diff(x(t),t,t))+(diff(a(t),t,t))=0;
FirstOrderSys := convertsys(test, [], x(t), t, y, yp );
When it is executed Maple says: Error, (in is/internal) too many levels of recursion
Now if i change just the letter a to, say, p (a(t)->p(t)) like this:
with(DEtools):
test:=(diff(x(t),t,t))+(diff(p(t),t,t))=0;
Lo and Behold! Suddenly Maple gives the answer:
/ d / d \\ / d / d \\ |--- |--- x(t)|| + |--- |--- p(t)|| = 0 \ dt \ dt // \ dt \ dt // [[ d / d \] [[yp[1] = y[2], yp[2] = ---- |--- p(t)|], [[ dt \ dt /] [ d ] ] [y[1] = x(t), y[2] = --- x(t)], undefined, []] [ dt ] ]
Why is that so? I don't see how one letter makes this difference. I have learned Maple on my own, so maybe I have missed something?
Please, i need help USING ODE1 and ODE2 with given BCS and Pr=0.714
it is needed to to generates
                   [-0.2], [0.51553], [0.4000]
                  [-0.1], [0.57000], [0.4371]
                   [0.], [0.62756], [0.4764]
                  [0.1], [0.68811], [0.5176]
                  [0.2], [0.75153], [0.5609]
but it is generarting
                  [-0.2], [0.51553], [0.42342]
                  [-0.1], [0.57000], [0.46114]
                   [0.], [0.62756], [0.50088]
                  [0.1], [0.68811], [0.54261]
                  [0.2], [0.75153], [0.58628]
the values of D(theata)(0) is wrong. Please i need HELP. this the code below that i use:
>restart;
>with (plots):ode1:=diff(f(eta),eta,eta,eta)+f(eta)*diff(f(eta),eta,eta)-M*diff(f(eta),eta)=0:
>ode2:=diff(theta(eta),eta,eta)+Pr*f(eta)*diff(theta(eta),eta)=0:
>bcs1:= f(0)=w,D(f)(0)=1,D(f)(10)=0:
>bcs2theta(10)=0,theta(0)=1:
>fixedparameter1:=[M=0.0]:
>ode3:=eval(ode1,fixedparameter1):
>fixedparameter2:=[Pr=0.714]:
>ode4:=eval(ode2,fixedparameter2):
>G:=[-0.2,-0.1,0.0,0.1,0.2]:
>for ode3 and ode4:
  for k from 1 to 5 do
  sol_All:=dsolve(eval({ode3,ode4,bcs1},w=G[k]),    [f(eta),theta(eta)],numeric,output=listprocedure);
Y_sol||k:= -rhs(sol_All[4]);
YP_sol||k:=-rhs(sol_All[6]);
>Digits:=5:
evalf([G[k]]),evalf([(Y_sol||k(0))]),evalf([YP_sol||k(0)]);
od;
Hi all.
I am using Maple2015.
I typed in as input y=x/sqrt(1-x^2).
I hit enter.  The output is:
 y=x/sqrt(1-x^2)
I know the 2 answers are equivalent.
My question is why did Maple swap 1-x^2 to -x^2+1???
Any advice to swap it back would be greatly appreciated.
First 1301 1302 1303 1304 1305 1306 1307 Last Page 1303 of 2459
