please help check what's wrong with this code. I need the analytic solution and convert to Bessel but return error. Here is the worksheet ID_1.mw
Best regards.
this code not answer:
> whit*evalf; tx := evalf((t1+t2)*(1/2));
> t1 := 326*40; t2 := 327*40;
> y1, y2 := eval([y1, y2], Ns(t1), Ns(t2));
>while (t1 < tx) and (tx < t2) do:
yx := rhs(Ns(tx)[c2]):
if yx > 0 then
y2 := yx: t2 := tx:
y1 := yx: t1 := tx:
fi;
od;
>Tx = evalf(tx);
> Hx := floor((1/3600)*tx):
> Mx := floor((tx-3600*Hx)*(1/60)):
> Sx := tx-3600*Hx-60*Mx:
> Hx, Mx, Sx;
> XS := [seq(X[i], i = 0 .. 328)]: YS := [seq(Y[i], i = 0 .. 328)]:
> VxS := [seq(Vx[i], i = 0 .. 328)]: VyS := [seq(Vy[i], i = 0 .. 328)]:
> save(G,Mz,Xs,VxS,VyS, 'orbit.sav'):
 can you help me?
This might seem easy but i am a total beginner in Maple and i really need to know how to do this. If i have an expression like this:
X^2 + 3*y + 3*z + X^7
where (y) and (z) are constants of unknown values. I need to integrate the expression over an interval for example (from 1 to 10) so that the answer would still be in terms of (y) and (z).
Would anyone please help me and give me the right expression for writing this on Maple?
(a) Show that if {an} ∞ n=1 is Cauchy then {a 2 n} ∞ n=1 is also Cauchy. (b) Give an example of a Cauchy sequence {a 2 n} ∞ n=1 such that {an} ∞ n=1 is not Cauchy
Show that 2^3 + x ^2 − 3x + 2 is O(x ^3 ).
guys , i have a metric and i want to define a componenets of a tensor and then obtain its covariant derivative with respect to a metric, what is your idea ?
N_1=-A(r)^1/2 , A_2=A_3=A_4=0 , what is D_[nu] N_1 =?
 in general i want to define N[1]=-A(r)^(1/2) and N[2] = N[3]= N[3] = N[4] = 0 And define F[mu, nu] = 2*(D_[mu] N[nu]-D_[nu] N[mu]) And define Omega[mu, nu] = 2*(D_[mu] N[nu]+D_[nu] N[mu]) and compute expression F_[alpha, beta] F_[~alpha`, ~beta ] And N_[alpha] N_[~beta`] F_[ ~alpha, ~lambda ] Omega_[beta, lambda])
i have problem with this how to difine this tensorial terms and how to compute them.
Covariant.mw
thxxxx
Hi EveryOne!
In the the answer of the question "How to find k^th root of the given matrix over finite field (at URL: http://www.mapleprimes.com/questions/203997-How-To-Find-Kth-Root-Of-The-Given-Matrix#comment215683). Carl Love helped to find k^th root of the given matrix M over GF(2m)/f(x).
Now, I need to compute direct exponentiation of the given matrix M in finite field. (If M = [mi,j], we say Direct Exponent (element-wise exponent matrix), Mdk of M is a matrix whose each element is the result of exponentiation of corresponding elements of M. If k=2, then we say Md2 is a direct square matrix of M )
Please help me!!! Thank you very much.
I've seen a few maple presentations where a block of code is wrapped in a box. Does anyone know how this is done?
Hi, I'm trying to solve a system of equation and I keep getting this error. Could anyone help me figure out what I'm doing wrong?
My problem is:
> alpha := .3; G := 3.5; L := 6; f := 1.1;
for i to 50 do
I0 := x(z)+y[i](z); ICon := x(0) = 1, y[i](0) = 0;
for j to 50 do
i <> j;
d1 := diff(x(z), z) = -G*x(z)*y[i](z)/IC-alpha*x(z);
d2 := diff(y[i](z), z) = G*y[i](z)*y[j](z)/IC-alpha*y[i](z);
dsys := {d1, d2};
F := dsolve({ICon, op(dsys)}, [x(z), y[i](z)], numeric);
Error, (in dsolve/numeric/process_input) unknown y[2] present in ODE system is not a specified dependent variable or evaluatable procedure
When I calculate the nullspace of a Matrix my solution comes out in a different order than Maple.  So, the question is what steps does Maple use to calculate Nullspace, ColumnSpace, and eigenvalues.  All of these are calculated by Maple in a different order that when I calculate by hand.
What I meant to say is that the answer given by for nullspace is in a different order than if I were do the same calculation by Hand.
A=<<[1,1,1,1],[1,2,3,4],[4,3,2,1]>>   this is what got calculating the Nullspace by hand <1,-2,1,0>,<2,-3,0,1>  when Maple does the calc. It returns the answer in the opposite order
Bill
     I an trying to plot a function of a single variable, which is an implicit function of another variable, i.e. I want to plot F(x(t)), given that x and t are related through the implicit constraint equation f(x,t) = 0. Is there any plot stuctures in Maple that would easily let me do this? I tried implicit plot but this seems insufficient.
     As an example, consider plotting F = x + x^2 subject to f = x + sin(x) + ln (t) = 0. I could also write this as  a function subject o a differential constraint, as is f = diff(x(t), t) + 1/t + (diff(x(t), t))*cos(x(t)) = 0 and try to use some sort of implicit DE plotting routine.
     Any ideas?
I am running Maple in a windows virtual machine, on a mac computer.
I have a number of worksheets on its disk
Windows advised me to run its error checking utility (chkdsk)
when I try and open them it gives me a number of options:
maple text
plain text
and maple input
None of these are the same as the original files. What has happened? and how can i fix it?
I have a list L:={1,2,3,4,5,6,7,8}. I choose three elements from list L. How many different combinations of three numbers can be selected from L so that the numbers could represent the side lengths of a triangle?
Thanks for helping me to solve the problem below using Maple.
dsys := {(1-4*(diff(ln(v(z)), z)))*(diff(u(z), z))+((3/2)*z^{-1}-2*(3* z^{-1} *(diff(ln(v(z)), z))+2*(diff(ln(v(z)),z,z )))))*u(z) = 0, -z*(diff(v(z), z))-v(z)+v(z)^(1/2)*u(z) = 0, v(0) = 1, u(0) = 1, (D(v))(0) = 1/4, (D(u))(0) = 3/8}
When trying    sol := dsolve(dsys, numeric)
I got : Error, (in DEtools/convertsys) unable to convert to an explicit first-order system.
Note that the analytic solution for z<=0 is:
if z>-4   then  u(z)=(1+z/4)exp(z/8) and   v(z)=exp(z/4)
else u(z)=0  and v(z)= (-4/z)exp(-1)
can anybody help me? i want to check the consistency of my scheme. My equation is too long if i check manually, so i used maple 13 to simplify my equation. But it cannot simplify it because of length of output exceed limit 1000000
eqn1 := u+(1-exp(-m))*u[t]+(1-exp(-m))^2*u[tt]/factorial(2)+(u-(1-exp(-m))*u[t]+(1-exp(-m))^2*u[tt]/factorial(2))-u-(1-exp(-m))*u[x]-(1-exp(-m))^2*u[xx]/factorial(2)-u+(1-exp(-m))*u[x]-(1-exp(-m))^2*u[xx]/factorial(2)+(1-exp(-m))^2*u+(1-exp(-m))^2*u^3-(1-exp(-m))^2*(4*(((x+1-exp(-m))^2-2)*cosh(x+1-exp(-m)+(t+1-exp(-m)))-(4*(x+1-exp(-m)))*sinh(x+1-exp(-m)+(t+1-exp(-m)))+(x+1-exp(-m))^6*cosh(x+1-exp(-m)+(t+1-exp(-m)))^3))*((x^2-2)*cosh(x+t)-4*x*sinh(x+t)+x^6*cosh(x+t)^3)*(((x+1-exp(-m))^2-2)*cosh(x+1-exp(-m)+t)-(4*(x+1-exp(-m)))*sinh(x+1-exp(-m)+t)+x^6*cosh(x+1-exp(-m)+t)^3)*((x^2-2)*cosh(x+1-exp(-m)+t)-4*x*sinh(x+1-exp(-m)+t)+x^6*cosh(x+1-exp(-m)+t)^3)/((((x+1-exp(-m))^2-2)*cosh(x+1-exp(-m)+(t+1-exp(-m)))-(4*(x+1-exp(-m)))*sinh(x+1-exp(-m)+(t+1-exp(-m)))+(x+1-exp(-m))^6*cosh(x+1-exp(-m)+(t+1-exp(-m)))^3)*((x^2-2)*cosh(x+t)-4*x*sinh(x+t)+x^6*cosh(x+t)^3)*(((x+1-exp(-m))^2-2)*cosh(x+1-exp(-m)+t)-(4*(x+1-exp(-m)))*sinh(x+1-exp(-m)+t)+(x+1-exp(-m))^6*cosh(x+1-exp(-m)+t)^3+(x^2-2)*cosh(x+1-exp(-m)+t)-4*x*sinh(x+1-exp(-m)+t)+x^6*cosh(x+1-exp(-m)+t)^3)+(((x+1-exp(-m))^2-2)*cosh(x+1-exp(-m)+t)-(4*(x+1-exp(-m)))*sinh(x+1-exp(-m)+t)+(x+1-exp(-m))^6*cosh(x+1-exp(-m)+t)^3)*((x^2-2)*cosh(x+1-exp(-m)+t)-4*x*sinh(x+1-exp(-m)+t)+x^6*cosh(x+1-exp(-m)+t)^3)*(((x+1-exp(-m))^2-2)*cosh(x+1-exp(-m)+(t+1-exp(-m)))-(4*(x+1-exp(-m)))*sinh(x+1-exp(-m)+(t+1-exp(-m)))+(x+1-exp(-m))^6*cosh(x+1-exp(-m)+(t+1-exp(-m)))^3+(x^2-2)*cosh(x+t)-4*x*sinh(x+t)+x^6*cosh(x+t)^3));
(1-exp(-m))^2*u[tt]-(1-exp(-m))^2*u[xx]+(1-exp(-m))^2*u+(1-exp(-m))^2*u^3-(1-exp(-m))^2*(4*((x+1-exp(-m))^2-2)*cosh(x+2-2*exp(-m)+t)-16*(x+1-exp(-m))*sinh(x+2-2*exp(-m)+t)+4*(x+1-exp(-m))^6*cosh(x+2-2*exp(-m)+t)^3)*((x^2-2)*cosh(x+t)-4*x*sinh(x+t)+x^6*cosh(x+t)^3)*(((x+1-exp(-m))^2-2)*cosh(x+1-exp(-m)+t)-4*(x+1-exp(-m))*sinh(x+1-exp(-m)+t)+x^6*cosh(x+1-exp(-m)+t)^3)*((x^2-2)*cosh(x+1-exp(-m)+t)-4*x*sinh(x+1-exp(-m)+t)+x^6*cosh(x+1-exp(-m)+t)^3)/((((x+1-exp(-m))^2-2)*cosh(x+2-2*exp(-m)+t)-4*(x+1-exp(-m))*sinh(x+2-2*exp(-m)+t)+(x+1-exp(-m))^6*cosh(x+2-2*exp(-m)+t)^3)*((x^2-2)*cosh(x+t)-4*x*sinh(x+t)+x^6*cosh(x+t)^3)*(((x+1-exp(-m))^2-2)*cosh(x+1-exp(-m)+t)-4*(x+1-exp(-m))*sinh(x+1-exp(-m)+t)+(x+1-exp(-m))^6*cosh(x+1-exp(-m)+t)^3+(x^2-2)*cosh(x+1-exp(-m)+t)-4*x*sinh(x+1-exp(-m)+t)+x^6*cosh(x+1-exp(-m)+t)^3)+(((x+1-exp(-m))^2-2)*cosh(x+1-exp(-m)+t)-4*(x+1-exp(-m))*sinh(x+1-exp(-m)+t)+(x+1-exp(-m))^6*cosh(x+1-exp(-m)+t)^3)*((x^2-2)*cosh(x+1-exp(-m)+t)-4*x*sinh(x+1-exp(-m)+t)+x^6*cosh(x+1-exp(-m)+t)^3)*(((x+1-exp(-m))^2-2)*cosh(x+2-2*exp(-m)+t)-4*(x+1-exp(-m))*sinh(x+2-2*exp(-m)+t)+(x+1-exp(-m))^6*cosh(x+2-2*exp(-m)+t)^3+(x^2-2)*cosh(x+t)-4*x*sinh(x+t)+x^6*cosh(x+t)^3))
a := simplify(eqn1);
`[Length of output exceeds limit of 1000000]`
Download consistency_expmle_4.mw
First 1311 1312 1313 1314 1315 1316 1317 Last Page 1313 of 2464
